I would like to use Zephyr SPI APIs (docs.zephyrproject.org/.../spi.html) to control external ADCs. Since I need two chip select pins for selection ADC1, ADC2, ADC3, and ADC4. Does Zephyr SPI APIs support two chip select pins?
Hi
There is no problem with multiple external ADC, you just need to set them up in a overlay.
This is described https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/build/dts/api/bindings/spi/nordic,nrf-spi.html
An array of chip select GPIOs to use. Each element
in the array specifies a GPIO. The index in the array
corresponds to the child node that the CS gpio controls.
Example:
spi@... {
cs-gpios = <&gpio0 23 GPIO_ACTIVE_LOW>,
<&gpio1 10 GPIO_ACTIVE_LOW>,
spi-device@0 {
reg = <0>;
spi-device@1 {
reg = <1>;
The child node "spi-device@0" specifies a SPI device with
chip select controller gpio0, pin 23, and devicetree
GPIO flags GPIO_ACTIVE_LOW. Similarly, "spi-device@1" has CS GPIO
controller gpio1, pin 10, and flags GPIO_ACTIVE_LOW. Additional
devices can be configured in the same way.
If unsure about the flags cell, GPIO_ACTIVE_LOW is generally a safe
choice for a typical "CSn" pin. GPIO_ACTIVE_HIGH may be used if
intervening hardware inverts the signal to the peripheral device or
the line itself is active high.
If this property is not defined, no chip select GPIOs are set.
SPI controllers with dedicated CS pins do not need to define
the cs-gpios property.
You can see below how it was done on the thingy91 with two different accelerometers on the same SPI bus
&spi3 {
status = "okay";
cs-gpios = <&gpio0 8 GPIO_ACTIVE_LOW>, <&gpio0 7 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi3_default>;
pinctrl-1 = <&spi3_sleep>;
adxl362: adxl362@0 {
compatible = "adi,adxl362";
spi-max-frequency = <8000000>;
reg = <0>;
int1-gpios = <&gpio0 9 0>;
adxl372: adxl372@1 {
compatible = "adi,adxl372";
reg = <1>;
int1-gpios = <&gpio0 6 0>;
Regards
Runar
Thanks for your reply!
No worries, happy to help. I will just set this case to closed if that is okey with you?
Regards
Runar
Thanks for your reply! Now I encounter another problem. From sample you provided, there are two SPI chip select pins (gpio0,8 and gpio0,7). How can I control SPI chip select for selecting adxl362 or adxl372?
If you are using the sensor api it you dont have to worry about it. The API does it for you https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/hardware/peripherals/sensor.html#sensor-api
Regards
Runar
