Two services on a single device
Here's what we're trying to do. We have a gesture recognition wearable that is intended to be used as a remote control for a smartphone. But some smartphone functions are easier to implement using the HID service and some using a custom service. We have the wearable and the phone connected and both services are shown in nRF Connect but if we pair with the HID service first we cannot connect to the custom service using a custom app on the smartphone. Similarly, if we pair to the custom service first, we cannot use the HID service. How do we get both services to work simultaneously from one device?
  • There is no second device, only a second service from the same device. But I need both services to be working so I'm heading down that path. So I'm trying to fix the 3401 error (attribute missing) when calling sd_ble_gatts_hvx by getting the attributes and then setting them. Here is the code for that:
        ret_code_t err_code;
        uint8_t p_attr_data[4];
        uint16_t p_len[1];
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                //apdobaj 27Jun2023 set tx power
                err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, +8);
                //apdobaj 3Mar2024 get and set system attributes to prevent error 3401 when calling
                //  sd_ble_gatts_hvx in ble_hids.c
                //Use a null pointer to get back the data length.
                err_code = sd_ble_gatts_sys_attr_get(m_conn_handle, NULL, p_len, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                err_code = sd_ble_gatts_sys_attr_get(m_conn_handle, p_attr_data, p_len, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, p_attr_data, *p_len, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                //apdobaj connect HID first then custom
                nrf_delay_ms(2);
    #if defined(USE_CUSTOM_SERVICE)
                advertising_init_cus();
                advertising_start_cus();
    The first call to sd_ble_gatts_sys_attr_get with the NULL attribute pointer is to get the length of the attribute data (this comes from the infocenter which states "NULL can be provided to obtain the length of the data."). But this call returns error code 5 which according to nrf_error.h means NRF_ERROR_NOT_FOUND which according to the comments in ble_gatts.h means "no system attributes found". The second call to sd_ble_gatts_sys_attr_get returns the same error.
    Am I understanding this correctly? Is the 3401 error the root cause of the keycode not being sent to the smartphone? Why would this error change to 0x0F when disabling the second service? If this is the correct resolution, why is sd_ble_gatts_sys_attr_get  returning error 5? Please advise.
    Ah, but then you will still need to bond with the second link, if the links are two separate links.
    Please make sure to check the error codes returned by your calls to sd_be_gatts_sys_attr_get as well.
    NRF_ERROR_NOT_FOUND means that the variable you are trying to read is not found.
    I am only seeing get calls here, and no set - if the issue is that these variables has not been set yet you will not be able to get them.
    You will need to add the sd_ble_gatts_sys_attr_set call to your handlng of the BLE_GAP_SYS_ATTR_MISSING event handling.
    Please see this comment, for instance.
    Karl
  • Ah, but then you will still need to bond with the second link, if the links are two separate links.
    The device is bonded with the smartphone, and the app that handles the custom service connects without intervention, so my conclusion is that it's bonded.
    There are two get commands and one set command. The first get is to obtain the size of the attribute data as I mentioned earlier. And there is no BLE_GAP_SYS_ATTR_MISSING event in SDK 17.1. Can you confirm that the 3401 error would exhibit that behavior (calling send_key_scan_press_release in the HID application runs but the code is never received by the smartphone)?
  • This line of inquiry might be a red herring. It seems the custom service handler is reaching the BLE_GAP_EVT_CONNECTED event before it's connected. Here's the call stack when breaking on line 278 of ble_cus.c.
    Could this be interfering with the HID service?
  • I've discovered that with both services running , if the smartphone goes out of BT range, neither of the services reconnect automatically. But if I run the HID service and not the custom one, the reconnect happens as expected and all is good. What might be preventing the HID service to reconnect when the custom service is active? What is supposed to happen during a reconnect with a bonded peripheral following a  reason 8 disconnect?
