nRF5340 netcore update with serial recovery
I have a custom board with a nRF5340 on it. The firmware gets built with MCUBoot in serial recovery mode to update the application core. The serial recovery mode is necessary for the update to work on this board. Updating the application core works perfectly fine.
As there is the possibility that I have to change something in the netcore firmware, I want to implement an update functionality for it via serial recovery mode as well.
I found this doc as well as this doc, but currently I am unsure as to what is really needed to get this update functionality to work.
I need some guidance as to what Kconfig statements need to go into which prj.conf, be it application firmware prj.conf, the mcuboot prj.conf or the netcore firmware prj.conf.
Another question: if I switch back to the nRF5340DK for testing, does the netcore print strings to a console like the application core?
I use SDK v2.2.0, the application core firmware is based on the central_bas sample project and the netcore firmware is based on the hci_rpmsg sample.
Thanks in advance,
Alex
prj.conf of central_bas:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
# was before CONFIG_HEAP_MEM_POOL_SIZE=1024, 1.6.1 was CONFIG_HEAP_MEM_POOL_SIZE=2048
#CONFIG_MAIN_STACK_SIZE=4096
CONFIG_BT_BAS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_PRIVACY=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_DK_LIBRARY=y
# Enable nordic security backend and PSA APIs
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
# START added from peripheral_UART example
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_NRFX_UARTE1=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# Enable the NUS service
CONFIG_BT_NUS=y
# END added from peripheral_UART example
### Added for MCUBoot as first-stage bootloader ###
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+1" # maj.min.rev+build
### Some command handlers require a large stack. Important for mcumgr, would otherwise timeout
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
### Start of necessary project config ###
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
CONFIG_SOC_LFXO_CAP_EXTERNAL=y
CONFIG_SOC_HFXO_CAP_EXTERNAL=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=n
CONFIG_NRFX_CLOCK=y
### End of necessary project config ###
prj.conf of mcuboot:
CONFIG_PM=n
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_RSA=n
CONFIG_BOOT_ENCRYPT_EC256=n
CONFIG_BOOT_ENCRYPT_X25519=n
CONFIG_BOOT_UPGRADE_ONLY=n
CONFIG_BOOT_BOOTSTRAP=n
### mbedTLS has its own heap
# CONFIG_HEAP_MEM_POOL_SIZE is not set
### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
### MCUboot has its own copy in tree.
# CONFIG_TINYCRYPT is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
# CONFIG_TINYCRYPT_SHA256 is not set
CONFIG_FLASH=y
CONFIG_FPROTECT=y
### Various Zephyr boards enable features that we don't want.
# CONFIG_BT is not set
# CONFIG_BT_CTLR is not set
# CONFIG_I2C is not set
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
### Ensure Zephyr logging changes don't use more resources
CONFIG_LOG_DEFAULT_LEVEL=0
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
### Added for serial recovery ###
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
### Only CONFIG_UART_CONSOLE=n should be necessary
#CONFIG_CONSOLE=n
#CONFIG_CONSOLE_HANDLER=n
### Enable wait for serial recovery ###
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=5000
CONFIG_NRFX_CLOCK=y
prj.conf of hci_rpmsg:
CONFIG_IPC_SERVICE=y
CONFIG_MBOX=y
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=512
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
CONFIG_BT=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_HCI_RAW_RESERVE=1
CONFIG_BT_MAX_CONN=16
CONFIG_BT_CTLR_ASSERT_HANDLER=y
# Workaround: Unable to allocate command buffer when using K_NO_WAIT since
# Host number of completed commands does not follow normal flow control.
CONFIG_BT_BUF_CMD_TX_COUNT=10
CONFIG_NRFX_CLOCK=n
In case it is needed, nrf5340dk_nrf5340_cpuapp.overlay:
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
// This information was auto-generated when this file was created in VS Code
	chosen {
		nordic,nus-uart = &uart1;
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default_overlay>;
	pinctrl-1 = <&uart0_sleep_overlay>;
&uart1 {
	status = "okay";
	pinctrl-0 = <&uart1_default_overlay>;
	pinctrl-1 = <&uart1_sleep_overlay>;
// TODO: add missing pin configuration
// sda-pin = < 0x16 >;
// scl-pin = < 0x17 >;
&i2c1 {
	status = "disabled";
// unsure
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default_overlay>;
	pinctrl-1 = <&pwm0_sleep_overlay>;
// io-pins = < 0xf >;
&qspi {
&pinctrl {
	uart0_default_overlay: uart0_default_overlay {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 28)>,
				<NRF_PSEL(UART_RTS, 0, 30)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 26)>,
				<NRF_PSEL(UART_CTS, 0, 31)>;
			bias-pull-up;
	uart0_sleep_overlay: uart0_sleep_overlay {
		group1 {
				<NRF_PSEL(UART_RTS, 0, 30)>,
			low-power-enable;
	uart1_default_overlay: uart1_default_overlay {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 2)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 13)>;
			bias-pull-up;
	uart1_sleep_overlay: uart1_sleep_overlay {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 2)>,
			low-power-enable;
/* unsure begin */
	pwm0_default_overlay: pwm0_default_overlay {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 0, 16)>;
	pwm0_sleep_overlay: pwm0_sleep_overlay {
		group1 {
			low-power-enable;
/* unsure end */
	leds {
		compatible = "gpio-leds";
        led0: led_0 {
			gpios = < &gpio0 0x13 0x1 >;
			label = "Green LED 0";
        led1: led_1 {
			gpios = < &gpio0 0x15 0x1 >;
			label = "Green LED 1";
        led2: led_2 {
			gpios = < &gpio1 0x08 0x1 >;
			label = "Green LED 2";
        led3: led_3 {
			gpios = < &gpio1 0x06 0x1 >;
			label = "Green LED 3";
        led4: led_4 {
			gpios = < &gpio1 0x04 0x1 >;
			label = "Green LED 4";
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		led3 = &led3;
		led4 = &led4;
		pwm-led0 = &pwm_led0;
		sw0 = &button0;
		sw1 = &button1;
		sw2 = &button2;
		sw3 = &button3;
		bootloader-led0 = &led0;
dts.overlay (mcuboot):
	chosen {
		zephyr,code-partition = &boot_partition;
&uart0 {
	status = "okay";
&uart1 {
	status = "okay";
&i2c1 {
// unsure
&pwm0 {
	status = "okay";
&qspi {
&pinctrl {
		group1 {
		group2 {
			bias-pull-up;
		group1 {
			low-power-enable;
		group1 {
		group2 {
			bias-pull-up;
		group1 {
			low-power-enable;
/* unsure begin */
		group1 {
		group1 {
			low-power-enable;
/* unsure end */
	leds {
        led0: led_0 {
        led1: led_1 {
        led2: led_2 {
        led3: led_3 {
        led4: led_4 {
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		led3 = &led3;
		led4 = &led4;
		sw0 = &button0;
		sw1 = &button1;
		sw2 = &button2;
		sw3 = &button3;
image list with mcumgr:
Y:\>mcumgr -c nrf53 image list
Images:
 image=0 slot=0
    version: 1.0.1.1
    bootable: false
    flags:
    hash: Unavailable
Split status: N/A (0)
    Due to summer vacation we are slightly reduced staff, so can you take a look at the peripheral uart example that show how you for instance can enable serial recovery of the network core:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/peripheral_uart/README.html#
    Kenneth
  • Alright, I will try to get it to work with this
  • So I got back to this project and added the Kconfig parameters from the peripheral_uart sample to my central_bas project.
    However, CONFIG_FLASH_SIMULATOR cannot be enabled because "CONFIG_FLASH_SIMULATOR was assigned the value y, but got the value n. Missing dependencies: DT_HAS_ZEPHYR_SIM_FLASH_ENABLED". There is however no Kconfig fragment to enable this.
    And with CONFIG_NRF53_RECOVERY_NETWORK_CORE, I get "CONFIG_NRF53_RECOVERY_NETWORK_CORE was assigned the value y, but got the value n. Missing dependencies: n"
    How can I solve these issues?
    Alex
    CONFIG_BT=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_SMP=y
    CONFIG_BT_GATT_DM=y
    CONFIG_BT_SCAN=y
    CONFIG_BT_PRIVACY=y
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_DK_LIBRARY=y
    ### START added from peripheral_UART example
    #CONFIG_NRFX_UARTE1=y
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    CONFIG_CONSOLE=y
    CONFIG_BT_NUS=y
    ### END added from peripheral_UART example
    CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+0" # maj.min.rev+build
    ### Update netcore
    CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
    CONFIG_PM=n
    CONFIG_FLASH=y
    CONFIG_FPROTECT=y
    CONFIG_LOG=y
    #CONFIG_MCUBOOT_INDICATION_LED=y
    #CONFIG_CONSOLE=n
    CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=1000
    ### The following configurations are required to support serial recovery of the network image
    CONFIG_PCD_APP=y
    CONFIG_FLASH_SIMULATOR=y
    CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
    CONFIG_FLASH_SIMULATOR_STATS=n
    CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
    CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
    CONFIG_NRF53_RECOVERY_NETWORK_CORE=y
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_MBOX=y
    CONFIG_BT=y
    CONFIG_BT_HCI_RAW=y
  • Hi Ryisen,
    Just wanted to let you know that I have taken over this case, as Kenneth is now on holiday. We are busy during the summer, but I'll try to get back to you soon.
    Raoul
  • Hi Alex,
    I haven't gotten to the bottom of this yet, sorry. Things are slowly returning to normal here now so I hope to find an answer soon.
    Meanwhile, my colleague has a github repo with various bootloader samples and I see that there has been a recent addition of serial updates on netcore. Would you mind taking a look, trying to build it on your machine and comparing to your current setup?
    Raoul
