Enabling pins P0.0, P0.1, P0.2, P0.3, and P0.19 as GPIO [NRF5340]
Hey y'all,
I'm having trouble enabling these pins as GPIO for our custom nrf5340 board, and from reading around, it's not clear to me as a beginner how to properly configure these pins.
Pins  P0.0 and P0.1 are usually used to operate an oscillator, but our board doesn't need it and instead these pins should operate as GPIO pins. My understanding is that to enable these pins, I need to operate the chip with the internal oscillator which I can do with the following lines in my proj.conf.
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
Pins P0.2 and P0.3 are typically used for an NFC antenna, but again, our board doesn't need this functionality and these pins should be configured to be used as GPIO. My understanding is that all I need to do is add the following line to my proj.conf.
I've read that these pins can only be used in a "secure domain", but I've tried creating different projects types (nrf5340dk_nrf5340_cpuapp_ns and nrf5340dk_nrf5340_cpuapp) and running them to no success. There is probably a misunderstanding here on my part. I get the same results as the following link (https://devzone.nordicsemi.com/f/nordic-q-a/94197/config_nfct_pins_as_gpios-y-doesn-t-work). Please direct me to resources to deepen my understanding of a secure domain so I can fix the issue.
CONFIG_NFCT_PINS_AS_GPIOS=y
Pin P.019 is the most confusing to me. On the dev kit, this pin along with pins P0.20, P0.21, P0.22 are used to make a virtual com port. Other than that though, from the manual, it seems like a normal GPIO pin with no other functionalities. It is unclear to me why this pin is not working. I've done my best to verify that the hardware and connections for this pin on the custom board are working. I'm also unable to toggle this pin on the dev board, despite making the needed physical changes to do so. Is there a setting to enable this particular pin?
If it helps, I'm using VSCode on Ubuntu.
Thanks for the help. I've included the full proj.conf and the overlay file below.
CONFIG_GPIO=y
# I2C
CONFIG_I2C=y
CONFIG_NRFX_TWIM1=y
CONFIG_PRINTK=y
# Rebooot
CONFIG_REBOOT=n
CONFIG_RESET_ON_FATAL_ERROR=n
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
	userpins {
		compatible = "gpio-keys";
		ex1: ex_1 {
			gpios = <&gpio0 20 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 1";
		ex2: ex_2 {
			gpios = <&gpio0 21 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 2";
		ex3: ex_3 {
			gpios = <&gpio0 22 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 3";
		ex4: ex_4 {
			gpios = <&gpio0 23 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 4";
		ex5: ex_5 {
			gpios = <&gpio0 24 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 5";
		ex6: ex_6 {
			gpios = <&gpio0 25 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 6";
		ex7: ex_7 {
			gpios = <&gpio0 26 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 7";
		ex8: ex_8 {
			gpios = <&gpio0 27 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 8";
		ex9: ex_9 {
			gpios = <&gpio0 28 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 9";
		ex10: ex_10 {
			gpios = <&gpio0 29 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 10";
		ex11: ex_11 {
			gpios = <&gpio0 30 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 11";
		ex12: ex_12 {
			gpios = <&gpio0 31 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "External pin 12";
		enl: en_l {
			gpios = <&gpio1 4 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Enable LED Mux";
		mux0: mux_0 {
			gpios = <&gpio1 5 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "LED Mux select 0";
		mux1: mux_1 {
			gpios = <&gpio1 6 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "LED Mux select 1";
		mux2: mux_2 {
			gpios = <&gpio1 7 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "LED Mux select 2";
		smux0: smux_0 {
			gpios = <&gpio1 8 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Stepper Mux select 0";
		smux1: smux_1 {
			gpios = <&gpio1 9 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Stepper Mux select 1";
		smux2: smux_2 {
			gpios = <&gpio1 10 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Stepper Mux select 2";
		smux3: smux_3 {
			gpios = <&gpio1 11 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Stepper Mux select 3";
		ens: en_s {
			gpios = <&gpio1 12 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Enable stepper motors";
		clks: clk_s {
			gpios = <&gpio1 13 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Clock for stepper motors";
		steps: step_s {
			gpios = <&gpio1 14 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Step pin for stepper motors";
		dirs: dir_s {
			gpios = <&gpio1 15 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Dir pin for stepper motors";
		mmux0: mmux_0 {
			gpios = <&gpio0 13 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Misc mux select 0";
		mmux1: mmux_1 {
			gpios = <&gpio0 14 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Misc mux select 1";
		mmux2: mmux_2 {
			gpios = <&gpio0 15 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Misc mux select 2";
		clkm: clk_m {
			gpios = <&gpio0 5 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Clock for miscellaneous";
		miscm: misc_m {
			gpios = <&gpio0 4 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Misc input";
		lmux0: lmux_0 {
			gpios = <&gpio0 16 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Limit mux select 0";
		lmux1: lmux_1 {
			gpios = <&gpio0 17 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Limit mux select 1";
		lmux2: lmux_2 {
			gpios = <&gpio0 18 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Limit mux select 2";
		lmux3: lmux_3 {
			gpios = <&gpio0 19 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Limit mux select 3";
		lmt: lmt {
			gpios = <&gpio0 6 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Limit pin";
		serv0: serv_0 {
			gpios = <&gpio0 0 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Servo 0 pin";
		serv1: serv_1 {
			gpios = <&gpio0 1 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Servo 1 pin";
		serv2: serv_2 {
			gpios = <&gpio0 2 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Servo 2 pin";
		serv3: serv_3 {
			gpios = <&gpio0 3 (GPIO_ACTIVE_HIGH | GPIO_VOLTAGE_3P3)>;
			label = "Servo 3 pin";
&i2c1 {
	status = "okay";
	label = "I2C_1";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
	clock-frequency = <100000>;
	bh1749: bh1749@38 {
		compatible = "rohm,bh1749";
		label = "BH1749";
		reg = <0x38>;
		int-gpios = <&gpio0 27 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
	tca9548: tca9548a@70 {
		compatible = "ti,tca9548a";
		label = "TCA9548";
		reg = <0x70>;
&pinctrl {
	i2c1_default: i2c1_default{
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 35)>,
				<NRF_PSEL(TWIM_SCL, 0, 34)>;
	i2c1_sleep: i2c1_sleep{
		group1 {
			low-power-enable;
  • Hi
    The build targets nrf5340dk_nrf5340_cpuapp_ns and nrf5340dk_nrf5340_cpuapp are created specifically for our developement kits.
    What you are experiencing is likely because these are configured to use the pins you need for something else.
    While we could try to figure out what that is, I instead suggest another approach:
    Since you use a custom board, you should sooner or later create your own custom build target to fit that custom board.
    If you do so, I bet that this issue will disappear.
    Our VS Code extension has a feature to create a new board. Also see Board Support.
    Sigurd Hellesvik
  • Thanks for the reply! I'll look into it and get back to y'all. This is my first non-atmega project, so a bit of a learning curve. Having fun though
    Good to hear!
    In that case, I highly advise that you have a look at our guides at https://academy.nordicsemi.com, especially the "getting started with nRF Connect SDK" there.
    I think it is very good.
  • Thanks for the advice and links. I did my best to read them and follow them closely. I had already completed the Nordic Dev Academy prior to posting. It was a great help.
    Unfortunately I've been unable to create my own board files. I went through the dts files of the semi-working project (the one where some of the pins don't work) to create the files. I've included the relevant files below. I'm getting the following error, which I assume is happening because I didn't make my board files properly. Please let me know where my understanding might be breaking down.
    [150/162] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [151/162] Linking C static library zephyr/kernel/libkernel.a
    [152/162] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    : && ccache /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/james/org/work/nrf/ncs_projects/blinky/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp"  -L/home/james/org/work/nrf/ncs_projects/blinky/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /home/james/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.17.a && cd /home/james/org/work/nrf/ncs_projects/blinky/build/zephyr && /home/james/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake -E echo
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `main':
    /home/james/org/work/nrf/ncs_projects/blinky/src/main.c:82: undefined reference to `__device_dts_ord_92'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj):(.rodata.lmt_0+0x0): undefined reference to `__device_dts_ord_92'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj):(.rodata.lmux_3+0x0): undefined reference to `__device_dts_ord_92'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj):(.rodata.lmux_2+0x0): undefined reference to `__device_dts_ord_92'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj):(.rodata.lmux_1+0x0): undefined reference to `__device_dts_ord_92'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj):(.rodata.lmux_0+0x0): more undefined references to `__device_dts_ord_92' follow
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/i2c/libdrivers__i2c.a(i2c_nrfx_twim.c.obj): in function `pinctrl_apply_state':
    /home/james/ncs/v2.4.0/zephyr/include/zephyr/drivers/pinctrl.h:348: undefined reference to `pinctrl_lookup_state'
    /home/james/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/i2c/libdrivers__i2c.a(i2c_nrfx_twim.c.obj): in function `pinctrl_apply_state_direct':
    /home/james/ncs/v2.4.0/zephyr/include/zephyr/drivers/pinctrl.h:329: undefined reference to `pinctrl_configure_pins'
    collect2: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: /home/james/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake --build /home/james/org/work/nrf/ncs_projects/blinky/build
    main.c
     * Copyright (c) 2016 Intel Corporation
    #include <zephyr/kernel.h>
    #include <zephyr/zephyr.h>
    #include <zephyr/drivers/i2c.h>
    #include <zephyr/drivers/pinctrl.h>
    #include <zephyr/device.h>
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   1000
     * A build error on this line means your board is unsupported.
     * See the sample documentation for information on how to fix this.
    #define LMUX0_NODE DT_NODELABEL(lmux0)
    #define LMUX1_NODE DT_NODELABEL(lmux1)
    #define LMUX2_NODE DT_NODELABEL(lmux2)
    #define LMUX3_NODE DT_NODELABEL(lmux3)
    #define LMT_NODE DT_NODELABEL(lmt)
    static const struct gpio_dt_spec lmux_0 = GPIO_DT_SPEC_GET_OR(LMUX0_NODE, gpios, {0});
    static const struct gpio_dt_spec lmux_1 = GPIO_DT_SPEC_GET_OR(LMUX1_NODE, gpios, {0});
    static const struct gpio_dt_spec lmux_2 = GPIO_DT_SPEC_GET_OR(LMUX2_NODE, gpios, {0});
    static const struct gpio_dt_spec lmux_3 = GPIO_DT_SPEC_GET_OR(LMUX3_NODE, gpios, {0});
    static const struct gpio_dt_spec lmt_0 = GPIO_DT_SPEC_GET_OR(LMT_NODE, gpios, {0});
    	int ret;
    	if (!device_is_ready(lmux_0.port)) {
    		return -1;
    	if (!device_is_ready(lmux_1.port)) {
    		return -1;
    	if (!device_is_ready(lmux_2.port)) {
    		return -1;
    	if (!device_is_ready(lmux_3.port)) {
    		return -1;
    	if (!device_is_ready(lmt_0.port)) {
    		return -1;
    	ret = gpio_pin_configure_dt(&lmux_0, GPIO_OUTPUT_LOW);
    	if (ret < 0) {
    		return ret;
    	ret = gpio_pin_configure_dt(&lmux_1, GPIO_OUTPUT_LOW);
    	if (ret < 0) {
    		return ret;
    	ret = gpio_pin_configure_dt(&lmux_2, GPIO_OUTPUT_LOW);
    	if (ret < 0) {
    		return ret;
    	ret = gpio_pin_configure_dt(&lmux_3, GPIO_OUTPUT_LOW);
    	if (ret < 0) {
    		return ret;
    	ret = gpio_pin_configure_dt(&lmt_0, GPIO_INPUT);
    	if (ret < 0) {
    		return ret;
    	while (1) {
    		ret = gpio_pin_toggle_dt(&lmux_3);
    		if (ret < 0) {
    			return 0;
    		k_msleep(SLEEP_TIME_MS);
    	return 0;
    nrf5340_tricca_board.dts
    /dts-v1/;
    #include <nordic/nrf5340_cpuapp_qkaa.dtsi>
    #include <nordic/nrf5340_tricca_board.dtsi>
    	model = "nrf5340 Tricca Board";
    	compatible = "tricca-technologies-inc-,nrf5340-tricca-board";
    	chosen {
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,bt-hci-rpmsg-ipc = &ipc0;
    		nordic,802154-spinel-ipc = &ipc0;
    		zephyr,ieee802154 = &ieee802154;
    		/* shared memory reserved for the inter-processor communication */
    		zephyr,ipc_shm = &sram0_shared;
    	reserved-memory {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		ranges;
    		sram0_image: image@20000000 {
    			/* Zephyr image(s) memory */
    		sram0_s: image_s@20000000 {
    			/* Secure image memory */
    		sram0_ns: image_ns@20040000 {
    			/* Non-Secure image memory */
    		sram0_shared: memory@20070000 {
    			/* SRAM allocated to shared memory */
    			reg = <0x20070000 0x10000>;
    &gpio0 {
    	status = "okay";
    &gpio1 {
    	status = "okay";
    &i2c1 {
    	status = "okay";
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x00000000 0x00010000>;
    		slot0_partition: partition@10000 {
    			label = "image-0";
    		slot0_ns_partition: partition@50000 {
    			label = "image-0-nonsecure";
    		slot1_partition: partition@80000 {
    			label = "image-1";
    		slot1_ns_partition: partition@c0000 {
    			label = "image-1-nonsecure";
    		/* 0xf0000 to 0xf7fff reserved for TF-M partitions */
    		storage_partition: partition@f8000 {
    			label = "storage";
    			reg = <0x000f8000 0x00008000>;
    &ieee802154 {
    	status = "okay";
    &slot0_partition {
    	reg = <0x00010000 0x40000>;
    &slot0_ns_partition {
    	reg = <0x00050000 0x30000>;
    &slot1_partition {
    	reg = <0x00080000 0x40000>;
    &slot1_ns_partition {
    	reg = <0x000c0000 0x30000>;
    &sram0_image {
    	reg = <0x20000000 DT_SIZE_K(448)>;
    &sram0_s {
    	reg = <0x20000000 0x40000>;
    &sram0_ns {
    	reg = <0x20040000 0x30000>;
    nrf5340_tricca_board.overlay
    	userpins {
    		ex1: ex_1 {
    			gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
    		ex2: ex_2 {
    			gpios = <&gpio0 21 GPIO_ACTIVE_HIGH>;
    		ex3: ex_3 {
    			gpios = <&gpio0 22 GPIO_ACTIVE_HIGH>;
    		ex4: ex_4 {
    			gpios = <&gpio0 23 GPIO_ACTIVE_HIGH>;
    		ex5: ex_5 {
    			gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>;
    		ex6: ex_6 {
    			gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
    		ex7: ex_7 {
    			gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>;
    		ex8: ex_8 {
    			gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>;
    		ex9: ex_9 {
    			gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
    		ex10: ex_10 {
    			gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
    		ex11: ex_11 {
    			gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
    		ex12: ex_12 {
    			gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
    		enl: en_l {
    			gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;
    		mux0: mux_0 {
    			gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
    		mux1: mux_1 {
    			gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>;
    		mux2: mux_2 {
    			gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
    		smux0: smux_0 {
    			gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>;
    		smux1: smux_1 {
    			gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
    		smux2: smux_2 {
    			gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
    		smux3: smux_3 {
    			gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
    		ens: en_s {
    			gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
    		clks: clk_s {
    			gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
    		steps: step_s {
    			gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
    		dirs: dir_s {
    			gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
    		mmux0: mmux_0 {
    			gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
    		mmux1: mmux_1 {
    			gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>;
    		mmux2: mmux_2 {
    			gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
    		clkm: clk_m {
    			gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
    		miscm: misc_m {
    			gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
    		lmux0: lmux_0 {
    			gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
    		lmux1: lmux_1 {
    			gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
    		lmux2: lmux_2 {
    			gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
    		lmux3: lmux_3 {
    			gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
    		lmt: lmt {
    			gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
    		serv0: serv_0 {
    			gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>;
    		serv1: serv_1 {
    			gpios = <&gpio0 1 GPIO_ACTIVE_HIGH>;
    		serv2: serv_2 {
    			gpios = <&gpio0 2 GPIO_ACTIVE_HIGH>;
    		serv3: serv_3 {
    			gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
    &i2c1 {
    	status = "okay";
    	label = "I2C_1";
    	bh1749: bh1749@38 {
    		label = "BH1749";
    		reg = <0x38>;
    		label = "TCA9548";
    		reg = <0x70>;
    &pinctrl {
    		group1 {
    		group1 {
    			low-power-enable;
    &pinctrl {
    	i2c1_default: i2c1_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
    				<NRF_PSEL(TWIM_SCL, 1, 3)>;
    	i2c1_sleep: i2c1_sleep {
    		group1 {
    			low-power-enable;
    	uart0_default: uart0_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 20)>,
    				<NRF_PSEL(UART_RTS, 0, 19)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, 22)>,
    				<NRF_PSEL(UART_CTS, 0, 21)>;
    			bias-pull-up;
    	uart0_sleep: uart0_sleep {
    		group1 {
    				<NRF_PSEL(UART_RTS, 0, 19)>,
    			low-power-enable;
    	uart1_default: uart1_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 1)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 1, 0)>;
    			bias-pull-up;
    	uart1_sleep: uart1_sleep {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 1)>,
    			low-power-enable;
    Maybe try to get inspiration from our DK boardfiles also? https://github.com/nrfconnect/sdk-zephyr/tree/main/boards/arm
    Can you zip and upload your whole "nrf5340_tricca_board/" directory, so I can have a look at all of it?
