Example of using external flash that is on nRF5340dk ?
Im having trouble setting up and using flash on nRF5340dk.
Is there any example on how to use LittleFS on external flash that is on the dev kit?
  • my code for testing the flash storage is:
    /* Matches LFS_NAME_MAX */
    #define MAX_PATH_LEN 255
    #define PARTITION_NODE DT_NODELABEL(lfs1)
    #if DT_NODE_EXISTS(PARTITION_NODE)
    FS_FSTAB_DECLARE_ENTRY(PARTITION_NODE);
    #else  /* PARTITION_NODE */
    FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
    static struct fs_mount_t lfs_storage_mnt = {
        .type = FS_LITTLEFS,
        .fs_data = &storage,
        .storage_dev = (void *)FLASH_AREA_ID(storage),
        .mnt_point = "/lfs",
    #endif /* PARTITION_NODE */
    void testLittleFS(void)
      struct fs_mount_t *mp =
          &FS_FSTAB_ENTRY(PARTITION_NODE)
    #else
          &lfs_storage_mnt
      unsigned int id = (uintptr_t)mp->storage_dev;
      char fname[MAX_PATH_LEN];
      const struct flash_area *pfa;
      int rc;
      snprintf(fname, sizeof(fname), "%s/boot_count", mp->mnt_point);
      rc = open_flash_area(id, &pfa);
      if (rc < 0)
        return;
      if (IS_ENABLED(CONFIG_APP_WIPE_STORAGE))
        rc = erase_flash_area(pfa);
      flash_area_close(pfa);
    #if !DT_NODE_EXISTS(PARTITION_NODE) || (FSTAB_ENTRY_DT_MOUNT_FLAGS(PARTITION_NODE) & !FS_MOUNT_FLAG_AUTOMOUNT)
      rc = mount_fs(mp);
      if (rc < 0)
        return;
      reformat_and_mount_lfs(mp);
      struct fs_statvfs sbuf;
      rc = get_fs_stats(mp->mnt_point, &sbuf);
      rc = read_update_write_boot_count(mp, fname);
      rc = list_directory_contents(mp);
      rc = unmount_fs(mp);
    int open_flash_area(unsigned int id, const struct flash_area **pfa)
      int rc = flash_area_open(id, pfa);
      if (rc < 0)
        printk("FAIL: unable to find flash area %u: %d\n", id, rc);
        printk("Area %u at 0x%x on %u for %u bytes\n", id, (unsigned int)(*pfa)->fa_off, (*pfa)->fa_id, (unsigned int)(*pfa)->fa_size);
      return rc;
    int erase_flash_area(const struct flash_area *pfa)
      printk("Erasing flash area ... ");
      int rc = flash_area_erase(pfa, 0, pfa->fa_size);
      printk("%d\n", rc);
      return rc;
    int mount_fs(struct fs_mount_t *mp)
      int rc = fs_mount(mp);
      if (rc < 0)
        printk("FAIL: mount id %" PRIuPTR " at %s: %d\n", (uintptr_t)mp->storage_dev, mp->mnt_point, rc);
        printk("%s mount: %d\n", mp->mnt_point, rc);
      return rc;
    int get_fs_stats(const char *mnt_point, struct fs_statvfs *sbuf)
      int rc = fs_statvfs(mnt_point, sbuf);
      if (rc < 0)
        printk("FAIL: statvfs: %d\n", rc);
        printk("LittleFS statistics:\n");
        printk(" - Total space: %lu bytes\n", (unsigned long)sbuf->f_blocks * sbuf->f_frsize);
        printk(" - Free space: %lu bytes\n", (unsigned long)sbuf->f_bfree * sbuf->f_frsize);
        printk(" - Block size: %lu bytes\n", (unsigned long)sbuf->f_frsize);
      return rc;
    int read_update_write_boot_count(struct fs_mount_t *mp, const char *fname)
      struct fs_dirent dirent;
      int rc = fs_stat(fname, &dirent);
      printk("%s stat: %d\n", fname, rc);
      if (rc >= 0)
        printk("\tfn '%s' size %zu\n", dirent.name, dirent.size);
      struct fs_file_t file;
      fs_file_t_init(&file);
      rc = fs_open(&file, fname, FS_O_CREATE | FS_O_RDWR);
      if (rc < 0)
        printk("FAIL: open %s: %d\n", fname, rc);
        return rc;
      uint32_t boot_count = 0;
      rc = fs_read(&file, &boot_count, sizeof(boot_count));
      printk("%s read count %u: %d\n", fname, boot_count, rc);
      rc = fs_seek(&file, 0, FS_SEEK_SET);
      printk("%s seek start: %d\n", fname, rc);
      boot_count += 1;
      rc = fs_write(&file, &boot_count, sizeof(boot_count));
      printk("%s write new boot count %u: %d\n", fname, boot_count, rc);
      rc = fs_close(&file);
      printk("%s close: %d\n", fname, rc);
      return rc;
    int list_directory_contents(struct fs_mount_t *mp)
      struct fs_dir_t dir;
      fs_dir_t_init(&dir);
      int rc = fs_opendir(&dir, mp->mnt_point);
      printk("%s opendir: %d\n", mp->mnt_point, rc);
      while (rc >= 0)
        struct fs_dirent ent = {0};
        rc = fs_readdir(&dir, &ent);
        if (rc < 0)
        if (ent.name[0] == 0)
          printk("End of files\n");
        printk("  %c %zu %s\n",
               (ent.type == FS_DIR_ENTRY_FILE) ? 'F' : 'D',
               ent.size,
               ent.name);
      (void)fs_closedir(&dir);
      return rc;
    int unmount_fs(struct fs_mount_t *mp)
      int rc = fs_unmount(mp);
      printk("%s unmount: %d\n", mp->mnt_point, rc);
      return rc;
    static int write_test_file(const char *filename)
      int res = fs_open(&file, filename, FS_O_CREATE | FS_O_WRITE);
      if (res < 0)
        printk("Failed to open file for writing: %d\n", res);
        return res;
    #define FILE_SIZE 512
      uint8_t buffer[512];
      size_t remaining = FILE_SIZE;
      while (remaining > 0)
        size_t to_write = MIN(remaining, sizeof(buffer));
        ssize_t written = fs_write(&file, buffer, to_write);
        if (written < 0)
          printk("Failed to write to file: %d\n", (int)written);
          fs_close(&file);
          return (int)written;
        remaining -= written;
      fs_close(&file);
      return 0;
    void erase_partition(const struct flash_area *fa)
      flash_area_erase(fa, fa->fa_off, fa->fa_size);
    int reformat_littlefs(struct fs_mount_t *mp)
      printk("REFORMATING");
      struct fs_littlefs *fs = mp->fs_data;
      const struct lfs_config *lfs_cfg = &fs->cfg; // Access the 'cfg' member directly
      int rc = lfs_format(&fs->lfs, lfs_cfg);
      return rc;
    void reformat_and_mount_lfs(struct fs_mount_t *mp)
      // Unmount the filesystem
      fs_unmount(mp);
      // Erase the partition
      const struct flash_area *fa;
      flash_area_open(FLASH_AREA_ID(storage), &fa);
      erase_partition(fa);
      flash_area_close(fa);
      // Reformat the filesystem using the updated configuration
      reformat_littlefs(mp);
      // Remount the filesystem
      fs_mount(mp);
    with overlay:
    /delete-node/ &storage_partition;
        fstab {
            compatible = "zephyr,fstab";
            lfs1: lfs1 {
                compatible = "zephyr,fstab,littlefs";
                mount-point = "/lfs1";
                partition = <&lfs1_part>;
                automount;
                read-size = <256>;
                prog-size = <256>;
                cache-size = <256>;
                lookahead-size = <16>;
                block-cycles = <512>;
    &mx25r64 {
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            lfs1_part: partition@0 {
                label = "storage";
                reg = <0x00000000 0x00800000>;
    Area 7 at 0xf8000 on 7 for 24576 bytes
    [00:00:00.451,812] [0m<inf> littlefs: /lfs1 unmounted[0m
    REFORMATING[00:00:00.630,737] [0m<inf> littlefs: LittleFS version 2.5, disk version 2.0[0m
    [00:00:00.630,767] [0m<inf> littlefs: FS at flash-controller@39000:0xf8000 is 6 0x1000-byte blocks with 512 cycle[0m
    [00:00:00.630,767] [0m<inf> littlefs: sizes: rd 256 ; pr 256 ; ca 256 ; la 16[0m
    [00:00:00.631,134] [0m<inf> littlefs: /lfs1 mounted[0m
    - Total space: 24576 bytes
    - Free space: 16384 bytes
    - Block size: 4096 bytes
    but it should be 8mb ??
    Here is the example https://github.com/nrfconnect/sdk-zephyr/tree/main/samples/subsys/fs/littlefs.
    Please duplicate this https://github.com/nrfconnect/sdk-zephyr/blob/main/samples/subsys/fs/littlefs/boards/nrf52840dk_nrf52840_qspi.conf  config file and rename it to nrf5340dk_nrf5340_cpuapp.conf.
    Duplicate https://github.com/nrfconnect/sdk-zephyr/blob/main/samples/subsys/fs/littlefs/boards/nrf52840dk_nrf52840_qspi.overlay overlay file, rename it to nrf5340dk_nrf5340_cpuapp.overlay and update with the following content:
     * Copyright (c) 2019 Peter Bigot Consulting, LLC
    	chosen {
    		nordic,pm-ext-flash = &mx25r64;
    	fstab {
    		lfs1: lfs1 {
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    			lookahead-size = <32>;
    &mx25r64 {
    	partitions {
    		#size-cells = <1>;
    			label = "storage";
    			reg = <0x00000000 0x00010000>;
    Then, you could get the output like this
    Amanda H.
  • Thank you, It's working. I can now see all 8mb of flash. But there is an issue.
    When running the littlefs example I get
    Area 0 at 0x0 on mx25r6435f@0 for 8388608 bytes - Which is correct
    but when I transfer that code, exact code, to my app I get
    Area 2 at 0xfa000 on flash-controller@39000 for 24576 bytes
    Ive been going over whats different but cant find it, Maybe Im missing something?
    I also tried moving my code to littlefs example and everything was going fine until I added
    CONFIG_SYS_HEAP_RUNTIME_STATS=y to prj.conf.
    It switched to flash  flash-controller@39000, after commenting it out it stayed with flash and I cant get it to go back to mx25??
  • Ok, an Update. As soon as I add
    CONFIG_BT=y to nrf5340dk_nrf5340_cpuapp.conf
    the example stops working.
    Been testing for hours now removing and adding line by line and as soon BT is enabled the example falls apart.
