Hi, I was currently trying to run the example code on my linux virtual machine(virtual box).
I followed the steps from https://github.com/NordicSemiconductor/pc-ble-driver/tree/master
and the results shows that : Serial port used: /dev/ttyACM0
Hi spike dou,
The pc-ble-driver is designed to work with the nRF5 SDK and is therefore not recommended for new project. Please see Einar's answer here for a detailed explanation: Is pc-ble-driver still supported? .
For this particular case, 0x0D is likely NRF_ERROR_TIMEOUT. Considering that the communication could never be started, could you please review if you are using the correct hex file for 1M baud rate?
Please also take a look at these previous cases to see if any of the issues and fixes there are applicable to your situation.
connectivity firmware and pc-ble-driver issues
pc-ble-driver: "Failed to open nRF BLE Driver. Error code: 0x0D"
Hieu
