Thingy91 How to manually configure SPI chip select pin as GPIO output pin
I am having some issues with the Thingy91 and SPI. I want to configure GPIO0 8 as GPIO_OUTPUT pin.
This is my source code:
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/spi.h>
#include <zephyr/device.h>
#define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
LOG_MODULE_REGISTER(main);
// Define the CS pin
#define CS_PIN 8
const struct device *gpio_dev;
	int err;
	printk("Program started \n");
	gpio_pin_configure(gpio_dev, CS_PIN, GPIO_OUTPUT);
	if (err < 0)
		printk("GPIO pin configure failed with error %d\n", err);
		return 0;
	k_msleep(1000);
	printk("getting into while loop \n");
	return 0;
You can also access my code at github:
https://github.com/krupis/thingy91_spi_test
gpio_configure_bug branch.
It is also important to mention that on the Thing91 nRF52840, Connectivity Bridge application is running. I am only interested in programming nRF9160.
I have read about how to configure CS pin as GPIO from the following post:
 Is it possible to control SPI chip select pin with Zephyr GPIO API?
and basically copy and pasted the code that has been suggested.
But for me it does not seem to work. The code just halts when gpio_pin_configure(gpio_dev, CS_PIN, GPIO_OUTPUT)is called. I have tried looking at the serial monitor but no logs are coming out even though I have added multiple printk statements.
After launching debugger, I have discovered that the Securefault_hanlder is triggered when the gpio_pin_configure is called:
I have 2 questions
  1. Am I configuring the GPIO correctly? (gpio0 8). If not, could you suggest an alternative way?
  2. Why am I not seeing a single printk statement being printed to the serial console? I have printk("Program started \n"); statement before the gpio_pin_configure call but that never gets printed.
Thanks in advance.
Parents Reply
  • Yeah I figured that could be the case. The reason why I believe it could be somehow related to the Thingy 91 is because it does not support logging via UART from the nRF9160 by default. You need to have connectivity bridge application running on the nRF52840 so all the logs from the nRF9160 are transfered the nRF52840 and then being transfered to serial monitor.
    Perhaps that has to do something why it acts so weird.
