Error: "region `FLASH' overflowed by 5164 bytes" occurred after enabling image signing for mcuboot
I was facing below warning that I am using default MCUBoot Key, which I should not use it for our production. I was new to this topic and wanted to resolve this issues asap. Because we will be certifying our product very soon with Verizon and I hope this was a crucial step to remove this warning before certification.
CMake Warning at C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
So to remove this warning I created a private key using openssl using below cmd in bash window and added below prj.conf and kconfig options.
prj.conf
CONFIG_SECURE_BOOT=y
kconfig
config BOOT_SIGNATURE_KEY_FILE
	string "Firmware Signature File Absolute Path"
	default "C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/private.pem"
OpenSSL CMD
openssl ecparam -name prime256v1 -noout -out private.pem
Although, after performing above changes the warning seems to be removed in the logs but the build is failing with the error stating that "region `FLASH' overflowed by 5164 bytes". Please refer complete logs below and a new warning appears mentioned below.
New Warning:
CMake Warning at ../../subsys/bootloader/CMakeLists.txt:21 (message):
        --- WARNING: When using the immutable bootloader on  ---
        --- this SoC, the UICR must be erased when flashing. ---
        --- E.g. by calling 'west flash --erase'             ---
Complete Log: (Somehow I am not able to attach the log in <\> option so attaching it below.)
Building Hermes_Cloud_Firmware
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/prj.conf" -DOVERLAY_CONFIG:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52833dk_nrf52833.conf;c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52dk_nrf52832.conf;c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.conf" -DDTC_OVERLAY_FILE:STRING="c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.overlay""
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware
-- Found Python3: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/.cache
-- Zephyr version: 3.1.99 (C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr)
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Found host-tools: zephyr 0.14.1 (C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk)
-- Found dtc: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk)
-- Found BOARD.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/Kconfig
Loaded configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/prj.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52833dk_nrf52833.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf52dk_nrf52832.conf'
Merged configuration 'c:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/boards/nrf9160dk_nrf9160_ns.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/Kconfig
Loaded configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning at C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr/CMakeLists.txt:1839 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/spm
=== child image spm - end ===
=== child image b0 - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/bootloader
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/dts.cmake
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/samples/bootloader/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/b0
=== child image b0 - end ===
-- Found Python3: C:/Users/Chetan.Kale/nordic_ncs/toolchains/v2.1.3/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/child_image_preload.cmake
-- Application: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/child_image/mcuboot/boards/nrf9160dk_nrf9160.overlay
-- Found devicetree overlay: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/dts.cmake
Parsing C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/bl_override/override_external_mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/image/multi_image_mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/bootloader/image/fw_info.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/child_image/mcuboot.conf'
Merged configuration 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/build/mcuboot
=== child image mcuboot - end ===
-- Found partition manager static configuration: C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/Hermes_Cloud_Firmware/pm_static.yml
Partition 'lwm2m_carrier' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_ctrl' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_rx' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'nrf_modem_lib_tx' is not included in the dynamic resolving since it is statically defined.
Partition 'nvs_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'spm' is not included in the dynamic resolving since it is statically defined.
Partition 'spm_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'sram_nonsecure' is not included in the dynamic resolving since it is statically defined.
Partition 'sram_secure' is not included in the dynamic resolving since it is statically defined.
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
Dropping partition 's1_pad' since its size is 0.
Dropping partition 's0_pad' since its size is 0.
-- Configuring done
-- Generating done
[0/407] Generating extra provision key files
[1/407] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/zephyr), build: v3.1.99-ncs1-2
[5/407] Creating directories for 'b0_subimage'
[6/407] Generating signing key
[9/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/bignum.c.obj
[10/407] Creating public key from private key used for signing
[13/407] No download step for 'mcuboot_subimage'
[14/407] Creating data to be provisioned to the Bootloader, storing to provision.hex
[19/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/nist_kw.c.obj
[21/407] No patch step for 'b0_subimage'
[22/407] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[23/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/padlock.c.obj
[24/407] No patch step for 'spm_subimage'
[25/407] No patch step for 'mcuboot_subimage'
[26/407] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform_util.c.obj
[27/407] No configure step for 'b0_subimage'
[27/407] Performing build step for 'b0_subimage'
[1/165] Generating include/generated/version.h
[2/165] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/165] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[4/165] Generating include/generated/driver-validation.h
[5/165] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/165] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/165] Generating include/generated/offsets.h
[8/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[9/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[10/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[11/165] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[12/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[13/165] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[14/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[15/165] Generating linker_zephyr_pre1.cmd
[16/165] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[17/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[18/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[19/165] Generating linker_zephyr_pre0.cmd
[20/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[21/165] Linking C static library zephyr\arch\common\libisr_tables.a
[22/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[23/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[24/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[25/165] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[26/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[27/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[28/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[29/165] Linking C static library zephyr\arch\common\libarch__common.a
[30/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[31/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[32/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[33/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[34/165] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[35/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[36/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[37/165] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[38/165] Generating ../../../include/generated/libc/minimal/strerror_table.h
[39/165] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[40/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[41/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[42/165] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[43/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[44/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[45/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[46/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[47/165] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[48/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[49/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[50/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[51/165] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[52/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[53/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[54/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[55/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[56/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[57/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[58/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[59/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[60/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[61/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[62/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[63/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[64/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[65/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[66/165] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[67/165] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[68/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[69/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[70/165] Building C object CMakeFiles/app.dir/src/main.c.obj
[71/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[72/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[73/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[74/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[75/165] Linking C static library zephyr\lib\posix\liblib__posix.a
[76/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[77/165] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[78/165] Linking C static library app\libapp.a
[79/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[80/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[81/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[82/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[83/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[84/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[85/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[86/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[87/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[88/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[89/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[90/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[91/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[92/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[93/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[94/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[95/165] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[96/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[97/165] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[98/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[99/165] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[100/165] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[101/165] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[102/165] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[103/165] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[104/165] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[105/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[106/165] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[107/165] Linking C static library zephyr\libzephyr.a
[108/165] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[109/165] Linking C static library zephyr\drivers\console\libdrivers__console.a
[110/165] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[111/165] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[112/165] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[113/165] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[114/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_ecdsa.c.obj
[115/165] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[116/165] Building C object modules/nrf/subsys/bootloader/bl_boot/CMakeFiles/..__nrf__subsys__bootloader__bl_boot.dir/bl_boot.c.obj
[117/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto.c.obj
[118/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_common.c.obj
[119/165] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[120/165] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[121/165] Building C object modules/nrf/subsys/bootloader/bl_crypto/CMakeFiles/..__nrf__subsys__bootloader__bl_crypto.dir/bl_crypto_cc310_hash.c.obj
[122/165] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[123/165] Linking C static library modules\nrf\subsys\bootloader\bl_boot\lib..__nrf__subsys__bootloader__bl_boot.a
[124/165] Building C object modules/nrf/subsys/bootloader/bl_validation/CMakeFiles/..__nrf__subsys__bootloader__bl_validation.dir/bl_validation.c.obj
[125/165] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[126/165] Building C object modules/nrf/subsys/bootloader/bl_storage/CMakeFiles/..__nrf__subsys__bootloader__bl_storage.dir/bl_storage.c.obj
[127/165] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[128/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[129/165] Linking C static library modules\nrf\subsys\bootloader\bl_crypto\lib..__nrf__subsys__bootloader__bl_crypto.a
[130/165] Linking C static library modules\nrf\subsys\bootloader\bl_validation\lib..__nrf__subsys__bootloader__bl_validation.a
[131/165] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[132/165] Linking C static library modules\nrf\subsys\bootloader\bl_storage\lib..__nrf__subsys__bootloader__bl_storage.a
[133/165] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[134/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[135/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[136/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[137/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[138/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[139/165] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[140/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[141/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[142/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[143/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[144/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[145/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[146/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[147/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[148/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[149/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[150/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[151/165] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[152/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[153/165] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[154/165] Linking C static library zephyr\kernel\libkernel.a
[155/165] Linking C executable zephyr\zephyr_pre0.elf
[156/165] Generating dev_handles.c
[157/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[158/165] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[159/165] Linking C executable zephyr\zephyr_pre1.elf
[160/165] Generating linker.cmd
[161/165] Generating isr_tables.c, isrList.bin
[162/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[163/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[164/165] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[165/165] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 23004 B 32 KB 70.20%
SRAM: 37288 B 211736 B 17.61%
IDT_LIST: 0 GB 2 KB 0.00%
[85/407] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[86/407] Performing build step for 'spm_subimage'
[1/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha1.c.obj
[2/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pk.c.obj
[3/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cipher_wrap.c.obj
[4/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pk_wrap.c.obj
[5/265] Generating include/generated/version.h
[6/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ripemd160.c.obj
[7/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha256.c.obj
[8/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/md5.c.obj
[9/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/md.c.obj
[10/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/aesni.c.obj
[11/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/camellia.c.obj
[12/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/aria.c.obj
[13/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cmac.c.obj
[14/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/sha512.c.obj
[15/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/des.c.obj
[16/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecdsa.c.obj
[17/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/chachapoly.c.obj
[18/265] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[19/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ccm.c.obj
[20/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecdh.c.obj
[21/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecp.c.obj
[22/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/hmac_drbg.c.obj
[23/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/gcm.c.obj
[24/265] Generating include/generated/driver-validation.h
[25/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/hkdf.c.obj
[26/265] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[27/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecjpake.c.obj
[28/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ecp_curves.c.obj
[29/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/chacha20.c.obj
[30/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/poly1305.c.obj
[31/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/rsa_alt_helpers.c.obj
[32/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[33/265] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[34/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[35/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[36/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_create.c.obj
[37/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509.c.obj
[38/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/rsa.c.obj
[39/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509write_csr.c.obj
[40/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_crl.c.obj
[41/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cache.c.obj
[42/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/net_sockets.c.obj
[43/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_crt.c.obj
[44/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/debug.c.obj
[45/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/x509_csr.c.obj
[46/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_ciphersuites.c.obj
[47/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_msg.c.obj
[48/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cookie.c.obj
[49/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_tls13_keys.c.obj
[50/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_cli.c.obj
[51/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_srv.c.obj
[52/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_ticket.c.obj
[53/265] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[54/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/asn1parse.c.obj
[55/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/asn1write.c.obj
[56/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/base64.c.obj
[57/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/ssl_tls.c.obj
[58/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/padlock.c.obj
[59/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform.c.obj
[60/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/nist_kw.c.obj
[61/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/platform_util.c.obj
[62/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/version.c.obj
[63/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/oid.c.obj
[64/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/constant_time.c.obj
[65/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_cipher.c.obj
[66/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_client.c.obj
[67/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/bignum.c.obj
[68/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_ecp.c.obj
[69/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_slot_management.c.obj
[70/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_aead.c.obj
[71/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_rsa.c.obj
[72/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_hash.c.obj
[73/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_mac.c.obj
[74/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pem.c.obj
[75/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/random_ext.c.obj
[76/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[77/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto.c.obj
[78/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/psa_crypto_storage.c.obj
[79/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[80/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkcs12.c.obj
[81/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkcs5.c.obj
[82/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/dhm.c.obj
[83/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkwrite.c.obj
[84/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/pkparse.c.obj
[85/265] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/mbedtls/library/cipher.c.obj
[86/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[87/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedx509.a
[88/265] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedtls.a
[89/265] Generating include/generated/offsets.h
[90/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[91/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/spm/secure_services.c.obj
[92/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[93/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/spm/spm.c.obj
[94/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[95/265] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[96/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[97/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[98/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[99/265] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[100/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[101/265] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[102/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[103/265] Generating linker_zephyr_pre1.cmd
[104/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[105/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[106/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[107/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[108/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[109/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[110/265] Linking C static library zephyr\arch\common\libisr_tables.a
[111/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[112/265] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[113/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[114/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[115/265] Generating linker_zephyr_pre0.cmd
[116/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[117/265] Linking C static library zephyr\arch\common\libarch__common.a
[118/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[119/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[120/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[121/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[122/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[123/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[124/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[125/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[126/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[127/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[128/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[129/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[130/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[131/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[132/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[133/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[134/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[135/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[136/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[137/265] Building C object CMakeFiles/app.dir/src/main.c.obj
[138/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[139/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[140/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[141/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[142/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[143/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[144/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[145/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[146/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[147/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[148/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[149/265] Linking C static library app\libapp.a
[150/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[151/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[152/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[153/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[154/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[155/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[156/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[157/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[158/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[159/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[160/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[161/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[162/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[163/265] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[164/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[165/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[166/265] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[167/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[168/265] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[169/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[170/265] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[171/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[172/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[173/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[174/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
[175/265] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[176/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[177/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[178/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[179/265] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[180/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[181/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[182/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[183/265] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[184/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[185/265] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[186/265] Linking C static library zephyr\kernel\libkernel.a
[187/265] Linking C static library zephyr\libzephyr.a
[188/265] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[189/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[190/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[191/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[192/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[193/265] Generating ../../../include/generated/libc/minimal/strerror_table.h
[194/265] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[195/265] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[196/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[197/265] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[198/265] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[199/265] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[200/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[201/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[202/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[203/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[204/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[205/265] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[206/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[207/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[208/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[209/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[210/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[211/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[212/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[213/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[214/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[215/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[216/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[217/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[218/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[219/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[220/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[221/265] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[222/265] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[223/265] Linking C static library zephyr\lib\posix\liblib__posix.a
[224/265] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[225/265] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[226/265] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[227/265] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[228/265] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c.obj
[229/265] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[230/265] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[231/265] Linking C static library zephyr\subsys\random\libsubsys__random.a
[232/265] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[233/265] Linking C static library zephyr\drivers\console\libdrivers__console.a
[234/265] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[235/265] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[236/265] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/cortex_m_systick.c.obj
[237/265] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[238/265] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[239/265] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[240/265] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[241/265] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[242/265] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[243/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[244/265] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[245/265] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[246/265] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[247/265] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[248/265] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[249/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[250/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[251/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[252/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[253/265] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
[254/265] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[255/265] Linking C executable zephyr\zephyr_pre0.elf
[256/265] Generating dev_handles.c
[257/265] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[258/265] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[259/265] Linking C executable zephyr\zephyr_pre1.elf
[260/265] Generating linker.cmd
[261/265] Generating isr_tables.c, isrList.bin
[262/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[263/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[264/265] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[265/265] Linking C executable zephyr\zephyr.elf
FLASH: 65024 B 64 KB 99.22%
SRAM: 11848 B 32 KB 36.16%
[89/407] Generating zephyr/b0_container.hex
[90/407] Performing build step for 'mcuboot_subimage'
[1/211] Generating include/generated/version.h
[2/211] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/211] Generating include/generated/driver-validation.h
[4/211] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/211] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/211] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/211] Generating include/generated/offsets.h
[8/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[9/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[10/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[11/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[12/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[13/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[14/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[15/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[16/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[17/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[18/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[19/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[20/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[21/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[22/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[23/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[24/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[25/211] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[26/211] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[27/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[28/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[29/211] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[30/211] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[31/211] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[32/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[33/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[34/211] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[35/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[36/211] Generating linker_zephyr_pre1.cmd
[37/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[38/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[39/211] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[40/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[41/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[42/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[43/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[44/211] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[45/211] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[46/211] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[47/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[48/211] Generating linker_zephyr_pre0.cmd
[49/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[50/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[51/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[52/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[53/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[54/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[55/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[56/211] Linking C static library zephyr\arch\common\libisr_tables.a
[57/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[58/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[59/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[60/211] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[61/211] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[62/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[63/211] Linking C static library zephyr\arch\common\libarch__common.a
[64/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[65/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[66/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[67/211] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[68/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[69/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[70/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[71/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[72/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[73/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[74/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[75/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[76/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[77/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[78/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[79/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[80/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[81/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[82/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[83/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[84/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[85/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[86/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[87/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[88/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[89/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[90/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[91/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[92/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[93/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[94/211] Generating zephyr/autogen-pubkey.c
[95/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[96/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[97/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[98/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[99/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[100/211] Building C object CMakeFiles/app.dir/os.c.obj
[101/211] Building C object CMakeFiles/app.dir/main.c.obj
[102/211] Building C object CMakeFiles/app.dir/keys.c.obj
[103/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[104/211] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[105/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[106/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[107/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[108/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[109/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[110/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[111/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[112/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[113/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[114/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[115/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
[116/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[117/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
[118/211] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[119/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
[120/211] Building C object CMakeFiles/app.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[121/211] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[122/211] Generating ../../../include/generated/libc/minimal/strerror_table.h
[123/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[124/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[125/211] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[126/211] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[127/211] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[128/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[129/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[130/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[131/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[132/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[133/211] Linking C static library app\libapp.a
[134/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[135/211] Linking C static library zephyr\libzephyr.a
[136/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[137/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[138/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[139/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[140/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[141/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[142/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[143/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[144/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[145/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[146/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[147/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[148/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[149/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[150/211] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[151/211] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[152/211] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[153/211] Linking C static library zephyr\lib\posix\liblib__posix.a
[154/211] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[155/211] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[156/211] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[157/211] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[158/211] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[159/211] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[160/211] Linking C static library zephyr\drivers\console\libdrivers__console.a
[161/211] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[162/211] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[163/211] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[164/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
[165/211] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[166/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[167/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[168/211] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[169/211] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[170/211] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[171/211] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[172/211] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[173/211] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[174/211] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[175/211] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[176/211] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[177/211] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[178/211] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[179/211] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[180/211] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[181/211] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[182/211] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[183/211] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[184/211] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[185/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[186/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[187/211] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[188/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[189/211] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[190/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[191/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[192/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[193/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[194/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[195/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[196/211] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[197/211] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[198/211] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[199/211] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[200/211] Linking C static library zephyr\kernel\libkernel.a
[201/211] Linking C executable zephyr\zephyr_pre0.elf
[202/211] Generating dev_handles.c
[203/211] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[204/211] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[205/211] Linking C executable zephyr\zephyr_pre1.elf
[206/211] Generating linker.cmd
[207/211] Generating isr_tables.c, isrList.bin
[208/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[209/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[210/211] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[211/211] Linking C executable zephyr\zephyr.elf
FLASH: 44680 B 48 KB 90.90%
SRAM: 25360 B 211736 B 11.98%
[165/407] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/nonsecure/soc_secure.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/nonsecure/soc_secure.c: In function 'soc_secure_mem_read':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\nonsecure\soc_secure.c:19:2: warning: 'spm_request_read' is deprecated [-Wdeprecated-declarations]
19 | return spm_request_read(dst, (uint32_t)src, len);
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\nonsecure\soc_secure.c:10:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:88:18: note: declared here
88 | __deprecated int spm_request_read(void *destination, uint32_t addr, size_t len);
[182/407] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/drivers/entropy/entropy_cc3xx.c: In function 'entropy_cc3xx_rng_get_entropy':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\drivers\entropy\entropy_cc3xx.c:65:3: warning: 'spm_request_random_number' is deprecated [-Wdeprecated-declarations]
65 | ret = spm_request_random_number(buffer + offset,
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\drivers\entropy\entropy_cc3xx.c:18:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:75:18: note: declared here
75 | __deprecated int spm_request_random_number(uint8_t *output, size_t len, size_t *olen);
[192/407] Building C object modules/nrf/lib/bin/lwm2m_carrier/CMakeFiles/..__nrf__lib__bin__lwm2m_carrier.dir/os/lwm2m_carrier.c.obj
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\lib\bin\lwm2m_carrier\os\lwm2m_carrier.c:15:31: warning: 'config' defined but not used [-Wunused-variable]
15 | static lwm2m_carrier_config_t config;
[267/407] Building C object modules/nrf/subsys/net/lib/fota_download/CMakeFiles/..__nrf__subsys__net__lib__fota_download.dir/src/fota_download.c.obj
C:/Users/Chetan.Kale/nordic_ncs/v2.1.3/nrf/subsys/net/lib/fota_download/src/fota_download.c: In function 'fota_download_s0_active_get':
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\net\lib\fota_download\src\fota_download.c:348:2: warning: 'spm_s0_active' is deprecated [-Wdeprecated-declarations]
348 | err = spm_s0_active(PM_S0_ADDRESS, PM_S1_ADDRESS, s0_active);
In file included from C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\subsys\net\lib\fota_download\src\fota_download.c:20:
C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\nrf\include\secure_services.h:99:18: note: declared here
99 | __deprecated int spm_s0_active(uint32_t s0_address, uint32_t s1_address, bool *s0_active);
[382/407] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build\zephyr && C:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\bin\cmake.exe -E echo ""
c:/users/chetan.kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `datas' will not fit in region `FLASH'
c:/users/chetan.kale/nordic_ncs/toolchains/v2.1.3/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 5164 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\Users\Chetan.Kale\nordic_ncs\toolchains\v2.1.3\opt\bin\cmake.EXE' --build 'c:\Users\Chetan.Kale\nordic_ncs\v2.1.3\Hermes_Cloud_Firmware\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it
I tried to search on Nordic forum but the solution provided/worked for others did not worked for me. Can you please help me to solve this issue asap ?
Thank you!
Chetan
