Output driver not working for P1.13 on nRF5340 DK
I am trying to set up two GPIOs to control an external chip. Development and testing is currently using the nRF5340 DK. NCS version is 2.5.0.
In my nrf5340dk_nrf5340_cpuapp.overfile, I have the following. There are other GPIOs, but ignore those for now. Also, ignore the fact that reset should be an open-drain. I am just sanity testing right now. The pins are not connected and only being monitored with a logic analyzer.
    gpiocustom {
        compatible = "gpio-keys";
        gpiocus1: gpiocus_1 {
            gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
            label = "nRST";
        gpiocus2: gpiocus_2 {
            gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
            label = "MFIO";
    aliases {
        max32664reset = &gpiocus1;
        max32664mfio = &gpiocus2;
In the code we have:
static const struct gpio_dt_spec gpio_sh_reset = GPIO_DT_SPEC_GET(DT_ALIAS(max32664reset), gpios);
static const struct gpio_dt_spec gpio_sh_mfio = GPIO_DT_SPEC_GET(DT_ALIAS(max32664mfio), gpios);
and then to test it we have the following declarations
    gpio_pin_configure_dt(&gpio_sh_reset, GPIO_OUTPUT_HIGH);
    gpio_pin_configure_dt(&gpio_sh_mfio, GPIO_OUTPUT_HIGH);
and test code
    for(int i = 0; i < 3; i++)
        k_msleep(500);
        gpio_pin_set_dt(&gpio_sh_mfio, 0);
        k_msleep(500);
        gpio_pin_set_dt(&gpio_sh_reset, 0);
        k_msleep(500);
        gpio_pin_set_dt(&gpio_sh_mfio, 1);
        k_msleep(500);
        gpio_pin_set_dt(&gpio_sh_reset, 1);
asd
The MFIO pin (P1.14) moves. The reset pin (P1.13) does not. I have done a lot of tracing to determine exactly where the problem is occurring. It happens at:
reg->PIN_CNF[pin_number] = cnf;
When the pin configuration gets changed from input-with-pullup to output. This is in nrf_gpio_reconfigure() and is occurring in the secure domain at 0x50842a34. The nRF Debug peripheral registers view does not seem to give access to GPIO P1 in the secure domain, so I am using gdb commands in the debug console to set and verify the P1_S registers and observing the result via Saleae logic analyzer. I must do this while still in the nrf driver functions or I lose privilage to access 0x50000000 register range from the debug console.
Here are my observations:
Set P1.13 high via pullup, *((uint32_t*)0x50842a34)=0xC, pin goes high.
Set P1.13 low via pulldown, *((uint32_t*)0x50842a34)=0x4, pin goes low.
Set P1.13 to output, *((uint32_t*)0x50842a34)=0x3, pin goes low and stays low regardless of state of P1->OUT bit 13. I have set and cleared the bit by using *((uint32_t*)0x50842808)=0x2000 and *(uint32_t*)0x5084280c)=0x2000. The pin state does not change. 0x50842a34 verifies that it is in output mode, owned by APP CPU, with drive set to S0S1 (i.e. register = 0x03). When I change P1.14 using *((uint32_t*)0x50842808)=0x4000 and *((uint32_t*)0x5084280c)=0x4000, that pin does change.
One thing I noticed, if I have the pin in input-with-pullup state and then set it to output, it doesn't go straight to 0. It decays to 0 as though it's draining through something (possibly the Saleae?). That's why I suggest that it seems the output driver is not even connected when PIN_CFG[13].DIR is set to output.
I have searched around in the nRF5340 product specification and on the PCA10095 schematic and cannot figure out anything that would be interfering with P1.13.
  • Ah, never mind. I have found the source of the problem:
        uart3_default: uart3_default {
            group1 {
                psels = <NRF_PSEL(UART_TX, 1, 12)>,
                    <NRF_PSEL(UART_RTS, 1, 10)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 1, 11)>,
                    <NRF_PSEL(UART_CTS, 1, 13)>;
                bias-pull-up;
    It seems that this must be affecting OUT_OVERRIDE, DIR_OVERRIDE or both. That is my problem.
  • Assuming your board is based on nrf5340dk, I noticed in boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet-pinctrl.dtsi
    spi0_default: spi0_default {
    group1 {
    psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,
    <NRF_PSEL(SPIM_MISO, 1, 14)>,
    <NRF_PSEL(SPIM_MOSI, 1, 13)>;
    This means the pins are assigned to cpunet and settings from the application process wlll not be used.
  • On further investigation, I see that the overlay view in VS Code does have a squiggle underline for the conflict and does provide a pop-up saying there is a conflict when hovering over the underlined value.
    I am going to change this ticket to a feature request. Would it be possible to have this conflict cause a build failure, or is it considered valid to do this?
  • In the final build/zephyr/zephyr.dts I see that spi4 also has a claim on 0x2D (i.e. P1.13). However, spi4 is disabled in this configuration. That spi4 configuration must be coming from .dtsi files. I wish there was an easier way to view all the pin assignments.
  • Two tips, not sure if either is exactly what you want:
    * In Visual Studio Code in the nRF Connect extension there is an Action called "Devicetree" which allows exploring the device tree files.
    * All the devicetree configuration ends up in
    build_dir/zephyr/include/generated/device_tree_generated.h
    or for cpunet  in
    build_dir/hci_rpmsg/zephyr/include/generated/device_tree_generated.h
    these files are big and not exactly pretty but I believe they have everything determined from devicetree in it.
    BTW, if you know anyone looking for a developer experienced with zephyr and Nordic's SDK, I'm currently looking for new clients:
    www.linkedin.com/.../
