MQTT-SN communication problem using
I am trying to use the MQTT-SN Publisher-subscriber example.
Using RP4 as OTBR with Dongle. DK board flashed with the program.
Paho-MQTT-sn and RSMB were installed in RP4 along with mosquitto broker. All are configured and the whole set-up worked for a few hours. Now I am not able to connect to  Gateway.
I have tried connecting MQTT-SN Tools at one end and MQTT-Explorer at the other end and they are perfectly working. But when I press Key-2 from the DK board, it gets stuck at Gateway connection failure. By the way, one of my colleagues has also done a similar setup, we have matched all our config files and his setup is working perfectly.
Enclosed are my Gateway and RSMB config files and some of the command line outputs confirming set-up.
https://docs.google.com/presentation/d/1Y8J64QZEk_hiM8vAjlFAFYxM_D-j6yMM/edit?usp=sharing&ouid=109046646427669848489&rtpof=true&sd=true
Is this some version issue? Please help resolve the issue so that I can proceed further.
