QSPI has slower performance than single lane SPI using same CLK frequency with external QSPI flash with LittleFS.
Registers have been reconfigured according to your Errata;
System is using Zephyr os with kconfig file containig:
It's likely due to the very long time to enter deep-powerdown (t-enter-dpd) and time to exit deep-powerdown (t-exit-dpd). The driver must enter and exit deep powerdown before and after every interaction with the chip, and those wait times each get rounded up the nearest millisecond.
Try disabling dpd and see if that speeds things up.
Thank you for your response. I tried to disable pdp mode but observed no improvement over previous run.
Current dts file config:
Have you tried running faster than 16MHz sck-frequency? It looks like the Macronix MX66 supports reading up to 50MHz and writing up to 133MHz. The nRF5340 supports QSPI speeds from 6 to 96 MHz. I would try setting the frequency to 50MHz (keeping DPD disabled still).
sck-frequency = <50000000>;
Thank you for your input. This is valid point and we considered in but 16MHz has to be kept because of EMC compatibility. Nevertheless, It seems that theoretically QSPI should give:
But that's not what we observe. Right now SPI is performing faster than QSPI when writing file to flash (same clock), which is not aligning with QSPI specs.
Unfortunately, I'm out of ideas. I'm using QSPI on the nRF5340 with an Infineon S25FL064L 64Mb (8 MB) flash chip, and it is lightning fast compared to ordinary SPI. Here is my dts definition, maybe it will help.
&qspi {
status = "okay";
pinctrl-0 = <&qspi_default>;
pinctrl-1 = <&qspi_sleep>;
s25fl064l: s25fl064l@0 {
compatible = "nordic,qspi-nor";
reg = <0>;
/* S25FL064L supports pp4o (Quad Page Program (QPP) instruction 0x32) */
writeoc = "pp4o";
/* S25FL064L supports read4o (Quad Output Read (QOR) instruction 0x6B) */
readoc = "read4o";
quad-enable-requirements = "S2B1v5";
sck-frequency = <108000000>;
jedec-id = [01 60 17];
sfdp-bfp = [
e5 20 fb ff ff ff ff 03 48 eb 08 6b 08 3b 88 bb
fe ff ff ff ff ff ff ff ff ff 48 eb 0c 20 0f 52
10 d8 00 ff 31 92 0d ff 81 66 4e cd cc 83 18 44
7a 75 7a 75 f7 a2 d5 5c 22 f6 5d ff e8 50 f8 a1
size = <67108864>;
/* has-dpd; */
/* t-enter-dpd = <3000>; */
/* t-exit-dpd = <5000>; */
