Device Tree translation into devicetree_generated.h not going as planned
I am developing in VSCode on an nRF52832 and trying to get peripherals setup correctly on my device. Using the device tree beyond the examples is proving difficult. I had one little issue that I made a really hacky solution to get a button working, but now I need 7 PWM channels and in digging for he solution I have been learning more and realize that these issues are related. In the end, I am probably not setting up something right in the device tree, but I cannot spot it.
First I'll explain the issue and the hack that made it work:
I have 3 buttons on a device and one is different than the other two. Ultimately, two have pull ups and one has a pull down. They have reversed logic.
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = <&gpio0 10 (GPIO_INPUT)>;
			label = "SW_MD";
		button1: button_1 {
			gpios = <&gpio0 3 (GPIO_INPUT | GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "SW_UP";
		button2: button_2 {
			gpios = <&gpio0 8 (GPIO_INPUT | GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "SW_DN";
Above is my current definitions. You will not that on button has no pull up or pull down defined. It has a pull down on the board. Also, this same hardware worked in project built using the NRF5 SDK.
void rem_ui_init(void)
	int ret;
	if (!gpio_is_ready_dt(&z_btn_u)) {
		LOG_ERR("Error: button device %s is not ready", z_btn_u.port->name);
	ret = gpio_pin_configure_dt(&z_btn_u, GPIO_INPUT);
	if (ret != 0) {
		LOG_ERR("Error %d: failed to configure %s pin %d", ret, z_btn_u.port->name, z_btn_u.pin);
	if (!gpio_is_ready_dt(&z_btn_d)) {
		LOG_ERR("Error: button device %s is not ready", z_btn_d.port->name);
	ret = gpio_pin_configure_dt(&z_btn_d, GPIO_INPUT);
	if (ret != 0) {
		LOG_ERR("Error %d: failed to configure %s pin %d", ret, z_btn_d.port->name, z_btn_d.pin);
	if (!gpio_is_ready_dt(&z_btn_m)) {
		LOG_ERR("Error: button device %s is not ready", z_btn_m.port->name);
	z_btn_m.dt_flags &= ~GPIO_PULL_UP; // HACK this is somehow getting setup wrong and has the pull up flag set when it should not be set.
	ret = gpio_pin_configure_dt(&z_btn_m, GPIO_INPUT | GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH);
	if (ret != 0) {
		LOG_ERR("Error %d: failed to configure %s pin %d", ret, z_btn_m.port->name, z_btn_m.pin);
	LOG_INF(LOG_GREEN "Buttons initialized!");
	leds_init();
Above is my initialization function for the buttons. You may note that above the configuration of "z_btn_m" is a line of code that changes the flags for the GPIO by erasing the pull up flag, which should not be set in according to the device tree, but it is set. We can see in devicetree_generated.h that the flags are set to 17.
 * Devicetree node: /buttons/button_2
 * Node identifier: DT_N_S_buttons_S_button_2
 * (Descriptions have moved to the Devicetree Bindings Index
 * in the documentation.)
/* Node's full path: */
#define DT_N_S_buttons_S_button_2_PATH "/buttons/button_2"
/* Node's name with unit-address: */
#define DT_N_S_buttons_S_button_2_FULL_NAME "button_2"
/* Node parent (/buttons) identifier: */
#define DT_N_S_buttons_S_button_2_PARENT DT_N_S_buttons
/* Node's index in its parent's list of children: */
#define DT_N_S_buttons_S_button_2_CHILD_IDX 2
/* Helper macros for child nodes of this node. */
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD(fn)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_SEP(fn, sep)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_VARGS(fn, ...)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_SEP_VARGS(fn, sep, ...)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_STATUS_OKAY(fn)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_STATUS_OKAY_SEP(fn, sep)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_STATUS_OKAY_VARGS(fn, ...)
#define DT_N_S_buttons_S_button_2_FOREACH_CHILD_STATUS_OKAY_SEP_VARGS(fn, sep, ...)
/* Node's dependency ordinal: */
#define DT_N_S_buttons_S_button_2_ORD 12
/* Ordinals for what this node depends on directly: */
#define DT_N_S_buttons_S_button_2_REQUIRES_ORDS \
	8, /* /buttons */ \
	9, /* /soc/gpio@50000000 */
/* Ordinals for what depends directly on this node: */
#define DT_N_S_buttons_S_button_2_SUPPORTS_ORDS /* nothing */
/* Existence and alternate IDs: */
#define DT_N_S_buttons_S_button_2_EXISTS 1
#define DT_N_ALIAS_sw2         DT_N_S_buttons_S_button_2
#define DT_N_NODELABEL_button2 DT_N_S_buttons_S_button_2
/* Macros for properties that are special in the specification: */
#define DT_N_S_buttons_S_button_2_REG_NUM 0
#define DT_N_S_buttons_S_button_2_RANGES_NUM 0
#define DT_N_S_buttons_S_button_2_FOREACH_RANGE(fn)
#define DT_N_S_buttons_S_button_2_IRQ_NUM 0
#define DT_N_S_buttons_S_button_2_STATUS_okay 1
/* Pin control (pinctrl-<i>, pinctrl-names) properties: */
#define DT_N_S_buttons_S_button_2_PINCTRL_NUM 0
/* Generic property macros: */
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_EXISTS 1
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_PH DT_N_S_soc_S_gpio_50000000
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_VAL_pin 10
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_VAL_pin_EXISTS 1
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_VAL_flags 17
#define DT_N_S_buttons_S_button_2_P_gpios_IDX_0_VAL_flags_EXISTS 1
#define DT_N_S_buttons_S_button_2_P_gpios_FOREACH_PROP_ELEM(fn) fn(DT_N_S_buttons_S_button_2, gpios, 0)
#define DT_N_S_buttons_S_button_2_P_gpios_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_buttons_S_button_2, gpios, 0)
#define DT_N_S_buttons_S_button_2_P_gpios_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_buttons_S_button_2, gpios, 0, __VA_ARGS__)
#define DT_N_S_buttons_S_button_2_P_gpios_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_buttons_S_button_2, gpios, 0, __VA_ARGS__)
#define DT_N_S_buttons_S_button_2_P_gpios_LEN 1
#define DT_N_S_buttons_S_button_2_P_gpios_EXISTS 1
#define DT_N_S_buttons_S_button_2_P_label "SW_MD"
#define DT_N_S_buttons_S_button_2_P_label_STRING_TOKEN SW_MD
#define DT_N_S_buttons_S_button_2_P_label_STRING_UPPER_TOKEN SW_MD
#define DT_N_S_buttons_S_button_2_P_label_FOREACH_PROP_ELEM(fn) fn(DT_N_S_buttons_S_button_2, label, 0) \
	fn(DT_N_S_buttons_S_button_2, label, 1) \
	fn(DT_N_S_buttons_S_button_2, label, 2) \
	fn(DT_N_S_buttons_S_button_2, label, 3) \
	fn(DT_N_S_buttons_S_button_2, label, 4)
#define DT_N_S_buttons_S_button_2_P_label_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_buttons_S_button_2, label, 0) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 1) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 2) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 3) DT_DEBRACKET_INTERNAL sep \
#define DT_N_S_buttons_S_button_2_P_label_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_buttons_S_button_2, label, 0, __VA_ARGS__) \
	fn(DT_N_S_buttons_S_button_2, label, 1, __VA_ARGS__) \
	fn(DT_N_S_buttons_S_button_2, label, 2, __VA_ARGS__) \
	fn(DT_N_S_buttons_S_button_2, label, 3, __VA_ARGS__) \
	fn(DT_N_S_buttons_S_button_2, label, 4, __VA_ARGS__)
#define DT_N_S_buttons_S_button_2_P_label_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_buttons_S_button_2, label, 0, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 1, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 2, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
	fn(DT_N_S_buttons_S_button_2, label, 3, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
#define DT_N_S_buttons_S_button_2_P_label_EXISTS 1
#define DT_N_S_buttons_S_button_2_P_zephyr_code 0
#define DT_N_S_buttons_S_button_2_P_zephyr_code_EXISTS 1
The flags from the above code is here: "DT_N_S_buttons_S_button_2_P_gpios_IDX_0_VAL_flags 17". This maps to the pull up flag being set, despite in not having been set in the device tree. My hack corrects this, but it looks like there is some sort issue in the translation of the device tree into the devicetree_generated.h file. This process is a black box to me, so I do not know how to correct it, hence the hack.
That leads me to the actual issue I need fixed and hopefully in the process I can find a solution to the issue I just described without the hack. I am setting up 7 PWM output for some LEDs. I need to use two PWM modules, 4 channels from one and only 3 from another. The 4 are white LEDs and the 3 are for an RGB LED. I am trying to use the pinctrl system as well. Below I will include some of the devicetree snippets.
leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
			label = "LED_W0";
		led1: led_1 {
			gpios = <&gpio0 29 GPIO_ACTIVE_LOW>;
			label = "LED_W1";
		led2: led_2 {
			gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
			label = "LED_W2";
		led3: led_3 {
			gpios = <&gpio0 12 GPIO_ACTIVE_LOW>;
			label = "LED_W3";
		led4: led_4 {
			gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
			label = "LED_R";
		led5: led_5 {
			gpios = <&gpio0 5 GPIO_ACTIVE_LOW>;
			label = "LED_G";
		led6: led_6 {
			gpios = <&gpio0 4 GPIO_ACTIVE_LOW>;
			label = "LED_B";
	pwmleds {
		compatible = "pwm-leds";
		pwm_led0: pwm_led_0 {
			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led1: pwm_led_1 {
			pwms = <&pwm0 1 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led2: pwm_led_2 {
			pwms = <&pwm0 2 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led3: pwm_led_3 {
			pwms = <&pwm0 3 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led4: pwm_led_4 {
			pwms = <&pwm1 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led5: pwm_led_5 {
			pwms = <&pwm1 1 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
		pwm_led6: pwm_led_6 {
			pwms = <&pwm1 2 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
pwm0_default: pwm0_default {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 0, 28)>,
					<NRF_PSEL(PWM_OUT1, 0, 29)>,
					<NRF_PSEL(PWM_OUT2, 0, 9)>,
					<NRF_PSEL(PWM_OUT3, 0, 12)>;
			nordic,invert;
	pwm0_sleep: pwm0_sleep {
		group1 {
			low-power-enable;
	pwm1_default: pwm1_default {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 0, 7)>,
					<NRF_PSEL(PWM_OUT1, 0, 5)>,
					<NRF_PSEL(PWM_OUT2, 0, 4)>;
			nordic,invert;
	pwm1_sleep: pwm1_sleep {
		group1 {
			low-power-enable;
As a note, I have seen in the examples both "leds" and "pwmleds" defined in the devicetree, but only "pwmleds" seems to be used. I'm assuming that those are left in the examples from the development of the examples, but like I said, that an assumption based on my failed attempts to get this working. Needless to say, I don't think that they are important, but I included them in the snippet. Starting with the first entry in the devicetree "pwmleds":
pwmleds {
compatible = "pwm-leds" is the way that the device tree interpreter understand how to parse the information in that section. I've dug for information about that in the past but it is hard to understand for the uninitiated.
pwm_led0: pwm_led_0 names the entry, I think the second name one is a keyword defined by "pwm_leds" but Im not sure. The first name needs to match the something in the list of aliases.
I believe that this is defined here: https://docs.zephyrproject.org/latest/build/dts/api/bindings/pwm/nordic%2Cnrf-pwm.html#dtbinding-nordic-nrf-pwm. I've included a screen shot below.
I was looking for what pwms means, and one can observe that "pwms" appears nowhere on this page. In the section "#pwm-cells" it mentions that it is a definition for the pwm specifier number of cells, so I assume that "pwms" is short for "pwm specifier" and to understand what is in those cells you have to look at what is basically an unlinked foot note that does not contain the name "pwms" or "PWM specifier" but only "Specifier Cell names". So am I correct in my assumption that this is the definition of what should be in the "pwms" cells? One last source of confusion is in "pwms" there appears to be 4 cells instead of 3 because the &pwm0  is another name. It has been my assumption that is does not count as a cell because it is a tag as opposed to the other 3 being settings for that tagged device. So if my assumptions are correct, the tag is the PWM module being modified (&pwm0). The first cell is the channel being used within that module (channel 0). The second cell is the period for the pwm (20ns). The third and final cell is whether or not to invert that pwm channel (inverted in the sample). Is my understanding correct?
Next I would like to look at the pinctrl part of the devicetree.
		group1 {
			nordic,invert;
		group1 {
			low-power-enable;
		group1 {
			nordic,invert;
		group1 {
			low-power-enable;
From what I understand is allows the user to configure alternative configurations. I'm not yet sure how I would select on configuration or the other, but from the examples I have looked at I see a default and a sleep configuration. I believe the name links it to the actual peripherial (pwm0_default -> pwm0 in normal operation and pwm0_sleep -> pwm0 in sleep mode). I'm not really clear what "group1" accomplishes but it's in the examples. I think that "low-power-enable" and "nordic,invert" are tags that actually define how to interpret the information, but I believe "psels" is where the important stuff happens.
After some searching I found this: https://docs.zephyrproject.org/latest/build/dts/api/bindings/pinctrl/nordic%2Cnrf-pinctrl.html#dtbinding-nordic-nrf-pinctrl and it show some example code for a simple GPIO setup. It did provide a reference to this:
Available pin functions can be found in the
include/zephyr/dt-bindings/pinctrl/nrf-pinctrl.h header file.
After a bit of digging I found it:
 * @brief Utility macro to build nRF psels property entry.
 * @param fun Pin function configuration (see NRF_FUNC_{name} macros).
 * @param port Port (0 or 1).
 * @param pin Pin (0..31).
#define NRF_PSEL(fun, port, pin)						       \
	((((((port) * 32U) + (pin)) & NRF_PIN_MSK) << NRF_PIN_POS) |		       \
	 ((NRF_FUN_ ## fun & NRF_FUN_MSK) << NRF_FUN_POS))
Now I know the fields, mostly. port an pin is straighforward. They are the port and pin values used to output to a pin. On my nRF52832 there is only port 0 (as opposed the thenRF52840 that had port 0 and 1), so it is simply setting the port number to 0 and the pin to match my output pin. The field "fun" is much more vague:
/** PWM OUT0 */
#define NRF_FUN_PWM_OUT0 22U
/** PWM OUT1 */
#define NRF_FUN_PWM_OUT1 23U
/** PWM OUT2 */
#define NRF_FUN_PWM_OUT2 24U
/** PWM OUT3 */
#define NRF_FUN_PWM_OUT3 25U
Just a ways above the NRF_PSEL() macro you can find the definitions, but what is an "out"? My guess is that it is the channel since there are 4 channels poer module, but the are 4 modules in the nRF52840 (I think that there are only 3 in the nRF52832). This nrf_pinctrl.h finle I am guessing is used for all nrf devices and it does not say clearly if this is for the channel, module or something else entirely. In the devicetree pwm0 I think tags the module. There is a pwm1 that I am trying to use as well. I think in pinctrl pwm0_default tags the module. But I thought that I already set the channel in the device tress in the pwms cells? SO it looks like it goes in two places, but maybe the pinctrl module overrides the devicetree defined one? I am not sure, but for now I am defining channel 0 in the devicetree and "NRF_FUN_PWM_OUT0" in pinctrl. What is best for here?
Now how does this all work when I compile and flash? It does not. The device runs, but there is not PWM output. I call "pwm_set_pulse_dt()" with a test period of one quarter the period and I see no output. I have pwm loggin on and see this output:
[00:00:00.280,639] <dbg> pwm_nrfx: pwm_nrfx_set_cycles: channel 0, pulse 80000, period 320000, prescaler: 4.
I did a similar hack as what I did to the buttons and I can get the different channels to report in the logging, but only for PWM0, but still no light output. So I dig into devicetree_generated.h.
I found that for all 7 PWMs that I setup, they all are set to channel 0 and only PWM0 seems to be used. That include the ones I setup up using &pwm1. PWM0 is at address 0x4001c000, and PWM1 is at 0x40021000. I've included definitions for channel 3 of pwm1 below:
 * Devicetree node: /pwmleds/pwm_led_6
 * Node identifier: DT_N_S_pwmleds_S_pwm_led_6
#define DT_N_S_pwmleds_S_pwm_led_6_PATH "/pwmleds/pwm_led_6"
#define DT_N_S_pwmleds_S_pwm_led_6_FULL_NAME "pwm_led_6"
/* Node parent (/pwmleds) identifier: */
#define DT_N_S_pwmleds_S_pwm_led_6_PARENT DT_N_S_pwmleds
#define DT_N_S_pwmleds_S_pwm_led_6_CHILD_IDX 6
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD(fn)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_SEP(fn, sep)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_VARGS(fn, ...)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_SEP_VARGS(fn, sep, ...)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_STATUS_OKAY(fn)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_STATUS_OKAY_SEP(fn, sep)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_STATUS_OKAY_VARGS(fn, ...)
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_CHILD_STATUS_OKAY_SEP_VARGS(fn, sep, ...)
#define DT_N_S_pwmleds_S_pwm_led_6_ORD 61
#define DT_N_S_pwmleds_S_pwm_led_6_REQUIRES_ORDS \
	53, /* /pwmleds */ \
	54, /* /soc/pwm@4001c000 */
#define DT_N_S_pwmleds_S_pwm_led_6_SUPPORTS_ORDS /* nothing */
#define DT_N_S_pwmleds_S_pwm_led_6_EXISTS 1
#define DT_N_ALIAS_pwm_led6     DT_N_S_pwmleds_S_pwm_led_6
#define DT_N_NODELABEL_pwm_led6 DT_N_S_pwmleds_S_pwm_led_6
#define DT_N_S_pwmleds_S_pwm_led_6_REG_NUM 0
#define DT_N_S_pwmleds_S_pwm_led_6_RANGES_NUM 0
#define DT_N_S_pwmleds_S_pwm_led_6_FOREACH_RANGE(fn)
#define DT_N_S_pwmleds_S_pwm_led_6_IRQ_NUM 0
#define DT_N_S_pwmleds_S_pwm_led_6_STATUS_okay 1
#define DT_N_S_pwmleds_S_pwm_led_6_PINCTRL_NUM 0
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_EXISTS 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_PH DT_N_S_soc_S_pwm_4001c000
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_channel 0
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_channel_EXISTS 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_period 20000000
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_period_EXISTS 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_flags 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_IDX_0_VAL_flags_EXISTS 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_FOREACH_PROP_ELEM(fn) fn(DT_N_S_pwmleds_S_pwm_led_6, pwms, 0)
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_pwmleds_S_pwm_led_6, pwms, 0)
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_pwmleds_S_pwm_led_6, pwms, 0, __VA_ARGS__)
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_pwmleds_S_pwm_led_6, pwms, 0, __VA_ARGS__)
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_LEN 1
#define DT_N_S_pwmleds_S_pwm_led_6_P_pwms_EXISTS 1
I can see the correct period is set, but channel 0 is set when it should be set to channel 2. You can also see that it references the address 0x4001c000 erroneously instead of 0x40021000 for PWM1. I see no refeneces to pwm1_default and I do not see any pinctrl refeneces to the pins I defined for the pwm outputs.
What I see is something is wrong with the inperpretation of my device tree into the devicetree_generated.h file. I could be misunderstadning a lot since I have made several assumptions along the way. Please correct my assumptions and help me understand how to generate the correct devicetree header.
  • I can't remember why I eliminated the NFC setting at the issue, but I do see in devicetree_generated.h that it looks like there are flags set to disable it.
     * Devicetree node: /soc/nfct@40005000
     * Node identifier: DT_N_S_soc_S_nfct_40005000
     * Binding (compatible = nordic,nrf-nfct):
     *   $ZEPHYR_BASE\dts\bindings\net\wireless\nordic,nrf-nfct.yaml
    #define DT_N_S_soc_S_nfct_40005000_PATH "/soc/nfct@40005000"
    #define DT_N_S_soc_S_nfct_40005000_FULL_NAME "nfct@40005000"
    /* Node parent (/soc) identifier: */
    #define DT_N_S_soc_S_nfct_40005000_PARENT DT_N_S_soc
    #define DT_N_S_soc_S_nfct_40005000_CHILD_IDX 14
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD(fn)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_SEP(fn, sep)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_VARGS(fn, ...)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_SEP_VARGS(fn, sep, ...)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_STATUS_OKAY(fn)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_STATUS_OKAY_SEP(fn, sep)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_STATUS_OKAY_VARGS(fn, ...)
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_CHILD_STATUS_OKAY_SEP_VARGS(fn, sep, ...)
    #define DT_N_S_soc_S_nfct_40005000_ORD 81
    #define DT_N_S_soc_S_nfct_40005000_REQUIRES_ORDS \
    	4, /* /soc */ \
    	5, /* /soc/interrupt-controller@e000e100 */
    #define DT_N_S_soc_S_nfct_40005000_SUPPORTS_ORDS /* nothing */
    #define DT_N_S_soc_S_nfct_40005000_EXISTS 1
    #define DT_N_INST_0_nordic_nrf_nfct DT_N_S_soc_S_nfct_40005000
    #define DT_N_NODELABEL_nfct         DT_N_S_soc_S_nfct_40005000
    #define DT_N_S_soc_S_nfct_40005000_REG_NUM 1
    #define DT_N_S_soc_S_nfct_40005000_REG_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_REG_IDX_0_VAL_ADDRESS 1073762304 /* 0x40005000 */
    #define DT_N_S_soc_S_nfct_40005000_REG_IDX_0_VAL_SIZE 4096 /* 0x1000 */
    #define DT_N_S_soc_S_nfct_40005000_RANGES_NUM 0
    #define DT_N_S_soc_S_nfct_40005000_FOREACH_RANGE(fn)
    #define DT_N_S_soc_S_nfct_40005000_IRQ_NUM 1
    #define DT_N_S_soc_S_nfct_40005000_IRQ_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_IRQ_IDX_0_VAL_irq 5
    #define DT_N_S_soc_S_nfct_40005000_IRQ_IDX_0_VAL_irq_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_IRQ_IDX_0_VAL_priority 1
    #define DT_N_S_soc_S_nfct_40005000_IRQ_IDX_0_VAL_priority_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_COMPAT_MATCHES_nordic_nrf_nfct 1
    #define DT_N_S_soc_S_nfct_40005000_COMPAT_VENDOR_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_COMPAT_VENDOR_IDX_0 "Nordic Semiconductor"
    #define DT_N_S_soc_S_nfct_40005000_COMPAT_MODEL_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_COMPAT_MODEL_IDX_0 "nrf-nfct"
    #define DT_N_S_soc_S_nfct_40005000_STATUS_disabled 1
    #define DT_N_S_soc_S_nfct_40005000_PINCTRL_NUM 0
    #define DT_N_S_soc_S_nfct_40005000_P_reg {1073762304 /* 0x40005000 */, 4096 /* 0x1000 */}
    #define DT_N_S_soc_S_nfct_40005000_P_reg_IDX_0 1073762304
    #define DT_N_S_soc_S_nfct_40005000_P_reg_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_reg_IDX_1 4096
    #define DT_N_S_soc_S_nfct_40005000_P_reg_IDX_1_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_reg_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_nfct_40005000, reg, 0) \
    	fn(DT_N_S_soc_S_nfct_40005000, reg, 1)
    #define DT_N_S_soc_S_nfct_40005000_P_reg_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_nfct_40005000, reg, 0) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_reg_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_nfct_40005000, reg, 0, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, reg, 1, __VA_ARGS__)
    #define DT_N_S_soc_S_nfct_40005000_P_reg_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_nfct_40005000, reg, 0, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_reg_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts {5 /* 0x5 */, 1 /* 0x1 */}
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_IDX_0 5
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_IDX_1 1
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_IDX_1_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_nfct_40005000, interrupts, 0) \
    	fn(DT_N_S_soc_S_nfct_40005000, interrupts, 1)
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_nfct_40005000, interrupts, 0) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_nfct_40005000, interrupts, 0, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, interrupts, 1, __VA_ARGS__)
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_nfct_40005000, interrupts, 0, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_interrupts_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_status "disabled"
    #define DT_N_S_soc_S_nfct_40005000_P_status_STRING_TOKEN disabled
    #define DT_N_S_soc_S_nfct_40005000_P_status_STRING_UPPER_TOKEN DISABLED
    #define DT_N_S_soc_S_nfct_40005000_P_status_ENUM_IDX 2
    #define DT_N_S_soc_S_nfct_40005000_P_status_ENUM_TOKEN disabled
    #define DT_N_S_soc_S_nfct_40005000_P_status_ENUM_UPPER_TOKEN DISABLED
    #define DT_N_S_soc_S_nfct_40005000_P_status_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_nfct_40005000, status, 0) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 1) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 2) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 3) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 4) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 5) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 6) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 7)
    #define DT_N_S_soc_S_nfct_40005000_P_status_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_nfct_40005000, status, 0) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 1) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 2) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 3) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 4) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 5) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 6) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_status_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_nfct_40005000, status, 0, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 1, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 2, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 3, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 4, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 5, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 6, __VA_ARGS__) \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 7, __VA_ARGS__)
    #define DT_N_S_soc_S_nfct_40005000_P_status_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_nfct_40005000, status, 0, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 1, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 2, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 3, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 4, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 5, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    	fn(DT_N_S_soc_S_nfct_40005000, status, 6, __VA_ARGS__) DT_DEBRACKET_INTERNAL sep \
    #define DT_N_S_soc_S_nfct_40005000_P_status_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_compatible {"nordic,nrf-nfct"}
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_IDX_0 "nordic,nrf-nfct"
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_IDX_0_STRING_TOKEN nordic_nrf_nfct
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_IDX_0_STRING_UPPER_TOKEN NORDIC_NRF_NFCT
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_IDX_0_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_nfct_40005000, compatible, 0)
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_nfct_40005000, compatible, 0)
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_nfct_40005000, compatible, 0, __VA_ARGS__)
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_nfct_40005000, compatible, 0, __VA_ARGS__)
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_LEN 1
    #define DT_N_S_soc_S_nfct_40005000_P_compatible_EXISTS 1
    #define DT_N_S_soc_S_nfct_40005000_P_wakeup_source 0
    #define DT_N_S_soc_S_nfct_40005000_P_wakeup_source_EXISTS 1
    The line that I think should make the difference is "#define DT_N_S_soc_S_nfct_40005000_STATUS_disabled 1" so it appears to be disabled.
    As a note , this is a custom board definition and I'm planning on attending the webinar later today on the subject of building custom boards. I the end, I expect it to be a syntax error on my part in the devicetree, but I just don't see it yet.
    Concerning the PWM channels, right not I have just a single call to select a output level that is set once, so I can verify that I have it working. Since I am using a custom board, the pins are different than the ones in the developer kit board for the nRF52832. The issue I see so far with them is that devicetree_generated.h does not seem to correctly reflect the devicetree I setup. Only PWM0 is used and the channels are not as set. Unfortunately there is not a lot off error checking in the devicetree toolchain so my issues fail silently without giving me very many clues as to where the issue lies.
  • Hi again Ryjan
    You should still set the CONFIG_NFCT_PINS_AS_GPIOS=y in your NCS version, as this is the correct way to set NFCT pins as GPIOs in most nRF Connect SDK versions.
    Unfortunately I don't have much more to add to the PWM issue either, but let me know how the webinar went and whether or not it helped at all. I don't see what's set up incorrectly I'm afraid but will discuss this with a few colleagues to see if they have any suggestions on this as well. Do you have a Development Kit available, and if so do you also see the same issue with the PWMs there as well?
    One thing could be to try using the nRF DeviceTree extension in VS code to get a better view of what is enabled and not in your project. It gives a more user friendly display (GUI style) of the device tree and makes it easier to keep track of.
    Simon
  • I think I've found the cause. Once I get a solution going I'll report back. As expected it looks like a something that I've missed, but this chat has helped me arrive at that conclusion.
  • The short version of my issue is I had another copy of my device tree in a location where West could find it, but the one I was editing was not the correct one.
    This came from several attempts at getting this working while being pulled off onto a different project daily. I had the device tree that I was editing in the project root under boards/ but the one the West could find was a temporary version I put in the Zephyr boards/ directory. That is why my pullups were all set to up for the GPIOs and even the pin number were incorrect. None of the PWM changes I made were changes to the correct file. I found this after using Nordic's graphical tool for the device tree and noted that it was opening the copy I was not editing.
    This brought me back to the issue I hadn't solved, but had forgotten about. I want to use an out of tree board definition. The seminar showed a couple of different ways to do it in NCS:
    I've opted to use something that works for regular Zephyr by adding a few lines to my CMakeLists.txt file:
    # BOARD_ROOT and BOARD need to be defined before finding Zephyr so the definitions are available before compilation
    set(BOARD_ROOT ${CMAKE_CURRENT_SOURCE_DIR})
    set(BOARD smrtsw_v1_2)
    I inserted this before
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    After that line is too late to define the BOARD_ROOT and BOARD.
    By including the BOARD I no longer need to define on the command line if just using West and the code is easier for me to keep in one repo and distribute to my coworkers.
    Now the device tree is at least referenced correctly, but I haven't gotten the code to run because there is an issue with the UART initialization. I had to include "zephyr,bt-uart = &uart0" in the chosen section of the device tree to allow it finish compiling, but I didn't need or have that before. I don't think my project needs the UART even for the RTT. Is that correct? Getting rid of all references to the UART in my device tree also does not make it happy. I found
    # enable uart driver
    CONFIG_SERIAL=y
    # enable console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    But even when disabling those my project still thinks I need UART stuff compiled to run. When I include all of that I get an initialization assert on line 330 of hci_init because a semaphore times out during initialization. It appears to be just the first bt_hci_cmd_send_sync() call to preform a reset. Seem logical for starting up the system the host controller for the Bluetooth. I was guessing that my addition of bt-uart was messing up the initialization because I don't have some other dependency initialized for the bt-uart. However, I don't think that I need any of that. So where else could something be asking for the uart to be setup. I would like to not include it. Am I correct that I do not need the UART to be initialized  to have a working RTT console?
  • I just found an error I thought I had corrected 3 times already, but I must have deleted that changes. In my board definition file  Kconfig.defconfig I had my board defined as BOARD_CONFIG_BOARD_SMRTSW_V1_2 instead of BOARD_SMRTSW_V1_2. I'm not sure why it gave me the error it did. I'm guessing that it silently defaults to some other settings and ended up wanting to initialize a bunch of UART features. After fixing that, it compiled and ran. I saw my LEDs illuminate for the first time.
