How to enable APPPROTECT, SECUREAPPROTECT and ERASEPROTECT on nRF5340?
Hi All
I'm devolving the product by using nRF5340. I found a problem when I needed to disable the J-Link Port by enabling APPPROTECT, SECUREAPPROTECT and ERASEPROTECT.
This is my source for testing that feature.
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr/kernel.h>
#define GPIO_DEV     gpio0
#define BUTTON_A_PIN 23
#define BUTTON_B_PIN 24
#define LED_PIN      30
#define UNLOCK_KEY   0xDEADBEEF
static const struct device *gpio_dev;
    k_msleep(3000);
    printk("Start Program %s\n", CONFIG_BOARD);
    k_msleep(1000);
    NRF_NVMC->CONFIG = ( (NVMC_CONFIG_WEN_Wen  ) << NVMC_CONFIG_WEN_Pos);
    while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
    NRF_UICR->APPROTECT = 0x00000000;
    NRF_UICR->SECUREAPPROTECT = 0x00000000;
    NRF_UICR->ERASEPROTECT = 0x00000000;
    NRF_NVMC->CONFIG = ( (NVMC_CONFIG_WEN_Ren  ) << NVMC_CONFIG_WEN_Pos);
    gpio_dev = DEVICE_DT_GET(DT_NODELABEL(GPIO_DEV));
    if (NULL == gpio_dev)
        printk("gpio_dev is null\r\n");
        k_msleep(1000);
        gpio_pin_configure(gpio_dev, BUTTON_A_PIN, GPIO_INPUT | GPIO_PULL_UP);
        gpio_pin_configure(gpio_dev, BUTTON_B_PIN, GPIO_INPUT | GPIO_PULL_UP);
        while (1)
            if (0 == gpio_pin_get_raw(gpio_dev, BUTTON_A_PIN))
                k_msleep(50);
                    printk("Button A has been pushed\r\n");
                    printk("Unlock nRF5340 with key: %X\r\n", UNLOCK_KEY);
                    NRF_CTRLAP->ERASEPROTECT.DISABLE = UNLOCK_KEY;
                    NRF_CTRLAP->APPROTECT.DISABLE    = UNLOCK_KEY;
                while (0 == gpio_pin_get_raw(gpio_dev, BUTTON_A_PIN))
                    k_msleep(10);
            if (0 == gpio_pin_get_raw(gpio_dev, BUTTON_B_PIN))
                k_msleep(50);
                    printk("Button B has been pushed\r\n");
                    printk("NRF_CTRLAP->ERASEPROTECT.DISABLE: %X\r\n", NRF_CTRLAP->ERASEPROTECT.DISABLE);
                    printk("NRF_CTRLAP->APPROTECT.DISABLE   : %X\r\n", NRF_CTRLAP->APPROTECT.DISABLE);
                while (0 == gpio_pin_get_raw(gpio_dev, BUTTON_B_PIN))
                    k_msleep(10);
    return 0;
} /* main */
And this is my project configuration.
# nothing here
CONFIG_GPIO=y
However, after I uploaded my firmware to the nRF5340DK board, I powered off and powered on the DK board again.
Next step, I try to read "ERASEPROTECT.STATUS 0x018" by using the script below.
SWDSelect // Activate SWD
SWDWriteDP 1 0x50000000
SWDWriteDP 2 0x02000010
SWDReadAP 2
SWDReadAP 2
exit
The result of this script is shown below.
JLink.exe -commandfile 00F_Get_EraseProtect_Status.jlink
SEGGER J-Link Commander V7.88j (Compiled Jun 28 2023 13:40:51)
DLL version V7.88j, compiled Jun 28 2023 13:39:15
J-Link Command File read successfully.
Processing script file...
J-Link>SWDSelect // Activate SWD
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link OB-nRF5340-NordicSemi compiled Aug 8 2023 16:16:56
Hardware version: V1.00
J-Link uptime (since boot): 0d 00h 00m 06s
S/N: 1050074579
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
USB speed mode: Full speed (12 MBit/s)
VTref=3.300V
Select SWD by sending SWD switching sequence.
Found SWD-DP with ID 0x6BA02477
J-Link>SWDWriteDP 1 0x50000000
Write DP register 1 = 0x50000000
J-Link>SWDWriteDP 2 0x02000010
Write DP register 2 = 0x02000010
J-Link>SWDReadAP 2
Read AP register 2 = 0x00000000
J-Link>SWDReadAP 2
J-Link>exit
Script processing completed.
From that result, I believe I have successfully enabled ERASEPROTECT.
However, when I try to re-program the nRF5340, it takes around 2 – 3 times. The process allowed us to upload the new firmware, as shown below.
(I click yes)
Flashing build to 1050074579
west flash -d c:\ncs\v2.4.0\zephyr\samples\hello_world\build --skip-rebuild --dev-id 1050074579
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: c:\ncs\v2.4.0\zephyr\samples\hello_world\build\zephyr\zephyr.hex
[ #################### ] 0.948s | Erase file - Done erasing
[ #################### ] 0.205s | Program file - Done programming
[ #################### ] 0.164s | Verify file - Done verifying
Applying pin reset.
-- runners.nrfjprog: Board with serial number 1050074579 flashed successfully.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Build: hello_world/build (active)
Building hello_world
west build --build-dir c:/ncs/v2.4.0/zephyr/samples/hello_world/build c:/ncs/v2.4.0/zephyr/samples/hello_world
ninja: no work to do.
* Executing task: nRF Connect: Flash: hello_world/build (active)
[error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 16 milliseconds with result -90
[error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.
[error] [ Client] - Encountered error -90: Command erase_file executed for 14 milliseconds with result -90
[error] [ nRF53] - Failed while detecting device memory block protection status!
[error] [ nRF53] - Failed while erasing device. -90: Access protection is enabled, can't read block protection state.
[error] [ Worker] - Access protection is enabled, can't read block protection state.
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
ERROR: runners.nrfjprog: Flashing failed because the target must be recovered.
To fix, run "west flash --recover" instead.
Note: your target is an nRF53; all flash memory for both the network and application cores will be erased prior to reflashing.
FATAL ERROR: command exited with status 24: nrfjprog --program 'c:\ncs\v2.4.0\zephyr\samples\hello_world\build\zephyr\zephyr.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050074579
* The terminal process terminated with exit code: 24.
west flash -d c:\ncs\v2.4.0\zephyr\samples\hello_world\build --skip-rebuild --dev-id 1050074579 --recover
-- runners.nrfjprog: Recovering and erasing flash memory for both the network and application cores.
[error] [ Client] - Encountered error -90: Command enable_coprocessor executed for 6 milliseconds with result -90
Recovering device. This operation might take 30s.
[error] [ Worker] - Application core access protection is enabled, can't enable coprocessor.
[error] [ Client] - Encountered error -21: Command recover executed for 1038 milliseconds with result -21
[error] [ nRF53] - Application core access protection is enabled, can't enable coprocessor.
[error] [ Worker] - Encountered error during recovery cleanup, -90: Exception encountered while enabling coprocessor
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
FATAL ERROR: command exited with status 62: nrfjprog --recover -f NRF53 --coprocessor CP_NETWORK --snr 1050074579
* The terminal process terminated with exit code: 62.
[ #################### ] 0.914s | Erase file - Done erasing
[ #################### ] 0.203s | Program file - Done programming
Applying pin reset.
What is wrong with my code?
Do you have any suggestions for my problem?
Wasan
    Firstly, I advise you to be very careful when doing this. If you enable ERASEPROTECT and APPROTECT at the same time and do not have firmware running on the nRF to unlock the ERASEPROTECT or APPROTECT you will no longer be able to reprogram your chip.
    Can I suggest that you implement a timeout that will automatically unlock the nRF after X seconds when you are developing?
    Then I suggest you try to use the features standalone one by one first.
    For approtect, see Enabling access port protection mechanism.
    For eraseprotect, see my unofficial sample, but mark its disclaimers.
    PS: For the nRF5340, I think you might have to enable approtect for the network core as well.
    Sigurd Hellesvik
  • HI Sigurd
    Thank you for your information.
    Actually, I work with nRF9160 to enable APPPROTECT, SECUREAPPROTECT, and ERASEPROTECT of the nRF device before using nRF5340. In this post, I've submitted a ticket providing information on how to enable it:
    https://devzone.nordicsemi.com/f/nordic-q-a/93169/how-to-remove-the-nrf9160-s-erase-protection
    However, I've discovered that the same process doesn't work when applied to nRF5340. After studying your playground and reviewing the information, I found differences between nRF9160 and nRF5340 regarding the mechanism to lock. Here are the key distinctions:
    1. nRF9160 has only one core, while nRF5340 has two cores – an application core and a network core, both of which need to be locked .
    2. If I lock only the application core of nRF5340, the device can still unlock the J-Link port when attempting to recover the network core.
    3. I have found a new method using nrfjprog to enable app-protect and enable erase-protect. This approach is easier compared to using J-Link scripts as mentioned above.
    Example script for using to enable APPPROTECT, SECUREAPPROTECT and ERASEPROTECT of nRF5340
    # Enable APPPROTECT and ERASEPROTECT of network core
    nrfjprog.exe -f NRF53 --coprocessor CP_NETWORK --memwr 0x01FF8004 --val 0x00000000 --verify
    nrfjprog.exe -f NRF53 --coprocessor CP_NETWORK --memwr 0x01FF8000 --val 0x00000000 --verify
    # Enable APPPROTECT, SECUREAPPROTECT and ERASEPROTECT of application core
    nrfjprog.exe -f NRF53 --coprocessor CP_APPLICATION --memwr 0x00FF8020 --val 0x00000000 --verify
    nrfjprog.exe -f NRF53 --coprocessor CP_APPLICATION --memwr 0x00FF801C --val 0x00000000 --verify
    nrfjprog.exe -f NRF53 --coprocessor CP_APPLICATION --memwr 0x00FF8000 --val 0x00000000 --verify
    nrfjprog.exe -p
    #Noted: Noted: Before using this command, please ensure that your application has a method to #disable ERASEPROTECT both the network core and application core.
    Best Regards
    Wasan
