NRF Connect for desktop install fail - blank screen and error windows
I am trying to install NRF Connect onto a brand new Windows 11 PC (all WIN11 updates made) to program both the PDA10056 and PDA10059 DK's
I installed Segger 5.20a Embedded Software plus the J-Link software plus the NRF SDK and managed to get the blink program compiled and sent to the PDA10056 (Works flawlessly)
To program the PDA10059 Dongle I have tried to install the NRF connect for desktop, a selection screen pops up however when I try to install services they fail with errors (see below) or just give a blank screen with rotating blue swirly thing.
I have checked at the location above and the file does exist there.
I have also uninstalled j-link and segger embedded , then tried reinstalling nrf connect, however same error messages.
I have also tried installing Microsoft Visual Code manually (which works), however nrf connect still fails.
Do you have any ideas on how to proceed ?.
Thanks in anticipation.
  • I have been testing further and have also been getting this error, when trying to install the toolchain/serial services.
    I have tried backtracking releases without much success, many give just a blank nrf connect screen, even when i refresh screen.
  • Thank you for the additional information. We are looking into this issue. I will keep you posted.
  • Update:-
    Has there been any change on the NRF download servers since this posting ?
    The reason I ask is because I have since tried making a manual install of the Connect SDK .
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/installation/installing.html
    After installing chocolatey and west I checked the NRF Connect app again and lo-and-behold everything started downloading from your servers!!!
    Don't know if its an issue with a reset of your nrf Connect Download package (licenses) your end or my end now.
    Current Situation :-
    NRF Connect Serial Terminal Installs and works.
    NRF Connect Programmer Installs and works.
    Toolchain Manager installs (however Visual Basic does not pick up my two DK's in the "Connected devices")
    With the PCA 10056 DK (when I issue the command line "nrfjprog -i" in the terminal window it does respond with a serial code of the jlink device so I know the jlink is present and sitting on the "Bus".
    I have tried an uninstall and reinstall (also deleting the app data folder) and also a different version, no change.
    Is there an additional thing you have to do to enable "connected devices"  in VCode ?.
    With the PCA10059 (not sure how to test this from the visual basic command line, however I know it links working with the NRF Connect Programmer/Serial terminal, tested with blink example).
    At least its a step forward, just the "Connected devices" in Visual Studio Code have to sync. in, somehow.
    You should not need to install that manually as west and most other dependencies is part of the toolchain distribution, so the fact that this helps indicates an issue of some sorts with you environment or configuration.
    There have not been any changes recently that I am aware of, nor any increase in reports of people having problems with downloading from our servers.
    It should work out of the box if everything is set up correctly (which should be handled automatically by the toolchain manager), so this could be linked to the toolchain issues it seems you are seeing for some reason. But it could be interesting if you can check which device provider you have selected as shown in this post? If you have the latest versions of the tools, you should normally select "nrfutil", but it would be interesting to know if either of the options work in your case.
  • But it could be interesting if you can check which device provider you have selected as shown in this post? If you have the latest versions of the tools, you should normally select "nrfutil", but it would be interesting to know if either of the options work in your case.
    Bingo..... the Device Provider had defaulted to "nrfutil" !!!.... when I changed to "nrfjprog" (that is the second selection in its dropdown list) and refreshed the VB's connected devices ......the PDA10056 signed in and is detected correctly.
    I was expecting the PDA10059 dongle to show up there also, alas it is not, should it appear there? or do I have to drop hex files and soft devices to it using the NRF Connect Programmer.
