Do not know what value of RAM to configure after adding new characteristic to custom BLE service
Hi Nordic team,
I'm using S132 with nRF52832 on my custom board. The SDK is nRF5_SDK_17.1.0_ddde560
I have made a custom BLE service that worked for several months. Now I want to add a new characteristic to my custom service. I know what to do in firmware as the new characteristic is 99% similar to the existing custom characteristic inside the custom service.
Firstly, my custom board crashed as expected because I didn't reconfigure the RAM space and
NRF_SDH_BLE_GATT_MAX_MTU_SIZE in sdk_config. Therefore, I tested this firmware on DK to get the debug message (I currently don't have the hardware to debug the custom board so all debug tasks are on the DK). Initially, here are the RAM configurations on DK.
The original NRF_SDH_BLE_GATT_MAX_MTU_SIZE value is 1408. Based on the Segger IDE suggestion, I changed the RAM_START to 0x20002D30. I keep the NRF_SDH_BLE_GATT_MAX_MTU_SIZE  unchanged. The firmware works on the DK. I can see the new characteristic on my custom service. So that's good!
However, weird things started when I uploaded the same firmware on the custom board. The original RAM configurations of custom board are
I know the original RAM configuration between DK and custom board are not the same but since they worked fine in the past, I didn't bother to match them together. But today, after I changed the RAM configuration on custom board to be the same as DK's configuration , the board crashes. Below is the custom board RAM configuration after the change
I thought it's probably the RAM change causing the crash. So instead of matching the RAM configuration of 2 boards, I increase the original RAM location up by 8 (0x20002D30 - 0x20002D28), similar to what I did on the DK. However, the board still crashes.
I tried changing the
NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE to 1460. It still crashes.
I removed the BLE code in my firmware, it doesn't crash.
I added the BLE code back, but this time removed my new characteristic. It doesn't crash.
So that means my custom board is lacked of RAM to add the new characteristic and the amount of extra RAM required is not the same with the DK. Therefore, can you please give me a suggestion of what kind of RAM value I should change it to on the custom board? I program the DK with Segger IDE but program the custom board with GCC
Thank you for your help and suggestion.
Xander
  • Hi Einar,
    The simplest way to do this is to increase the app start address significantly, and then adjust the RAM start address to what is calculated by the SoftDevice. See this post for details.
    I just changed FLASH_START from 0x26000 to 0x56000 but the program just doesn't run at all. No crash is detected. I can compile and flash the code to the DK but it just doesn't run. Even a breakpoint doesn't help to see if the program can run and pause at the desire breakpoint.
    If it is the exact same firmware, then you should not need to change the memory configuration. Is it the exact same firmware, or are there same changes? If so, what are those changes?
    I can verify they use the exact 100% same firmware. I also copied the FLASH and RAM from the DK to the custom board.
    Weird behavior detected: I tried removing the newly added characteristic to see if I can make the firmware not crash. However, it's still crashed. Then I changed the NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE from 1508 back to 1408 then the app won't crash anymore on my custom board. However, on the DK, the app can run fine with NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE = 1508. I changed this value from 1408 to 1508 because the app (with added characteristic) will crash on DK if I don't do so. This is extremely confusing as they always share same firmware, same RAM/Flash configurations, same sdk_config
    Weirder behavior detected: This is something I have observed several times in the last week but I thought it was my mistake until today I clearly witnessed it. My firmware can be configured to enable/disable debug LEDs on the custom board. I just removed completely everything related to the newly added characteristic, this time the firmware still crashed and I'm so frustrated. Then I disable the LEDs, the firmware won't crash anymore and work fine. It makes me think maybe my LEDs code has issued. However, I press Ctrl + Z in VSCode ( just 1 press to enable the LEDs back in my personal config file), then this time firmware still works with LEDs. Therefore, I can confidently conclude that somehow, the same firmware can crash or cannot crash. This doesn't sound too strange for me. However, I stay at this firmware, trying to upload the code 10 times, and none of them crash, and this is super weird to me now. In conclusion, it looks like to make version A of a firmware work, I have to flash a version B to the board, then upload version A of firmware again and it works. This is insanely wrong to me.
    Xander
  • Einar mean to change RAM_START and not FLASH_START.
    The latter won't work unless you modifiy the bootloader - softdevice is only able to start from the address specified in the sds or a bootloader via MBR or UICR.
    That LED disabling helps sounds very sus to me -  a problem with the layout like not enough decoupling capacitors seems likely.
  • Hi Turbo,
    But is it possible if an external signal affect an output pin to crash the board? I don’t think the capacitors matter?
    Xander
  • If you don't add characteristics or change the attribute table size compared ot the firmware you run on the DK, there is no need to change the RAM start address. So I suggest you don't make any changes there for now, to keep the changes to a minimal while trying to understand what is going wrong.
    Then, you essentially have firmware that works on the DK but not on your custom board, even though the same firmware should have worked on both devices. That leads to the question about your HW and how it differs from the DK, and which HW features you use. Particularily this problematic LED is odd. Can you share your schematics and layout, and explain which LED that cause problems (if you have multiple)?
  • Hi Einar,
    I have tried removing any changes on RAM start address. However, the firmware after removing all change will work on both side. From this starting firmware (the working firmware before I made any change), adding the new characteristic will definitely crash the custom board and DK (should be due to not enough RAM). Increasing the RAM start address will make DK work and custom board still crashes. Staying at this point, I have a firmware that works on DK and crashes on custom board.
    Below is the schematic of our custom board, including the 2 LEDs I mentioned before: LED.Blue and LED.Red. These LEDs are controlled by PPI module. Noted that for firmware using on DK, I have to disable LEDs as DK doesn't have LEDs on these pins. Firmware with disabled LEDs (to match firmware on DK) will still crash on custom board.
