What are the conditions that produce an MPSL ASSERT 112, 2105 ?
Hello, anyone.
On a NRF52840DK, modified to match my target. Using nrf SDK v2.1.0.
I have bluetooth (config for firmware upgrade by BT) advertize smp, have connection and notifs seemingly working
I am having a MPSL ASSERT 112, 2105 as soon as the fw upgrade starts.
I know that it fundamentally has to do with conflicting configurations that I am fighting with for eons now.
Could you please publish the exhaustive list of MPSL ASSERT x,y. We would gain some dev time.
  • Here are the logs Using nrf logger
    Device Manager, 2023-09-26
    Lynx-R1 HST (Device Manager)
    I17:27:02.271[j] Connected to E6:C4:DA:D4:02:8A
    I17:27:02.567[j] Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I17:27:02.627[j] PHY updated (TX: LE 2M, RX: LE 2M)
    I17:27:02.966[j] Services discovered
    I17:27:03.041[j] Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    I17:27:03.110[j] MTU changed to: 252
    I17:27:03.287[j] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb
    I17:27:03.306[j] Notifications enabled
    I17:27:03.329[j] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I17:27:03.427[j] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-06-00-00-FF-06-BF-62-72-63-08-FF
    I17:27:03.448[j] Wait for value changed complete
    I17:27:03.500[j] Received Header (Op: 1, Flags: 0, Len: 6, Group: 0, Seq: 255, Command: 6) CBOR {"rc":8}
    I17:27:03.528[j] PHY read (TX: LE 2M, RX: LE 2M)
    I17:27:03.566[j] Sending (19 bytes) Header (Op: 2, Flags: 0, Len: 11, Group: 0, Seq: 0, Command: 0) CBOR {"d":"Hello!"}
    I17:27:03.596[j] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I17:27:03.617[j] Sending (10 bytes) Header (Op: 0, Flags: 0, Len: 2, Group: 0, Seq: 1, Command: 6) CBOR {}
    I17:27:03.640[j] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I17:27:03.660[j] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 03-00-00-0B-00-00-00-00-BF-61-72-66-48-65-6C-6C-6F-21-FF
    I17:27:03.681[j] Received Header (Op: 3, Flags: 0, Len: 11, Group: 0, Seq: 0, Command: 0) CBOR {"r":"Hello!"}
    I17:27:03.712[j] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-06-00-00-01-06-BF-62-72-63-08-FF
    I17:27:03.810[j] Received Header (Op: 1, Flags: 0, Len: 6, Group: 0, Seq: 1, Command: 6) CBOR {"rc":8}
    I17:27:07.422[j] Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
    V17:29:24.837[l] Starting DFU, mode: CONFIRM_ONLY
    I17:29:25.045[j] Sending (10 bytes) Header (Op: 0, Flags: 0, Len: 2, Group: 1, Seq: 2, Command: 0) CBOR {}
    I17:29:25.063[j] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I17:29:25.123[j] Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 20000ms)
    I17:29:25.141[j] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-E2-53-41-E1-19-CE-20-97-49-E7-4D-03-5E-93-0B-3F-3E-94-C6-6D-49-84-3E-97-AC-E8-8F-86-57-E4-78-C9-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
    I17:29:25.159[j] Received Header (Op: 1, Flags: 0, Len: 134, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"0.0.0","hash":"4lNB4RnOIJdJ500DXpMLPz6Uxm1JhD6XrOiPhlfkeMk=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}
    V17:29:25.194[k] Validation response: {"images":[{"slot":0,"version":"0.0.0","hash":"4lNB4RnOIJdJ500DXpMLPz6Uxm1JhD6XrOiPhlfkeMk=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}
    V17:29:25.209[l] Moving from state VALIDATE to state UPLOAD
    I17:29:25.231Uploading firmware...
    then the board goes into MPSL ASSERT 112, 2105
    W17:29:45.274[j] Error: (0x8): GATT CONN TIMEOUT
    W17:29:45.418[Uploader] Uploader write failure for chunk with offset=0: m2.b
    W17:29:50.515[j] Error: (0x85): GATT ERROR
    W17:29:56.331[j] Error: (0x85): GATT ERROR
    W17:30:02.101[j] Error: (0x85): GATT ERROR
    W17:30:07.907[j] Error: (0x85): GATT ERROR
    W17:30:07.945[j] Connection attempt timed out
    W17:30:07.974[Uploader] Uploader write failure for chunk with offset=0: GATT ERROR
    W17:30:13.051[j] Error: (0x85): GATT ERROR
    W17:30:18.837[j] Error: (0x85): GATT ERROR
    W17:30:24.731[j] Error: (0x85): GATT ERROR
    W17:30:30.638[j] Error: (0x85): GATT ERROR
    W17:30:30.669[j] Connection attempt timed out
    W17:30:30.719[Uploader] Uploader write failure for chunk with offset=0: GATT ERROR
    W17:30:35.810[j] Error: (0x85): GATT ERROR
    W17:30:41.693[j] Error: (0x85): GATT ERROR
    W17:30:47.575[j] Error: (0x85): GATT ERROR
    W17:30:53.459[j] Error: (0x85): GATT ERROR
    W17:30:53.491[j] Connection attempt timed out
    W17:30:53.546[Uploader] Uploader write failure for chunk with offset=0: GATT ERROR
    W17:30:58.649[j] Error: (0x85): GATT ERROR
    W17:31:04.512[j] Error: (0x85): GATT ERROR
    W17:31:07.054Upgrade cancelled
    W17:31:10.296[j] Error: (0x85): GATT ERROR
    W17:31:16.061[j] Error: (0x85): GATT ERROR
    W17:31:16.096[j] Connection attempt timed out
  • Hi Laurent,
    I don't have the exhaustive list either, unfortunately. I've asked the MPSL team and will get back to you when I know more.
    I understand that this would be useful, but as far as I know there are no plans to publish this. Still, I've passed on your request!
    Raoul
  • Hi Laurent,
    I heard back from our MPSL team:
    Regarding the list of MPSL asserts: We don't have such a list internally, and also these assert codes can be different for each new NCS release. Also, each assert can have many different reasons so unfortunately I don't think there is convenient way to share such a list with customers, it will be basically unusable.
    Regarding the issue itself, they are asking for some clarification:
    1) Is the customer disabling interrupts in their application for some reason?
    2) Is the customer writing to flash or is he doing some other time-consuming operations?
    3) Can they share their prj.conf files to check if they have the correct settings?
    Could you expand on this, and also share your config files?
    Are you suspecting some kconfig options in particular?
    Thanks.
    Raoul
  • If you don't mind, I continue the discussion in our private thread that already exists about the same subject. Titled "Need to postpone inits (like SYS_INIT hidden everywhere) so that my device can do either bluetooth or radio_test or other protocols and switch."
