nrf Connect v2023.9.169 Extension for VS Code - how to restore Sidebar to "old" layout!?
I am using nrf SDK v2.3.0 with nrf Connect extension of VS Code on MacOS
The nrf Connect Extension was automatically upgraded to v2023.9.169 last week.
I noticed that the "nrf Connect Sidebar" is now quite different & I find it has missing "sections" (fast shortcuts) that I used to use a LOT on the older versions of nrf Connect Extension.
The older versions sidebar looked like this:
Notice the separate (expandable) "sections for "Sensor_Firmware" (for quick access to source, etc) and the "Actions" section.
My new sidebar (v2023.9.169) now looks like this:
I can live with the new "Explorer" tree of the Application in the new version (it is good BUT it would be "nice" to have a more obvious toggle/section to "show Application in Explorer")
BUT I REALLY would like to get the "Actions" section back on my sidebar!? How do I do that...!?
Is there a way to get that "Actions" section back in the new nrfConnect Extension Sidebar?
I can't figure out how to "get that back"! :)
Of course I like the new expanded "Welcome" section showing the SDK's installed & currently selected or in use.
Thanks!
Gerard
  • OK Marte - here is the support info from VSCode that you requested:
    [10:34:47] nRF Command Line Tools 10.23.0 are up to date
    [10:35:01] sh -c west build --build-dir /Users/gerardbucas/GitHub/sensor_firmware/build /Users/gerardbucas/GitHub/sensor_firmware
    [10:35:16] Success.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 22.6.0: Wed Jul  5 22:21:56 PDT 2023; root:xnu-8796.141.3~6/RELEASE_X86_64",
        "osKernel": "22.6.0",
        "vscode": "1.82.1",
        "electron": "25.8.0",
        "node": "v18.15.0"
      "system": {
        "date": "2023-09-14T14:37:25.228Z",
        "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "vscodeUptime": "00:02:41",
        "osUptime": "152:51:53",
        "cpu": {
          "model": "Intel(R) Core(TM) i5-8279U CPU @ 2.40GHz",
          "speed": "2400 MHz",
          "count": 4
        "memory": {
          "total": "16.00 GB",
          "free": "1.01 GB"
      "workspace": {
        "name": "sensor_firmware",
        "workspaceFile": null,
        "folders": [
          "/Users/gerardbucas/GitHub/sensor_firmware"
      "extensions": {
        "internal": {
            "version": "2023.9.169",
            "path": "/Users/gerardbucas/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.9.169-darwin-x64",
            "isActive": true
            "version": "2023.7.47",
            "path": "/Users/gerardbucas/.vscode/extensions/nordic-semiconductor.nrf-terminal-2023.7.47",
            "isActive": true
            "version": "2023.9.57",
            "path": "/Users/gerardbucas/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2023.9.57",
            "isActive": true
            "version": "2023.9.31",
            "path": "/Users/gerardbucas/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2023.9.31",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.17.5",
          "ms-vscode.js-debug": "1.82.0",
          "ms-vscode.js-debug-companion": "1.1.2",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "twxs.cmake": "0.0.17"
      "tools": {
        "/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.15.2",
        "/Applications/SEGGER/JLink/JLinkExe": "7.88j",
        "/usr/local/bin/nrfjprog": "10.23.0",
        "/Library/Frameworks/Python.framework/Versions/3.9/bin/nrfutil": null,
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/cmake": "3.20.5",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/west": "0.14.0",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/python3": "3.9.6",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/ninja": "1.10.2",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/gperf": "3.1",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/dtc": "1.6.1",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/gn": "2082",
        "/opt/nordic/ncs/toolchains/v2.3.0/bin/git": "2.37.3",
        "gdbPath": "/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
      "sdks": [
          "version": "1.9.1",
          "path": "/opt/nordic/ncs/v1.9.1"
          "version": "2.3.0",
          "path": "/opt/nordic/ncs/v2.3.0"
      "toolchains": [
          "version": "1.9.1",
          "path": "/opt/nordic/ncs/v1.9.1/toolchain"
          "version": "2.3.0",
          "path": "/opt/nordic/ncs/toolchains/v2.3.0"
      "connectedDevices": [],
      "deviceProvider": "nrfutil",
      "config": {
          "topdir": "${nrf-connect.sdk:2.3.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.3.0}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig",
            "executeInDefaultShell": false
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "terminalMode": "character"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/v2.3.0/Cellar/git/2.37.3/libexec/git-core",
          "HOME": "/Users/gerardbucas",
          "PATH": "/opt/nordic/ncs/toolchains/v2.3.0/bin:/opt/nordic/ncs/toolchains/v2.3.0/usr/bin:/opt/nordic/ncs/toolchains/v2.3.0/usr/local/bin:/opt/nordic/ncs/toolchains/v2.3.0/opt/bin:/opt/nordic/ncs/toolchains/v2.3.0/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/Users/gerardbucas/google-cloud-sdk/bin:/Library/Frameworks/Python.framework/Versions/3.9/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/gerardbucas/development/flutter/bin:/Users/gerardbucas/google-cloud-sdk/bin:/Library/Apple/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Visual Studio Code.app/Contents/Resources/app/bin:/Users/gerardbucas/google-cloud-sdk/bin:/Library/Frameworks/Python.framework/Versions/3.9/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/gerardbucas/development/flutter/bin:/Users/gerardbucas/google-cloud-sdk/bin:/Library/Apple/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Visual Studio Code.app/Contents/Resources/app/bin",
          "ZEPHYR_BASE": "/opt/nordic/ncs/v2.3.0/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk",
          "USER": "gerardbucas"
        "inherited": {
          "PATH": "/Users/gerardbucas/google-cloud-sdk/bin:/Library/Frameworks/Python.framework/Versions/3.9/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/gerardbucas/development/flutter/bin:/Users/gerardbucas/google-cloud-sdk/bin:/Library/Apple/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Applications/Visual Studio Code.app/Contents/Resources/app/bin",
        "toolchainPath": "/opt/nordic/ncs/toolchains/v2.3.0",
        "toolchainBinPath": "/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
        "toolchainVersion": "2.3.0"
      "terminal": {
        "defaultProfile": null
  • [21:13:58] Update available https://nsscprodmedia.blob.core.windows.net/prod/software-and-other-downloads/desktop-software/nrf-command-line-tools/sw/versions-10-x-x/10-23-0/nrf-command-line-tools-10.23.0-darwin.dmg
      "platform": {
        "os": "darwin",
        "osVersion": "Darwin Kernel Version 21.6.0: Wed Aug 10 14:25:27 PDT 2022; root:xnu-8020.141.5~2/RELEASE_X86_64",
        "osKernel": "21.6.0",
        "vscode": "1.81.1",
        "electron": "22.3.18",
        "node": "v16.17.1"
      "system": {
        "date": "2023-09-15T01:13:58.544Z",
        "vscodeUptime": "00:01:02",
        "osUptime": "09:28:27",
        "cpu": {
          "model": "Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz",
          "speed": "2300 MHz",
          "count": 8
        "memory": {
          "free": "3.41 GB"
      "workspace": {
        "name": null,
        "folders": []
      "extensions": {
        "internal": {
            "path": "/Users/radiotagproject/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.9.169-darwin-x64",
            "isActive": true
            "version": "2023.9.29",
            "path": "/Users/radiotagproject/.vscode/extensions/nordic-semiconductor.nrf-terminal-2023.9.29",
            "isActive": true
            "path": "/Users/radiotagproject/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2023.9.57",
            "isActive": true
            "path": "/Users/radiotagproject/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2023.9.31",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.12.1",
          "ms-vscode.js-debug": "1.81.0",
          "basdp.language-gas-x86": "0.0.2",
          "cschlosser.doxdocgen": "1.4.0",
          "dseight.disasexpl": "0.2.4",
          "jeff-hykin.better-cpp-syntax": "1.17.2",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.24",
          "mcu-debug.peripheral-viewer": "1.4.6",
          "mcu-debug.rtos-views": "0.0.7",
          "ms-vscode.hexeditor": "1.9.12",
          "plorefice.devicetree": "0.1.1",
          "trond-snekvik.gnu-mapfiles": "1.1.0"
      "tools": {
        "/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.0",
        "/Applications/SEGGER/JLink/JLinkExe": "7.86",
        "/usr/local/bin/nrfjprog": "10.16.0",
        "nrfutil": "Not found",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/cmake": "3.20.5",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/west": "1.0.0",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/python3": "3.9.6",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/ninja": "1.10.2",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/gperf": "3.1",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/dtc": "1.6.1",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/gn": "2105",
        "/opt/nordic/ncs/toolchains/4ef6631da0/bin/git": "2.37.3",
        "gdbPath": "/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
      "sdks": [
          "version": "2.4.0",
          "path": "/opt/nordic/ncs/v2.4.0"
      "toolchains": [
          "version": "2.4.0",
          "path": "/opt/nordic/ncs/toolchains/4ef6631da0"
      "config": {
          "topdir": "${nrf-connect.sdk:2.4.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.4.0}"
          "ozonePath": "",
          "applications": [],
          "kconfig": {
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "/Users/radiotagproject/Documents/Radio-Projects/MT_Exotic1_Rev_B_220711A_Threads/boards"
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
            "indexURL": null,
          "nrfutil": {
            "home": null
        "marus25.cortex-debug": {
          "variableUseNaturalFormat": true,
          "liveWatchRefreshRate": "300",
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "dbgServerLogfile": null
      "environment": {
        "westEnv": {
          "GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/4ef6631da0/Cellar/git/2.37.3/libexec/git-core",
          "HOME": "/Users/radiotagproject",
          "PATH": "/opt/nordic/ncs/toolchains/4ef6631da0/bin:/opt/nordic/ncs/toolchains/4ef6631da0/usr/bin:/opt/nordic/ncs/toolchains/4ef6631da0/usr/local/bin:/opt/nordic/ncs/toolchains/4ef6631da0/opt/bin:/opt/nordic/ncs/toolchains/4ef6631da0/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
          "ZEPHYR_BASE": "/opt/nordic/ncs/v2.4.0/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk",
          "USER": "radiotagproject"
        "inherited": {
          "PATH": "/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
        "toolchainPath": "/opt/nordic/ncs/toolchains/4ef6631da0",
        "toolchainBinPath": "/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin",
        "toolchainVersion": "2.4.0"
      "terminal": {
    Thank you for sharing logs. I have reported this to the development team, and I will update you when I get a response.
    Marte
  • Hi Marte,
    Just to let you know that this problem now seems to be fixed in the latest version of nrf Connect Extension for VS Code.
    I just upgraded to v2023.9.336 & everything now seems to work fine!
    So we can close this case...!
    Thanks for all you help in getting this resolved.
    Regards
    Gerard
