nRF9160dk ADC and AWS_IOT
I am working with a dk along side a custom PCB that is used to read and amplify the signal from a load cell. I cannot change anything on the custom PCB and I need to be able to run a differential ADC using pins 14 and 15, I also need to output on pin 17 to trigger the sensor reading on the custom PCB. I have gotten that all working on an application that only in reading mode. I have an issue when I added that reading file to the aws_iot sample project where both pin 14 and 15 are set to around 1.79V. I am pretty sure this is because UART1 uses pin 14 for RTS and 15 for CTS. My question is how can I turn off or move those functions to different pins. I haven't been able to find what is turning RTS or CTS on. I have found that in the device tree I can change the pins used for RTS and CTS but I feel like this isn't the best solution to the problem.
	//In nrf9160dk_nrf9160_common-pinctrl.dtsi
	uart1_default: uart1_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 1)>,
				<NRF_PSEL(UART_RTS, 0, 14)>; //Change to 16
		group2 {
			psels = <NRF_PSEL(UART_RX, 0, 0)>,
				<NRF_PSEL(UART_CTS, 0, 15)>; //Change to 18
			bias-pull-up;
	uart1_sleep: uart1_sleep {
		group1 {
				<NRF_PSEL(UART_RTS, 0, 14)>,//Change to 16
				<NRF_PSEL(UART_CTS, 0, 15)>;//Change to 18
			low-power-enable;
It also leaves pin 14 and 15 at around 400mV which I need to be 0. How can I isolate those pins so that they are only used for reading? I would also like to confirm that I am properly using the ADC in differential mode and ask how to properly find pin 17 to output on. I have just changed led0 to use pin 17.
	// In nrf9160dk_nrf9160_common.dts
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio0 17 0>;
			label = "Green LED 1";
		led1: led_1 {
			gpios = <&gpio0 3 0>;
			label = "Green LED 2";
		led2: led_2 {
			gpios = <&gpio0 4 0>;
			label = "Green LED 3";
		led3: led_3 {
			gpios = <&gpio0 5 0>;
			label = "Green LED 4";
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <stdio.h>
#include <stdlib.h>
#if defined(CONFIG_NRF_MODEM_LIB)
#include <modem/lte_lc.h>
#include <modem/nrf_modem_lib.h>
#include <modem/modem_info.h>
#include <nrf_modem.h>
#include <net/aws_iot.h>
#include <zephyr/sys/reboot.h>
#include <date_time.h>
#include <zephyr/dfu/mcuboot.h>
#include <cJSON.h>
#include <cJSON_os.h>
#if defined(CONFIG_AWS_IOT_SAMPLE_DEVICE_ID_USE_HW_ID)
#include <hw_id.h>
LOG_MODULE_REGISTER(aws_iot_sample, CONFIG_AWS_IOT_SAMPLE_LOG_LEVEL);
BUILD_ASSERT(!IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT),
	     "This sample does not support LTE auto-init and connect");
#define APP_TOPICS_COUNT CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT
static struct k_work_delayable shadow_update_work;
static struct k_work_delayable connect_work;
static struct k_work shadow_update_version_work;
static bool cloud_connected;
static K_SEM_DEFINE(lte_connected, 0, 1);
static K_SEM_DEFINE(date_time_obtained, 0, 1);
static int json_add_obj(cJSON *parent, const char *str, cJSON *item)
	cJSON_AddItemToObject(parent, str, item);
	return 0;
static int json_add_str(cJSON *parent, const char *str, const char *item)
	cJSON *json_str;
	json_str = cJSON_CreateString(item);
	if (json_str == NULL) {
		return -ENOMEM;
	return json_add_obj(parent, str, json_str);
static int json_add_number(cJSON *parent, const char *str, double item)
	cJSON *json_num;
	json_num = cJSON_CreateNumber(item);
	if (json_num == NULL) {
		return -ENOMEM;
	return json_add_obj(parent, str, json_num);
static int shadow_update(bool version_number_include)
	int err;
	char *message;
	int64_t message_ts = 0;
	int mV = 0;
	int raw = 0;
	LOG_INF("Getting date and time");
	err = date_time_now(&message_ts);
	if (err) {
		LOG_ERR("date_time_now, error: %d", err);
		return err;
	LOG_INF("Trying to read from the ADC");
	err = get_adc_reading(&mV, &raw);
		if (err) {
		LOG_ERR("get_adc_reading, error: %d", err);
		return err;
	cJSON *root_obj = cJSON_CreateObject();
	cJSON *state_obj = cJSON_CreateObject();
	cJSON *reported_obj = cJSON_CreateObject();
	if (root_obj == NULL || state_obj == NULL || reported_obj == NULL) {
		cJSON_Delete(root_obj);
		cJSON_Delete(state_obj);
		cJSON_Delete(reported_obj);
		err = -ENOMEM;
		return err;
	if (version_number_include) {
		err = json_add_str(reported_obj, "app_version", CONFIG_AWS_IOT_SAMPLE_APP_VERSION);
	} else {
		err = 0;
	err += json_add_number(reported_obj, "raw adc reading", raw);
	err += json_add_number(reported_obj, "converted adc reading mV", mV);
	err += json_add_number(reported_obj, "ts", message_ts);
	err += json_add_obj(state_obj, "reported", reported_obj);
	err += json_add_obj(root_obj, "state", state_obj);
	if (err) {
		LOG_ERR("json_add, error: %d", err);
		goto cleanup;
	message = cJSON_Print(root_obj);
	if (message == NULL) {
		LOG_ERR("cJSON_Print, error: returned NULL");
		err = -ENOMEM;
		goto cleanup;
	struct aws_iot_data tx_data = {
		.qos = MQTT_QOS_0_AT_MOST_ONCE,
		.topic.type = AWS_IOT_SHADOW_TOPIC_UPDATE,
		.ptr = message,
		.len = strlen(message)
	LOG_INF("Publishing: %s to AWS IoT broker", message);
	err = aws_iot_send(&tx_data);
	if (err) {
		LOG_ERR("aws_iot_send, error: %d", err);
	cJSON_FreeString(message);
cleanup:
	return err;
static void connect_work_fn(struct k_work *work)
	int err;
	if (cloud_connected) {
		return;
	err = aws_iot_connect(NULL);
	if (err) {
		LOG_ERR("aws_iot_connect, error: %d", err);
	LOG_INF("Next connection retry in %d seconds",
		CONFIG_AWS_IOT_SAMPLE_CONNECTION_RETRY_TIMEOUT_SECONDS);
	k_work_schedule(&connect_work,
			K_SECONDS(CONFIG_AWS_IOT_SAMPLE_CONNECTION_RETRY_TIMEOUT_SECONDS));
static void shadow_update_work_fn(struct k_work *work)
	int err;
	if (!cloud_connected) {
		return;
	err = shadow_update(false);
	if (err) {
		LOG_ERR("shadow_update, error: %d", err);
	LOG_INF("Next data publication in %d seconds",
		CONFIG_AWS_IOT_SAMPLE_PUBLICATION_INTERVAL_SECONDS);
	k_work_schedule(&shadow_update_work,
			K_SECONDS(CONFIG_AWS_IOT_SAMPLE_PUBLICATION_INTERVAL_SECONDS));
static void shadow_update_version_work_fn(struct k_work *work)
	int err;
	err = shadow_update(true);
	if (err) {
static void print_received_data(const char *buf, const char *topic,
				size_t topic_len)
	char *str = NULL;
	cJSON *root_obj = NULL;
	root_obj = cJSON_Parse(buf);
	if (root_obj == NULL) {
		LOG_ERR("cJSON Parse failure");
		return;
	str = cJSON_Print(root_obj);
	if (str == NULL) {
		LOG_ERR("Failed to print JSON object");
		goto clean_exit;
	LOG_INF("Data received from AWS IoT console: Topic: %.*s Message: %s",
		topic_len, topic, str);
	cJSON_FreeString(str);
clean_exit:
void aws_iot_event_handler(const struct aws_iot_evt *const evt)
	switch (evt->type) {
	case AWS_IOT_EVT_CONNECTING:
		LOG_INF("AWS_IOT_EVT_CONNECTING");
	case AWS_IOT_EVT_CONNECTED:
		LOG_INF("AWS_IOT_EVT_CONNECTED");
		cloud_connected = true;
		/* This may fail if the work item is already being processed,
		 * but in such case, the next time the work handler is executed,
		 * it will exit after checking the above flag and the work will
		 * not be scheduled again.
		(void)k_work_cancel_delayable(&connect_work);
		if (evt->data.persistent_session) {
			LOG_INF("Persistent session enabled");
		/** Successfully connected to AWS IoT broker, mark image as
		 *  working to avoid reverting to the former image upon reboot.
		boot_write_img_confirmed();
		/** Send version number to AWS IoT broker to verify that the
		 *  FOTA update worked.
		k_work_submit(&shadow_update_version_work);
		/** Start sequential shadow data updates.
		int err = lte_lc_psm_req(true);
		if (err) {
			LOG_ERR("Requesting PSM failed, error: %d", err);
	case AWS_IOT_EVT_READY:
		LOG_INF("AWS_IOT_EVT_READY");
	case AWS_IOT_EVT_DISCONNECTED:
		LOG_INF("AWS_IOT_EVT_DISCONNECTED");
		cloud_connected = false;
		(void)k_work_cancel_delayable(&shadow_update_work);
		k_work_schedule(&connect_work, K_NO_WAIT);
	case AWS_IOT_EVT_DATA_RECEIVED:
		LOG_INF("AWS_IOT_EVT_DATA_RECEIVED");
		print_received_data(evt->data.msg.ptr, evt->data.msg.topic.str,
				    evt->data.msg.topic.len);
	case AWS_IOT_EVT_PUBACK:
		LOG_INF("AWS_IOT_EVT_PUBACK, message ID: %d", evt->data.message_id);
	case AWS_IOT_EVT_FOTA_START:
		LOG_INF("AWS_IOT_EVT_FOTA_START");
	case AWS_IOT_EVT_FOTA_ERASE_PENDING:
		LOG_INF("AWS_IOT_EVT_FOTA_ERASE_PENDING");
		LOG_INF("Disconnect LTE link or reboot");
		err = lte_lc_offline();
		if (err) {
			LOG_ERR("Error disconnecting from LTE");
	case AWS_IOT_EVT_FOTA_ERASE_DONE:
		LOG_INF("AWS_FOTA_EVT_ERASE_DONE");
		LOG_INF("Reconnecting the LTE link");
		err = lte_lc_connect();
		if (err) {
			LOG_ERR("Error connecting to LTE");
	case AWS_IOT_EVT_FOTA_DONE:
		LOG_INF("AWS_IOT_EVT_FOTA_DONE");
		LOG_INF("FOTA done, rebooting device");
		aws_iot_disconnect();
		sys_reboot(0);
	case AWS_IOT_EVT_FOTA_DL_PROGRESS:
		LOG_INF("AWS_IOT_EVT_FOTA_DL_PROGRESS, (%d%%)", evt->data.fota_progress);
	case AWS_IOT_EVT_ERROR:
		LOG_INF("AWS_IOT_EVT_ERROR, %d", evt->data.err);
	case AWS_IOT_EVT_FOTA_ERROR:
		LOG_INF("AWS_IOT_EVT_FOTA_ERROR");
		LOG_WRN("Unknown AWS IoT event type: %d", evt->type);
static void work_init(void)
	k_work_init_delayable(&shadow_update_work, shadow_update_work_fn);
	k_work_init_delayable(&connect_work, connect_work_fn);
	k_work_init(&shadow_update_version_work, shadow_update_version_work_fn);
static void lte_handler(const struct lte_lc_evt *const evt)
	case LTE_LC_EVT_NW_REG_STATUS:
		if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
		     (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
		LOG_INF("Network registration status: %s",
			evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ?
			"Connected - home network" : "Connected - roaming");
		k_sem_give(&lte_connected);
	case LTE_LC_EVT_PSM_UPDATE:
		LOG_INF("PSM parameter update: TAU: %d, Active time: %d",
			evt->psm_cfg.tau, evt->psm_cfg.active_time);
	case LTE_LC_EVT_EDRX_UPDATE: {
		char log_buf[60];
		ssize_t len;
		len = snprintf(log_buf, sizeof(log_buf),
			       "eDRX parameter update: eDRX: %f, PTW: %f",
			       evt->edrx_cfg.edrx, evt->edrx_cfg.ptw);
		if (len > 0) {
			LOG_INF("%s", log_buf);
	case LTE_LC_EVT_RRC_UPDATE:
		LOG_INF("RRC mode: %s",
			evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ?
			"Connected" : "Idle");
	case LTE_LC_EVT_CELL_UPDATE:
		LOG_INF("LTE cell changed: Cell ID: %d, Tracking area: %d",
			evt->cell.id, evt->cell.tac);
static void nrf_modem_lib_dfu_handler(int err)
	switch (err) {
	case NRF_MODEM_DFU_RESULT_OK:
		LOG_INF("Modem update suceeded, reboot");
		sys_reboot(SYS_REBOOT_COLD);
	case NRF_MODEM_DFU_RESULT_UUID_ERROR:
	case NRF_MODEM_DFU_RESULT_AUTH_ERROR:
		LOG_INF("Modem update failed, error: %d", err);
		LOG_INF("Modem will use old firmware");
	case NRF_MODEM_DFU_RESULT_HARDWARE_ERROR:
	case NRF_MODEM_DFU_RESULT_INTERNAL_ERROR:
		LOG_INF("Modem update malfunction, error: %d, reboot", err);
	case NRF_MODEM_DFU_RESULT_VOLTAGE_LOW:
		LOG_INF("Modem update cancelled due to low power, error: %d", err);
		LOG_INF("Please reboot once you have sufficient power for the DFU");
static int app_topics_subscribe(void)
	int err;
	static char custom_topic[75] = "my-custom-topic/example";
	static char custom_topic_2[75] = "my-custom-topic/example_2";
	const struct aws_iot_topic_data topics_list[APP_TOPICS_COUNT] = {
		[0].str = custom_topic,
		[0].len = strlen(custom_topic),
		[1].str = custom_topic_2,
		[1].len = strlen(custom_topic_2)
	err = aws_iot_subscription_topics_add(topics_list, ARRAY_SIZE(topics_list));
	if (err) {
		LOG_ERR("aws_iot_subscription_topics_add, error: %d", err);
	return err;
static void date_time_event_handler(const struct date_time_evt *evt)
	case DATE_TIME_OBTAINED_MODEM:
		/* Fall through */
	case DATE_TIME_OBTAINED_NTP:
		/* Fall through */
	case DATE_TIME_OBTAINED_EXT:
		LOG_INF("Date time obtained");
		k_sem_give(&date_time_obtained);
		/* De-register handler. At this point the sample will have
		 * date time to depend on indefinitely until a reboot occurs.
		date_time_register_handler(NULL);
	case DATE_TIME_NOT_OBTAINED:
		LOG_INF("DATE_TIME_NOT_OBTAINED");
		LOG_ERR("Unknown event: %d", evt->type);
	int err;
	LOG_INF("The AWS IoT sample started, version: %s", CONFIG_AWS_IOT_SAMPLE_APP_VERSION);
	cJSON_Init();
	err = nrf_modem_lib_init();
	if (err) {
		LOG_ERR("Modem library initialization failed, error: %d", err);
		return 0;
	nrf_modem_lib_dfu_handler(err);
	char device_id[HW_ID_LEN] = { 0 };
	err = hw_id_get(device_id, ARRAY_SIZE(device_id));
	if (err) {
		LOG_ERR("Failed to retrieve device ID, error: %d", err);
		return 0;
	struct aws_iot_config config = {
	    .client_id = device_id,
	    .client_id_len = strlen(device_id)
	LOG_INF("Device id: %s", device_id);
	err = aws_iot_init(&config, aws_iot_event_handler);
#else
	err = aws_iot_init(NULL, aws_iot_event_handler);
	if (err) {
		LOG_ERR("AWS IoT library could not be initialized, error: %d", err);
	/** Subscribe to customizable non-shadow specific topics
	 *  to AWS IoT backend.
	err = app_topics_subscribe();
	if (err) {
		LOG_ERR("Adding application specific topics failed, error: %d", err);
	work_init();
	err = lte_lc_init_and_connect_async(lte_handler);
	if (err) {
		LOG_ERR("Modem could not be configured, error: %d", err);
		return 0;
	err = modem_info_init();
	if (err) {
		LOG_ERR("Failed initializing modem info module, error: %d", err);
	k_sem_take(&lte_connected, K_FOREVER);
	/* Trigger a date time update. The date_time API is used to timestamp data that is sent
	 * to AWS IoT.
	date_time_update_async(date_time_event_handler);
	/* Postpone connecting to AWS IoT until date time has been obtained. */
	k_sem_take(&date_time_obtained, K_FOREVER);
	return 0;
#include <zephyr/device.h>
#include <zephyr/drivers/adc.h>
#include <stdio.h>
#include <string.h>
//ADC
#include <hal/nrf_saadc.h>
#define ADC_DEVICE_NODE		DT_NODELABEL(adc)
#define ADC_RESOLUTION 12
#define ADC_GAIN ADC_GAIN_1_6
#define ADC_REFERENCE ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 10)
#define ADC_1ST_CHANNEL_ID 1
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1
#define ADC_2ND_CHANNEL_ID 2
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN2
#define SLEEP_TIME_MS 700
static const struct device *adc_dev = DEVICE_DT_GET(ADC_DEVICE_NODE);
static const struct adc_channel_cfg m_1st_channel_cfg = {
	.gain = ADC_GAIN,
	.reference = ADC_REFERENCE,
	.acquisition_time = ADC_ACQUISITION_TIME,
	.channel_id = ADC_1ST_CHANNEL_ID,
    .differential = 1,
#if defined(CONFIG_ADC_CONFIGURABLE_INPUTS)
	.input_positive = ADC_1ST_CHANNEL_INPUT,
    .input_negative = ADC_2ND_CHANNEL_INPUT,
#define BUFFER_SIZE 1
static int16_t m_sample_buffer[BUFFER_SIZE];
static int adc_sample(int *volt, int *raw)
	int ret;
	const struct adc_sequence sequence = {
		.channels = BIT(ADC_1ST_CHANNEL_ID),
		.buffer = m_sample_buffer,
		.buffer_size = sizeof(m_sample_buffer),
		.resolution = ADC_RESOLUTION,
	if (!adc_dev) {
		return -1;
	ret = adc_read(adc_dev, &sequence);
	int32_t adc_voltage = m_sample_buffer[0];
	ret = adc_raw_to_millivolts(adc_ref_internal(adc_dev), ADC_GAIN, ADC_RESOLUTION-1, &adc_voltage);
	if (ret)
		printk("raw_to_mili Broke!");
		return ret;
	*raw = m_sample_buffer[0];
	*volt = adc_voltage;
	return ret;
int get_adc_reading(int *milivolt, int *raw) {
	struct gpio_dt_spec p17 = GPIO_DT_SPEC_GET(DT_NODELABEL(led0), gpios);
	struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(DT_ALIAS(led1), gpios);
	if (!device_is_ready(p17.port)) {
		return -1;
	if (!device_is_ready(led1.port)) {
		return -1;
	int err;
	gpio_pin_configure_dt(&p17, GPIO_OUTPUT);
	gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
	err = gpio_pin_set_dt(&p17, 1);
	err = gpio_pin_set_dt(&led1, 1);
	if (err)
		return err;
	err = adc_channel_setup(adc_dev, &m_1st_channel_cfg);
	if (err) {
		return err;
	for (int i = 0; i <= 20; i++) {
		err = adc_sample(milivolt, raw);
		if (err) {
			return err;
		k_msleep(SLEEP_TIME_MS);
	gpio_pin_set_dt(&p17, 0);
	gpio_pin_set_dt(&led1, 0);
	return 0;
  • I found this post on a similar question about disconnecting RTS and CTS, and I have tried the overlay and haven't seen a change. I still see 1.7V at 14 and 15. I tried using the nrfprog but I got an error so I wasn't able to look at registers.
    nrfjprog --memrd 0x50009508 --n 4 --log
    ERROR: [SeggerBackend] - JLinkARM.dll ReadMem returned error 1.
    ERROR: [  nRF91] - Memory access failed with SECUREFAULT at 1342189832.
    ERROR: [  nRF91] - The read access failed due to memory protection.
    ERROR: Access to the selected address is blocked by the SPU
    have you checked that the changes where applied in the build? You should check build/zephyr/zephyr.dts and make sure the RTS and CTS pins have been changed.
  • I don't see anywhere that they are defined in that file. I see all the UART1 default and sleep but it doesn't specify pins, and there isn't anything about RTS or CTS in there. I see that it says that UART1 is disabled so could it be something else that is powering those pins?
     8231.zephyr.dts
    This is the overlay file that I have been using, but the pins 14 and 15 are still around 1.79V.
    &led0 {
        gpios = <&gpio0 17 0 >;
    &pinctrl {
        uart1_default {
            group1 {
                psels = <NRF_PSEL(UART_RTS, 0, 1)>;
            group2 {
                psels = <NRF_PSEL(UART_CTS, 0, 0)>;
        uart1_sleep {
            group1 {
                psels = <NRF_PSEL(UART_RTS, 0, 1)>,
                low-power-enable;
  • AWS isn't a requirement for the project, we could try other cloud services. Would that make a difference or is RTS and CTS part of the modem and iot libraries? Would we be able to change the mqtt shadow for the nrfCloud? I feel like I remember seeing in the nrfCloud documentation that the shadows were determined off of the samples.
