Warning : Stack pointer is setup to incorrect alignment. Stack Addr = 0xFFFFFFFF
Dear sir,
Hope you are doing well.
I am trying to debug my project using the IAR toolchain. I am using nRF 52832. In my project, I have added dfu init service for performing OTA.
Now I want to debug my project using IAR toolchain. For that, I have commented the DFU portion for debugging. While debugging I am getting the error of "Stack pointer is setup to incorrect path. Stack Addr = 0xFFFFFFFF". I am using Jlink for compilation.
Any help would be appreciated.
Thanks
    Did you flash the bootloader and Softdevice to your board before you started debugging your project? Also, were you able to debug your project before you started adding DFU support?
    Vidar
  • Here's a tip for IAR if you haven't come across this before; debugging when (eventually) running the SoftDevice is not easy unless the SoftDevice interrupts are allowed to run during a breakpoint halt. Not sure about DFU without SoftDevice.
    #if defined(SOFTDEVICE_PRESENT)
       // This allows all interrupts higher than _PRIO_SD_LOW (ie 4, BLE SD stuff) to continue execution even during a break
       // note Two J-Link commands are required in command file:
       // SetMonModeDebug = 1
       // SetMonModeVTableAddr = ADDR
       //  where ADDR is the application's vector table located in FLASH, ie the start address for the
       // application, probably either 0x1B000 or 0x1C000 or 0x26000 depending on SoftDevice
       // See https://github.com/NordicPlayground/j-link-monitoring-mode-debugging
       NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW);
    IAR-Specific:  enabling-monitor-mode-debugging-in-iar-for-nrf52-when-using-sdk-17-0-2-and-s132-soft-device
    Keil and SES:  j-link-monitoring-mode-debugging
    iar-monitor-mode-debugging-not-linking-correctly
    Ensure JLinkMonitor subdirectory is enabled in the project (not greyed out)
    When finished debugging, in the BLE project settings under Options->Common->Debug->Set Addional J-Link Options
    SetMonModeDebug = 0
    Depending on your J-Link and licence there is an irritating message pop-up at the start of very debug session; this is why we usually leave SetMonModeDebug = 0
    Do not use this for non-BLE projects.
  • I have solved the issue after flashing the soft device using nrfconnect. It is now debugging. Thanks a lot for the support.
