I designed before my board for 2 layer PCB and i used the coplanar waveguide with ground-plane in the bottom. now i want to move to the 4 PCB layer and i choose the ground-plane as the layer number 2 just above the top-layer, and i have some doubt about the design.
as known the track width depend on the characteristic of the board in order to match 50 Ohm, like the cooper thickness, the distance between the top layer and the Ground-plane layer....
i will make the board with oshpark and here the Fabrication Spec here : docs.oshpark.com/.../
above a screenshot of the calculation that i made to determine the track width :
as described in the oshpark 4 layer spec the separation between the top layer and the layer number 2 is the prepreg which width is equal to 6.7mil = 0.17018 .
and the dielectric is equal 3.66 @ 1Ghz according to this docs.oshpark.com/.../FR408-High-Performance-Laminate-and-Prepreg-Data-Sheet.pdf
Here's how it look like my board :
i choose the PI network components with 0402 dimension to be as closest as possible to the track width.
are my calculation correct ? did i made something wrong ?
