Sample code for Tinycrypt AES encryption
I would like to use Tinycrypt library to do AES encryption. Does Nordic provide sample code?
  • Hi Snowuyl,
    I haven't had time to look more closely at this, sorry. We are very busy in the summer weeks since we have fewer staff than usual.
    If you still have this issue, I'll try to take a look at it soon.
    Raoul
  • I encounter another warning message as follows.
    WARNING: Using default MCUBoot key, it should not be used for production.
    Procedures to reproduce this issue are as follows.
    1. Unzipping hello-world.zip to D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\ folder.
    2. cd D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\
    3. west build -b nrf5340dk_nrf5340_cpuapp
  • D:\ncs\v2.3.0\bootloader\mcuboot\samples\zephyr\hello-world>west build -b nrf5340dk_nrf5340_cpuapp
    -- Application: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world
    -- Using NCS Toolchain 2.3.0 for building. (D:/ncs/toolchains/v2.3.0/cmake)
    -- Found Python3: D:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/ncs/v2.3.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr)
    -- Board: nrf5340dk_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found Dtc: D:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/ncs/v2.3.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/dts.cmake
    Parsing D:/ncs/v2.3.0/zephyr/Kconfig
    Loaded configuration 'D:/ncs/v2.3.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/prj.conf'
    Configuration saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: D:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    === child image mcuboot -  begin ===
    loading initial cache file D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/child_image_preload.cmake
    -- Application: D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: D:/ncs/v2.3.0/nrf/modules/mcuboot/usb.overlay
    -- Found devicetree overlay: D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/dts.cmake
    warning: The choice symbol BOOT_ECDSA_TINYCRYPT (defined at
    D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/Kconfig:98) was selected (set =y), but no symbol ended
    up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BOOT_ECDSA_TINYCRYPT and/or look up
    BOOT_ECDSA_TINYCRYPT in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    Parsing D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'D:/ncs/v2.3.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/child_image/mcuboot.conf'
    Merged configuration 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: D:/ncs/v2.3.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/ncs/v2.3.0/bootloader/mcuboot/samples/zephyr/hello-world/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at D:/ncs/v2.3.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- WARNING: Using default MCUBoot key, it should not ---
              --- be used for production.                           ---
    -- Configuring done
    -- Generating done
    [1/183] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr), build: v3.2.99-ncs2
    [6/183] Performing build step for 'mcuboot_subimage'
    [1/281] Generating include/generated/version.h
    [271/281] Linking C executable zephyr\zephyr_pre0.elf
    [275/281] Linking C executable zephyr\zephyr_pre1.elf
    [281/281] Linking C executable zephyr\zephyr.elf
               FLASH:       40432 B        48 KB     82.26%
                 RAM:       22712 B       512 KB      4.33%
            IDT_LIST:          0 GB         2 KB      0.00%
    [162/183] Linking C executable zephyr\zephyr_pre0.elf
    [166/183] Linking C executable zephyr\zephyr_pre1.elf
    [172/183] Linking C executable zephyr\zephyr.elf
               FLASH:       23524 B     491008 B      4.79%
                 RAM:        6240 B       512 KB      1.19%
    [178/183] Generating ../../zephyr/app_update.bin
    sign the payload
    [179/183] Generating ../../zephyr/app_signed.hex
    sign the payload
    [181/183] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [183/183] Generating zephyr/merged.hex
    If I'm not mistaken, you've also created another ticket for this issue. I think you'll get an answer there. But the answer is what it says in the warning (and in the documentation) - the default MCUboot key should be replaced when you go into production, otherwise every NCS user in the world will know your key.
    Raoul
