Unknown function 0xA60: seems to happen while calling a particular application API only
OK I'm seeing this weird behavior that I'm trying to understand
I have a sensor task that reads sensor data continuously every 4 seconds. The value is then notified to the subscriber (NotificationManager) which then sends the data to UART, (and later to BLE custom service.
Until I connect the BLE service from nRF Connect app, it all works ok (I see the UART print fine)
But when I attempt to connect to the BLE service via nRF Connect App, the program halts at 0xA60. (I have previously dealt with issues around logging and I wonder if it's related to it). Note that when I comment out the Notify call, the BLE connects OK. What does that tell us?
void MCP9808::Run()
    Write(Register::AMBIENT, 1);
    ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
    while(true)
        Read();
        uint32_t taskNotify = ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
        ParseTempInC();
        //Notify();  // uncommenting out results in A60 error upon BLE connection
        vTaskDelay(pdMS_TO_TICKS(DELAY_MS_PER_READ));
void NotificationManager::Update(Publisher* publisher)
    // retrieve the publisher's category
    auto category = publisher->GetCategory();
    switch (category)
      case Publisher::Category::TEMPERATURE:
	    MCP9808* mcp9808 = dynamic_cast<MCP9808*>(publisher);
	    if (!mcp9808) return;
	    uint16_t value = mcp9808->GetTempInC();
	    char msg[100] = {0};
	    snprintf (msg, sizeof(msg) - 1, "Temp = %uC", value);
	    PushNotification(MakeNotification(msg),
Notification NotificationManager::MakeNotification(char* msg)
    Notification notification = {0};
    strncpy(notification.msg, msg, sizeof(notification.msg));
    notification.category = category;
    return notification;
void NotificationManager::PushNotification(Notification notification)
    // write data to UART
    mUART.Write(notification.msg);
    // updating the custom value in the BLE characteristic table
    // mBLENotifierSrv.UpdateValue(reinterpret_cast<uint8_t*>(notification.msg));
