High current consuption using BME280 on Seeed Xiao BLE (nRF52840) in Zephyr RTOS
I'm developing an IoT product using nRF52840 provided by Seeed (Xiao BLE) with a BME280 sensor connected via I2C on a custom PCB, without another peripheral that BME280 and passive components for I2C connection. I can't get low power consumption, even if I try the system_off Zephyr example.
When I try the bme_280 example of Zephyr and enable the PM/PM_DEVICE features, the consumption is still so high (about 1mA). I need that it consumes a few hundred uA . An strange ripple between BME280 measurements is seen when I measure current using PPK2:
  • My config file:
CONFIG_SENSOR=y
CONFIG_PM=y
CONFIG_PM_DEVICE=y
  • I2C circuit Diagram (VCC=3V3):
  • Overlay file:
&i2c1 {
	status = "okay";
	bme280@76 {
		compatible = "bosch,bme280";
		reg = <0x76>;
  • Zephyr version: 3.2.99
  • nRF Connect version:2.3.0
I also tried:
I don't know what can I try.
Thanks
    Can you read out the PIN_CNF[n] register for the I2C pins after pm_device_action_run(dev, PM_DEVICE_ACTION_SUSPEND) has returned? I'm suspecting that pins are not configured back to default.
    Also could you try to cut the trace between the slave and the nRF52840 after putting it in low power mode to see if it makes the system off sleep current decrease?
    regards
    Jared
    I've read PIN_CNF[4] and PIN_CNF[5] registers corresponding to SDA/SCL pins, and there is no change:
    • Before  PM_DEVICE_ACTION_SUSPEND:
    • After PM_DEVICE_ACTION_SUSPEND:
    Also I realize that PIN_CFG[2] bit SENSE is like this (LOW):
    It's that OK? Or maybe it can reset SYSTEM_ON mode?
    In the other hand, I've cutted both (SDA and SCL) traces and current in SYSTEM OFF has made no change.
    If I try sleep_demo of Seeed in Arduino, the power consuption is very low.
    Regards
    Ok, seems my suspicion was right. Can you try to configure the pins back to the default which is as input, input buffer disconnected, no PULL, SOS1, and SENSE disabled? You can write 0x00000002 directly to both registers to put their back to default.
    SENSE isn't enabled by default, so I would disable it  unless you use that feature on purpose.
    Thanks for this information, that is very good to know.
    Yes, my guess is that there is some fw configuration that is causing this.
    regards
    Jared
  • Hi Jared,
    I've modified registers with debugger and power consuption has decreased a few dozen of uA. How can I set registers on code? There is some API?
    In the other hand, I realized that SAADC still idle consumes about 200uA. When I measure current with "CONFIG_ADC=n", power consumption turns as desired (just 6uA in idle vs 200uA with CONFIG_ADC=y):
    How can I set ADC to sleep mode between readings in Zephyr? In config file I've set:
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    And in overlay file:
    &adc {
    	#address-cells = <1>;
    	#size-cells = <0>;
    	channel@7 {
    		reg = <7>;
    		zephyr,gain = "ADC_GAIN_1_5";
    		zephyr,reference = "ADC_REF_INTERNAL";
    		zephyr,vref-mv = <750>;
    		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
    		zephyr,input-positive = <NRF_SAADC_AIN7>; /* P0.31 */
    		zephyr,resolution = <12>;
    Thanks for your help
    Very good progress on this,
    I see that there isn't any implementation for the power management module for the ADC yet.
    What API are you using for the ADC, are you using the nrfx driver directly or using the Zephyr API?
    regards
    Jared
