Possible SIGTRAP in Softdevice S140
We are currently in the progress of porting a project from the nrf52840dk reference board to a custom board and are having some issues during initilization.
Setup is using Softdevice S140 7.2.0 and nRF52 SDK 17.1.0 using secure_bootloader
On the nrf52840dk we can flash and get RTT logs without issue but when flashing to the custom board we get a SIGTRAP before the bootloader main() that seems to be located in the softdevice.
Any advice or hints where to continue digging?
  • This is not in the softdevice. After further digging, and handeling signals a bit better in gdb, this is happening during RTT logging backend init/first log within the bootloader.
  • The reason seems to be that nrf_memobj_alloc() in nrf_log_frontend_dequeue() returns NULL
    This happens because
    if (p_pool->p_cb->p_stack_pointer > p_pool->p_stack_base)
    in
    nrf_balloc_alloc() fails
    p_stack_pointer = 0x20002953
    p_stack_base = 0x2000926c
    What is the differences in the firmware you run on the DK (successfully) and the firmware you run on your custom board?
    bsp_board_init() has been changed to not use any led's or buttons as there are other devices connected, ie a empty function compared with components/boards/boards.c.
    NRF_DFU_HW_VERSION has been changed.
    New signing key for application image as been included.
    Aligned ld linker-scripts to keep the rtt sections at the same place between both bootloader and application. We are using SEGGER_RTT_SECTION set to ".rtt" and then defining a
    .rtt (NOLOAD) :
    } > RAM
    in the linker-script.
    Of course using a external segger jlink on the custom board instead of the embedded jlink on the DK board. JMemExe, JLinkGDBServer and JLinkRTTViewerExe works as expected from what i can see.
    During troubleshooting i did changed the linker-script to allocate a bit more ram for the SD.
    RAM (rwx) :  ORIGIN = 0x20008000, LENGTH = 0x38000
    Do you have a mail i could share the linker-scripts on?
    I see. None of that should explain why you see a difference in the buffer handling in the logger, though. How did you narrow down to the values of the pointers in nrf_memobj_alloc()? Could it be that you are missing something when debugging? First of all, I would suggest disablign optimization when debugging you have not done so. And as you wrote earlier that you had some problems with GDB (I know I do), perhaps it would be better to use a GUI debugger, like Segger Ozone? (note that you. need to change the Ozon configuration to start from address 0 as described in this post, or just attach to the running target if the issue does not occur immediately).
    You can upload here (Insert -> Image/video/file) or make a new private case where you refer to this thread, and upload there if you do not want tos hare it publically.
