Building gnss
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1 c:/ncs/v2.4.2/nrf/samples/nrf9160/gnss --pristine --board nrf9160dk_nrf9160 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/ncs/v2.4.2/nrf/applications/asset_tracker_v2""
-- Application: C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.2/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.2/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Generated zephyr.dts: C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/dts.cmake
Parsing C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/Kconfig
Loaded configuration 'C:/ncs/v2.4.2/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/prj.conf'
Configuration saved to 'C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Warning at C:/ncs/v2.4.2/zephyr/CMakeLists.txt:839 (message):
No SOURCES given to Zephyr library: lib__libc__common
Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1
[1/191] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.2/zephyr), build: v3.3.99-ncs1-1
[2/191] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/191] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/191] Generating include/generated/driver-validation.h
[5/191] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[6/191] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/191] Generating include/generated/offsets.h
[8/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[9/191] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[10/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
[11/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
[12/191] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[13/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[14/191] Generating linker_zephyr_pre0.cmd
[15/191] Generating linker_zephyr_pre1.cmd
[16/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[17/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
[18/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[19/191] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[20/191] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[21/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[22/191] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[23/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[24/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[25/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[26/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[27/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[28/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[29/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[30/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[31/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[32/191] Linking C static library zephyr\arch\common\libisr_tables.a
[33/191] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[34/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
[35/191] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[36/191] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[37/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[38/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[39/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[40/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[41/191] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[42/191] Linking C static library zephyr\arch\common\libarch__common.a
[43/191] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[44/191] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[45/191] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[46/191] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[47/191] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[48/191] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[49/191] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[50/191] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
[51/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[52/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[53/191] Building C object CMakeFiles/app.dir/src/main.c.obj
[54/191] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[55/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[56/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[57/191] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[58/191] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
[59/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[60/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[61/191] Linking C static library app\libapp.a
[62/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[63/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[64/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[65/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[66/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[67/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[68/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[69/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[70/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[71/191] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[72/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[73/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[74/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[75/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[76/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[77/191] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[78/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[79/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[80/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[81/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[82/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[83/191] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[84/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj
[85/191] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[86/191] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[87/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
[88/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
[89/191] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[90/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[91/191] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[92/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
[93/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[94/191] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[95/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[96/191] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[97/191] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
[98/191] Building C object zephyr/subsys/net/l2/offloaded_netdev/CMakeFiles/subsys__net__l2__offloaded_netdev.dir/offloaded_netdev.c.obj
[99/191] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[100/191] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf_simple.c.obj
[101/191] Linking C static library zephyr\subsys\random\libsubsys__random.a
[102/191] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
[103/191] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[104/191] Linking C static library zephyr\subsys\net\l2\offloaded_netdev\libsubsys__net__l2__offloaded_netdev.a
[105/191] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[106/191] Linking C static library zephyr\libzephyr.a
[107/191] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[108/191] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/ncs/v2.4.2/nrf/drivers/entropy/entropy_cc3xx.c.obj
[109/191] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
[110/191] Linking C static library zephyr\subsys\net\libsubsys__net.a
[111/191] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
[112/191] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[113/191] Linking C static library zephyr\drivers\console\libdrivers__console.a
[114/191] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[115/191] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[116/191] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[117/191] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[118/191] Linking C static library zephyr\subsys\net\ip\libsubsys__net__ip.a
[119/191] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=0 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/net/lib/sockets/. -I../../../../include -I../../../../lib/at_cmd_parser/include -I../../../../tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.4.2/nrfxlib/nrf_modem/include -isystem C:/ncs/v2.4.2/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj -MF modules\nrf\lib\nrf_modem_lib\CMakeFiles\..__nrf__lib__nrf_modem_lib.dir\nrf_modem_lib.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj -c C:/ncs/v2.4.2/nrf/lib/nrf_modem_lib/nrf_modem_lib.c
C:\ncs\v2.4.2\nrf\lib\nrf_modem_lib\nrf_modem_lib.c:17:10: fatal error: pm_config.h: No such file or directory
17 | #include <pm_config.h>
compilation terminated.
[120/191] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[121/191] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=0 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/net/lib/sockets/. -I../../../../include -I../../../../lib/at_cmd_parser/include -I../../../../tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.4.2/nrfxlib/nrf_modem/include -isystem C:/ncs/v2.4.2/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj -MF modules\nrf\lib\nrf_modem_lib\CMakeFiles\..__nrf__lib__nrf_modem_lib.dir\nrf_modem_os.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj -c C:/ncs/v2.4.2/nrf/lib/nrf_modem_lib/nrf_modem_os.c
C:\ncs\v2.4.2\nrf\lib\nrf_modem_lib\nrf_modem_os.c:16:10: fatal error: pm_config.h: No such file or directory
16 | #include <pm_config.h>
[122/191] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[123/191] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[124/191] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
[125/191] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[126/191] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=0 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.4.2/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.2/zephyr/subsys/net/lib/sockets/. -I../../../../include -I../../../../lib/at_cmd_parser/include -I../../../../tests/include -IC:/ncs/v2.4.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.2/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.4.2/nrfxlib/nrf_modem/include -isystem C:/ncs/v2.4.2/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss/build_1/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.4.2/nrf/samples/nrf9160/gnss=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj -MF modules\nrf\lib\nrf_modem_lib\CMakeFiles\..__nrf__lib__nrf_modem_lib.dir\sanity.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj -c C:/ncs/v2.4.2/nrf/lib/nrf_modem_lib/sanity.c
C:\ncs\v2.4.2\nrf\lib\nrf_modem_lib\sanity.c:10:10: fatal error: pm_config.h: No such file or directory
10 | #include <pm_config.h>
[127/191] Building C object modules/nrf/lib/at_host/CMakeFiles/..__nrf__lib__at_host.dir/at_host.c.obj
[128/191] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf91_sockets.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\ncs\v2.4.2\nrf\samples\nrf9160\gnss\build_1'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
