Updatable bootlaoder (over BLE SMP)
I have added a support for application DFU over BLE SMP to our project (with mcumgr). It work with no problem. Now what I want to achieve is an updatable MCUBoot with the same transport layer. We already have a NSIB and proper static memory map configuration (configured with Partition Manager's pm_static.yml - we have mcuboot_secondary slot set in the external flash and B0 slots in internal flash). I have looked through code and it seems to me like the zephyr_img_mgmt implementation natively supports only application image updates with mcuboot backend. Is there any out of the box solution for updating the mcuboot itself? Is mcumgr flexible enough to upload the image to the partition/address other than mcuboot_secondary - in particular to the S1 slot of the B0 bootloader configured in the internal flash memory?
I have tried the solution proposed here but with the BLE SMP transport instead of UART:Update mcuboot with SMP
But it doesn't seem to work as the uploaded image lands in the mcuboot's external flash partition (verified with debbuger that the flash device being opened is the mx25r64).
I'd presume that the binary to be uploaded with mcumgr must have encoded all information needed to upload it to the proper memory address (judged by CBOR decoding implemented here: https://github.com/nrfconnect/sdk-zephyr/blob/main/subsys/mgmt/mcumgr/grp/img_mgmt/src/img_mgmt.c#L508). Does the `signed_by_mcuboot_and_b0_s1_image_update` file meet this criteria? If so, I guess it should be feasible to adapt the mcumgr to handle my case. I'd really appreciate any kind of guide or list of steps required to achieve that.
Also, I saw the CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD, which sounds like something which might help, but I cannot really understand what it does from the KConfig description. I'd warmly welcome any explanation here.
Thanks in advance,
G
1 2 3 4
