"Error: sending the request failed" trying to perform OTA DFU with nRF Connect app
I am on nRF Connect 2.5.0 SDK. I am trying to add OTA DFU support to my custom board using the MCUBoot bootloader, and everything appears normal when I look at the characteristic table but when trying to upload to the device using the nRF Connect app on iOS, the app appears to slowly upload the firmware (displaying low upload speed ~0.5kbps) then after a few minutes gives me "Error: sending the request failed". My board has no UART connection and I have been using RTT logging using the J-link on an nrf52DK; from what I have seen MCUboot logging with RTT is not reliable, and I have not been able to get it to work either.
My procedure:
1. Build and flash MCUboot and app onto the custom board with an nrf52DK.
2. Change my app and build the new app.
3. use nRF Connect app to try to upload 'app_update.bin' to device in upgrade mode "test and confirm". The procedure always fails before completing.
Here is my bootlaoder config in my prj.conf:
# Bootloader Configuration
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE=n
CONFIG_IMG_MANAGER=y
CONFIG_PARTITION_MANAGER_ENABLED=y
# Enable most core commands.
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
# Enable mcumgr.
CONFIG_MCUMGR=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_AUTHEN=n
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=3072
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y
# LOGGING Configuration
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
CONFIG_THREAD_NAME=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_INIT_STACKS=y
CONFIG_THREAD_ANALYZER=y
# Bluetooth Configuration
CONFIG_BT=y
CONFIG_BT_NUS=y
CONFIG_BT_SMP=n
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_THROUGHPUT=y
CONFIG_BT_DEVICE_NAME="test"
CONFIG_BT_DEVICE_APPEARANCE=832
CONFIG_BT_PRIVACY=n
CONFIG_BT_MAX_CONN=1
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_AUTO_PHY_UPDATE=y
CONFIG_BT_BUF_ACL_TX_COUNT=20
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
CONFIG_BT_ATT_PREPARE_COUNT=2
Here is my child_image/mcuboot.conf:
CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
#this is an absolute path, change it yourself
CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/Vitalmark/keys/private.pem"
#reduce mcuboot partition size
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
# Disable UART Console and enable the RTT console
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
# Config logger
CONFIG_LOG_BACKEND_UART=n
CONFIG_MULTITHREADING=y
and I have also statically defined the flash partitions in pm_static.yml based on the first automatically partitioned build:
app:
  address: 0x10200
  end_address: 0x48000
  region: flash_primary
mcuboot:
  address: 0x0
  end_address: 0x10000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  end_address: 0x10200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x10200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x48000
  end_address: 0x80000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
    align_next: 0x1000
  share_size:
  - mcuboot_primary
sram_primary:
  address: 0x20000000
  end_address: 0x20010000
  region: sram_primary
Here is the log from the nrf connect app:
Scanner On.
Device Scanned.
Device Appearance switched from Generic to UART.
Connected.
Discovered Nordic UART Service, 0483DADD-6C9D-6CA9-5D41-03AD4FFF4ABB, and SMP Service Services.
Discovered Characteristics UART TX Characteristic and UART RX Characteristic for Service Nordic UART Service.
Discovered Characteristics 1524 for Service 0483DADD-6C9D-6CA9-5D41-03AD4FFF4ABB.
Discovered Characteristics SMP Characteristic for Service SMP Service.
Discovered Client Characteristic Configuration for Characteristic UART TX Characteristic
Characteristic UART RX Characteristic has no Descriptors.
Characteristic 1524 has no Descriptors.
Device Appearance switched from UART to McuMgrDFU.
Discovered Client Characteristic Configuration for Characteristic SMP Characteristic
Found valid Firmware in file:///var/mobile/Containers/Data/Application/4D4197EB-C6BC-4ECA-861F-10957E6527CB/Library/Caches/app_updateAF08E5E7-D04E-4537-986B-CAA02FF5CA2D-95620-00001C3F1CF8B74E.bin for Device DFU McuMgr.
Central Manager ready
Peripheral connected
Device ready
LIST Command Performed with Success.
Upgrade started with 1 image(s) using 'Test and Confirm' mode
Firmware Upgrade Started.
State changed from none to requestMcuMgrParameters
Device ready
Mcu Manager parameters received (4 x 2475)
State changed from requestMcuMgrParameters to bootloaderInfo
Bootloader info received (mode: Swap without scratch)
State changed from bootloaderInfo to validate
Image List response: Header: {"version": "1", "op": "1", "flags": 0, "length": 134, "group": 1, "seqNum": 129, "commandId": 0}, Payload: {"splitStatus" : 0, "images" : {{"confirmed" : true, "bootable" : true, "pending" : false, "slot" : 0, "active" : true, "version" : "0.0.1", "permanent" : false, "hash" : 0xC3ED37EE6691E2DAF0070AEF8FC5C2EE5651FAE20D6EEE2CDC8C40E2720025B7}}}
Scheduling upload (hash: 0x468347114A3BAEB15B0D72C5D64286A195190BF76D65F3A5C87DAD409B5A5A8A) for image 0 (slot: 1)
State changed from validate to upload
Retry 1 for seq: 132
Retry 1 for seq: 133
Retry 1 for seq: 139
Retry 1 for seq: 144
Retry 1 for seq: 145
Retry 1 for seq: 146
Retry 2 for seq: 144
Retry 1 for seq: 148
Retry 1 for seq: 149
Retry 1 for seq: 150
Retry 2 for seq: 148
Retry 1 for seq: 155
Retry 1 for seq: 156
Scanner Off.
Retry 2 for seq: 156
Retry 1 for seq: 164
Retry 1 for seq: 165
Retry 1 for seq: 173
Retry 1 for seq: 174
Retry 1 for seq: 175
Retry 2 for seq: 173
Retry 1 for seq: 184
Retry 1 for seq: 185
Retry 1 for seq: 186
Retry 2 for seq: 185
Retry 1 for seq: 194
Retry 1 for seq: 195
Retry 1 for seq: 202
Retry 1 for seq: 203
Retry 1 for seq: 204
Retry 1 for seq: 205
Retry 1 for seq: 210
Retry 1 for seq: 215
Retry 1 for seq: 216
Retry 1 for seq: 217
Retry 1 for seq: 218
Retry 2 for seq: 218
Retry 1 for seq: 233
Retry 1 for seq: 234
Retry 1 for seq: 235
Retry 2 for seq: 233
Retry 1 for seq: 245
Retry 2 for seq: 245
Retry 1 for seq: 6
Retry 1 for seq: 7
Retry 1 for seq: 8
Retry 2 for seq: 8
Retry 1 for seq: 21
Retry 1 for seq: 26
Retry 1 for seq: 32
Retry 2 for seq: 32
Retry 1 for seq: 48
Retry 1 for seq: 49
Retry 1 for seq: 50
Retry 2 for seq: 48
Retry 2 for seq: 50
Retry 1 for seq: 58
Retry 2 for seq: 58
Retry 1 for seq: 77
Retry 1 for seq: 78
Retry 1 for seq: 79
Retry 2 for seq: 77
Retry 1 for seq: 89
Retry 1 for seq: 98
Retry 1 for seq: 99
Retry 2 for seq: 89
Retry 3 for seq: 89
Request (SMPv2, group: image, seq: 89, command: upload) failed: Sending the request failed.
Upload cancelled due to error: sendFailed
Image upload is not in progress
DFU failed: Sending the request failed.
DFU Failed with Error: Sending the request failed.
I am fairly certain it is not a connection issue, since I never had any issues with the old NordicDFU on the nrf5 SDK using the exact same board. Since I don't have a UART port for MCUBoot logging I'm not sure how I can diagnose this issue. Any help would be much appreciated
    I was able to make enough space for CONFIG_BT_L2CAP_TX_MTU=498 by setting CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=3 and CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1650, but it is still just as slow.
  • Do you see the MTU update to 498 in the sniffer log? Could you provide the sniffer log and build/zephyr/.config again?
  • I lowered the MCUMGR_TRANSPORT_NETBUF count and size more and also reduced the workqueue stack. It seems the app built correctly, my CONFIG_BT_L2CAP_TX_MTU is correct in build/zephyr/.config, but I don't see the MTU update to 498 in the sniffer log and the the packets are still size 272.
    Sniffer log:
    INFO: Log started at Fri Feb  2 11:16:57 2024
    INFO: Extcap version 4.2
    INFO: Opening serial port COM5
    INFO: closing UART
    INFO: args: ()
    INFO: kwargs: {'callbacks': [('*', <bound method Notifier.passOnNotification of <Sniffer(Thread-3, initial)>>)]}
    INFO: board ID: 5
    INFO: Sniffer created
    INFO: Software version: 4.1.1
    INFO: sniffer started
    INFO: starting scan
    INFO: Scan flags: 0b11
    INFO: Sent TK to sniffer: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
    INFO: scanning started
    INFO: defaults written
    INFO: control loop
    INFO: gap in packets, between 824 and 1026 packet before: [31, 0, 3, 56, 3, 2, 10, 1, 39, 69, 0, 0, 75, 202, 37, 0, 214, 190, 137, 142, 195, 12, 212, 177, 2, 36, 132, 95, 222, 100, 202, 163, 233, 85, 217, 165, 250] packet after: [56, 0, 3, 2, 4, 2, 10, 1, 37, 66, 0, 0, 133, 39, 48, 0, 214, 190, 137, 142, 70, 37, 1, 228, 52, 40, 130, 109, 30, 255, 76, 0, 7, 25, 1, 19, 32, 43, 153, 143, 0, 0, 9, 33, 103, 72, 191, 156, 60, 233, 221, 133, 149, 85, 171, 235, 56, 241, 118, 216, 165, 192]
    INFO: gap in packets, between 1026 and 1860 packet before: [56, 0, 3, 2, 4, 2, 10, 1, 37, 66, 0, 0, 133, 39, 48, 0, 214, 190, 137, 142, 70, 37, 1, 228, 52, 40, 130, 109, 30, 255, 76, 0, 7, 25, 1, 19, 32, 43, 153, 143, 0, 0, 9, 33, 103, 72, 191, 156, 60, 233, 221, 133, 149, 85, 171, 235, 56, 241, 118, 216, 165, 192] packet after: [55, 0, 3, 68, 7, 2, 10, 1, 37, 51, 0, 0, 179, 121, 93, 0, 214, 190, 137, 142, 64, 36, 152, 41, 232, 170, 149, 83, 2, 1, 26, 26, 255, 76, 0, 12, 14, 0, 211, 187, 154, 92, 113, 41, 25, 92, 86, 119, 255, 2, 143, 16, 5, 0, 28, 186, 170, 139, 104, 85, 243]
    INFO: Firmware version 4.1.1
    INFO: Firmware timestamp 6138945 reference: Feb 02 2024 11:16:57.961414 Pacific Standard Time
    INFO: follow_device: [b'205', b' 148', b' 145', b' 142', b' 124', b' 238', b' 1']
    INFO: Sniffing device 27 - """"
    INFO: Follow flags: 0b0
    INFO: Following cd:94:91:8e:7c:ee  random
    build/zephyr/.config:
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_LV_COLOR_16_SWAP is not set
    CONFIG_LV_DPI_DEF=130
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    CONFIG_SPI=y
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    # CONFIG_BT_HCI_VS_EXT is not set
    CONFIG_BOARD="vitalmark_nrf52832_board"
    CONFIG_BT_CTLR=y
    CONFIG_NUM_IRQS=39
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF52832_QFAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=512
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_HEAP_MEM_POOL_SIZE=256
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_CLOCK_CONTROL=y
    # CONFIG_WATCHDOG is not set
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_PM_DEVICE is not set
    CONFIG_NRF52_ANOMALY_132_WORKAROUND=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    CONFIG_FPU=y
    # CONFIG_MBEDTLS is not set
    # CONFIG_MEMC is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=2048
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_USE_DT_CODE_PARTITION=y
    CONFIG_FLASH_LOAD_OFFSET=0xc000
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=128
    CONFIG_BT_USER_PHY_UPDATE=y
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_HAS_DTS=y
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_MAXIM_MAX30101_ENABLED=y
    CONFIG_DT_HAS_MAXIM_MAX31875_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_BPROT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PDM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NXP_IMX_FLEXSPI_MX25UM51345G_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ST_LSM6DSO_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.5.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=3584
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
    # CONFIG_MCUMGR_GRP_ZBASIC is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=2048
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL=y
    # CONFIG_BT_LL_SOFTDEVICE_MULTIROLE is not set
    # CONFIG_BT_LL_SOFTDEVICE_EXPERIMENTAL_ISO is not set
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    CONFIG_BT_NRF_SERVICES=y
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    CONFIG_BT_NUS=y
    # CONFIG_BT_NUS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_NUS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_NUS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_NUS_LOG_LEVEL_INF is not set
    # CONFIG_BT_NUS_LOG_LEVEL_DBG is not set
    CONFIG_BT_NUS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_NUS_LOG_LEVEL=3
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_RX_COUNT=4
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    # CONFIG_BT_LONG_WQ is not set
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=20
    # CONFIG_BT_CONN_PARAM_ANY is not set
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    # CONFIG_BT_SMP is not set
    CONFIG_BT_L2CAP_TX_BUF_COUNT=20
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    # CONFIG_BT_GATT_CACHING is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is not set
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
    CONFIG_BT_MAX_PAIRED=0
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Vitalmark"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_ESB_LOG_LEVEL_OFF is not set
    # CONFIG_ESB_LOG_LEVEL_ERR is not set
    # CONFIG_ESB_LOG_LEVEL_WRN is not set
    # CONFIG_ESB_LOG_LEVEL_INF is not set
    # CONFIG_ESB_LOG_LEVEL_DBG is not set
    CONFIG_ESB_LOG_LEVEL_DEFAULT=y
    CONFIG_ESB_LOG_LEVEL=3
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_COAP is not set
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # CONFIG_FW_INFO_API is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=64
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x10000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # TF-M SPM component configs
    CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
    # end of TF-M SPM component configs
    # CONFIG_WPA_SUPP is not set
    CONFIG_POSIX_MAX_FDS=4
    # Libraries
    # Binary libraries
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=3
    # end of Log levels
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_BPROT_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_OFF is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_ERR is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_WRN is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_INF is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_DBG is not set
    CONFIG_MODEM_BATTERY_LOG_LEVEL_DEFAULT=y
    CONFIG_MODEM_BATTERY_LOG_LEVEL=3
    # CONFIG_MODEM_INFO is not set
    CONFIG_MULTITHREADING_LOCK=y
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.5.0/nrf)
    # wfa-qt-control-app (C:/ncs/v2.5.0/modules/lib/wfa-qt-control-app)
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_ZEPHYR_WFA_QT_CONTROL_APP_MODULE=y
    # end of wfa-qt-control-app (C:/ncs/v2.5.0/modules/lib/wfa-qt-control-app)
    # mcuboot (C:/ncs/v2.5.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_SIGN_IMAGES=y
    # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
    # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
    # CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.5.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.5.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # end of PSA Asymmetric support
    # end of mbedtls (C:/ncs/v2.5.0/modules/crypto/mbedtls)
    # trusted-firmware-m (C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    # cjson (C:/ncs/v2.5.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.5.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v2.5.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.5.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.5.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.5.0/modules/lib/openthread)
    # memfault-firmware-sdk (C:/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # canopennode (C:/ncs/v2.5.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.5.0/modules/lib/canopennode)
    # chre (C:/ncs/v2.5.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.5.0/modules/lib/chre)
    # cmsis (C:/ncs/v2.5.0/modules/hal/cmsis)
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    CONFIG_CMSIS_DSP=y
    # Components
    CONFIG_CMSIS_DSP_BASICMATH=y
    # CONFIG_CMSIS_DSP_COMPLEXMATH is not set
    # CONFIG_CMSIS_DSP_CONTROLLER is not set
    CONFIG_CMSIS_DSP_FASTMATH=y
    CONFIG_CMSIS_DSP_FILTERING=y
    # CONFIG_CMSIS_DSP_INTERPOLATION is not set
    # CONFIG_CMSIS_DSP_MATRIX is not set
    # CONFIG_CMSIS_DSP_QUATERNIONMATH is not set
    # CONFIG_CMSIS_DSP_STATISTICS is not set
    CONFIG_CMSIS_DSP_SUPPORT=y
    # CONFIG_CMSIS_DSP_TRANSFORM is not set
    # CONFIG_CMSIS_DSP_SVM is not set
    # CONFIG_CMSIS_DSP_BAYES is not set
    # CONFIG_CMSIS_DSP_DISTANCE is not set
    CONFIG_CMSIS_DSP_TABLES=y
    CONFIG_CMSIS_DSP_TABLES_ALL_FAST=y
    # CONFIG_CMSIS_DSP_TABLES_ALL_FFT is not set
    # Interpolation Tables
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_COS_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_LMS_NORM_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_LMS_NORM_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q15=y
    # Transformation Tables
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX4_Q31 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX4_Q15 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX2_Q31 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX2_Q15 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_8192 is not set
    # Instruction Set
    # Features
    # CONFIG_CMSIS_DSP_LOOPUNROLL is not set
    # CONFIG_CMSIS_DSP_ROUNDING is not set
    # CONFIG_CMSIS_DSP_MATRIXCHECK is not set
    # CONFIG_CMSIS_DSP_AUTOVECTORIZE is not set
    CONFIG_CMSIS_DSP_FLOAT16=y
    # CONFIG_CMSIS_NN is not set
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    # end of cmsis (C:/ncs/v2.5.0/modules/hal/cmsis)
    # fatfs (C:/ncs/v2.5.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.5.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.5.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_PDM_LOG is not set
    # CONFIG_NRFX_PPI_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TWIM_LOG is not set
    # end of nrfx drivers logging
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    CONFIG_NRFX_PDM=y
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PPI=y
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI1 is not set
    # CONFIG_NRFX_SPI2 is not set
    CONFIG_NRFX_SPIM=y
    CONFIG_NRFX_SPIM0=y
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TIMER3 is not set
    # CONFIG_NRFX_TIMER4 is not set
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM0 is not set
    CONFIG_NRFX_TWIM1=y
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (C:/ncs/v2.5.0/modules/hal/nordic)
    # liblc3 (C:/ncs/v2.5.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (C:/ncs/v2.5.0/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.5.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.5.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.5.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.5.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.5.0/modules/lib/gui/lvgl)
    # LVGL configuration
    # CONFIG_LV_CONF_SKIP is not set
    # CONFIG_LV_CONF_MINIMAL is not set
    # Color settings
    # CONFIG_LV_COLOR_DEPTH_32 is not set
    CONFIG_LV_COLOR_DEPTH_16=y
    # CONFIG_LV_COLOR_DEPTH_8 is not set
    # CONFIG_LV_COLOR_DEPTH_1 is not set
    CONFIG_LV_COLOR_DEPTH=16
    # CONFIG_LV_COLOR_SCREEN_TRANSP is not set
    CONFIG_LV_COLOR_MIX_ROUND_OFS=128
    CONFIG_LV_COLOR_CHROMA_KEY_HEX=0x00FF00
    # end of Color settings
    # Memory settings
    # CONFIG_LV_MEM_CUSTOM is not set
    CONFIG_LV_MEM_SIZE_KILOBYTES=32
    CONFIG_LV_MEM_ADDR=0x0
    CONFIG_LV_MEM_BUF_MAX_NUM=16
    # CONFIG_LV_MEMCPY_MEMSET_STD is not set
    # end of Memory settings
    # HAL Settings
    CONFIG_LV_DISP_DEF_REFR_PERIOD=30
    CONFIG_LV_INDEV_DEF_READ_PERIOD=30
    # CONFIG_LV_TICK_CUSTOM is not set
    # end of HAL Settings
    # Feature configuration
    # Drawing
    CONFIG_LV_DRAW_COMPLEX=y
    CONFIG_LV_SHADOW_CACHE_SIZE=0
    CONFIG_LV_CIRCLE_CACHE_SIZE=4
    CONFIG_LV_LAYER_SIMPLE_BUF_SIZE=24576
    CONFIG_LV_IMG_CACHE_DEF_SIZE=0
    CONFIG_LV_GRADIENT_MAX_STOPS=2
    CONFIG_LV_GRAD_CACHE_DEF_SIZE=0
    # CONFIG_LV_DITHER_GRADIENT is not set
    CONFIG_LV_DISP_ROT_MAX_BUF=10240
    # end of Drawing
    # GPU
    # CONFIG_LV_USE_GPU_ARM2D is not set
    # CONFIG_LV_USE_GPU_STM32_DMA2D is not set
    # CONFIG_LV_USE_GPU_SWM341_DMA2D is not set
    # CONFIG_LV_USE_GPU_NXP_PXP is not set
    # CONFIG_LV_USE_GPU_NXP_VG_LITE is not set
    # CONFIG_LV_USE_GPU_SDL is not set
    # end of GPU
    # Logging
    # CONFIG_LV_USE_LOG is not set
    # end of Logging
    # Asserts
    CONFIG_LV_USE_ASSERT_NULL=y
    CONFIG_LV_USE_ASSERT_MALLOC=y
    # CONFIG_LV_USE_ASSERT_STYLE is not set
    # CONFIG_LV_USE_ASSERT_MEM_INTEGRITY is not set
    # CONFIG_LV_USE_ASSERT_OBJ is not set
    CONFIG_LV_ASSERT_HANDLER_INCLUDE="assert.h"
    # end of Asserts
    # Others
    # CONFIG_LV_USE_PERF_MONITOR is not set
    # CONFIG_LV_USE_MEM_MONITOR is not set
    # CONFIG_LV_USE_REFR_DEBUG is not set
    # CONFIG_LV_SPRINTF_CUSTOM is not set
    # CONFIG_LV_SPRINTF_USE_FLOAT is not set
    CONFIG_LV_USE_USER_DATA=y
    # CONFIG_LV_ENABLE_GC is not set
    # end of Others
    # Compiler settings
    # CONFIG_LV_BIG_ENDIAN_SYSTEM is not set
    CONFIG_LV_ATTRIBUTE_MEM_ALIGN_SIZE=1
    # CONFIG_LV_ATTRIBUTE_FAST_MEM_USE_IRAM is not set
    # CONFIG_LV_USE_LARGE_COORD is not set
    # end of Compiler settings
    # end of Feature configuration
    # Font usage
    # Enable built-in fonts
    # CONFIG_LV_FONT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_MONTSERRAT_10 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_UNSCII_8 is not set
    # CONFIG_LV_FONT_UNSCII_16 is not set
    # CONFIG_LV_FONT_CUSTOM is not set
    # end of Enable built-in fonts
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_DEFAULT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEFAULT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_DEFAULT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_8 is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_16 is not set
    # CONFIG_LV_FONT_FMT_TXT_LARGE is not set
    # CONFIG_LV_USE_FONT_COMPRESSED is not set
    # CONFIG_LV_USE_FONT_SUBPX is not set
    CONFIG_LV_USE_FONT_PLACEHOLDER=y
    # end of Font usage
    # Text Settings
    CONFIG_LV_TXT_ENC_UTF8=y
    # CONFIG_LV_TXT_ENC_ASCII is not set
    CONFIG_LV_TXT_BREAK_CHARS=" ,.;:-_"
    CONFIG_LV_TXT_LINE_BREAK_LONG_LEN=0
    CONFIG_LV_TXT_COLOR_CMD="#"
    # CONFIG_LV_USE_BIDI is not set
    # CONFIG_LV_USE_ARABIC_PERSIAN_CHARS is not set
    # end of Text Settings
    # Widget usage
    CONFIG_LV_USE_ARC=y
    CONFIG_LV_USE_BAR=y
    CONFIG_LV_USE_BTN=y
    CONFIG_LV_USE_BTNMATRIX=y
    CONFIG_LV_USE_CANVAS=y
    CONFIG_LV_USE_CHECKBOX=y
    CONFIG_LV_USE_DROPDOWN=y
    CONFIG_LV_USE_IMG=y
    CONFIG_LV_USE_LABEL=y
    CONFIG_LV_LABEL_TEXT_SELECTION=y
    CONFIG_LV_LABEL_LONG_TXT_HINT=y
    CONFIG_LV_USE_LINE=y
    CONFIG_LV_USE_ROLLER=y
    CONFIG_LV_ROLLER_INF_PAGES=7
    CONFIG_LV_USE_SLIDER=y
    CONFIG_LV_USE_SWITCH=y
    CONFIG_LV_USE_TEXTAREA=y
    CONFIG_LV_TEXTAREA_DEF_PWD_SHOW_TIME=1500
    CONFIG_LV_USE_TABLE=y
    # end of Widget usage
    # Extra Widgets
    CONFIG_LV_USE_ANIMIMG=y
    CONFIG_LV_USE_CALENDAR=y
    # CONFIG_LV_CALENDAR_WEEK_STARTS_MONDAY is not set
    CONFIG_LV_USE_CALENDAR_HEADER_ARROW=y
    CONFIG_LV_USE_CALENDAR_HEADER_DROPDOWN=y
    CONFIG_LV_USE_CHART=y
    CONFIG_LV_USE_COLORWHEEL=y
    CONFIG_LV_USE_IMGBTN=y
    CONFIG_LV_USE_KEYBOARD=y
    CONFIG_LV_USE_LED=y
    CONFIG_LV_USE_LIST=y
    CONFIG_LV_USE_MENU=y
    CONFIG_LV_USE_METER=y
    CONFIG_LV_USE_MSGBOX=y
    CONFIG_LV_USE_SPAN=y
    CONFIG_LV_SPAN_SNIPPET_STACK_SIZE=64
    CONFIG_LV_USE_SPINBOX=y
    CONFIG_LV_USE_SPINNER=y
    CONFIG_LV_USE_TABVIEW=y
    CONFIG_LV_USE_TILEVIEW=y
    CONFIG_LV_USE_WIN=y
    # end of Extra Widgets
    # Themes
    CONFIG_LV_USE_THEME_DEFAULT=y
    # CONFIG_LV_THEME_DEFAULT_DARK is not set
    CONFIG_LV_THEME_DEFAULT_GROW=y
    CONFIG_LV_THEME_DEFAULT_TRANSITION_TIME=80
    CONFIG_LV_USE_THEME_BASIC=y
    # CONFIG_LV_USE_THEME_MONO is not set
    # end of Themes
    # Layouts
    CONFIG_LV_USE_FLEX=y
    CONFIG_LV_USE_GRID=y
    # end of Layouts
    # 3rd Party Libraries
    # CONFIG_LV_USE_FS_STDIO is not set
    # CONFIG_LV_USE_FS_POSIX is not set
    # CONFIG_LV_USE_FS_WIN32 is not set
    # CONFIG_LV_USE_FS_FATFS is not set
    # CONFIG_LV_USE_PNG is not set
    # CONFIG_LV_USE_BMP is not set
    # CONFIG_LV_USE_SJPG is not set
    # CONFIG_LV_USE_GIF is not set
    # CONFIG_LV_USE_QRCODE is not set
    # CONFIG_LV_USE_FREETYPE is not set
    # CONFIG_LV_USE_RLOTTIE is not set
    # CONFIG_LV_USE_FFMPEG is not set
    # end of 3rd Party Libraries
    # Others
    CONFIG_LV_USE_SNAPSHOT=y
    # CONFIG_LV_USE_MONKEY is not set
    # CONFIG_LV_USE_GRIDNAV is not set
    # CONFIG_LV_USE_FRAGMENT is not set
    # CONFIG_LV_USE_IMGFONT is not set
    # CONFIG_LV_USE_MSG is not set
    # CONFIG_LV_USE_IME_PINYIN is not set
    # end of Others
    # Examples
    CONFIG_LV_BUILD_EXAMPLES=y
    # end of Examples
    # Demos
    # CONFIG_LV_USE_DEMO_WIDGETS is not set
    # CONFIG_LV_USE_DEMO_KEYPAD_AND_ENCODER is not set
    # CONFIG_LV_USE_DEMO_BENCHMARK is not set
    # CONFIG_LV_USE_DEMO_STRESS is not set
    # CONFIG_LV_USE_DEMO_MUSIC is not set
    # end of Demos
    # end of LVGL configuration
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.5.0/modules/lib/gui/lvgl)
    # lz4 (C:/ncs/v2.5.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.5.0/modules/lib/lz4)
    # nanopb (C:/ncs/v2.5.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.5.0/modules/lib/nanopb)
    # picolibc (C:/ncs/v2.5.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.5.0/modules/lib/picolibc)
    # segger (C:/ncs/v2.5.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # end of segger (C:/ncs/v2.5.0/modules/debug/segger)
    # TraceRecorder (C:/ncs/v2.5.0/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (C:/ncs/v2.5.0/modules/debug/TraceRecorder)
    # uoscore-uedhoc (C:/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.5.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    CONFIG_ZCBOR=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    # end of zcbor (C:/ncs/v2.5.0/modules/lib/zcbor)
    # zscilib (C:/ncs/v2.5.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.5.0/modules/lib/zscilib)
    # nrfxlib (C:/ncs/v2.5.0/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.5.0/nrfxlib)
    # connectedhomeip (C:/ncs/v2.5.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.5.0/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    # Components
    # Instruction Set
    # Features
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.1+0"
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_VITALMARK_NRF52832_BOARD=y
    # Board Options
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    CONFIG_SOC_SERIES_NRF52X=y
    # CONFIG_SOC_SERIES_NRF53X is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3_M7 is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_BPROT=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_PDM=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SPIM0=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF52832=y
    # CONFIG_SOC_NRF52805_CAAA is not set
    # CONFIG_SOC_NRF52810_QFAA is not set
    # CONFIG_SOC_NRF52811_QFAA is not set
    # CONFIG_SOC_NRF52820_QDAA is not set
    # CONFIG_SOC_NRF52832_CIAA is not set
    CONFIG_SOC_NRF52832_QFAA=y
    # CONFIG_SOC_NRF52832_QFAB is not set
    # CONFIG_SOC_NRF52833_QDAA is not set
    # CONFIG_SOC_NRF52833_QIAA is not set
    # CONFIG_SOC_NRF52840_QFAA is not set
    # CONFIG_SOC_NRF52840_QIAA is not set
    # CONFIG_GPIO_AS_PINRESET is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF52_ANOMALY_132_DELAY_US=330
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_NRF_STORE_REBOOT_TYPE_GPREGRET is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_STACK_GUARD=y
    CONFIG_MPU_STACK_GUARD_MIN_SIZE_FLOAT=128
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    CONFIG_FPU_SHARING=y
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    CONFIG_INSTRUMENT_THREAD_SWITCHING=y
    CONFIG_THREAD_RUNTIME_STATS=y
    # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
    CONFIG_SCHED_THREAD_USAGE=y
    # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
    CONFIG_SCHED_THREAD_USAGE_ALL=y
    CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    # CONFIG_TIMESLICING is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_AUDIO is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=20
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_RTT_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    CONFIG_GPIO_HOGS=y
    CONFIG_GPIO_HOGS_INIT_PRIORITY=41
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    CONFIG_I2C=y
    # CONFIG_I2C_DUMP_MESSAGES is not set
    CONFIG_I2C_CALLBACK=y
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=3
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_SMBUS is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # CONFIG_PLIC_SUPPORTS_EDGE_IRQ is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # Serial Drivers
    CONFIG_SPI_ASYNC=y
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=70
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_HWSPINLOCK is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_HEAP_SIZE=-2
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_PICOLIBC_IO_FLOAT=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_CRYPTO=y
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=0
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # BLE Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    # CONFIG_BT_CTLR_CONN_RSSI is not set
    # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
    # CONFIG_BT_CTLR_PRIVACY is not set
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    # CONFIG_BT_CTLR_ADV_EXT is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_EAD is not set
    CONFIG_BT_LOG=y
    # Bluetooth logging
    CONFIG_BT_LOG_LEGACY=y
    # Bluetooth legacy logging options
    # CONFIG_BT_DEBUG_HCI_DRIVER is not set
    # [DEPRECATED] Audio
    # CONFIG_BT_DEBUG_AICS is not set
    # CONFIG_BT_DEBUG_AICS_CLIENT is not set
    # CONFIG_BT_DEBUG_CSIP_SET_MEMBER is not set
    # CONFIG_BT_DEBUG_CSIP_SET_COORDINATOR is not set
    # CONFIG_BT_DEBUG_HAS is not set
    # CONFIG_BT_DEBUG_MCS is not set
    # CONFIG_BT_DEBUG_MCC is not set
    # CONFIG_MCTL_DEBUG is not set
    # CONFIG_BT_DEBUG_MICP_MIC_DEV is not set
    # CONFIG_BT_DEBUG_MICP_MIC_CTLR is not set
    # CONFIG_BT_DEBUG_MPL is not set
    # CONFIG_BT_DEBUG_TBS is not set
    # CONFIG_BT_DEBUG_TBS_CLIENT is not set
    # CONFIG_BT_DEBUG_VCP_VOL_REND is not set
    # CONFIG_BT_DEBUG_VCP_VOL_CTLR is not set
    # CONFIG_BT_DEBUG_VOCS is not set
    # CONFIG_BT_DEBUG_VOCS_CLIENT is not set
    # end of [DEPRECATED] Audio
    # [DEPRECATED] Others
    # CONFIG_BT_DEBUG_ATT is not set
    # CONFIG_BT_DEBUG_GATT is not set
    # CONFIG_BT_DEBUG_L2CAP is not set
    # CONFIG_BT_DEBUG_DF is not set
    # CONFIG_BT_DEBUG_HCI_CORE is not set
    # CONFIG_BT_DEBUG_CONN is not set
    # CONFIG_BT_DEBUG_ISO is not set
    # CONFIG_BT_DEBUG_SERVICE is not set
    # end of [DEPRECATED] Others
    # [DEPRECATED] BR/EDR
    # end of [DEPRECATED] BR/EDR
    # [DEPRECATED] Mesh
    # CONFIG_BT_MESH_DEBUG is not set
    # CONFIG_BT_MESH_DEBUG_NET is not set
    # CONFIG_BT_MESH_DEBUG_RPL is not set
    # CONFIG_BT_MESH_DEBUG_TRANS is not set
    # CONFIG_BT_MESH_DEBUG_BEACON is not set
    # CONFIG_BT_MESH_DEBUG_CRYPTO is not set
    # CONFIG_BT_MESH_DEBUG_KEYS is not set
    # CONFIG_BT_MESH_DEBUG_PROV is not set
    # CONFIG_BT_MESH_DEBUG_PROVISIONER is not set
    # CONFIG_BT_MESH_DEBUG_PROV_DEVICE is not set
    # CONFIG_BT_MESH_DEBUG_ACCESS is not set
    # CONFIG_BT_MESH_DEBUG_MODEL is not set
    # CONFIG_BT_MESH_DEBUG_ADV is not set
    # CONFIG_BT_MESH_DEBUG_LOW_POWER is not set
    # CONFIG_BT_MESH_DEBUG_FRIEND is not set
    # CONFIG_BT_MESH_DEBUG_CFG is not set
    # end of [DEPRECATED] Mesh
    # [DEPRECATED] Services
    # CONFIG_BT_DEBUG_OTS_CLIENT is not set
    # end of [DEPRECATED] Services
    # end of Bluetooth legacy logging options
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL=3
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    # Audio
    CONFIG_BT_AICS_LOG_LEVEL=3
    CONFIG_BT_AICS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_STREAM_LOG_LEVEL=3
    CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL=3
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ASCS_LOG_LEVEL=3
    CONFIG_BT_ASCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ASCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL=3
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_ISO_LOG_LEVEL=3
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL=3
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL=3
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_STREAM_LOG_LEVEL=3
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_LOG_LEVEL=3
    CONFIG_BT_HAS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCS_LOG_LEVEL=3
    CONFIG_BT_MCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCC_LOG_LEVEL=3
    CONFIG_BT_MCC_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCC_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCTL_LOG_LEVEL=3
    CONFIG_MCTL_LOG_LEVEL_INHERIT=y
    # CONFIG_MCTL_LOG_LEVEL_OFF is not set
    # CONFIG_MCTL_LOG_LEVEL_ERR is not set
    # CONFIG_MCTL_LOG_LEVEL_WRN is not set
    # CONFIG_MCTL_LOG_LEVEL_INF is not set
    # CONFIG_MCTL_LOG_LEVEL_DBG is not set
    # CONFIG_MCTL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MPL_LOG_LEVEL=3
    CONFIG_BT_MPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_PACS_LOG_LEVEL=3
    CONFIG_BT_PACS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_PACS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_PACS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_PACS_LOG_LEVEL_INF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_LOG_LEVEL=3
    CONFIG_BT_TBS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_LOG_LEVEL=3
    CONFIG_BT_VOCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # end of Audio
    # Others
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL=3
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL=3
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_EAD_LOG_LEVEL_INHERIT=y
    CONFIG_BT_EAD_LOG_LEVEL=3
    # CONFIG_BT_EAD_LOG_LEVEL_OFF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_ERR is not set
    # CONFIG_BT_EAD_LOG_LEVEL_WRN is not set
    # CONFIG_BT_EAD_LOG_LEVEL_INF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DBG is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_DF_LOG_LEVEL=3
    CONFIG_BT_DF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_DF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_DF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_DF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_DF_LOG_LEVEL_INF is not set
    # CONFIG_BT_DF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL=3
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL=3
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ISO_LOG_LEVEL=3
    CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL=3
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL=3
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL=3
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DEFAULT is not set
    # end of Others
    # BR/EDR
    CONFIG_BT_RFCOMM_LOG_LEVEL=3
    CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HFP_HF_LOG_LEVEL=3
    CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AVDTP_LOG_LEVEL=3
    CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_A2DP_LOG_LEVEL=3
    CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SDP_LOG_LEVEL=3
    CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SDP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DEFAULT is not set
    # end of BR/EDR
    # Mesh
    CONFIG_BT_MESH_LOG_LEVEL=3
    CONFIG_BT_MESH_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL=3
    CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_NET_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_RPL_LOG_LEVEL=3
    CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL=3
    CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL=3
    CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_KEYS_LOG_LEVEL=3
    CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_LOG_LEVEL=3
    CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL=3
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL=3
    CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL=3
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL=3
    CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_DFU_LOG_LEVEL=3
    CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ADV_LOG_LEVEL=3
    CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL=3
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL=3
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROXY_LOG_LEVEL=3
    CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CDB_LOG_LEVEL=3
    CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CFG_LOG_LEVEL=3
    CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DEFAULT is not set
    # end of Mesh
    # Services
    # CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_BAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_BAS_LOG_LEVEL=3
    # CONFIG_BT_HRS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HRS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HRS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_DBG is not set
    CONFIG_BT_HRS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_HRS_LOG_LEVEL=3
    # CONFIG_BT_TPS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TPS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TPS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_DBG is not set
    CONFIG_BT_TPS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_TPS_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_IAS_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_OTS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_DBG is not set
    CONFIG_BT_OTS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_OTS_LOG_LEVEL=3
    # end of Services
    # end of Bluetooth logging
    CONFIG_BT_COMPANY_ID=0x05F1
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    CONFIG_THREAD_ANALYZER=y
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_OFF is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_ERR is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_WRN is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_INF is not set
    # CONFIG_THREAD_ANALYZER_LOG_LEVEL_DBG is not set
    CONFIG_THREAD_ANALYZER_LOG_LEVEL_DEFAULT=y
    CONFIG_THREAD_ANALYZER_LOG_LEVEL=3
    # CONFIG_THREAD_ANALYZER_USE_LOG is not set
    CONFIG_THREAD_ANALYZER_USE_PRINTK=y
    CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE=y
    CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
    # CONFIG_THREAD_ANALYZER_AUTO is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_FCB is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    # CONFIG_LOG_MODE_DEFERRED is not set
    CONFIG_LOG_MODE_IMMEDIATE=y
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    # CONFIG_LOG_IMMEDIATE_CLEAN_OUTPUT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    # CONFIG_LOG_BACKEND_SWO is not set
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_ALWAYS_RUNTIME=y
    # CONFIG_LOG_FMT_SECTION is not set
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_LOG_LEVEL=3
    # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    # CONFIG_SMP_CLIENT is not set
    # end of SMP Client
    # Command Handlers
    CONFIG_MCUMGR_GRP_IMG=y
    # CONFIG_MCUMGR_GRP_IMG_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
    CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=1
    # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
    # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
    # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
    # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO=y
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=3584
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=3
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
    # CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG is not set
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=3
    CONFIG_MCUMGR_TRANSPORT_BT=y
    CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
    # end of Transports and Transport Related Configuration Options
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_TIMER_RANDOM_GENERATOR=y
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRING_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_FLASH_LOAD_SIZE=0x32000
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    CONFIG_BUILD_OUTPUT_META=y
    # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_CHECK_INIT_PRIORITIES_FAIL_ON_WARNING is not set
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
  • Could you provide the .pcapng file for the nRF Sniffer log?
