Two services on a single device
Here's what we're trying to do. We have a gesture recognition wearable that is intended to be used as a remote control for a smartphone. But some smartphone functions are easier to implement using the HID service and some using a custom service. We have the wearable and the phone connected and both services are shown in nRF Connect but if we pair with the HID service first we cannot connect to the custom service using a custom app on the smartphone. Similarly, if we pair to the custom service first, we cannot use the HID service. How do we get both services to work simultaneously from one device?
  • I'm kind of stumped here. I keep getting an NRF_ERROR_NO_MEM when initializing the adv object for one of the services, but from the map file it seems there's plenty of room in RAM. Here's the error message that hardfaults the instant I try to run advertising_init_cus. Debugger output, map file and code snippet attached.
    Haptic driver interface go!
    LIS3MDL Sensor interface go!
    <info> app_timer: RTC: initialized.
    <debug> nrf_sdh: State request: 0x00000000
    <debug> nrf_sdh: Notify observer 0x00044078 => ready
    <debug> nrf_sdh: State change: 0x00000000
    <debug> nrf_sdh: State change: 0x00000001
    <debug> nrf_sdh_ble: RAM starts at 0x20002800
    <info> ble_bms: Init complete.
    <info> app: HID Keyboard example started.
    <info> app: Fast advertising.
    <debug> nrf_sdh_ble: BLE event: 0x10.
    <info> app: Connected
    <error> app: ERROR 4 [NRF_ERROR_NO_MEM] at C:\Nordic\gestr_GRM_Rev2.0\main.c:3809
    PC at: 0x0002BFB5
    <error> app: End of error report
    0624.gestr_GRM_Rev2.0.map
    void advertising_init_cus(void)
        uint8_t                adv_flags;
        ble_advertising_init_t init;
        //apdobaj move the uuid's to the scan response packet to advertise the whole name
        ble_advdata_t sr_data;
        memset(&sr_data, 0, sizeof(sr_data));
        adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = false;
        //apdobaj change flags per HRS example
        init.advdata.flags                   = adv_flags;
        //init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids_cus) / sizeof(m_adv_uuids_cus[0]);
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids_cus;
        init.config.ble_adv_whitelist_enabled          = false; //apdobaj debug note setting
        init.config.ble_adv_directed_high_duty_enabled = false;
        // try connecting to the most recent connection
        init.config.ble_adv_directed_enabled           = false;
        init.config.ble_adv_directed_interval          = APP_ADV_DIRECTED_INTERVAL;
        init.config.ble_adv_directed_timeout           = APP_ADV_DIRECTED_DURATION;
        init.config.ble_adv_fast_enabled               = true;
        init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
        init.config.ble_adv_slow_enabled               = true;
        init.config.ble_adv_slow_interval              = APP_ADV_SLOW_INTERVAL;
        init.config.ble_adv_slow_timeout               = APP_ADV_SLOW_DURATION;
        init.evt_handler   = on_adv_evt_cus;
        init.error_handler = ble_advertising_error_handler;
        err_code = ble_advertising_init(&m_advertising_cus, &init);
        ble_advertising_conn_cfg_tag_set(&m_advertising_cus, APP_BLE_CONN_CFG_TAG);
  • I really need to get this figured out, your attention would be most appreciated.
    Thank you for your patience with this.
    apdobaj said:
    The device is bonded with the smartphone, and the app that handles the custom service connects without intervention, so my conclusion is that it's bonded.
    Could you share the full log from your device when both connections are live?
    apdobaj said:
    I've discovered that with both services running , if the smartphone goes out of BT range, neither of the services reconnect automatically. But if I run the HID service and not the custom one, the reconnect happens as expected and all is good. What might be preventing the HID service to reconnect when the custom service is active? What is supposed to happen during a reconnect with a bonded peripheral following a  reason 8 disconnect?
    Reason 8 is connection time out, which is expected when the peer stops replying (such as if it goes out of range).
    What happens after the disconnection is up to the peripheral device - you could for instance attempt to reconnect quickly by doing high duty cycle directed advertising targeting the peer that was just lost, to attempt to reconnect, or you could start to advertise normally again and see if the central device shows up again.
    You will then need to make sure that your central device is also immediately attempting to reconnect to the lost peer, if you wish for that to happen.
    Assuming the NRF_ERROR_NO_MEM is returned by the call to ble_advertising_init, then it likely stems from sd_ble_gap_adv_set_configure which will be returned when there is not enough memory to configure a new advertising set.
    Could you possibly share the full main.c source file (or the file where you set up your advertising) here instead, so that I may see what might be happening here? It would also be great if you could share your sdk_config.h file, so that I may take a look there as well.
    Please let me know if you would like me to make the ticket private before sharing, in case there is any sensitive code.
    A private ticket is only viewable by yourself and the support staff here at Nordic.
    As a side-note you should also change to using the BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE flag if your advertising will timeout and stop (as opposed to using an infinite advertising duration).
    Karl
  • The no mem issue appears to have been a bad sensor with a stuck interrupt bit. This is very difficult to reproduce in a reliable way, but the two services seem to be coexisting. I did this by getting the HID service to connect and bond first and not starting the custom service advertising until after. But now I can't read the characteristic value in nRF Connect for android, or any other similar app for that matter. I can connect to the server with the app but when I tap refresh services the whirliegig just keeps spinning forever and none of the arrow buttons do anything. Another app told me that notifications were disabled so I added the following to the init structure for the custom service:
        cus_init.custom_value_char_attr_md.cccd_write_perm.sm = 1;
        cus_init.custom_value_char_attr_md.cccd_write_perm.lv = 1;
        cus_init.custom_value_char_attr_md.write_perm.sm = 1;
        cus_init.custom_value_char_attr_md.write_perm.lv = 1;
        cus_init.custom_value_char_attr_md.read_perm.sm = 1;
        cus_init.custom_value_char_attr_md.read_perm.lv = 1;
    The app now reports that notifications are enabled but the services still don't refresh and I still cannot read the characteristic values in nRF connect on Android. And you suggest adding the BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE  flag, how and why would I want to do that? Please advise.
    Karl is out of office, so I will look into your questions.
    I am sorry but there is a lot of information in this ticket. Is it correct that you are trying to connect, then add a new service after the connection? You are not trying to have two concurrent connections with the same device, right?
    Your snippet:
    "cus_init.custom_value_char_attr_md. ..."
    Where do you use this? The custom_calue_char_attr_md is not something coming from us, so it must be something that you wrote. I understand the context, and that you are trying to say that the device needs to be paired to use this characteristic, but perhaps you can show how it is used in your code?
    If the issue is that you do not see the other service on the mobile phone, do you see it if you try to connect to it using nRF Connect for Desktop -> Bluetooth Low Energy?
    BR,
    Edvin
