what are nrf51 SDK 10.0 known issues
On SDK 10.0 only
  • Do not judge the quality of SDK based on number of entries here. This thread should be considered part of Nordic effort to main the quality of the release.
GENERAL RULES TO KEEP THIS PAGE READABLE
This is ONLY for already confirmed bugs which are discussed in another threads. Please do not discuss here in the comments to try to figure out that the issue you are facing is a bug or not. Please create a seperate question
Do not edit the answer. If I forgot/missed to add an already discussed and confirmed bug, then please add the link to the issue in comment, I will then update the answer with your link.
If it is a minor edit, then I will select "minor edit" option in my edits. But if i am adding new issue, then I will not select "minor edit" and hence will send notifications to one following.
Parents Reply
  • @Aryan definitely; also on the documentation side of things; spelling out that SDK10 added this parameter and that it's necessary to use GPIOTE would have been helpful to have in the docs: GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS. Updating from 9 to 10 caused code to not work because of that; and it took a non-trivial amount of time to track down with all the SDK changes between 9 and 10 (for instance; in 9, spi_master_init happened each time; in 10 it only happens once).
