Sample code for Tinycrypt AES encryption
I would like to use Tinycrypt library to do AES encryption. Does Nordic provide sample code?
  • D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world>west build -b nrf5340dk_nrf5340_cpuapp
    -- Application: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world
    -- Using NCS Toolchain 2.3.0 for building. (D:/ncs/toolchains/v2.3.0/cmake)
    -- Found Python3: D:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/ncs/v2.3.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr)
    -- Board: nrf5340dk_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found Dtc: D:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/ncs/v2.3.0/nrf/boards/arm/mdbt53db_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/dts.cmake
    Parsing D:/ncs/v2.3.0/zephyr/Kconfig
    Loaded configuration 'D:/ncs/v2.3.0/nrf/boards/arm/mdbt53db_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/prj.conf'
    Configuration saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: D:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    === child image mcuboot -  begin ===
    loading initial cache file D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/child_image_preload.cmake
    -- Application: D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: D:/ncs/v2.3.0/nrf/modules/mcuboot/usb.overlay
    -- Found devicetree overlay: D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/dts.cmake
    Parsing D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'D:/ncs/v2.3.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: D:/ncs/v2.3.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at D:/ncs/v2.3.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- WARNING: Using default MCUBoot key, it should not ---
              --- be used for production.                           ---
    -- Configuring done
    -- Generating done
    [5/198] Performing build step for 'mcuboot_subimage'
    [1/281] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr), build: v3.2.99-ncs2
    [271/281] Linking C executable zephyr\zephyr_pre0.elf
    [275/281] Linking C executable zephyr\zephyr_pre1.elf
    [281/281] Linking C executable zephyr\zephyr.elf
               FLASH:       40432 B        48 KB     82.26%
                 RAM:       22712 B       512 KB      4.33%
            IDT_LIST:          0 GB         2 KB      0.00%
    [7/198] Generating include/generated/version.h
    [177/198] Linking C executable zephyr\zephyr_pre0.elf
    [181/198] Linking C executable zephyr\zephyr_pre1.elf
    [187/198] Linking C executable zephyr\zephyr.elf
               FLASH:       36608 B     491008 B      7.46%
                 RAM:        9808 B       512 KB      1.87%
    [193/198] Generating ../../zephyr/app_update.bin
    sign the payload
    [194/198] Generating ../../zephyr/app_signed.hex
    sign the payload
    [196/198] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [198/198] Generating zephyr/merged.hex
    D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world>west flash --recover
    -- west flash: rebuilding
    [0/4] Performing build step for 'mcuboot_subimage'
    ninja: no work to do.
    -- west flash: using runner nrfjprog
    Using board 801036305
    -- runners.nrfjprog: Recovering and erasing flash memory for both the network and application cores.
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    Writing image to disable ap protect.
    -- runners.nrfjprog: Flashing file: D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world\build\zephyr\merged.hex
    [ #################### ]   2.874s | Erase file - Done erasing
    [ #################### ]   0.601s | Program file - Done programming
    [ #################### ]   0.562s | Verify file - Done verifying
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 801036305 flashed successfully.
    D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world>rm -rf build
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    [1/197] Generating include/generated/version.h
    [6/197] Performing build step for 'mcuboot_subimage'
    [176/197] Linking C executable zephyr\zephyr_pre0.elf
    [180/197] Linking C executable zephyr\zephyr_pre1.elf
    [186/197] Linking C executable zephyr\zephyr.elf
               FLASH:       32332 B     491008 B      6.58%
                 RAM:        7704 B       512 KB      1.47%
    [189/197] Generating ../../zephyr/app_update.bin
    sign the payload
    [190/197] Generating ../../zephyr/app_signed.hex
    sign the payload
    [192/197] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [197/197] Generating zephyr/merged.hex
    [ #################### ]   2.917s | Erase file - Done erasing
    [ #################### ]   0.580s | Program file - Done programming
    [ #################### ]   0.536s | Verify file - Done verifying
    Applying pin reset.
    You usually configure mcuboot by creating "child_image/mcuboot.conf" in your application folder. My colleague describes it well here: How to configure the bootloader.
    Alternatively you can assign custom project configurations for the bootloader with
    -Dmcuboot_CONF_FILE=<filename>.conf
    as described here: Using custom project configurations
    Could you try doing this? Remember to undo your previous CMake change, in that case.
    Raoul
  • Thanks for your reply! I have added the following configuration in D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world\child_image\mcuboot.conf file.
    CONFIG_BOOT_ECDSA_TINYCRYPT=y
    But west build shows the following warning messages.
    warning: The choice symbol BOOT_ECDSA_TINYCRYPT (defined at
    D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/Kconfig:98) was selected (set =y), but no symbol ended
    up as the choice selection. See
    docs.zephyrproject.org/.../kconfig.html and/or look up
    BOOT_ECDSA_TINYCRYPT in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/child_image/mcuboot.conf'
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BOOT_ECDSA_TINYCRYPT and/or look up
    helpful too.
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    [5/197] Performing build step for 'mcuboot_subimage'
    [6/197] Generating include/generated/version.h
    [192/197] Generating ../../zephyr/app_update.bin
    sign the payload
    [193/197] Generating ../../zephyr/app_signed.hex
    sign the payload
    [195/197] Generating ../../zephyr/app_test_update.hex
    sign the payload
