DFU: nRF51822 OTA bootloader jams after reset_prepare()
I managed to upload my application OTA DFU when there was only the bootloader running. After my application is there, I can start DFU and my application runs thru reset_prepare() function as expected. However, it seems that it never enters the bootloader although DfuTarg seems to appear as an available BLE device. So I cannot upload my application another time :(
Any ideas what could be wrong? Why my application does not start bootloader (correctly) after reset_prepare()?
EDIT: The bootloader enters event loop and jams there, see the code below (from bootloader.c/nRF51_SDK_8.0.0_5fc2c3a). The DFU loader at phone side says "disconnected" (mostly, sometimes it jams). I cannot reconnect although DfuTarg is visible.
for (;;)
    // Wait in low power state for any events.
    uint32_t err_code = sd_app_evt_wait();
	myLedIndication(); // This shows me bootloader is running here very busy
    // Event received. Process it from the scheduler.
    app_sched_execute();
    if ((m_update_status == BOOTLOADER_COMPLETE) ||
        (m_update_status == BOOTLOADER_TIMEOUT)  ||
        (m_update_status == BOOTLOADER_RESET))
        // When update has completed or a timeout/reset occured we will return.
        return;
And the reset_prepare() looks like:
static void reset_prepare(void)
	uint32_t err_code;
	if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
		// Disconnect from peer.
		err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
		//err_code = bsp_indication_set(BSP_INDICATE_IDLE);
		//APP_ERROR_CHECK(err_code);
		// If not connected, the device will be advertising. Hence stop the advertising.
		advertising_stop();
	err_code = ble_conn_params_stop();
