VSCODE NOT ACTIVE
error code :
Building hello_world
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir e:/ublox/example/hello_world/build e:/ublox/example/hello_world --pristine --board nrf52833dk_nrf52833 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="e:/ublox/example/observer" -DCONF_FILE:STRING="e:/ublox/example/hello_world/prj.conf""
-- Application: E:/ublox/example/hello_world
-- Found Python3: E:/ublox/ncs/toolchains/v2.1.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: E:/ublox/ncs/v2.1.0/zephyr/.cache
-- Zephyr version: 3.1.99 (E:/ublox/ncs/v2.1.0/zephyr)
-- Board: nrf52833dk_nrf52833
-- Found host-tools: zephyr 0.14.1 (E:/ublox/ncs/toolchains/v2.1.0/opt/zephyr-sdk)
-- Found dtc: E:/ublox/ncs/toolchains/v2.1.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
CMake Error at E:/ublox/ncs/v2.1.0/zephyr/cmake/modules/extensions.cmake:2038 (message):
Assertion failed: GNUARMEMB_TOOLCHAIN_PATH is not set
E:/ublox/ncs/v2.1.0/zephyr/cmake/toolchain/gnuarmemb/generic.cmake:13 (assert)
E:/ublox/ncs/v2.1.0/zephyr/cmake/modules/generic_toolchain.cmake:45 (include)
E:/ublox/ncs/v2.1.0/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
E:/ublox/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
E:/ublox/ncs/v2.1.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:5 (find_package)
FATAL ERROR: command exited with status 1: 'E:\ublox\ncs\toolchains\v2.1.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=E:\ublox\ncs\toolchains\v2.1.0\opt\bin\python.exe' '-Be:\ublox\example\hello_world\build' -GNinja -DBOARD=nrf52833dk_nrf52833 -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DBOARD_ROOT:STRING=e:/ublox/example/observer -DCONF_FILE:STRING=e:/ublox/example/hello_world/prj.conf '-Se:\ublox\example\hello_world'
all example code not actived
I have tried reinstalling the toolchain or GCC compiler, but it still doesn't work.
It was working fine initially, but it stopped functioning after I tried adding the .overlay file.
I tried setting the GNUARMEMB_TOOLCHAIN_PATH to 'E:\ublox\ncs\toolchains\v2.1.0\opt', but it still doesn't work.
Is the file path incorrect, or could there be another cause?
The GNU toolchain is installed in 'C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major', and the toolchain file is located in 'E:\ublox\ncs'.
I can't identify the cause.
    Could you generate support information in VScode and  upload the details in here. You can generate the support information by opening the command palette and writing nRF Connect: Generate support information.
    Kind Regards,
    Abhijith
  • The following content is nRF Connect: Generate support information.
    [09:19:45] Update available nsscprodmedia.blob.core.windows.net/.../nrf-command-line-tools-10.22.0-x64.exe
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Home",
        "osKernel": "10.0.22621",
        "vscode": "1.79.2",
        "electron": "22.5.7",
        "node": "v16.17.1"
      "system": {
        "date": "2023-07-06T00:21:10.317Z",
        "vscodeRoot": "c:\\Users\\ehdck\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:01:38",
        "osUptime": "408:05:57",
        "cpu": {
          "model": "12th Gen Intel(R) Core(TM) i7-1260P",
          "speed": "2496 MHz",
          "count": 8
        "memory": {
          "total": "15.71 GB",
          "free": "6.27 GB"
      "workspace": {
        "name": "제목 없음(작업 영역)",
        "workspaceFile": "1687932133790",
        "folders": [
          "e:\\ublox\\c209-aoa-tag_n",
          "e:\\ublox\\example\\new_rfm",
          "e:\\ublox\\example\\observer"
      "extensions": {
        "internal": {
            "version": "2023.6.345",
            "path": "c:\\Users\\ehdck\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.6.345-win32-x64",
            "isActive": true
            "version": "2023.6.78",
            "path": "c:\\Users\\ehdck\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.6.78",
            "isActive": true
            "version": "2023.6.108",
            "path": "c:\\Users\\ehdck\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.6.108",
            "isActive": true
            "version": "2023.6.51",
            "path": "c:\\Users\\ehdck\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.6.51",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.12.0",
          "ms-vscode.cpptools": "1.16.3",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.19",
          "ms-vscode.js-debug": "1.78.0",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "hoovercj.vscode-power-mode": "3.0.2",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.22",
          "mcu-debug.peripheral-viewer": "1.4.6",
          "mcu-debug.rtos-views": "0.0.7",
          "MS-CEINTL.vscode-language-pack-ko": "1.79.2023061409",
          "ms-vscode.cmake-tools": "1.14.34",
          "ms-vscode.hexeditor": "1.9.11",
          "twxs.cmake": "0.0.17"
      "tools": {
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.14.1",
        "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.86b",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.19.0",
        "C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\nrfutil.exe": null,
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\cmake.exe": "3.20.5",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\Scripts\\west.exe": "0.14.0",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\python.exe": "3.8.2",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\ninja.exe": "1.9.0",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\gperf.exe": "3.1",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\dtc.exe": "1.4.7",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\gn.exe": "2060",
        "E:\\ublox\\ncs\\toolchains\\v2.1.0\\mingw64\\bin\\git.exe": "2.26.2.windows.1",
        "gdbPath": "e:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb-no-py.exe"
      "sdks": [
          "version": "2.1.0",
          "path": "e:\\ublox\\ncs\\v2.1.0"
      "toolchains": [
          "version": "2.1.0",
          "path": "e:\\ublox\\ncs\\toolchains\\v2.1.0"
      "connectedDevices": [],
      "deviceProvider": "nrfjprog",
      "config": {
          "topdir": "${nrf-connect.sdk:2.1.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.1.0}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig",
            "executeInDefaultShell": false
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "enableTelemetry": true
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "variableUseNaturalFormat": true,
          "liveWatchRefreshRate": "300",
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "vscode"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\ehdck",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\ehdck",
          "PATH": "E:\\ublox\\ncs\\toolchains\\v2.1.0;E:\\ublox\\ncs\\toolchains\\v2.1.0\\mingw64\\bin;E:\\ublox\\ncs\\toolchains\\v2.1.0\\bin;E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin;E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\Scripts;E:\\ublox\\ncs\\toolchains\\v2.1.0\\nanopb\\generator-bin;E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\ehdck\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.6.345-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc16\\v2.00\\bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\Microchip\\MPLAB C30\\bin;C:\\Program Files\\Bandizip\\;C:\\Program Files (x86)\\HI-TECH Software\\PICC\\9.81\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2020-q4-major\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ehdck\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "e:\\ublox\\ncs\\v2.1.0\\zephyr",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "ZEPHYR_SDK_INSTALL_DIR": "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\zephyr-sdk",
          "PYTHONPATH": "E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin;E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\Lib;E:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc16\\v2.00\\bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\Microchip\\MPLAB C30\\bin;C:\\Program Files\\Bandizip\\;C:\\Program Files (x86)\\HI-TECH Software\\PICC\\9.81\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2020-q4-major\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ehdck\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc8\\v2.41\\bin;C:\\Program Files\\Microchip\\xc16\\v2.00\\bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\110\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\160\\DTS\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\Microchip\\MPLAB C30\\bin;C:\\Program Files\\Bandizip\\;C:\\Program Files (x86)\\HI-TECH Software\\PICC\\9.81\\bin;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\CMake\\bin;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2020-q4-major\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\ehdck\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ehdck\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
        "toolchainPath": "e:\\ublox\\ncs\\toolchains\\v2.1.0",
        "toolchainBinPath": "e:\\ublox\\ncs\\toolchains\\v2.1.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.1.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    dcjin said:
    "workspace": {
        "folders": [
          "e:\\ublox\\e
    Maybe the issue is because of this different path (outside ncs) you are choosing for the workspace folders. Can you place the workspace inside the ncs folder (e:\\ublox\\ncs) as this is where your sdk and toolchains are located, and check whether the problem happens? I can see some "problems" (pointing the problem tab in terminal) inside the screenshot you shared. Could you also share those if changing the path doesn't work?
    Kind Regards,
    Abhijith
  • [09:19:08] Update available nsscprodmedia.blob.core.windows.net/.../nrf-command-line-tools-10.22.0-x64.exe
    [09:20:26] cmd.exe /d /s /c "west build --build-dir e:/ublox/ncs/observer_test/build e:/ublox/ncs/observer_test --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="e:/ublox/ncs/observer_test/prj_extended.conf" -DBOARD_ROOT:STRING="e:/ublox/ncs/observer_test""
    [09:20:29] Failure (code 1).
      "platform": {
        "os": "win32",
        "vscode": "1.79.2",
        "node": "v16.17.1"
      "system": {
        "date": "2023-07-07T00:22:48.888Z",
        "vscodeUptime": "00:03:53",
        "osUptime": "432:07:36",
        "cpu": {
          "count": 8
        "memory": {
          "free": "7.11 GB"
      "workspace": {
        "folders": [
          "e:\\ublox\\ncs\\observer_test"
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
      "sdks": [
          "version": "2.1.0",
      "toolchains": [
          "version": "2.1.0",
      "config": {
          "toolchain": {
          "ozonePath": "",
          "applications": [],
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
      "environment": {
        "westEnv": {
          "HOMEDRIVE": "C:",
        "inherited": {
          "HOMEDRIVE": "C:",
      "terminal": {
        "shell": null,
    I created a test project in the path 'e:\ublox\ncs\observer_test' with the same issue occurred.
    I'm not sure what the problem is.
  • I have some idea of what the problem might be, but I'm not entirely certain.
    I need to use ZEPHYR_TOOLCHAIN_VARIANT:STRING=zephyr, but it keeps getting changed to ZEPHYR_TOOLCHAIN_VARIANT:STRING=gnumemb. Where do I need to make the modification?
