nRF52DK nRF52832 UART asynchronous receive
I am working through the Nordic Developer Academy and got stuck at lesson 4 (UART receive)
https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-4-serial-communication-uart/topic/uart-driver/
In particular, I am confused about this part:
I have created a sample project and connected external CP2102 USB->Serial adapter to P0.06 and P0.08 pins.
The code that I use:
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr/kernel.h>
#include "stdio.h"
#include "zephyr/drivers/uart.h"
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
static uint8_t tx_buf[] =  {"nRF Connect SDK Fundamentals Course \n\r"};
static uint8_t rx_buf[10] = {0}; //A buffer to store incoming UART data
const struct uart_config uart_cfg = {
		.baudrate = 115200,
		.parity = UART_CFG_PARITY_NONE,
		.stop_bits = UART_CFG_STOP_BITS_1,
		.data_bits = UART_CFG_DATA_BITS_8,
		.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	switch (evt->type) {
	case UART_TX_DONE:
		printf("transmission complete \n");
	case UART_TX_ABORTED:
		// do something
	case UART_RX_RDY:
		printf("rx rdy \n");
		if((evt->data.rx.len) != 0){
			printf("data received = %s \n", evt->data.rx.buf[evt->data.rx.offset]);
	case UART_RX_BUF_REQUEST:
		printf("requesting buffer \n");
		// do something
	case UART_RX_BUF_RELEASED:
		printf("buffer released \n");
		// do something
	case UART_RX_DISABLED:
		printf("rx disabled \n");
		uart_rx_enable(dev, rx_buf, sizeof(rx_buf), 100);
	case UART_RX_STOPPED:
		// do something
	if (!device_is_ready(uart)) {
    	return;
	int err;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	uart_rx_enable(uart, rx_buf, sizeof(rx_buf), 100);
	err = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_US);
	if (err) {
		return err;
	while(1){
		k_msleep(1000);
	return 0;
I am having issues understanding how to properly print out all the received data:
I tried to do:
	case UART_RX_RDY:
but when I send the data via UART (using Termite) , the following is printed:
I would appreciate if someone could clarify how to correctly print out all the received data.  Thanks in advance
Just for testing, I have also tried to print:
    case UART_RX_RDY:
        printf("data: %s \n", rx_buf);
and the logs are as following: (captured using Termite):
As you can see, it receives the first message (ping) correctly, but after that, the buffer overflows (rx_buf is 10 bytes size) and then it cannot print out the data correctly)
    Apologies for the long response time.
    Unfortunately I could not find a simple sample that showcase how to do this, so my best current suggestion is to investigate the peripheral UART and Central uart BLE samples and see how it is done in these samples
    Starting at L129 in peripheral_uarts main.c you can see how the UART_RD_RDY case is handled
    case UART_RX_RDY:
    		LOG_DBG("UART_RX_RDY");
    		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
    		buf->len += evt->data.rx.len;
    		if (disable_req) {
    			return;
    		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
    		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
    			disable_req = true;
    			uart_rx_disable(uart);
    and bt_receive_cb() L465 peripheral, ble_data_received() L83 in Central_uart should show how the uart messages are handled with regards to writing.
    Andreas
  • Hello. I had a look at the zephyr/samples/drivers/uart/echo_bot sample and that sample works exactly how I want it to work. Please look at the serial terminal logs below:
    *** Booting Zephyr OS build v3.3.99-ncs1 ***
    Hello! I'm your echo bot.
    Tell me something and press enter:
    hello
    Echo: hello
    ping
    Echo: ping
    test
    Echo: test
    apple
    Echo: apple
    I can easily echo any message that I send. However this sample uses different UART method (polling) and thats not what I want. I want to be able to echo the whole buffer using ASYNC uart method.
    Being able to echo the whole buffer is the most basic requirement for any UART program, it is really hard for me wrap my head around why is this so complicated using the ASYNC method. Would you be able to help any further?. Being able to print a whole received buffer should be as simple as 1 line of code..
    I have posted a ticket on zephyr git :
    https://github.com/zephyrproject-rtos/zephyr/issues/64115
    Perhaps my question is more suited for zephyr instead of here :)
  • Of course the echo_bot sample is what I should've suggested immediately Laughing That sample was not on my mind at all this morning!
    But as you state there is a difference in using polling and the async method, and the lesson you started with from the academy course uses Async. Have you attempted to merge the lesson you started with, i.e https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-4-serial-communication-uart/topic/uart-driver/, into the echo_bot?
    PS: Unless you've already been recommended by users on the discord to create a ticket on the github, you can also find Zephyrs discord at zephyrproject.org, which might be an even easier way to communicate with other developers using Zephyr
    Andreas
  • I have tried to merge the echo_bot to the async uart sample but that is not as straight forward as it may look as it is using completely different functions.. I dont think it can be done this way.
    I have posted on Zephyr Git as well as the Zephyr discord that you have recommended but there is no solution yet.. I am still waiting. If you have any more ideas let me know.
    I will be sure to post back here the answer if someone replies on git or discord :)
    I did some more digging and found an older, unofficial sample created by someone in tech support showcasing how to use the Asynchronous UART Driver. Here's a version of the sample that should work in NCS v2.4.2
    ncs-uart-async-count-rx.zip
    Andreas
