DFU BLE bootloader doesn't seem to work
I am trying to implement the smp_svr example as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html.
I have successfully built and flashed the MCU bootloader. (to a nRF52840dk)
I have successfully built, the mcumgr.
I have successfully built, signed, and flashed the smp_svr.
At this point I looked at my nRF_CONNECT_FOR_MOBILE scanner but I do not see the device.
I modified the smp_svr bluetooth.c as follows:
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID128_ALL,
0x84, 0xaa, 0x60, 0x74, 0x52, 0x8a, 0x8b, 0x86,
0xd3, 0x4c, 0xb7, 0x1d, 0x1d, 0xdc, 0x53, 0x8d),
BT_DATA(BT_DATA_NAME_COMPLETE, "Zephyr_DFU", 8),
This I did because I was unsure what the default advertising name was.
I then rebuilt, resigned, and re-flashed.
I still did not see the the device on my scanner.
When I attempt to flash with mcumgr It doesn't connect.
sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' echo hello
hello
Error: Failed to connect to peer after 10s
and
sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='ZephyrDFU' echo hello
This suggests to me the smp_svr program isn't working correctly.
I'm not sure where to go with this, any suggestions?
Jerry
  • Hi Jerry,
    I attached here how i built the project with VS Code:
    First you create new application based on smp_svr:
    After that you create the configuration, and select the overlay_bt.conf as the Kconfig fragments, make sure you click OK after you select the file:
    After the build, you should be able to find overlay_bt.conf in the project configuration:
    I attached here the hex file that worked for me:
    4544.merged.hex
  • Hi Hung,
    I followed your excellent instructions and voila, I can see the advertisement on iPad!
    Thank you so much!
    Jerry
  • I am trying to upload my blinky sample to the smp_svr; I'm getting errors because the zephyr.bin file is unsigned,  Is there a way to sign it under vscode?
    Jerry
  • Hi Jerry,
    You should use app_update.bin. It's the signed binary that you can use to do FOTA.
    You can read more about different hex/bin files here:
    developer.nordicsemi.com/.../multi_image.html
  • Hi Hung,
    I have (I think) gotten the smp_svr sample working correctly. I have established a serial connection under vscode and it will interact with me.  However, I have modified both the blinky and hello_world sample applications to upload to the smp_svr via ble.  I get the following message: "[00:02:31.535,949] <inf> smp_bt_sample: Disconnected (reason 0x13)" from the smp_svr.  I suspect that I have not correctly configured the apps I am trying to upload.
    This is my prj.conf for blinky:
    CONFIG_GPIO=y
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
    This is the serial log file at reset
    uart:~$ *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    [00:00:00.006,927] <inf> bt_hci_core: Identity: C7:28:33:33:F4:D5 (random)
    [00:00:00.006,958] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
    [00:00:00.006,988] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x1077
    [00:00:00.007,904] <inf> smp_bt_sample: Advertising successfully started
    In a terminal, I entered my upload command:
    (.venv) jerry@Ubuntu:~/zephyrproject$ sudo ~/go/bin/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload ~/MyApps/blinky/build_dk/zephyr/app_update.bin
     23.03 KiB / 23.03 KiB [=====================================================================================================================] 100.00% 9.22 KiB/s 2s
    Done
    The serial log responded with:
    [00:00:00.007,965] <inf> smp_sample: build time: Aug 15 2023 05:04:51
    [00:01:52.927,215] <inf> smp_bt_sample: Connected
    [00:01:53.752,197] <inf> mcumgr_img_grp: Erased 0x6000 bytes of image slot
    [00:01:53.849,670] <inf> mcumgr_img_grp: Erased 0x1000 bytes of image slot trailer
    [00:01:55.670,562] <inf> smp_bt_sample: Disconnected (reason 0x13)
    [00:01:55.672,058] <inf> smp_bt_sample: Advertising successfully started
    The blinky application, apparently, was not started; (led0 not blinking).
    Do you have any ideas?
    Jerry
