I would like to use Tinycrypt library to do AES encryption. Does Nordic provide sample code?
Hi Snowuyl,
As far as I know we don't have a sample for this, sorry. I do see that there is some test code available for it, which might be useful: https://github.com/zephyrproject-rtos/zephyr/blob/main/tests/crypto/tinycrypt/src/sha256.c
And of course the documentation: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/services/crypto/tinycrypt.html
If Tinycrypt is not a necessity, then we do have other AES Crypto samples: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/crypto.html
Raoul
Thanks for your reply! I would like to build MCUboot with TinyCrypt. Could you kindly to provide reference documentation?
According to this release note, TinyCrypt has been included in the mcuboot code base, you should be able to enable it via Kconfig.
I was unable to find reference documentation, but I see mention of the CONFIG_BOOT_USE_TINYCRYPT option here: https://github.com/nrfconnect/sdk-mcuboot/blob/823fd369c1430b50d263ccd6fbcf98bdd44001ba/boot/zephyr/Kconfig#L28
I also see that there is CONFIG_BOOT_ECDSA_TINYCRYPT, discussed in this case: Bulid MCUBoot with TINYCRYPT to support DFU image cipher/encryption
Would you mind trying these?
I'm sorry I can't dig deeper into this at the moment, we are quite busy during the summer weeks.
Raoul
Thanks for your reply! I have added the following setting in D:\ncs\v2.3.0\bootloader\mcuboot\boot\zephyr\CMakeLists.txt. But west build and west flash doesn't show any log messages related to Tinycrypt. How can I make sure Tinycrypt is built with MCUboot?
set(CONFIG_BOOT_ECDSA_TINYCRYPT y)
# CMakeLists.txt for building mcuboot as a Zephyr project # # Copyright (c) 2017 Open Source Foundries Limited # # SPDX-License-Identifier: Apache-2.0 cmake_minimum_required(VERSION 3.13.1) # Add a common dts overlay necessary to ensure mcuboot is linked into, # and fits inside, the boot partition. (If the user specified a # DTC_OVERLAY_FILE on the CMake command line, we need to append onto # the list). if(DTC_OVERLAY_FILE) set(DTC_OVERLAY_FILE "${DTC_OVERLAY_FILE} ${CMAKE_CURRENT_LIST_DIR}/dts.overlay" CACHE STRING "" FORCE ) else() set(DTC_OVERLAY_FILE ${CMAKE_CURRENT_LIST_DIR}/dts.overlay) endif() # Enable Zephyr runner options which request mass erase if so # configured. # # Note that this also disables the default "leave" option when # targeting STM32 DfuSe devices with dfu-util, making the chip stay in # the bootloader after flashing. # # That's the right thing, because mcuboot has nothing to do since the # chip was just erased. The next thing the user is going to want to do # is flash the application. (Developers can reset DfuSE devices # manually to test mcuboot behavior on an otherwise erased flash # device.) macro(app_set_runner_args) if(CONFIG_ZEPHYR_TRY_MASS_ERASE) board_runner_args(dfu-util "--dfuse-modifiers=force:mass-erase") board_runner_args(pyocd "--flash-opt=-e=chip") board_runner_args(nrfjprog "--erase") endif() endmacro() # find_package(Zephyr) in order to load application boilerplate: # http://docs.zephyrproject.org/application/application.html find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE}) project(NONE) # Path to "boot" subdirectory of repository root. get_filename_component(BOOT_DIR ${APPLICATION_SOURCE_DIR} DIRECTORY) # Path to top-level repository root directory. get_filename_component(MCUBOOT_DIR ${BOOT_DIR} DIRECTORY) # Path to tinycrypt library source subdirectory of MCUBOOT_DIR. set(TINYCRYPT_DIR "${MCUBOOT_DIR}/ext/tinycrypt/lib") assert_exists(TINYCRYPT_DIR) set(TINYCRYPT_SHA512_DIR "${MCUBOOT_DIR}/ext/tinycrypt-sha512/lib") assert_exists(TINYCRYPT_SHA512_DIR) # Path to crypto-fiat set(FIAT_DIR "${MCUBOOT_DIR}/ext/fiat") assert_exists(FIAT_DIR) # Path to mbed-tls' asn1 parser library. set(MBEDTLS_ASN1_DIR "${MCUBOOT_DIR}/ext/mbedtls-asn1") assert_exists(MBEDTLS_ASN1_DIR) set(NRF_DIR "${MCUBOOT_DIR}/ext/nrf") if(CONFIG_BOOT_USE_NRF_CC310_BL) set(NRFXLIB_DIR ${ZEPHYR_BASE}/../nrfxlib) if(NOT EXISTS ${NRFXLIB_DIR}) message(FATAL_ERROR " ------------------------------------------------------------------------ No such file or directory: ${NRFXLIB_DIR} The current configuration enables nRF CC310 crypto accelerator hardware with the `CONFIG_BOOT_USE_NRF_CC310_BL` option. Please follow `ext/nrf/README.md` guide to fix your setup or use tinycrypt instead of the HW accelerator. To use the tinycrypt set `CONFIG_BOOT_ECDSA_TINYCRYPT` to y. ------------------------------------------------------------------------") endif() endif() set(CONFIG_BOOT_ECDSA_TINYCRYPT y) zephyr_library_include_directories( include targets ) if(EXISTS targets/${BOARD}.h) zephyr_library_compile_definitions(MCUBOOT_TARGET_CONFIG="${BOARD}.h") endif() # Zephyr port-specific sources. zephyr_library_sources( main.c flash_map_extended.c os.c keys.c ) if(DEFINED CONFIG_ENABLE_MGMT_PERUSER) zephyr_library_sources( boot_serial_extensions.c ) endif() if(NOT DEFINED CONFIG_FLASH_PAGE_LAYOUT) zephyr_library_sources( flash_map_legacy.c ) endif() # Generic bootutil sources and includes. zephyr_library_include_directories(${BOOT_DIR}/bootutil/include) zephyr_library_sources( ${BOOT_DIR}/bootutil/src/image_validate.c ${BOOT_DIR}/bootutil/src/tlv.c ${BOOT_DIR}/bootutil/src/encrypted.c ${BOOT_DIR}/bootutil/src/image_rsa.c ${BOOT_DIR}/bootutil/src/image_ec256.c ${BOOT_DIR}/bootutil/src/image_ed25519.c ${BOOT_DIR}/bootutil/src/bootutil_misc.c ${BOOT_DIR}/bootutil/src/fault_injection_hardening.c ) # library which might be common source code for MCUBoot and an application zephyr_link_libraries(MCUBOOT_BOOTUTIL) if(CONFIG_BOOT_FIH_PROFILE_HIGH) zephyr_library_sources( ${BOOT_DIR}/bootutil/src/fault_injection_hardening_delay_rng_mbedtls.c ) endif() if(CONFIG_SINGLE_APPLICATION_SLOT) zephyr_library_sources( ${BOOT_DIR}/zephyr/single_loader.c ) zephyr_library_include_directories(${BOOT_DIR}/bootutil/src) else() zephyr_library_sources( ${BOOT_DIR}/bootutil/src/loader.c ${BOOT_DIR}/bootutil/src/swap_misc.c ${BOOT_DIR}/bootutil/src/swap_scratch.c ${BOOT_DIR}/bootutil/src/swap_move.c ${BOOT_DIR}/bootutil/src/caps.c ) endif() if(CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 OR CONFIG_BOOT_ENCRYPT_EC256 OR CONFIG_BOOT_SERIAL_ENCRYPT_EC256) zephyr_library_include_directories( ${MBEDTLS_ASN1_DIR}/include ) zephyr_library_sources( # Additionally pull in just the ASN.1 parser from mbedTLS. ${MBEDTLS_ASN1_DIR}/src/asn1parse.c ${MBEDTLS_ASN1_DIR}/src/platform_util.c ) if(CONFIG_BOOT_USE_TINYCRYPT) # When using ECDSA signatures, pull in our copy of the tinycrypt library. zephyr_library_include_directories( ${BOOT_DIR}/zephyr/include ${TINYCRYPT_DIR}/include ) zephyr_include_directories(${TINYCRYPT_DIR}/include) zephyr_library_sources( ${TINYCRYPT_DIR}/source/ecc.c ${TINYCRYPT_DIR}/source/ecc_dsa.c ${TINYCRYPT_DIR}/source/sha256.c ${TINYCRYPT_DIR}/source/utils.c ) elseif(CONFIG_BOOT_USE_NRF_CC310_BL) zephyr_library_sources(${NRF_DIR}/cc310_glue.c) zephyr_library_include_directories(${NRF_DIR}) zephyr_link_libraries(nrfxlib_crypto) elseif(CONFIG_BOOT_USE_NRF_EXTERNAL_CRYPTO) zephyr_include_directories(${BL_CRYPTO_DIR}/../include) endif() # Since here we are not using Zephyr's mbedTLS but rather our own, we need # to set MBEDTLS_CONFIG_FILE ourselves. When using Zephyr's copy, this # variable is set by its Kconfig in the Zephyr codebase. zephyr_library_compile_definitions( MBEDTLS_CONFIG_FILE="${CMAKE_CURRENT_LIST_DIR}/include/mcuboot-mbedtls-cfg.h" ) elseif(CONFIG_BOOT_SIGNATURE_TYPE_NONE) zephyr_library_include_directories( ${BOOT_DIR}/zephyr/include ${TINYCRYPT_DIR}/include ) zephyr_library_sources( ${TINYCRYPT_DIR}/source/sha256.c ${TINYCRYPT_DIR}/source/utils.c ) elseif(CONFIG_BOOT_SIGNATURE_TYPE_RSA) # Use mbedTLS provided by Zephyr for RSA signatures. (Its config file # is set using Kconfig.) zephyr_include_directories(include) if(CONFIG_BOOT_ENCRYPT_RSA) set_source_files_properties( ${BOOT_DIR}/bootutil/src/encrypted.c PROPERTIES INCLUDE_DIRECTORIES ${ZEPHYR_MBEDTLS_MODULE_DIR}/library ) endif() elseif(CONFIG_BOOT_SIGNATURE_TYPE_ED25519 OR CONFIG_BOOT_ENCRYPT_X25519) if(CONFIG_BOOT_USE_TINYCRYPT) zephyr_library_include_directories( ${MBEDTLS_ASN1_DIR}/include ${BOOT_DIR}/zephyr/include ${TINYCRYPT_DIR}/include ${TINYCRYPT_SHA512_DIR}/include ) zephyr_library_sources( ${TINYCRYPT_DIR}/source/sha256.c ${TINYCRYPT_DIR}/source/utils.c ${TINYCRYPT_SHA512_DIR}/source/sha512.c # Additionally pull in just the ASN.1 parser from mbedTLS. ${MBEDTLS_ASN1_DIR}/src/asn1parse.c ${MBEDTLS_ASN1_DIR}/src/platform_util.c ) zephyr_library_compile_definitions( MBEDTLS_CONFIG_FILE="${CMAKE_CURRENT_LIST_DIR}/include/mcuboot-mbedtls-cfg.h" ) else() zephyr_include_directories(include) endif() zephyr_library_include_directories( ${BOOT_DIR}/zephyr/include ${FIAT_DIR}/include/ ) zephyr_library_sources( ${FIAT_DIR}/src/curve25519.c ) endif() if(CONFIG_BOOT_ENCRYPT_EC256 OR CONFIG_BOOT_ENCRYPT_X25519 OR CONFIG_BOOT_SERIAL_ENCRYPT_EC256) zephyr_library_sources( ${TINYCRYPT_DIR}/source/aes_encrypt.c ${TINYCRYPT_DIR}/source/aes_decrypt.c ${TINYCRYPT_DIR}/source/ctr_mode.c ${TINYCRYPT_DIR}/source/hmac.c ${TINYCRYPT_DIR}/source/ecc_dh.c ) endif() if(CONFIG_BOOT_ENCRYPT_EC256) zephyr_library_sources( ${TINYCRYPT_DIR}/source/ecc_dh.c ) endif() if(CONFIG_MCUBOOT_SERIAL) zephyr_sources(${BOOT_DIR}/zephyr/serial_adapter.c) zephyr_sources(${BOOT_DIR}/boot_serial/src/boot_serial.c) zephyr_sources(${BOOT_DIR}/boot_serial/src/serial_recovery_cbor.c) zephyr_sources(${BOOT_DIR}/boot_serial/src/zcbor_decode.c) zephyr_sources(${BOOT_DIR}/boot_serial/src/zcbor_encode.c) zephyr_sources(${BOOT_DIR}/boot_serial/src/zcbor_common.c) zephyr_sources_ifdef(CONFIG_BOOT_MGMT_ECHO ${BOOT_DIR}/boot_serial/src/serial_recovery_echo.c) zephyr_include_directories(${BOOT_DIR}/bootutil/include) zephyr_include_directories(${BOOT_DIR}/boot_serial/include) zephyr_include_directories(include) zephyr_include_directories_ifdef( CONFIG_BOOT_ERASE_PROGRESSIVELY ${BOOT_DIR}/bootutil/src ) endif() if(NOT CONFIG_BOOT_SIGNATURE_KEY_FILE STREQUAL "") # CONF_FILE points to the KConfig configuration files of the bootloader. foreach (filepath ${CONF_FILE}) file(READ ${filepath} temp_text) string(FIND "${temp_text}" ${CONFIG_BOOT_SIGNATURE_KEY_FILE} match) if (${match} GREATER_EQUAL 0) if (NOT DEFINED CONF_DIR) get_filename_component(CONF_DIR ${filepath} DIRECTORY) else() message(FATAL_ERROR "Signature key file defined in multiple conf files") endif() endif() endforeach() if(IS_ABSOLUTE ${CONFIG_BOOT_SIGNATURE_KEY_FILE}) set(KEY_FILE ${CONFIG_BOOT_SIGNATURE_KEY_FILE}) elseif((DEFINED CONF_DIR) AND (EXISTS ${CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE})) set(KEY_FILE ${CONF_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}) else() set(KEY_FILE ${MCUBOOT_DIR}/${CONFIG_BOOT_SIGNATURE_KEY_FILE}) endif() message("MCUBoot bootloader key file: ${KEY_FILE}") set_property( GLOBAL PROPERTY KEY_FILE ${KEY_FILE} ) set(GENERATED_PUBKEY ${ZEPHYR_BINARY_DIR}/autogen-pubkey.c) add_custom_command( OUTPUT ${GENERATED_PUBKEY} COMMAND ${PYTHON_EXECUTABLE} ${MCUBOOT_DIR}/scripts/imgtool.py getpub -k ${KEY_FILE} > ${GENERATED_PUBKEY} DEPENDS ${KEY_FILE} ) zephyr_library_sources(${GENERATED_PUBKEY}) endif() if(CONFIG_BOOT_ENCRYPTION_KEY_FILE AND NOT CONFIG_BOOT_ENCRYPTION_KEY_FILE STREQUAL "") # CONF_FILE points to the KConfig configuration files of the bootloader. unset(CONF_DIR) foreach(filepath ${CONF_FILE}) file(READ ${filepath} temp_text) string(FIND "${temp_text}" ${CONFIG_BOOT_ENCRYPTION_KEY_FILE} match) if(${match} GREATER_EQUAL 0) if(NOT DEFINED CONF_DIR) get_filename_component(CONF_DIR ${filepath} DIRECTORY) else() message(FATAL_ERROR "Encryption key file defined in multiple conf files") endif() endif() endforeach() if(IS_ABSOLUTE ${CONFIG_BOOT_ENCRYPTION_KEY_FILE}) set(KEY_FILE ${CONFIG_BOOT_ENCRYPTION_KEY_FILE}) elseif((DEFINED CONF_DIR) AND (EXISTS ${CONF_DIR}/${CONFIG_BOOT_ENCRYPTION_KEY_FILE})) set(KEY_FILE ${CONF_DIR}/${CONFIG_BOOT_ENCRYPTION_KEY_FILE}) else() set(KEY_FILE ${MCUBOOT_DIR}/${CONFIG_BOOT_ENCRYPTION_KEY_FILE}) endif() message("MCUBoot bootloader encryption key file: ${KEY_FILE}") set(GENERATED_ENCKEY ${ZEPHYR_BINARY_DIR}/autogen-enckey.c) add_custom_command( OUTPUT ${GENERATED_ENCKEY} COMMAND ${PYTHON_EXECUTABLE} ${MCUBOOT_DIR}/scripts/imgtool.py getpriv -k ${KEY_FILE} > ${GENERATED_ENCKEY} DEPENDS ${KEY_FILE} ) zephyr_library_sources(${GENERATED_ENCKEY}) endif() if(CONFIG_MCUBOOT_CLEANUP_ARM_CORE) zephyr_library_sources( ${BOOT_DIR}/zephyr/arm_cleanup.c ) endif() if(CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL OR CONFIG_MCUBOOT_CLEANUP_NONSECURE_RAM) zephyr_library_sources( ${BOOT_DIR}/zephyr/nrf_cleanup.c ) endif()
