Hello everyone,
i'm having some issues on configurate the BMI270 sensor using nrf52840 dongle's twi interface. The initialization process includes a burst writing of a configuration file of 8Kbytes dimension on a single register of the sensor, due to limitation of writing buffer i have implemented a custom function to repeat transfer on twi for every byte in the same register. Here are the codes for init and main:
//custom function to write in BMI's registers
bool BMI270_register_write(uint8_t register_address , uint8_t value)
ret_code_t err_code;
uint8_t tx_buff[BMI2_ADDRESS_LEN+1];
tx_buff[0]=register_address;
tx_buff[1]=value;
m_xfer_done=false;
//transimt data
err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,tx_buff,BMI2_ADDRESS_LEN+1,false);
while(m_xfer_done==false)
if(err_code != NRF_SUCCESS)
return false;
return true;
bool BMI270_init(void)
bool init_succ=true;
//following datasheet
if(!BMI270_verify_product_id())
init_succ=false;
if(!BMI270_register_write(0x7C,0x00))
init_succ=false;
nrf_delay_us(800);
if(!BMI270_register_write(0x59,0x00))
init_succ=false;
if(!BMI270_conf_file_init())
init_succ=false;
while(BMI270_conf_file_init())
if(!BMI270_register_write(0x59,0x01)){
init_succ=false;// it seems that this function returns false
return init_succ;
// custom function to burst write in the 0x5e register the config file
bool BMI270_conf_file_init(void)
uint8_t buff[2];
int a;
for(a=0;a<(sizeof(bmi270_context_config_file)-1);a++)
buff[0]=0x5E;
buff[1]=bmi270_context_config_file[a];
err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,buff,2,false);
while(m_xfer_done==false){}
return false;
buff[0]=0x5E;
buff[1]=bmi270_context_config_file[sizeof(bmi270_context_config_file)-1];
return false;
return true;
Here is the config file:
uint8_t bmi270_context_config_file[] = {
0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0x00, 0xb0, 0xc8, 0x2e, 0x00, 0x2e, 0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0xc9,
0x01, 0x80, 0x2e, 0xe2, 0x00, 0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0x77, 0xb0, 0x50, 0x30, 0x21, 0x2e, 0x59, 0xf5,
0x10, 0x30, 0x21, 0x2e, 0x6a, 0xf5, 0x80, 0x2e, 0xaf, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x09, 0x01, 0x00, 0x22,
0x00, 0x76, 0x00, 0x00, 0x10, 0x00, 0x10, 0xd1, 0x00, 0xcb, 0xa7, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1,
0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00,
0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e,
0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80,
0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1,
0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0xfd, 0x2d, 0x2c, 0x56, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x02, 0x08, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x04, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1a, 0x24, 0x22, 0x00, 0x80, 0x2e, 0x48, 0x02, 0x01, 0x2e, 0x49,
0xf1, 0x0b, 0xbc, 0x10, 0x50, 0x0f, 0xb8, 0x00, 0x90, 0xfb, 0x7f, 0x07, 0x2f, 0x03, 0x2e, 0x21, 0xf2, 0x02, 0x31,
0x4a, 0x0a, 0x23, 0x2e, 0x21, 0xf2, 0x09, 0x2c, 0x00, 0x30, 0x98, 0x2e, 0x0e, 0xc7, 0x03, 0x2e, 0x21, 0xf2, 0xf2,
0x3e, 0x4a, 0x08, 0x23, 0x2e, 0x21, 0xf2, 0xfb, 0x6f, 0xf0, 0x5f, 0xb8, 0x2e, 0x13, 0x52, 0x00, 0x2e, 0x60, 0x40,
0x41, 0x40, 0x0d, 0xbc, 0x98, 0xbc, 0xc0, 0x2e, 0x01, 0x0a, 0x0f, 0xb8, 0x43, 0x86, 0x25, 0x40, 0x04, 0x40, 0xd8,
0xbe, 0x2c, 0x0b, 0x22, 0x11, 0x54, 0x42, 0x03, 0x80, 0x4b, 0x0e, 0xf6, 0x2f, 0xb8, 0x2e, 0x20, 0x50, 0xe7, 0x7f,
0xf6, 0x7f, 0x46, 0x30, 0x0f, 0x2e, 0xa4, 0xf1, 0xbe, 0x09, 0x80, 0xb3, 0x06, 0x2f, 0x0d, 0x2e, 0x84, 0x00, 0x84,
0xaf, 0x02, 0x2f, 0x16, 0x30, 0x2d, 0x2e, 0x7b, 0x00, 0x86, 0x30, 0x2d, 0x2e, 0x60, 0xf5, 0xf6, 0x6f, 0xe7, 0x6f,
0xe0, 0x5f, 0xc8, 0x2e, 0x80, 0x2e, 0xfb, 0x00, 0x00, 0x30, 0xc0, 0x2e, 0x21, 0x2e, 0x8d, 0x00, 0x44, 0x47, 0x99,
0x00, 0xff, 0x3f, 0x00, 0x0c, 0xff, 0x0f, 0x00, 0x04, 0xc0, 0x00, 0x5b, 0xf5, 0x90, 0x00, 0x1e, 0xf2, 0xfd, 0xf5,
0x8e, 0x00, 0x96, 0x00, 0x96, 0x00, 0xe0, 0x00, 0x19, 0xf4, 0x66, 0xf5, 0x00, 0x18, 0x64, 0xf5, 0x9d, 0x00, 0x7f,
0x00, 0x81, 0x00, 0xae, 0x00, 0xff, 0xfb, 0x21, 0x02, 0x00, 0x10, 0x00, 0x40, 0xff, 0x00, 0x00, 0x80, 0xff, 0x7f,
0x54, 0x0f, 0xeb, 0x00, 0x7f, 0xff, 0xc2, 0xf5, 0x68, 0xf7, 0xb3, 0xf1, 0x4e, 0x0f, 0x42, 0x0f, 0x48, 0x0f, 0x80,
0x00, 0x67, 0x0f, 0x58, 0xf7, 0x5b, 0xf7, 0x6a, 0x0f, 0x86, 0x00, 0x59, 0x0f, 0x6c, 0x0f, 0xc6, 0xf1, 0x66, 0x0f,
0x6c, 0xf7, 0x00, 0xe0, 0x00, 0xff, 0xd1, 0xf5, 0x6e, 0x0f, 0x71, 0x0f, 0xff, 0x03, 0x00, 0xfc, 0xf0, 0x3f, 0xb9,
0x00, 0x2d, 0xf5, 0xca, 0xf5, 0x8a, 0x00, 0x00, 0x08, 0x71, 0x7d, 0xfe, 0xc0, 0x03, 0x3f, 0x05, 0x3e, 0x49, 0x01,
0x92, 0x02, 0xf5, 0xd6, 0xe8, 0x63, 0xd3, 0xf8, 0x2e, 0x07, 0x5c, 0xce, 0xa5, 0x67, 0x28, 0x02, 0x4e, 0x01, 0x00,
0xf0, 0x33, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x15, 0x50, 0x10,
0x50, 0x17, 0x52, 0x05, 0x2e, 0x7d, 0x00, 0xfb, 0x7f, 0x00, 0x2e, 0x13, 0x40, 0x93, 0x42, 0x41, 0x0e, 0xfb, 0x2f,
0x98, 0x2e, 0x91, 0x03, 0x98, 0x2e, 0x87, 0xcf, 0x01, 0x2e, 0x89, 0x00, 0x00, 0xb2, 0x08, 0x2f, 0x01, 0x2e, 0x69,
0xf7, 0xb1, 0x3f, 0x01, 0x08, 0x01, 0x30, 0x23, 0x2e, 0x89, 0x00, 0x21, 0x2e, 0x69, 0xf7, 0xfb, 0x6f, 0xf0, 0x5f,
0xb8, 0x2e, 0xa0, 0x50, 0x80, 0x7f, 0xe7, 0x7f, 0xd5, 0x7f, 0xc4, 0x7f, 0xb3, 0x7f, 0xa2, 0x7f, 0x91, 0x7f, 0xf6,
0x7f, 0x7b, 0x7f, 0x00, 0x2e, 0x01, 0x2e, 0x60, 0xf5, 0x60, 0x7f, 0x98, 0x2e, 0xce, 0x00, 0x62, 0x6f, 0x01, 0x32,
0x91, 0x08, 0x80, 0xb2, 0x11, 0x2f, 0x00, 0xb2, 0x03, 0x2f, 0x05, 0x2e, 0x18, 0x00, 0x80, 0x90, 0x09, 0x2f, 0x60,
0x7f, 0x98, 0x2e, 0xf9, 0x00, 0x23, 0x50, 0x01, 0x32, 0x01, 0x42, 0x02, 0x86, 0x60, 0x6f, 0x02, 0x30, 0xc2, 0x42,
0x23, 0x2e, 0x60, 0xf5, 0x00, 0x90, 0x00, 0x30, 0x01, 0x2f, 0x21, 0x2e, 0x7a, 0x00, 0xf6, 0x6f, 0x91, 0x6f, 0xa2,
0x6f, 0xb3, 0x6f, 0xc4, 0x6f, 0xd5, 0x6f, 0xe7, 0x6f, 0x7b, 0x6f, 0x80, 0x6f, 0x60, 0x5f, 0xc8, 0x2e, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2d, 0x01, 0xd4, 0x7b, 0x3b,
0x01, 0xdb, 0x7a, 0x04, 0x00, 0x3f, 0x7b, 0xcd, 0x6c, 0xc3, 0x04, 0x85, 0x09, 0xc3, 0x04, 0xec, 0xe6, 0x0c, 0x46,
0x01, 0x00, 0x27, 0x00, 0x19, 0x00, 0x96, 0x00, 0xa0, 0x00, 0x01, 0x00, 0x0c, 0x00, 0xf0, 0x3c, 0x00, 0x01, 0x01,
0x00, 0x03, 0x00, 0x01, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x01, 0x00, 0x07, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0x00, 0xe1, 0x06, 0x66, 0x0a, 0x0a, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x50, 0x98, 0x2e, 0xd7, 0x0e, 0x50, 0x32, 0x98, 0x2e,
0x48, 0x03, 0x10, 0x30, 0x21, 0x2e, 0x21, 0xf2, 0x00, 0x30, 0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0x00, 0x2e, 0x01,
0x80, 0x06, 0xa2, 0xfb, 0x2f, 0x01, 0x2e, 0x9c, 0x00, 0x00, 0xb2, 0x10, 0x2f, 0x01, 0x2e, 0x18, 0x00, 0x00, 0xb2,
0x0c, 0x2f, 0x01, 0x54, 0x03, 0x52, 0x01, 0x50, 0x98, 0x2e, 0xc2, 0xc0, 0x98, 0x2e, 0xf5, 0xb0, 0x01, 0x50, 0x98,
0x2e, 0xd5, 0xb6, 0x10, 0x30, 0x21, 0x2e, 0x19, 0x00, 0x01, 0x2e, 0x84, 0x00, 0x04, 0xae, 0x0b, 0x2f, 0x01, 0x2e,
0x9c, 0x00, 0x00, 0xb2, 0x07, 0x2f, 0x01, 0x52, 0x98, 0x2e, 0x8e, 0x0e, 0x00, 0xb2, 0x02, 0x2f, 0x10, 0x30, 0x21,
0x2e, 0x79, 0x00, 0x01, 0x2e, 0x79, 0x00, 0x00, 0x90, 0x90, 0x2e, 0x14, 0x03, 0x01, 0x2e, 0x87, 0x00, 0x00, 0xb2,
0x04, 0x2f, 0x98, 0x2e, 0x2f, 0x0e, 0x00, 0x30, 0x21, 0x2e, 0x7b, 0x00, 0x01, 0x2e, 0x7b, 0x00, 0x00, 0xb2, 0x12,
0x2f, 0x01, 0x2e, 0x84, 0x00, 0x00, 0x90, 0x02, 0x2f, 0x98, 0x2e, 0x1f, 0x0e, 0x09, 0x2d, 0x98, 0x2e, 0x81, 0x0d,
0x01, 0x2e, 0x84, 0x00, 0x04, 0x90, 0x02, 0x2f, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x00, 0x30, 0x21, 0x2e, 0x7b,
0x00, 0x01, 0x2e, 0x78, 0x00, 0x00, 0xb2, 0x90, 0x2e, 0x2c, 0x03, 0x01, 0x2e, 0x78, 0x00, 0x81, 0x30, 0x01, 0x08,
0x00, 0xb2, 0x61, 0x2f, 0x03, 0x2e, 0x24, 0x02, 0x01, 0x2e, 0x84, 0x00, 0x98, 0xbc, 0x98, 0xb8, 0x05, 0xb2, 0x0d,
0x58, 0x23, 0x2f, 0x07, 0x90, 0x07, 0x54, 0x00, 0x30, 0x37, 0x2f, 0x15, 0x41, 0x04, 0x41, 0xdc, 0xbe, 0x44, 0xbe,
0xdc, 0xba, 0x2c, 0x01, 0x61, 0x00, 0x0d, 0x56, 0x4a, 0x0f, 0x0c, 0x2f, 0xd1, 0x42, 0x94, 0xb8, 0xc1, 0x42, 0x11,
0x30, 0x05, 0x2e, 0x6a, 0xf7, 0x2c, 0xbd, 0x2f, 0xb9, 0x80, 0xb2, 0x08, 0x22, 0x98, 0x2e, 0xaf, 0x03, 0x21, 0x2d,
0x61, 0x30, 0x23, 0x2e, 0x84, 0x00, 0x98, 0x2e, 0xaf, 0x03, 0x00, 0x30, 0x21, 0x2e, 0x5a, 0xf5, 0x18, 0x2d, 0xf1,
0x7f, 0x50, 0x30, 0x98, 0x2e, 0x48, 0x03, 0x0d, 0x52, 0x05, 0x50, 0x50, 0x42, 0x70, 0x30, 0x0b, 0x54, 0x42, 0x42,
0x7e, 0x82, 0xf2, 0x6f, 0x80, 0xb2, 0x42, 0x42, 0x05, 0x2f, 0x21, 0x2e, 0x84, 0x00, 0x10, 0x30, 0x98, 0x2e, 0xaf,
0x03, 0x03, 0x2d, 0x60, 0x30, 0x21, 0x2e, 0x84, 0x00, 0x01, 0x2e, 0x84, 0x00, 0x06, 0x90, 0x18, 0x2f, 0x01, 0x2e,
0x77, 0x00, 0x09, 0x54, 0x05, 0x52, 0xf0, 0x7f, 0x98, 0x2e, 0x7a, 0xc1, 0xf1, 0x6f, 0x08, 0x1a, 0x40, 0x30, 0x08,
0x2f, 0x21, 0x2e, 0x84, 0x00, 0x20, 0x30, 0x98, 0x2e, 0x9b, 0x03, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x05, 0x2d,
0x98, 0x2e, 0x38, 0x0e, 0x00, 0x30, 0x21, 0x2e, 0x84, 0x00, 0x00, 0x30, 0x21, 0x2e, 0x78, 0x00, 0x18, 0x2d, 0x01,
0x2e, 0x84, 0x00, 0x03, 0xaa, 0x01, 0x2f, 0x98, 0x2e, 0x45, 0x0e, 0x01, 0x2e, 0x84, 0x00, 0x3f, 0x80, 0x03, 0xa2,
0x01, 0x2f, 0x00, 0x2e, 0x02, 0x2d, 0x98, 0x2e, 0x5b, 0x0e, 0x30, 0x30, 0x98, 0x2e, 0xba, 0x03, 0x00, 0x30, 0x21,
0x2e, 0x79, 0x00, 0x50, 0x32, 0x98, 0x2e, 0x48, 0x03, 0x01, 0x2e, 0x19, 0x00, 0x00, 0xb2, 0x10, 0x2f, 0x01, 0x2e,
0x85, 0x00, 0x21, 0x2e, 0x90, 0x00, 0x0f, 0x52, 0x7e, 0x82, 0x11, 0x50, 0x41, 0x40, 0x18, 0xb9, 0x11, 0x42, 0x02,
0x42, 0x02, 0x80, 0x00, 0x2e, 0x01, 0x40, 0x01, 0x42, 0x98, 0x2e, 0xaa, 0x01, 0x00, 0x30, 0x21, 0x2e, 0x19, 0x00,
0x21, 0x2e, 0x9c, 0x00, 0x80, 0x2e, 0x52, 0x02, 0x21, 0x2e, 0x59, 0xf5, 0x10, 0x30, 0xc0, 0x2e, 0x21, 0x2e, 0x4a,
0xf1, 0x80, 0x2e, 0x00, 0xc1, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9a, 0x01,
0x34, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0x2e, 0x7d, 0x00, 0x16, 0xb8, 0x02, 0x34, 0x4a, 0x0c, 0x21, 0x2e, 0x2d, 0xf5, 0xc0, 0x2e, 0x23,
0x2e, 0x7d, 0x00, 0x03, 0xbc, 0x21, 0x2e, 0x85, 0x00, 0x03, 0x2e, 0x85, 0x00, 0x40, 0xb2, 0x10, 0x30, 0x21, 0x2e,
0x19, 0x00, 0x01, 0x30, 0x05, 0x2f, 0x05, 0x2e, 0x88, 0x00, 0x80, 0x90, 0x01, 0x2f, 0x23, 0x2e, 0x6f, 0xf5, 0xc0,
0x2e, 0x21, 0x2e, 0x89, 0x00, 0x11, 0x30, 0x81, 0x08, 0x01, 0x2e, 0x6a, 0xf7, 0x71, 0x3f, 0x23, 0xbd, 0x01, 0x08,
0x02, 0x0a, 0xc0, 0x2e, 0x21, 0x2e, 0x6a, 0xf7, 0x30, 0x25, 0x00, 0x30, 0x21, 0x2e, 0x5a, 0xf5, 0x10, 0x50, 0x21,
0x2e, 0x7b, 0x00, 0x21, 0x2e, 0x78, 0x00, 0xfb, 0x7f, 0x98, 0x2e, 0xaf, 0x03, 0x40, 0x30, 0x21, 0x2e, 0x84, 0x00,
0xfb, 0x6f, 0xf0, 0x5f, 0x03, 0x25, 0x80, 0x2e, 0x9b, 0x03, 0x0b, 0x00, 0x94, 0x02, 0x14, 0x24, 0x80, 0x00, 0x04,
0x00, 0x04, 0x30, 0x08, 0xb8, 0x94, 0x02, 0xc0, 0x2e, 0x28, 0xbd, 0x02, 0x0a, 0x0d, 0x82, 0x02, 0x30, 0x12, 0x42,
0x41, 0x0e, 0xfc, 0x2f, 0xb8, 0x2e, 0x95, 0x50, 0xc0, 0x2e, 0x21, 0x2e, 0xa9, 0x01, 0x02, 0x30, 0x02, 0x2c, 0x41,
0x00, 0x12, 0x42, 0x41, 0x0e, 0xfc, 0x2f, 0xb8, 0x2e, 0x13, 0x82, 0x02, 0x30, 0x12, 0x42, 0x41, 0x0e, 0xfc, 0x2f,
0x3f, 0x80, 0xa1, 0x30, 0xc0, 0x2e, 0x01, 0x42, 0x00, 0x2e, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80,
0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0xc0, 0x50, 0xe7, 0x7f,
0xf6, 0x7f, 0x26, 0x30, 0x0f, 0x2e, 0x61, 0xf5, 0x2f, 0x2e, 0x78, 0x00, 0x0f, 0x2e, 0x78, 0x00, 0xbe, 0x09, 0xa2,
0x7f, 0x80, 0x7f, 0x80, 0xb3, 0xd5, 0x7f, 0xc4, 0x7f, 0xb3, 0x7f, 0x91, 0x7f, 0x7b, 0x7f, 0x0b, 0x2f, 0x19, 0x50,
0x1a, 0x25, 0x12, 0x40, 0x42, 0x7f, 0x74, 0x82, 0x12, 0x40, 0x52, 0x7f, 0x00, 0x2e, 0x00, 0x40, 0x60, 0x7f, 0x98,
0x2e, 0x6a, 0xd6, 0x81, 0x30, 0x01, 0x2e, 0x78, 0x00, 0x01, 0x08, 0x00, 0xb2, 0x42, 0x2f, 0x03, 0x2e, 0x24, 0x02,
0x01, 0x2e, 0x24, 0x02, 0x97, 0xbc, 0x06, 0xbc, 0x9f, 0xb8, 0x0f, 0xb8, 0x00, 0x90, 0x23, 0x2e, 0x88, 0x00, 0x10,
0x30, 0x01, 0x30, 0x2a, 0x2f, 0x03, 0x2e, 0x84, 0x00, 0x44, 0xb2, 0x05, 0x2f, 0x47, 0xb2, 0x00, 0x30, 0x2d, 0x2f,
0x21, 0x2e, 0x78, 0x00, 0x2b, 0x2d, 0x03, 0x2e, 0xfd, 0xf5, 0x9e, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x14, 0x2f, 0x03,
0x2e, 0xfc, 0xf5, 0x99, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x0e, 0x2f, 0x03, 0x2e, 0x49, 0xf1, 0x1b, 0x54, 0x4a, 0x08,
0x40, 0x90, 0x08, 0x2f, 0x98, 0x2e, 0xce, 0x00, 0x00, 0xb2, 0x10, 0x30, 0x03, 0x2f, 0x50, 0x30, 0x21, 0x2e, 0x84,
0x00, 0x10, 0x2d, 0x98, 0x2e, 0x9b, 0x03, 0x00, 0x30, 0x21, 0x2e, 0x78, 0x00, 0x0a, 0x2d, 0x05, 0x2e, 0x69, 0xf7,
0x2d, 0xbd, 0x2f, 0xb9, 0x80, 0xb2, 0x01, 0x2f, 0x21, 0x2e, 0x79, 0x00, 0x23, 0x2e, 0x78, 0x00, 0xe0, 0x31, 0x21,
0x2e, 0x61, 0xf5, 0xf6, 0x6f, 0xe7, 0x6f, 0x80, 0x6f, 0xa2, 0x6f, 0xb3, 0x6f, 0xc4, 0x6f, 0xd5, 0x6f, 0x7b, 0x6f,
0x91, 0x6f, 0x40, 0x5f, 0xc8, 0x2e, 0x90, 0x50, 0xf7, 0x7f, 0xe6, 0x7f, 0xd5, 0x7f, 0xc4, 0x7f, 0xb3, 0x7f, 0xa1,
0x7f, 0x90, 0x7f, 0x82, 0x7f, 0x7b, 0x7f, 0x98, 0x2e, 0xce, 0x00, 0x00, 0xb2, 0x10, 0x30, 0x49, 0x2f, 0x05, 0x2e,
0x21, 0x02, 0x03, 0x2e, 0x2d, 0x02, 0x21, 0x56, 0x08, 0x08, 0x93, 0x08, 0x90, 0x0a, 0x25, 0x2e, 0x18, 0x00, 0x05,
0x2e, 0xc1, 0xf5, 0x2e, 0xbc, 0x05, 0x2e, 0x84, 0x00, 0x84, 0xa2, 0x0e, 0xb8, 0x31, 0x30, 0x88, 0x04, 0x03, 0x2f,
0x01, 0x2e, 0x18, 0x00, 0x00, 0xb2, 0x0c, 0x2f, 0x1d, 0x50, 0x01, 0x52, 0x98, 0x2e, 0xd7, 0x00, 0x05, 0x2e, 0x7a,
0x00, 0x80, 0x90, 0x02, 0x2f, 0x10, 0x30, 0x21, 0x2e, 0x7a, 0x00, 0x25, 0x2e, 0x9c, 0x00, 0x05, 0x2e, 0x18, 0x00,
0x80, 0xb2, 0x20, 0x2f, 0x01, 0x2e, 0xc0, 0xf5, 0xf2, 0x30, 0x02, 0x08, 0x07, 0xaa, 0x73, 0x30, 0x03, 0x2e, 0x7c,
0x00, 0x18, 0x22, 0x41, 0x1a, 0x05, 0x2f, 0x03, 0x2e, 0x66, 0xf5, 0x9f, 0xbc, 0x9f, 0xb8, 0x40, 0x90, 0x0c, 0x2f,
0x1f, 0x52, 0x03, 0x30, 0x53, 0x42, 0x2b, 0x30, 0x90, 0x04, 0x5b, 0x42, 0x21, 0x2e, 0x7c, 0x00, 0x24, 0xbd, 0x7e,
0x80, 0x81, 0x84, 0x43, 0x42, 0x02, 0x42, 0x02, 0x32, 0x25, 0x2e, 0x62, 0xf5, 0x05, 0x2e, 0x86, 0x00, 0x81, 0x84,
0x25, 0x2e, 0x86, 0x00, 0x02, 0x31, 0x25, 0x2e, 0x60, 0xf5, 0x05, 0x2e, 0x25, 0x02, 0x10, 0x30, 0x90, 0x08, 0x80,
0xb2, 0x0b, 0x2f, 0x05, 0x2e, 0xca, 0xf5, 0xf0, 0x3e, 0x90, 0x08, 0x25, 0x2e, 0xca, 0xf5, 0x05, 0x2e, 0x59, 0xf5,
0xe0, 0x3f, 0x90, 0x08, 0x25, 0x2e, 0x59, 0xf5, 0x90, 0x6f, 0xa1, 0x6f, 0xb3, 0x6f, 0xc4, 0x6f, 0xd5, 0x6f, 0xe6,
0x6f, 0xf7, 0x6f, 0x7b, 0x6f, 0x82, 0x6f, 0x70, 0x5f, 0xc8, 0x2e, 0x2f, 0x52, 0x90, 0x50, 0x53, 0x40, 0x4a, 0x25,
0x40, 0x40, 0x39, 0x8b, 0xfb, 0x7f, 0x0c, 0xbc, 0x21, 0x52, 0x37, 0x89, 0x0b, 0x30, 0x59, 0x08, 0x0c, 0xb8, 0xe0,
0x7f, 0x8b, 0x7f, 0x4b, 0x43, 0x0b, 0x43, 0x40, 0xb2, 0xd1, 0x7f, 0x6e, 0x2f, 0x01, 0x2e, 0x83, 0x00, 0x00, 0xb2,
0x0e, 0x2f, 0x25, 0x52, 0x01, 0x2e, 0x7e, 0x00, 0xc3, 0x7f, 0xb4, 0x7f, 0xa5, 0x7f, 0x98, 0x2e, 0xbb, 0xcc, 0x05,
0x30, 0x2b, 0x2e, 0x83, 0x00, 0xc3, 0x6f, 0xd1, 0x6f, 0xb4, 0x6f, 0xa5, 0x6f, 0x36, 0xbc, 0x06, 0xb9, 0x35, 0xbc,
0x0f, 0xb8, 0x94, 0xb0, 0xc6, 0x7f, 0x00, 0xb2, 0x0c, 0x2f, 0x27, 0x50, 0x29, 0x56, 0x0b, 0x30, 0x05, 0x2e, 0x21,
0x02, 0x2d, 0x5c, 0x1b, 0x42, 0xdb, 0x42, 0x96, 0x08, 0x25, 0x2e, 0x21, 0x02, 0x0b, 0x42, 0xcb, 0x42, 0x00, 0x2e,
0x31, 0x56, 0xcb, 0x08, 0x25, 0x52, 0x01, 0x2e, 0x7e, 0x00, 0x01, 0x54, 0x2b, 0x5c, 0x98, 0x2e, 0x06, 0xcd, 0xd2,
0x6f, 0x27, 0x5a, 0x94, 0x6f, 0xa4, 0xbc, 0x53, 0x41, 0x00, 0xb3, 0x1f, 0xb8, 0x44, 0x41, 0x01, 0x30, 0xd5, 0x7f,
0x05, 0x2f, 0x00, 0xb2, 0x03, 0x2f, 0x29, 0x5c, 0x11, 0x30, 0x93, 0x43, 0x84, 0x43, 0x23, 0xbd, 0x2f, 0xb9, 0x80,
0xb2, 0x1c, 0x2f, 0x72, 0x6f, 0xda, 0x00, 0x82, 0x6f, 0x22, 0x03, 0x44, 0x43, 0x00, 0x90, 0x27, 0x2e, 0x7f, 0x00,
0x29, 0x5a, 0x12, 0x2f, 0x29, 0x54, 0x00, 0x2e, 0x90, 0x40, 0x82, 0x40, 0x18, 0x04, 0xa2, 0x06, 0x80, 0xaa, 0x04,
0x2f, 0x80, 0x90, 0x08, 0x2f, 0xc2, 0x6f, 0x50, 0x0f, 0x05, 0x2f, 0xc0, 0x6f, 0x00, 0xb2, 0x02, 0x2f, 0x53, 0x43,
0x44, 0x43, 0x11, 0x30, 0xe0, 0x6f, 0x98, 0x2e, 0x95, 0xcf, 0xd1, 0x6f, 0x15, 0x5a, 0x09, 0x2e, 0x7f, 0x00, 0x41,
0x40, 0x54, 0x43, 0x08, 0x2c, 0x41, 0x43, 0x15, 0x30, 0x2b, 0x2e, 0x83, 0x00, 0x01, 0x30, 0xe0, 0x6f, 0x98, 0x2e,
0x95, 0xcf, 0x00, 0x2e, 0xfb, 0x6f, 0x70, 0x5f, 0xb8, 0x2e, 0x50, 0x86, 0xcd, 0x88, 0x34, 0x85, 0xc5, 0x40, 0x91,
0x40, 0x8c, 0x80, 0x06, 0x41, 0x13, 0x40, 0x50, 0x50, 0x6e, 0x01, 0x82, 0x40, 0x04, 0x40, 0x34, 0x8c, 0xfb, 0x7f,
0x98, 0x2e, 0xce, 0x03, 0xe0, 0x7f, 0x00, 0x2e, 0x91, 0x41, 0x8c, 0x81, 0x82, 0x41, 0x13, 0x40, 0x04, 0x40, 0x34,
0x8e, 0x98, 0x2e, 0xce, 0x03, 0xc0, 0x7f, 0xd5, 0x7f, 0x13, 0x24, 0xff, 0x00, 0xd6, 0x41, 0xcc, 0x83, 0xc2, 0x41,
0x57, 0x40, 0x74, 0x80, 0x44, 0x40, 0x11, 0x40, 0x0c, 0x8a, 0xf7, 0x01, 0x94, 0x03, 0x12, 0x24, 0x80, 0x00, 0x3a,
0x01, 0x02, 0x30, 0xb2, 0x03, 0xce, 0x17, 0xfb, 0x08, 0x23, 0x01, 0xb2, 0x02, 0x48, 0xbb, 0x28, 0xbd, 0xf2, 0x0b,
0x53, 0x41, 0x02, 0x40, 0x44, 0x41, 0x74, 0x8d, 0xb7, 0x7f, 0x98, 0x2e, 0xce, 0x03, 0x50, 0x25, 0x91, 0x41, 0x8c,
0x81, 0x82, 0x41, 0x13, 0x40, 0x04, 0x40, 0x34, 0x8e, 0x98, 0x2e, 0xce, 0x03, 0x60, 0x25, 0xd1, 0x41, 0xcc, 0x81,
0xc2, 0x41, 0x13, 0x40, 0x04, 0x40, 0x98, 0x2e, 0xce, 0x03, 0x11, 0x24, 0xb3, 0x00, 0x71, 0x0e, 0xd3, 0x6f, 0xe1,
0x6f, 0x33, 0x2f, 0x12, 0x24, 0xdd, 0x00, 0xda, 0x0f, 0x2b, 0x2f, 0x12, 0x24, 0x8c, 0x00, 0x5a, 0x0e, 0x09, 0x2f,
0x10, 0x24, 0x83, 0x05, 0x48, 0x0e, 0x11, 0x24, 0x7f, 0x22, 0x10, 0x24, 0x18, 0x32, 0x08, 0x22, 0x80, 0x2e, 0xd7,
0xb4, 0x13, 0x24, 0xf4, 0x00, 0x73, 0x0e, 0x0f, 0x2f, 0x10, 0x24, 0x11, 0x10, 0x68, 0x0e, 0x10, 0x24, 0xa2, 0x30,
0x13, 0x24, 0x97, 0x23, 0x03, 0x22, 0x13, 0x24, 0x3b, 0x04, 0x4b, 0x0e, 0x11, 0x24, 0x0f, 0x30, 0x01, 0x22, 0x80,
0x2e, 0xd7, 0xb4, 0x11, 0x24, 0x53, 0x02, 0x41, 0x0e, 0x11, 0x24, 0xe7, 0x31, 0x10, 0x24, 0xfc, 0x25, 0x08, 0x22,
0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xe8, 0x40, 0x80, 0x2e, 0xd7, 0xb4, 0xf2, 0x37, 0x5a, 0x0e, 0x90, 0x2e, 0x50,
0xb3, 0x12, 0x24, 0xea, 0x00, 0x4a, 0x0e, 0x90, 0x2e, 0xc7, 0xb2, 0xc2, 0x6f, 0x14, 0x24, 0x4c, 0x0b, 0x54, 0x0e,
0x90, 0x2e, 0xab, 0xb2, 0x14, 0x24, 0x9b, 0x00, 0x5c, 0x0e, 0x90, 0x2e, 0xa1, 0xb2, 0x14, 0x24, 0x22, 0x01, 0x4c,
0x0e, 0x70, 0x2f, 0x82, 0xa3, 0x5e, 0x2f, 0x11, 0x24, 0xba, 0x0b, 0x51, 0x0e, 0x35, 0x2f, 0x11, 0x24, 0x03, 0x08,
0x69, 0x0e, 0x2d, 0x2f, 0xb1, 0x6f, 0x14, 0x24, 0x90, 0x00, 0x0c, 0x0e, 0x24, 0x2f, 0x11, 0x24, 0x31, 0x08, 0x69,
0x0e, 0x16, 0x2f, 0x11, 0x24, 0x7d, 0x01, 0x59, 0x0e, 0x0e, 0x2f, 0x11, 0x24, 0xd7, 0x0c, 0x51, 0x0e, 0x11, 0x24,
0x9f, 0x44, 0x13, 0x24, 0x41, 0x57, 0x4b, 0x22, 0x93, 0x35, 0x43, 0x0e, 0x10, 0x24, 0xbd, 0x42, 0x08, 0x22, 0x80,
0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x1c, 0x42, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0x47, 0x01, 0x59, 0x0e, 0x11, 0x24,
0xa2, 0x45, 0x10, 0x24, 0x31, 0x51, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x80, 0x41, 0x80, 0x2e, 0xd7,
0xb4, 0x10, 0x24, 0x67, 0x54, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0x8c, 0x08, 0xe9, 0x0f, 0x10, 0x24, 0x0a, 0x48,
0x90, 0x2e, 0xd7, 0xb4, 0xb1, 0x6f, 0x13, 0x24, 0xe8, 0x03, 0x8b, 0x0f, 0x10, 0x24, 0xcd, 0x57, 0x90, 0x2e, 0xd7,
0xb4, 0x73, 0x35, 0x8b, 0x0f, 0x10, 0x24, 0x6f, 0x42, 0x90, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xa0, 0xfe, 0x08, 0x0e,
0x10, 0x24, 0x38, 0x54, 0x13, 0x24, 0xa3, 0x46, 0x03, 0x22, 0x13, 0x24, 0x45, 0xfd, 0x0b, 0x0e, 0x11, 0x24, 0x04,
0x43, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0xb1, 0x6f, 0x00, 0x3a, 0x08, 0x0e, 0x11, 0x24, 0x3d, 0x45, 0x10, 0x24,
0x52, 0x54, 0x48, 0x22, 0x10, 0x24, 0x8f, 0x01, 0x58, 0x0e, 0x10, 0x24, 0x48, 0x44, 0x01, 0x22, 0x80, 0x2e, 0xd7,
0xb4, 0xb1, 0x6f, 0x13, 0x24, 0xfa, 0x03, 0x0b, 0x0e, 0x11, 0x24, 0x85, 0x43, 0x13, 0x24, 0x35, 0x55, 0x4b, 0x22,
0x11, 0xa2, 0x10, 0x24, 0xf6, 0x57, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0xa4, 0x0a, 0x69, 0x0e, 0x11,
0x24, 0x7b, 0x5a, 0x10, 0x24, 0x5e, 0x20, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0x0f, 0x01, 0x59, 0x0e,
0x0d, 0x2f, 0x18, 0xa2, 0x11, 0x24, 0x2b, 0x47, 0x10, 0x24, 0xf4, 0x55, 0x48, 0x22, 0x10, 0x24, 0x16, 0x0b, 0x50,
0x0e, 0x10, 0x24, 0xc7, 0x51, 0x01, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0x72, 0x0a, 0x51, 0x0e, 0x11, 0x24,
0x85, 0x55, 0x10, 0x24, 0xb2, 0x47, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x83, 0x00, 0x48, 0x0e, 0x53,
0x2f, 0x11, 0x24, 0xe1, 0x07, 0x69, 0x0e, 0x2d, 0x2f, 0x95, 0xaf, 0x27, 0x2f, 0x82, 0xaf, 0x21, 0x2f, 0x11, 0x24,
0xd7, 0x00, 0x59, 0x0e, 0x19, 0x2f, 0xb1, 0x6f, 0x10, 0x24, 0xcc, 0x03, 0x88, 0x0f, 0x10, 0x2f, 0x10, 0x24, 0xe8,
0xfe, 0x08, 0x0e, 0x11, 0x24, 0x7e, 0x56, 0x10, 0x24, 0x94, 0x45, 0x48, 0x22, 0xc0, 0x6f, 0x13, 0x24, 0x06, 0x0b,
0x43, 0x0e, 0x10, 0x24, 0x2f, 0x51, 0x01, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xde, 0x51, 0x80, 0x2e, 0xd7,
0xb4, 0x10, 0x24, 0xe8, 0x54, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xa4, 0x52, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24,
0xd0, 0x44, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0xb8, 0x00, 0xd9, 0x0f, 0x19, 0x2f, 0xc1, 0x6f, 0x10, 0x24, 0xe7,
0x0c, 0xc8, 0x0f, 0x10, 0x2f, 0x11, 0x24, 0xc7, 0x07, 0x69, 0x0e, 0x11, 0x24, 0xf6, 0x52, 0x10, 0x24, 0x7a, 0x12,
0x48, 0x22, 0xb0, 0x6f, 0x13, 0x24, 0x5d, 0x02, 0x03, 0x0e, 0x10, 0x24, 0x7c, 0x54, 0x01, 0x22, 0x80, 0x2e, 0xd7,
0xb4, 0x10, 0x24, 0x8d, 0x51, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x28, 0x52, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24,
0xd2, 0x07, 0xe8, 0x0f, 0x28, 0x2f, 0x10, 0x24, 0xb0, 0x00, 0xd8, 0x0f, 0x20, 0x2f, 0x10, 0x24, 0xc6, 0x07, 0x68,
0x0e, 0x18, 0x2f, 0x50, 0x35, 0x48, 0x0e, 0x11, 0x2f, 0xb1, 0x6f, 0x10, 0x24, 0xf4, 0x01, 0x08, 0x0e, 0x11, 0x24,
0x35, 0x51, 0x10, 0x24, 0x22, 0x12, 0x48, 0x22, 0xc0, 0x6f, 0x13, 0x24, 0xe0, 0x0c, 0x43, 0x0e, 0x10, 0x24, 0x7b,
0x50, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x81, 0x52, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x3b, 0x53,
0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x63, 0x51, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x27, 0x51, 0x80, 0x2e, 0xd7,
0xb4, 0x18, 0xa2, 0x90, 0x2e, 0xdb, 0xb3, 0x12, 0x24, 0x08, 0x02, 0x4a, 0x0e, 0x37, 0x2f, 0x12, 0x24, 0x2a, 0x09,
0x6a, 0x0e, 0x1d, 0x2f, 0x13, 0x24, 0x8e, 0x00, 0x73, 0x0e, 0x09, 0x2f, 0x11, 0x24, 0xa5, 0x01, 0x41, 0x0e, 0x11,
0x24, 0x76, 0x32, 0x10, 0x24, 0x12, 0x25, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xa9, 0x0d, 0x68, 0x0e,
0x10, 0x24, 0x04, 0x27, 0x13, 0x24, 0x73, 0x20, 0x03, 0x22, 0x13, 0x24, 0x14, 0x04, 0x4b, 0x0e, 0x11, 0x24, 0x15,
0x2c, 0x01, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x11, 0x24, 0xae, 0x08, 0x69, 0x0e, 0x08, 0x2f, 0xa1, 0x35, 0x71, 0x0e,
0x11, 0x24, 0x8b, 0x2b, 0x10, 0x24, 0x07, 0x35, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x91, 0x34, 0x59, 0x0e, 0x11,
0x24, 0x7b, 0x19, 0x10, 0x24, 0x50, 0x59, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x62, 0x32, 0x42, 0x0e, 0x22, 0x2f,
0xa2, 0x32, 0x5a, 0x0e, 0x1b, 0x2f, 0x12, 0x24, 0x0b, 0x08, 0x6a, 0x0e, 0x0e, 0x2f, 0xa3, 0x34, 0x43, 0x0e, 0x10,
0x24, 0x28, 0x2b, 0x13, 0x24, 0x20, 0x23, 0x03, 0x22, 0x13, 0x24, 0x8d, 0x01, 0x4b, 0x0e, 0x11, 0x24, 0x5c, 0x21,
0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x31, 0x36, 0x59, 0x0e, 0x11, 0x24, 0x43, 0x25, 0x10, 0x24, 0xfa, 0x49, 0x08,
0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xc7, 0x2a, 0x80, 0x2e, 0xd7, 0xb4, 0x40, 0x36, 0x58, 0x0e, 0x09, 0x2f,
0x11, 0x24, 0x9e, 0x08, 0x69, 0x0e, 0x11, 0x24, 0xe3, 0x54, 0x10, 0x24, 0x73, 0x22, 0x08, 0x22, 0x80, 0x2e, 0xd7,
0xb4, 0x10, 0x24, 0x38, 0x01, 0xc8, 0x0f, 0x10, 0x2f, 0x11, 0x24, 0x11, 0x08, 0x69, 0x0e, 0x11, 0x24, 0x6e, 0x48,
0x10, 0x24, 0x2b, 0x28, 0x48, 0x22, 0xc0, 0x6f, 0x13, 0x24, 0xc1, 0x0a, 0x43, 0x0e, 0x10, 0x24, 0x0f, 0x23, 0x08,
0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0xd0, 0x1a, 0x80, 0x2e, 0xd7, 0xb4, 0xe2, 0x33, 0x5a, 0x0e, 0x77, 0x2f,
0x12, 0x24, 0x0c, 0x08, 0x6a, 0x0e, 0x2a, 0x2f, 0x12, 0x24, 0xc5, 0x00, 0x4a, 0x0e, 0x08, 0x2f, 0x11, 0x36, 0x59,
0x0e, 0x11, 0x24, 0xfd, 0x18, 0x10, 0x24, 0x75, 0x58, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0xc2, 0x34, 0x5a, 0x0e,
0x0d, 0x2f, 0x11, 0x24, 0x36, 0x08, 0x69, 0x0e, 0x11, 0x24, 0x08, 0x58, 0x13, 0x24, 0x3b, 0x54, 0x4b, 0x22, 0x01,
0xa2, 0x10, 0x24, 0xc6, 0x52, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0xb3, 0x36, 0x4b, 0x0e, 0x11, 0x24, 0x0e, 0x24,
0x13, 0x24, 0x7b, 0x50, 0x59, 0x22, 0x0e, 0xa2, 0x10, 0x24, 0xf7, 0x56, 0x01, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0xc2,
0x35, 0x5a, 0x0e, 0x12, 0x2f, 0x01, 0xa2, 0x0c, 0x2f, 0x84, 0xa3, 0x10, 0x24, 0xd4, 0x58, 0x13, 0x24, 0x76, 0x56,
0x03, 0x22, 0x73, 0x36, 0x4b, 0x0e, 0x11, 0x24, 0xeb, 0x52, 0x08, 0x22, 0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x87,
0x16, 0x80, 0x2e, 0xd7, 0xb4, 0xb0, 0x6f, 0x13, 0x24, 0x02, 0xfd, 0x03, 0x0e, 0x29, 0x2f, 0x84, 0xa3, 0xc0, 0x6f,
0x09, 0x2f, 0x11, 0x24, 0xe4, 0x0a, 0x41, 0x0e, 0x11, 0x24, 0x5d, 0x44, 0x10, 0x24, 0x2f, 0x5a, 0x08, 0x22, 0x80,
0x2e, 0xd7, 0xb4, 0x13, 0x24, 0x96, 0x0c, 0x43, 0x0e, 0x0e, 0x2f, 0x40, 0x33, 0x48, 0x0e, 0x10, 0x24, 0xf2, 0x18,
0x13, 0x24, 0x31, 0x49, 0x03, 0x22, 0x13, 0x24, 0x99, 0x00, 0x4b, 0x0e, 0x11, 0x24, 0xab, 0x18, 0x01, 0x22, 0x80,
0x2e, 0xd7, 0xb4, 0x11, 0x24, 0xc6, 0x07, 0x69, 0x0e, 0x11, 0x24, 0xb0, 0x49, 0x10, 0x24, 0xbf, 0x17, 0x08, 0x22,
0x80, 0x2e, 0xd7, 0xb4, 0x10, 0x24, 0x03, 0x15, 0x80, 0x2e, 0xd7, 0xb4, 0xb0, 0x32, 0x48, 0x0e, 0x57, 0x2f, 0xa0,
0x37, 0x48, 0x0e, 0x13, 0x2f, 0x83, 0xa3, 0x08, 0x2f, 0x10, 0x24, 0xe0, 0x00, 0x48, 0x0e, 0x11, 0x24, 0xf6, 0x25,
0x10, 0x24, 0x75, 0x17, 0x71, 0x2c, 0x08, 0x22, 0x10, 0x24, 0xa0, 0x00, 0x48, 0x0e, 0x11, 0x24, 0x7f, 0x18, 0x10,
0x24, 0xa6, 0x13, 0x68, 0x2c, 0x08, 0x22, 0x11, 0x24, 0xf9, 0x07, 0x69, 0x0e, 0x0d, 0x2f, 0x11, 0x24, 0x10, 0x08,
0x69, 0x0e, 0x11, 0x24, 0xb1, 0x14, 0x10, 0x24, 0x8e, 0x58, 0x48, 0x22, 0x90, 0x32, 0x58, 0x0e, 0x10, 0x24, 0x6d,
0x14, 0x56, 0x2c, 0x01, 0x22, 0xc1, 0x6f, 0x10, 0x24, 0x68, 0x0c, 0x48, 0x0e, 0xb1, 0x6f, 0x0c, 0x2f, 0xcd, 0xa2,
0x10, 0x24, 0x23, 0x14, 0x13, 0x24, 0x8d, 0x42, 0x03, 0x22, 0x13, 0x24, 0x2a, 0xfd, 0x0b, 0x0e, 0x11, 0x24, 0x53,
0x12, 0x43, 0x2c, 0x08, 0x22, 0x10, 0x24, 0xcc, 0x07, 0x68, 0x0e, 0x0e, 0x2f, 0x10, 0x24, 0x08, 0xfd, 0x08, 0x0e,
0x10, 0x24, 0x08, 0x16, 0x13, 0x24, 0x83, 0x45, 0x03, 0x22, 0x13, 0x24, 0xa1, 0xfd, 0x0b, 0x0e, 0x11, 0x24, 0xa6,
0x14, 0x30, 0x2c, 0x01, 0x22, 0x10, 0x24, 0x5b, 0x01, 0x08, 0x0e, 0x11, 0x24, 0x2f, 0x12, 0x10, 0x24, 0xdd, 0x44,
0x27, 0x2c, 0x08, 0x22, 0xdb, 0xa2, 0x0f, 0x2f, 0xc1, 0x6f, 0x10, 0x24, 0xb2, 0x0b, 0x48, 0x0e, 0x11, 0x24, 0x21,
0x55, 0x10, 0x24, 0xc8, 0x14, 0x48, 0x22, 0x10, 0x24, 0x4c, 0x08, 0x68, 0x0e, 0x10, 0x24, 0xe4, 0x57, 0x15, 0x2c,
0x01, 0x22, 0x44, 0xa2, 0x0f, 0x2f, 0xc1, 0x6f, 0x10, 0x24, 0xcb, 0x0b, 0x48, 0x0e, 0x11, 0x24, 0x09, 0x58, 0x10,
0x24, 0xe4, 0x10, 0x48, 0x22, 0x10, 0x24, 0x4d, 0x08, 0x68, 0x0e, 0x10, 0x24, 0x1a, 0x12, 0x03, 0x2c, 0x01, 0x22,
0x10, 0x24, 0x0c, 0x10, 0xfb, 0x6f, 0xb0, 0x5f, 0xb8, 0x2e, 0xa3, 0x32, 0xc3, 0x00, 0x60, 0x51, 0xc2, 0x40, 0x81,
0x84, 0xd3, 0x7f, 0xd2, 0x42, 0xe0, 0x7f, 0x00, 0x30, 0xc4, 0x40, 0x20, 0x02, 0xc3, 0x7f, 0xd0, 0x42, 0x42, 0x3d,
0xc0, 0x40, 0x01, 0x80, 0xc0, 0x42, 0xda, 0x00, 0x93, 0x7f, 0xb1, 0x7f, 0xab, 0x7f, 0x98, 0x2e, 0xb3, 0xc0, 0x91,
0x6f, 0xf3, 0x32, 0x40, 0x42, 0x00, 0xac, 0x8b, 0x00, 0x02, 0x2f, 0xe1, 0x6f, 0x39, 0x56, 0x43, 0x42, 0xa1, 0x82,
0x91, 0x7f, 0x33, 0x33, 0x4b, 0x00, 0x81, 0x7f, 0x13, 0x3c, 0x4b, 0x00, 0x80, 0x40, 0x53, 0x34, 0xb5, 0x6f, 0x8b,
0x00, 0x0d, 0xb0, 0x43, 0x87, 0x76, 0x7f, 0xb2, 0x7f, 0x63, 0x7f, 0x65, 0x25, 0xb5, 0x6f, 0x92, 0x41, 0x63, 0x41,
0x64, 0x41, 0x44, 0x81, 0x56, 0x7f, 0x41, 0x7f, 0x00, 0x2e, 0x26, 0x40, 0x27, 0x40, 0x45, 0x41, 0xf7, 0x7f, 0xb0,
0x7f, 0x98, 0x2e, 0x67, 0xcc, 0x81, 0x6f, 0x0f, 0xa4, 0x43, 0x40, 0x72, 0x6f, 0x94, 0x6f, 0x05, 0x30, 0x01, 0x2f,
0xc0, 0xa0, 0x03, 0x2f, 0x31, 0xac, 0x07, 0x2f, 0xc0, 0xa4, 0x05, 0x2f, 0xa2, 0x00, 0xeb, 0x04, 0x80, 0x40, 0x01,
0x80, 0x43, 0x42, 0x80, 0x42, 0x41, 0x86, 0x56, 0x6f, 0x62, 0x6f, 0x41, 0x6f, 0x42, 0x82, 0x72, 0x0e, 0x83, 0x7f,
0xd5, 0x2f, 0x53, 0x32, 0x8b, 0x00, 0xa1, 0x86, 0x56, 0x25, 0xf0, 0x82, 0x82, 0x40, 0x8d, 0xb0, 0x52, 0x40, 0xde,
0x00, 0x91, 0x7f, 0xb3, 0x7f, 0x85, 0x7f, 0xb3, 0x30, 0x7b, 0x52, 0x98, 0x2e, 0x5a, 0xca, 0x1a, 0x25, 0x83, 0x6f,
0x6d, 0x82, 0xfd, 0x88, 0x50, 0x7f, 0x71, 0x7f, 0x81, 0x7f, 0x05, 0x30, 0x83, 0x30, 0x00, 0x30, 0x11, 0x41, 0x52,
0x6f, 0x25, 0x7f, 0x30, 0x7f, 0x44, 0x7f, 0x98, 0x2e, 0x0f, 0xca, 0x73, 0x6f, 0x20, 0x25, 0x90, 0x6f, 0x7d, 0x52,
0xd2, 0x42, 0x73, 0x7f, 0x12, 0x7f, 0x98, 0x2e, 0x86, 0xb7, 0x93, 0x6f, 0x11, 0x6f, 0xd2, 0x40, 0x0a, 0x18, 0x31,
0x6f, 0x0e, 0x00, 0x93, 0x7f, 0x83, 0x30, 0x44, 0x6f, 0x21, 0x6f, 0x62, 0x6f, 0x62, 0x0e, 0x4f, 0x03, 0xe1, 0x2f,
0x33, 0x52, 0x01, 0x00, 0x01, 0x30, 0x69, 0x03, 0x3a, 0x25, 0xea, 0x82, 0x92, 0x6f, 0xf0, 0x86, 0xd1, 0xbe, 0x0f,
0xb8, 0xbd, 0x84, 0x94, 0x7f, 0x05, 0x0a, 0x23, 0x7f, 0x52, 0x7f, 0x40, 0x7f, 0x31, 0x7f, 0x71, 0x7f, 0xd3, 0x30,
0x84, 0x6f, 0x55, 0x6f, 0x10, 0x41, 0x52, 0x41, 0x41, 0x6f, 0x55, 0x7f, 0x10, 0x7f, 0x04, 0x7f, 0x98, 0x2e, 0x0f,
0xca, 0x11, 0x6f, 0x20, 0x25, 0x98, 0x2e, 0xfe, 0xc9, 0x31, 0x6f, 0x04, 0x6f, 0x50, 0x42, 0x31, 0x7f, 0xd3, 0x30,
0x21, 0x6f, 0x61, 0x0e, 0xea, 0x2f, 0xb1, 0x6f, 0x41, 0x84, 0x32, 0x25, 0x90, 0x40, 0x84, 0x40, 0x71, 0x6f, 0xb4,
0x7f, 0x72, 0x7f, 0x40, 0x7f, 0x33, 0x7f, 0x98, 0x2e, 0xb3, 0xc0, 0x53, 0x6f, 0xb1, 0x32, 0x99, 0x00, 0x83, 0xb9,
0x41, 0x6f, 0x4b, 0x00, 0xb0, 0x6f, 0x03, 0x30, 0xc3, 0x02, 0x84, 0x40, 0xb2, 0x7f, 0xa1, 0x84, 0x0d, 0xb1, 0x52,
0x7f, 0x56, 0x01, 0x74, 0x6f, 0x30, 0x6f, 0x92, 0x6f, 0x43, 0x8b, 0x03, 0x43, 0x01, 0x42, 0x95, 0x7f, 0xbd, 0x86,
0x51, 0x41, 0x41, 0x7f, 0x75, 0x7f, 0x00, 0x2e, 0xd1, 0x40, 0x42, 0x41, 0x32, 0x7f, 0x23, 0x7f, 0x98, 0x2e, 0x74,
0xc0, 0x41, 0x6f, 0xc8, 0x00, 0x90, 0x6f, 0x01, 0x30, 0x75, 0x6f, 0x32, 0x6f, 0x03, 0x42, 0x91, 0x02, 0x23, 0x6f,
0x61, 0x6f, 0x59, 0x0e, 0x62, 0x43, 0x95, 0x7f, 0xe7, 0x2f, 0xb2, 0x6f, 0x51, 0x6f, 0x82, 0x40, 0x8d, 0xb0, 0x8e,
0x00, 0xfd, 0x8a, 0xb2, 0x7f, 0x02, 0x30, 0x79, 0x52, 0x05, 0x25, 0x03, 0x30, 0x54, 0x40, 0xec, 0x01, 0x16, 0x40,
0x43, 0x89, 0xc7, 0x41, 0x37, 0x18, 0x3d, 0x8b, 0x96, 0x00, 0x44, 0x0e, 0xdf, 0x02, 0xf4, 0x2f, 0x09, 0x52, 0x51,
0x00, 0x02, 0x30, 0x9a, 0x02, 0xb5, 0x6f, 0x45, 0x87, 0x1b, 0xba, 0x25, 0xbc, 0x51, 0x6f, 0x4d, 0x8b, 0x7a, 0x82,
0xc6, 0x40, 0x20, 0x0a, 0x30, 0x00, 0xd0, 0x42, 0x2b, 0xb5, 0xc0, 0x40, 0x82, 0x02, 0x40, 0x34, 0x08, 0x00, 0xd2,
0x42, 0xb0, 0x7f, 0x75, 0x7f, 0x93, 0x7f, 0x00, 0x2e, 0xb5, 0x6f, 0xe2, 0x6f, 0x63, 0x41, 0x64, 0x41, 0x44, 0x8f,
0x82, 0x40, 0xe6, 0x41, 0xc0, 0x41, 0xc4, 0x8f, 0x45, 0x41, 0xf0, 0x7f, 0xb7, 0x7f, 0x61, 0x7f, 0x98, 0x2e, 0x67,
0xcc, 0x00, 0x18, 0x09, 0x52, 0x71, 0x00, 0x03, 0x30, 0xbb, 0x02, 0x1b, 0xba, 0x93, 0x6f, 0x25, 0xbc, 0x61, 0x6f,
0xc5, 0x40, 0x42, 0x82, 0x20, 0x0a, 0x28, 0x00, 0xd0, 0x42, 0x2b, 0xb9, 0xc0, 0x40, 0x82, 0x02, 0xd2, 0x42, 0x93,
0x7f, 0x00, 0x2e, 0x72, 0x6f, 0x5a, 0x0e, 0xd9, 0x2f, 0xb1, 0x6f, 0xf3, 0x3c, 0xcb, 0x00, 0xda, 0x82, 0xc3, 0x40,
0x41, 0x40, 0x59, 0x0e, 0x50, 0x2f, 0xe1, 0x6f, 0xe3, 0x32, 0xcb, 0x00, 0xb3, 0x7f, 0x22, 0x30, 0xc0, 0x40, 0x01,
0x80, 0xc0, 0x42, 0x02, 0xa2, 0x30, 0x2f, 0xc2, 0x42, 0x98, 0x2e, 0x83, 0xb1, 0xe1, 0x6f, 0xb3, 0x35, 0xcb, 0x00,
0x24, 0x3d, 0xc2, 0x40, 0xdc, 0x00, 0x84, 0x40, 0x00, 0x91, 0x93, 0x7f, 0x02, 0x2f, 0x00, 0x2e, 0x06, 0x2c, 0x0c,
0xb8, 0x30, 0x25, 0x00, 0x33, 0x48, 0x00, 0x98, 0x2e, 0xf6, 0xb6, 0x91, 0x6f, 0x90, 0x7f, 0x00, 0x2e, 0x44, 0x40,
0x20, 0x1a, 0x15, 0x2f, 0xd3, 0x6f, 0xc1, 0x6f, 0xc3, 0x40, 0x35, 0x5a, 0x42, 0x40, 0xd3, 0x7e, 0x08, 0xbc, 0x25,
0x09, 0xe2, 0x7e, 0xc4, 0x0a, 0x42, 0x82, 0xf3, 0x7e, 0xd1, 0x7f, 0x34, 0x30, 0x83, 0x6f, 0x82, 0x30, 0x31, 0x30,
0x98, 0x2e, 0xb3, 0x00, 0xd1, 0x6f, 0x93, 0x6f, 0x43, 0x42, 0xf0, 0x32, 0xb1, 0x6f, 0x41, 0x82, 0xe2, 0x6f, 0x43,
0x40, 0xc1, 0x86, 0xc2, 0xa2, 0x43, 0x42, 0x03, 0x30, 0x02, 0x2f, 0x90, 0x00, 0x00, 0x2e, 0x83, 0x42, 0x61, 0x88,
0x42, 0x40, 0x8d, 0xb0, 0x26, 0x00, 0x98, 0x2e, 0xd9, 0x03, 0x1c, 0x83, 0x00, 0x2e, 0x43, 0x42, 0x00, 0x2e, 0xab,
0x6f, 0xa0, 0x5e, 0xb8, 0x2e, 0xb1, 0x35, 0x40, 0x51, 0x41, 0x01, 0x02, 0x30, 0x1a, 0x25, 0x13, 0x30, 0x40, 0x25,
0x12, 0x42, 0x45, 0x0e, 0xfc, 0x2f, 0x65, 0x34, 0x28, 0x80, 0x25, 0x01, 0x13, 0x42, 0x44, 0x0e, 0xfc, 0x2f, 0x27,
0x80, 0x65, 0x56, 0x03, 0x42, 0x15, 0x80, 0xa3, 0x30, 0x03, 0x42, 0x04, 0x80, 0x4d, 0x56, 0x7f, 0x58, 0x13, 0x42,
0xd4, 0x7e, 0xc2, 0x7e, 0xf2, 0x7e, 0x6c, 0x8c, 0x81, 0x56, 0x83, 0x58, 0xe3, 0x7e, 0x04, 0x7f, 0x71, 0x8a, 0x97,
0x41, 0x17, 0x42, 0x75, 0x0e, 0xfb, 0x2f, 0x85, 0x5c, 0x87, 0x5e, 0x16, 0x7f, 0x36, 0x7f, 0x27, 0x7f, 0x00, 0x2e,
0x89, 0x5c, 0x8b, 0x5e, 0x46, 0x7f, 0x57, 0x7f, 0x76, 0x8c, 0x57, 0x41, 0x17, 0x42, 0x6e, 0x0e, 0xfb, 0x2f, 0x8d,
0x5a, 0x8f, 0x5e, 0x65, 0x7f, 0x87, 0x7f, 0x72, 0x7f, 0x00, 0x2e, 0x91, 0x5a, 0x93, 0x5e, 0x95, 0x7f, 0xa7, 0x7f,
0x7b, 0x8a, 0x97, 0x41, 0x17, 0x42, 0x75, 0x0e, 0xfb, 0x2f, 0x7f, 0x5c, 0xb2, 0x7f, 0xc6, 0x7f, 0xd3, 0x7f, 0xe2,
0x7f, 0xf4, 0x7f, 0x40, 0x82, 0x52, 0x41, 0x12, 0x42, 0x69, 0x0e, 0xfb, 0x2f, 0xc0, 0x5e, 0xb8, 0x2e, 0x03, 0x2e,
0x2d, 0x02, 0x9f, 0xbc, 0x9f, 0xb8, 0x20, 0x50, 0x40, 0xb2, 0x14, 0x2f, 0x10, 0x25, 0x01, 0x2e, 0x8d, 0x00, 0x00,
0x90, 0x0b, 0x2f, 0x97, 0x50, 0xf1, 0x7f, 0xeb, 0x7f, 0x98, 0x2e, 0x83, 0xb6, 0x01, 0x2e, 0x8d, 0x00, 0x01, 0x80,
0x21, 0x2e, 0x8d, 0x00, 0xf1, 0x6f, 0xeb, 0x6f, 0xe0, 0x5f, 0x97, 0x50, 0x80, 0x2e, 0xda, 0xb4, 0x00, 0x30, 0x21,
0x2e, 0x8d, 0x00, 0xe0, 0x5f, 0xb8, 0x2e, 0x41, 0x25, 0x42, 0x8a, 0x50, 0x50, 0x99, 0x52, 0x81, 0x80, 0x99, 0x09,
0xf5, 0x7f, 0x52, 0x25, 0x07, 0x52, 0x03, 0x8e, 0xd9, 0x08, 0x02, 0x40, 0x03, 0x81, 0x44, 0x83, 0x6c, 0xbb, 0xda,
0x0e, 0xe7, 0x7f, 0xdb, 0x7f, 0x20, 0x2f, 0x02, 0x41, 0x32, 0x1a, 0x1d, 0x2f, 0x42, 0x85, 0x00, 0x2e, 0x82, 0x40,
0xda, 0x0e, 0x03, 0x30, 0x05, 0x2f, 0xf1, 0x6f, 0x06, 0x30, 0x42, 0x40, 0x81, 0x84, 0x18, 0x2c, 0x42, 0x42, 0xbf,
0x85, 0x82, 0x00, 0x41, 0x40, 0x86, 0x40, 0x81, 0x8d, 0x86, 0x42, 0x20, 0x25, 0x13, 0x30, 0x06, 0x30, 0x97, 0x40,
0x81, 0x8d, 0xf9, 0x0f, 0x09, 0x2f, 0x85, 0xa3, 0xf9, 0x2f, 0x03, 0x30, 0x06, 0x2c, 0x06, 0x30, 0x9b, 0x52, 0xd9,
0x0e, 0x13, 0x30, 0x01, 0x30, 0xd9, 0x22, 0xc0, 0xb2, 0x12, 0x83, 0xc1, 0x7f, 0x03, 0x30, 0xb4, 0x7f, 0x06, 0x2f,
0x51, 0x30, 0x70, 0x25, 0x98, 0x2e, 0xe3, 0x03, 0xff, 0x81, 0x00, 0x2e, 0x03, 0x42, 0x43, 0x8b, 0xe0, 0x6f, 0xf1,
0x6f, 0x00, 0x40, 0x41, 0x40, 0xc8, 0x0f, 0x37, 0x2f, 0x00, 0x41, 0x80, 0xa7, 0x3c, 0x2f, 0x01, 0x83, 0x47, 0x8e,
0x42, 0x40, 0xfa, 0x01, 0x81, 0x84, 0x08, 0x89, 0x45, 0x41, 0x55, 0x0e, 0xc6, 0x43, 0x42, 0x42, 0xf4, 0x7f, 0x00,
0x2f, 0x43, 0x42, 0x51, 0x82, 0x70, 0x1a, 0x41, 0x40, 0x06, 0x2f, 0xc3, 0x6f, 0x41, 0x82, 0xc1, 0x42, 0xcd, 0x0e,
0x26, 0x2f, 0xc5, 0x42, 0x25, 0x2d, 0x7f, 0x82, 0x51, 0xbb, 0xa5, 0x00, 0xce, 0x0f, 0x12, 0x2f, 0x14, 0x30, 0x05,
0x30, 0xf7, 0x6f, 0x06, 0x30, 0x05, 0x2c, 0xe0, 0x7f, 0xd0, 0x41, 0x05, 0x1a, 0x23, 0x22, 0xb0, 0x01, 0x7a, 0x0e,
0xf9, 0x2f, 0x71, 0x0f, 0xe0, 0x6f, 0x28, 0x22, 0x41, 0x8b, 0x71, 0x22, 0x45, 0xa7, 0xee, 0x2f, 0xb3, 0x6f, 0xc2,
0x6f, 0xc0, 0x42, 0x81, 0x42, 0x08, 0x2d, 0x04, 0x25, 0xc4, 0x6f, 0x98, 0x2e, 0xea, 0x03, 0x00, 0x2e, 0x40, 0x41,
0x00, 0x43, 0x00, 0x30, 0xdb, 0x6f, 0xb0, 0x5f, 0xb8, 0x2e, 0x10, 0x50, 0x03, 0x40, 0x19, 0x18, 0x37, 0x56, 0x19,
0x05, 0x36, 0x25, 0xf7, 0x7f, 0x4a, 0x17, 0x54, 0x18, 0xec, 0x18, 0x09, 0x17, 0x01, 0x30, 0x0c, 0x07, 0xe2, 0x18,
0xde, 0x00, 0xf2, 0x6f, 0x97, 0x02, 0x33, 0x58, 0xdc, 0x00, 0x91, 0x02, 0xbf, 0xb8, 0x21, 0xbd, 0x8a, 0x0a, 0xc0,
0x2e, 0x02, 0x42, 0xf0, 0x5f, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e,
0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x01, 0x2e, 0x5d, 0xf7, 0x08, 0xbc, 0x80, 0xac, 0x0e, 0xbb, 0x02, 0x2f,
0x00, 0x30, 0x41, 0x04, 0x82, 0x06, 0xc0, 0xa4, 0x00, 0x30, 0x11, 0x2f, 0x40, 0xa9, 0x03, 0x2f, 0x40, 0x91, 0x0d,
0x2f, 0x00, 0xa7, 0x0b, 0x2f, 0x80, 0xb3, 0x33, 0x58, 0x02, 0x2f, 0x90, 0xa1, 0x26, 0x13, 0x20, 0x23, 0x80, 0x90,
0x10, 0x30, 0x01, 0x2f, 0xcc, 0x0e, 0x00, 0x2f, 0x00, 0x30, 0xb8, 0x2e, 0x35, 0x50, 0x18, 0x08, 0x08, 0xbc, 0x88,
0xb6, 0x0d, 0x17, 0xc6, 0xbd, 0x56, 0xbc, 0x37, 0x58, 0xda, 0xba, 0x04, 0x01, 0x1d, 0x0a, 0x10, 0x50, 0x05, 0x30,
0x32, 0x25, 0x45, 0x03, 0xfb, 0x7f, 0xf6, 0x30, 0x21, 0x25, 0x98, 0x2e, 0x37, 0xca, 0x16, 0xb5, 0x9a, 0xbc, 0x06,
0xb8, 0x80, 0xa8, 0x41, 0x0a, 0x0e, 0x2f, 0x80, 0x90, 0x02, 0x2f, 0x39, 0x50, 0x48, 0x0f, 0x09, 0x2f, 0xbf, 0xa0,
0x04, 0x2f, 0xbf, 0x90, 0x06, 0x2f, 0x37, 0x54, 0xca, 0x0f, 0x03, 0x2f, 0x00, 0x2e, 0x02, 0x2c, 0x37, 0x52, 0x39,
0x52, 0xf2, 0x33, 0x98, 0x2e, 0xd9, 0xc0, 0xfb, 0x6f, 0xf1, 0x37, 0xc0, 0x2e, 0x01, 0x08, 0xf0, 0x5f, 0x41, 0x56,
0x3b, 0x54, 0xd0, 0x40, 0xc4, 0x40, 0x0b, 0x2e, 0xfd, 0xf3, 0x41, 0x52, 0x90, 0x42, 0x94, 0x42, 0x95, 0x42, 0x05,
0x30, 0x43, 0x50, 0x0f, 0x88, 0x06, 0x40, 0x04, 0x41, 0x96, 0x42, 0xc5, 0x42, 0x48, 0xbe, 0x73, 0x30, 0x0d, 0x2e,
0x88, 0x00, 0x4f, 0xba, 0x84, 0x42, 0x03, 0x42, 0x81, 0xb3, 0x02, 0x2f, 0x2b, 0x2e, 0x6f, 0xf5, 0x06, 0x2d, 0x05,
0x2e, 0x77, 0xf7, 0x3f, 0x56, 0x93, 0x08, 0x25, 0x2e, 0x77, 0xf7, 0x3d, 0x54, 0x25, 0x2e, 0xc2, 0xf5, 0x07, 0x2e,
0xfd, 0xf3, 0x42, 0x30, 0xb4, 0x33, 0xda, 0x0a, 0x4c, 0x00, 0x27, 0x2e, 0xfd, 0xf3, 0x43, 0x40, 0xd4, 0x3f, 0xdc,
0x08, 0x43, 0x42, 0x00, 0x2e, 0x00, 0x2e, 0x43, 0x40, 0x24, 0x30, 0xdc, 0x0a, 0x43, 0x42, 0x04, 0x80, 0x03, 0x2e,
0xfd, 0xf3, 0x4a, 0x0a, 0x23, 0x2e, 0xfd, 0xf3, 0x61, 0x34, 0xc0, 0x2e, 0x01, 0x42, 0x00, 0x2e, 0x60, 0x50, 0x1a,
0x25, 0x7a, 0x86, 0xe0, 0x7f, 0xf3, 0x7f, 0x03, 0x25, 0x45, 0x52, 0x41, 0x84, 0xdb, 0x7f, 0x33, 0x30, 0x98, 0x2e,
0x16, 0xc2, 0x1a, 0x25, 0x7d, 0x82, 0xf0, 0x6f, 0xe2, 0x6f, 0x32, 0x25, 0x16, 0x40, 0x94, 0x40, 0x26, 0x01, 0x85,
0x40, 0x8e, 0x17, 0xc4, 0x42, 0x6e, 0x03, 0x95, 0x42, 0x41, 0x0e, 0xf4, 0x2f, 0xdb, 0x6f, 0xa0, 0x5f, 0xb8, 0x2e,
0xb0, 0x51, 0xfb, 0x7f, 0x98, 0x2e, 0xe8, 0x0d, 0x5a, 0x25, 0x98, 0x2e, 0x0f, 0x0e, 0x4f, 0x58, 0x32, 0x87, 0xc4,
0x7f, 0x65, 0x89, 0x6b, 0x8d, 0x47, 0x5a, 0x65, 0x7f, 0xe1, 0x7f, 0x83, 0x7f, 0xa6, 0x7f, 0x74, 0x7f, 0xd0, 0x7f,
0xb6, 0x7f, 0x94, 0x7f, 0x17, 0x30, 0x49, 0x52, 0x4b, 0x54, 0x51, 0x7f, 0x00, 0x2e, 0x85, 0x6f, 0x42, 0x7f, 0x00,
0x2e, 0x51, 0x41, 0x45, 0x81, 0x42, 0x41, 0x13, 0x40, 0x3b, 0x8a, 0x00, 0x40, 0x4b, 0x04, 0xd0, 0x06, 0xc0, 0xac,
0x85, 0x7f, 0x02, 0x2f, 0x02, 0x30, 0x51, 0x04, 0xd3, 0x06, 0x41, 0x84, 0x05, 0x30, 0x5d, 0x02, 0xc9, 0x16, 0xdf,
0x08, 0xd3, 0x00, 0x8d, 0x02, 0xaf, 0xbc, 0xb1, 0xb9, 0x59, 0x0a, 0x65, 0x6f, 0x11, 0x43, 0xa1, 0xb4, 0x52, 0x41,
0x53, 0x41, 0x01, 0x43, 0x34, 0x7f, 0x65, 0x7f, 0x26, 0x31, 0xe5, 0x6f, 0xd4, 0x6f, 0x98, 0x2e, 0x37, 0xca, 0x32,
0x6f, 0x75, 0x6f, 0x83, 0x40, 0x42, 0x41, 0x23, 0x7f, 0x12, 0x7f, 0xf6, 0x30, 0x40, 0x25, 0x51, 0x25, 0x98, 0x2e,
0x37, 0xca, 0x14, 0x6f, 0x20, 0x05, 0x70, 0x6f, 0x25, 0x6f, 0x69, 0x07, 0xa2, 0x6f, 0x31, 0x6f, 0x0b, 0x30, 0x04,
0x42, 0x9b, 0x42, 0x8b, 0x42, 0x55, 0x42, 0x32, 0x7f, 0x40, 0xa9, 0xc3, 0x6f, 0x71, 0x7f, 0x02, 0x30, 0xd0, 0x40,
0xc3, 0x7f, 0x03, 0x2f, 0x40, 0x91, 0x15, 0x2f, 0x00, 0xa7, 0x13, 0x2f, 0x00, 0xa4, 0x11, 0x2f, 0x84, 0xbd, 0x98,
0x2e, 0x79, 0xca, 0x55, 0x6f, 0x37, 0x54, 0x54, 0x41, 0x82, 0x00, 0xf3, 0x3f, 0x45, 0x41, 0xcb, 0x02, 0xf6, 0x30,
0x98, 0x2e, 0x37, 0xca, 0x35, 0x6f, 0xa4, 0x6f, 0x41, 0x43, 0x03, 0x2c, 0x00, 0x43, 0xa4, 0x6f, 0x35, 0x6f, 0x17,
0x30, 0x42, 0x6f, 0x51, 0x6f, 0x93, 0x40, 0x42, 0x82, 0x00, 0x41, 0xc3, 0x00, 0x03, 0x43, 0x51, 0x7f, 0x00, 0x2e,
0x94, 0x40, 0x41, 0x41, 0x4c, 0x02, 0xc4, 0x6f, 0x55, 0x56, 0x63, 0x0e, 0x74, 0x6f, 0x51, 0x43, 0xa5, 0x7f, 0x8a,
0x2f, 0x09, 0x2e, 0x88, 0x00, 0x01, 0xb3, 0x21, 0x2f, 0x4f, 0x58, 0x90, 0x6f, 0x13, 0x41, 0xb6, 0x6f, 0xe4, 0x7f,
0x00, 0x2e, 0x91, 0x41, 0x14, 0x40, 0x92, 0x41, 0x15, 0x40, 0x17, 0x2e, 0x6f, 0xf5, 0xb6, 0x7f, 0xd0, 0x7f, 0xcb,
0x7f, 0x98, 0x2e, 0x00, 0x0c, 0x07, 0x15, 0xc2, 0x6f, 0x14, 0x0b, 0x29, 0x2e, 0x6f, 0xf5, 0xc3, 0xa3, 0xc1, 0x8f,
0xe4, 0x6f, 0xd0, 0x6f, 0xe6, 0x2f, 0x14, 0x30, 0x05, 0x2e, 0x6f, 0xf5, 0x14, 0x0b, 0x29, 0x2e, 0x6f, 0xf5, 0x18,
0x2d, 0x51, 0x56, 0x04, 0x32, 0xb5, 0x6f, 0x1c, 0x01, 0x51, 0x41, 0x52, 0x41, 0xc3, 0x40, 0xb5, 0x7f, 0xe4, 0x7f,
0x98, 0x2e, 0x1f, 0x0c, 0xe4, 0x6f, 0x21, 0x87, 0x00, 0x43, 0x04, 0x32, 0x53, 0x54, 0x5a, 0x0e, 0xef, 0x2f, 0x4d,
0x54, 0x09, 0x2e, 0x77, 0xf7, 0x22, 0x0b, 0x29, 0x2e, 0x77, 0xf7, 0xfb, 0x6f, 0x50, 0x5e, 0xb8, 0x2e, 0x10, 0x50,
0x01, 0x2e, 0x84, 0x00, 0x00, 0xb2, 0xfb, 0x7f, 0x51, 0x2f, 0x01, 0xb2, 0x48, 0x2f, 0x02, 0xb2, 0x42, 0x2f, 0x03,
0x90, 0x56, 0x2f, 0x5b, 0x52, 0x79, 0x80, 0x42, 0x40, 0x81, 0x84, 0x00, 0x40, 0x42, 0x42, 0x98, 0x2e, 0x93, 0x0c,
0x5d, 0x54, 0x5b, 0x50, 0xa1, 0x40, 0x98, 0xbd, 0x82, 0x40, 0x3e, 0x82, 0xda, 0x0a, 0x44, 0x40, 0x8b, 0x16, 0xe3,
0x00, 0x53, 0x42, 0x00, 0x2e, 0x43, 0x40, 0x9a, 0x02, 0x52, 0x42, 0x00, 0x2e, 0x41, 0x40, 0x4d, 0x54, 0x4a, 0x0e,
0x3a, 0x2f, 0x3a, 0x82, 0x00, 0x30, 0x41, 0x40, 0x21, 0x2e, 0x6c, 0x0f, 0x40, 0xb2, 0x0a, 0x2f, 0x98, 0x2e, 0xb1,
0x0c, 0x98, 0x2e, 0x45, 0x0e, 0x98, 0x2e, 0x5b, 0x0e, 0xfb, 0x6f, 0xf0, 0x5f, 0x00, 0x30, 0x80, 0x2e, 0xba, 0x03,
0x61, 0x52, 0x57, 0x54, 0x42, 0x42, 0x4f, 0x84, 0x73, 0x30, 0x5f, 0x52, 0x83, 0x42, 0x1b, 0x30, 0x6b, 0x42, 0x23,
0x30, 0x27, 0x2e, 0x87, 0x00, 0x37, 0x2e, 0x84, 0x00, 0x21, 0x2e, 0x86, 0x00, 0x7a, 0x84, 0x17, 0x2c, 0x42, 0x42,
0x30, 0x30, 0x21, 0x2e, 0x84, 0x00, 0x12, 0x2d, 0x21, 0x30, 0x00, 0x30, 0x23, 0x2e, 0x84, 0x00, 0x21, 0x2e, 0x7b,
0xf7, 0x0b, 0x2d, 0x17, 0x30, 0x98, 0x2e, 0x51, 0x0c, 0x59, 0x50, 0x0c, 0x82, 0x72, 0x30, 0x2f, 0x2e, 0x84, 0x00,
0x25, 0x2e, 0x7b, 0xf7, 0x40, 0x42, 0x00, 0x2e, 0xfb, 0x6f, 0xf0, 0x5f, 0xb8, 0x2e, 0x70, 0x50, 0x0a, 0x25, 0x39,
0x86, 0xfb, 0x7f, 0xe1, 0x32, 0x62, 0x30, 0x98, 0x2e, 0xc2, 0xc4, 0x35, 0x56, 0xa5, 0x6f, 0xab, 0x08, 0x91, 0x6f,
0x4b, 0x08, 0x63, 0x56, 0xc4, 0x6f, 0x23, 0x09, 0x4d, 0xba, 0x93, 0xbc, 0x8c, 0x0b, 0xd1, 0x6f, 0x0b, 0x09, 0x4f,
0x52, 0x65, 0x5e, 0x56, 0x42, 0xaf, 0x09, 0x4d, 0xba, 0x23, 0xbd, 0x94, 0x0a, 0xe5, 0x6f, 0x68, 0xbb, 0xeb, 0x08,
0xbd, 0xb9, 0x63, 0xbe, 0xfb, 0x6f, 0x52, 0x42, 0xe3, 0x0a, 0xc0, 0x2e, 0x43, 0x42, 0x90, 0x5f, 0x55, 0x50, 0x03,
0x2e, 0x25, 0xf3, 0x13, 0x40, 0x00, 0x40, 0x9b, 0xbc, 0x9b, 0xb4, 0x08, 0xbd, 0xb8, 0xb9, 0x98, 0xbc, 0xda, 0x0a,
0x08, 0xb6, 0x89, 0x16, 0xc0, 0x2e, 0x19, 0x00, 0x62, 0x02, 0x10, 0x50, 0xfb, 0x7f, 0x98, 0x2e, 0x81, 0x0d, 0x01,
0x2e, 0x84, 0x00, 0x31, 0x30, 0x08, 0x04, 0xfb, 0x6f, 0x01, 0x30, 0xf0, 0x5f, 0x23, 0x2e, 0x86, 0x00, 0x21, 0x2e,
0x87, 0x00, 0xb8, 0x2e, 0x01, 0x2e, 0x87, 0x00, 0x03, 0x2e, 0x86, 0x00, 0x48, 0x0e, 0x01, 0x2f, 0x80, 0x2e, 0x1f,
0x0e, 0xb8, 0x2e, 0x67, 0x50, 0x21, 0x34, 0x01, 0x42, 0x82, 0x30, 0xc1, 0x32, 0x25, 0x2e, 0x62, 0xf5, 0x01, 0x00,
0x22, 0x30, 0x01, 0x40, 0x4a, 0x0a, 0x01, 0x42, 0xb8, 0x2e, 0x67, 0x54, 0xf0, 0x3b, 0x83, 0x40, 0xd8, 0x08, 0x69,
0x52, 0x83, 0x42, 0x00, 0x30, 0x83, 0x30, 0x50, 0x42, 0xc4, 0x32, 0x27, 0x2e, 0x64, 0xf5, 0x94, 0x00, 0x50, 0x42,
0x40, 0x42, 0xd3, 0x3f, 0x84, 0x40, 0x7d, 0x82, 0xe3, 0x08, 0x40, 0x42, 0x83, 0x42, 0xb8, 0x2e, 0x61, 0x52, 0x00,
0x30, 0x40, 0x42, 0x7c, 0x86, 0x3b, 0x52, 0x09, 0x2e, 0x57, 0x0f, 0x41, 0x54, 0xc4, 0x42, 0xd3, 0x86, 0x54, 0x40,
0x55, 0x40, 0x94, 0x42, 0x85, 0x42, 0x21, 0x2e, 0x87, 0x00, 0x42, 0x40, 0x25, 0x2e, 0xfd, 0xf3, 0xc0, 0x42, 0x7e,
0x82, 0x05, 0x2e, 0x79, 0x00, 0x80, 0xb2, 0x14, 0x2f, 0x05, 0x2e, 0x24, 0x02, 0x27, 0xbd, 0x2f, 0xb9, 0x80, 0x90,
0x02, 0x2f, 0x21, 0x2e, 0x6f, 0xf5, 0x0c, 0x2d, 0x07, 0x2e, 0x58, 0x0f, 0x14, 0x30, 0x1c, 0x09, 0x05, 0x2e, 0x77,
0xf7, 0x3f, 0x56, 0x47, 0xbe, 0x93, 0x08, 0x94, 0x0a, 0x25, 0x2e, 0x77, 0xf7, 0x6b, 0x54, 0x50, 0x42, 0x4a, 0x0e,
0xfc, 0x2f, 0xb8, 0x2e, 0x50, 0x50, 0x02, 0x30, 0x43, 0x86, 0x69, 0x50, 0xfb, 0x7f, 0xe3, 0x7f, 0xd2, 0x7f, 0xc0,
0x7f, 0xb1, 0x7f, 0x00, 0x2e, 0x41, 0x40, 0x00, 0x40, 0x48, 0x04, 0x98, 0x2e, 0x74, 0xc0, 0x1e, 0xaa, 0xd3, 0x6f,
0x14, 0x30, 0xb1, 0x6f, 0xe3, 0x22, 0xc0, 0x6f, 0x52, 0x40, 0xe4, 0x6f, 0x4c, 0x0e, 0x12, 0x42, 0xd3, 0x7f, 0xeb,
0x2f, 0x03, 0x2e, 0x6d, 0x0f, 0x40, 0x90, 0x11, 0x30, 0x03, 0x2f, 0x23, 0x2e, 0x6d, 0x0f, 0x02, 0x2c, 0x00, 0x30,
0xd0, 0x6f, 0xfb, 0x6f, 0xb0, 0x5f, 0xb8, 0x2e, 0x40, 0x50, 0xf1, 0x7f, 0x0a, 0x25, 0x3c, 0x86, 0xeb, 0x7f, 0x41,
0x33, 0x22, 0x30, 0x98, 0x2e, 0xc2, 0xc4, 0xd3, 0x6f, 0xf4, 0x30, 0xdc, 0x09, 0x6f, 0x58, 0xc2, 0x6f, 0x94, 0x09,
0x71, 0x58, 0x6a, 0xbb, 0xdc, 0x08, 0xb4, 0xb9, 0xb1, 0xbd, 0x6d, 0x5a, 0x95, 0x08, 0x21, 0xbd, 0xf6, 0xbf, 0x77,
0x0b, 0x51, 0xbe, 0xf1, 0x6f, 0xeb, 0x6f, 0x52, 0x42, 0x54, 0x42, 0xc0, 0x2e, 0x43, 0x42, 0xc0, 0x5f, 0x50, 0x50,
0x75, 0x52, 0x93, 0x30, 0x53, 0x42, 0xfb, 0x7f, 0x7b, 0x30, 0x4b, 0x42, 0x13, 0x30, 0x42, 0x82, 0x20, 0x33, 0x43,
0x42, 0xc8, 0x00, 0x01, 0x2e, 0x80, 0x03, 0x05, 0x2e, 0x7d, 0x00, 0x19, 0x52, 0xe2, 0x7f, 0xd0, 0x7f, 0xc3, 0x7f,
0x98, 0x2e, 0xb6, 0x0e, 0xd1, 0x6f, 0x48, 0x0a, 0xd1, 0x7f, 0x3a, 0x25, 0xfb, 0x86, 0x01, 0x33, 0x12, 0x30, 0x98,
0x2e, 0xc2, 0xc4, 0xd1, 0x6f, 0x48, 0x0a, 0x40, 0xb2, 0x0d, 0x2f, 0xe0, 0x6f, 0x03, 0x2e, 0x80, 0x03, 0x53, 0x30,
0x07, 0x80, 0x27, 0x2e, 0x21, 0xf2, 0x98, 0xbc, 0x01, 0x42, 0x98, 0x2e, 0x91, 0x03, 0x00, 0x2e, 0x00, 0x2e, 0xd0,
0x2e, 0xb1, 0x6f, 0x9b, 0xb8, 0x07, 0x2e, 0x1b, 0x00, 0x19, 0x1a, 0xb1, 0x7f, 0x71, 0x30, 0x04, 0x2f, 0x23, 0x2e,
0x21, 0xf2, 0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0x98, 0x2e, 0x6d, 0xc0, 0x98, 0x2e, 0x5d, 0xc0, 0x98, 0x2e, 0xdf,
0x03, 0x20, 0x26, 0xc1, 0x6f, 0x02, 0x31, 0x52, 0x42, 0xab, 0x30, 0x4b, 0x42, 0x20, 0x33, 0x77, 0x56, 0xf1, 0x37,
0xc4, 0x40, 0xa2, 0x0a, 0xc2, 0x42, 0xd8, 0x00, 0x01, 0x2e, 0x5e, 0xf7, 0x41, 0x08, 0x23, 0x2e, 0x94, 0x00, 0xe3,
0x7f, 0x98, 0x2e, 0xaa, 0x01, 0xe1, 0x6f, 0x83, 0x30, 0x43, 0x42, 0x03, 0x30, 0xfb, 0x6f, 0x73, 0x50, 0x02, 0x30,
0x00, 0x2e, 0x00, 0x2e, 0x81, 0x84, 0x50, 0x0e, 0xfa, 0x2f, 0x43, 0x42, 0x11, 0x30, 0xb0, 0x5f, 0x23, 0x2e, 0x21,
0xf2, 0xb8, 0x2e, 0xc1, 0x4a, 0x00, 0x00, 0x6d, 0x57, 0x00, 0x00, 0x77, 0x8e, 0x00, 0x00, 0xe0, 0xff, 0xff, 0xff,
0xd3, 0xff, 0xff, 0xff, 0xe5, 0xff, 0xff, 0xff, 0xee, 0xe1, 0xff, 0xff, 0x7c, 0x13, 0x00, 0x00, 0x46, 0xe6, 0xff,
0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80,
0xc1, 0xfd, 0x2d
As i wrote also in the init function code, seems that the last function of write returns false and i don't know why exactly; by reading the 0x5e register at end of initialization the byte readed does not correspond to the last byte of the config file so i think that the function is not able to write the whole data config file, the problem is that i tried different method for writing it and the register gives me always the same values.
Here is the main code:
ret_code_t ret;
init_base();
NRF_LOG_INFO("Application Started");
NRF_LOG_FLUSH();
while(!nrf_drv_clock_lfclk_is_running())
/* Just waiting */
/*twi IMU */
twi_master_init();
bool flag_notinit=true;
if(!BMI270_init()){
flag_notinit=false;
NRF_LOG_INFO("LSM6DSO init success!!");
NRF_LOG_INFO("Reading values:....");
BMI270_default();
NRF_LOG_FLUSH();
int16_t gyro[3],acc[3];
while (true)
while (app_usbd_event_queue_process())
/* Nothing to do */
if(!flag_notinit && m_send_flag)
size_t size = sprintf(m_tx_buffer, "INITIALIZATION PROBLEM\r\n");
ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
nrf_delay_ms(500);
}else{
uint8_t register_read;
if(flag_register_reading_info && m_send_flag)
BMI270_register_read(0x5E,®ister_read,1);
size_t size = sprintf(m_tx_buffer, "byte REGISTER: %d\r\n",register_read);
nrf_delay_ms(1000);
size_t size = sprintf(m_tx_buffer, "PROBLEM init default");
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
i am using usbd to comunicate with nrf connect serial monitor.
