Using nrf-device-lib version: 0.17.3
Using nrfjprog DLL version: 10.23.1
Using JLink version: JLink_V7.88j
I did try to use precompiled Peripheral_LBS -> peripheral_lbs_2.5.0_thingy53_nrf5340.zip
I also tried to program via VS different samples like bliky and peripheral.
Not sure what you mean by
Programmer whether the bootloader is present?
If that :
In the Programmer navigation bar, click SELECT DEVICE.
A drop-down menu appears.
In the drop-down menu, select Bootloader Thingy:53.
Than no, I do not see Bootloader Thingy:53.
I do not see any output in Serial Terminal in nRF Connect for Desktop.
Hi Yuri,
As you have an external programmer, could you try programming the device from the command line directly, using nrfjprog? I can provide detals on Monday.
Yes, please provide how to do that. I will try using precompiled FW from nordic.
Sorry for the delay.
Please see Programming SoCs with nrfjprog.
Try nrfjprog --program zephyr.hex
Also try using --chiperase, as described in the link. However, you will then need to change family as described.
Thank you for commands. I did execute 2 of them.
Appears I was able to program. Device still would not blink or advertise.
Do I do something in wrong order?
Try #1
Try #2
