I need a SPI running at maximum SPI (32MHz).
My understanding is to have a 32 MHz SPI, I need a core running at 128MHz.
What is the correct way to configure the core clock: (Device Tree? KConfig? nrfx lib?
Thanks
Thanks
SPIM4 is capable of running 32 MHz (regardless of CPU clock freq).
Here's one example from 7002-DK for enabling spi4 (with ext flash):
You can enable this using the clock control subsys, and call it like this:
https://github.com/nrfconnect/sdk-nrf/blob/v2.5.1/samples/wifi/shell/src/main.c#L57-L62
Håkon
Hi Hakon,
I've been able to get SPI4 running at 32MHz. But I had to make a couple of manual changes to the SPIM4 register settings manually. It looks like the settings for max-frequency and rx-delay were not being set from the device tree settings.
I had to add this code to get higher than 16MHz running. Without it the frequency was being set to 16MHz and the rx-delay=2. A 30ns delay is way to much at 32MHz.
#include <nrfx_spim.h> #ifdef NRF_SPIM_HAS_32_MHZ_FREQ printk("spi has 32MHz\n"); nrf_spim_frequency_set(NRF_SPIM_INST_GET(4), NRF_SPIM_FREQ_32M); nrf_spim_iftiming_set(NRF_SPIM_INST_GET(4), 0); #endif
My project is using board nrf5340dk_nrf5340_cpuapp and SDK V2.5.1
My overlay for the SPIM4 setup is
&spi4{ compatible = "nordic,nrf-spim"; status = "okay"; rx-delay = < 0x0 >; max-frequency = <33000000>; cs-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>; w25q64jv: w25q64jv@0 { compatible = "jedec,spi-nor"; size = <0x4000000>; //8MBytes spi-max-frequency = <33000000>; reg = <0>; jedec-id = [ ef 40 17 ]; wp-gpios = <&gpio0 19 0>; hold-gpios = <&gpio0 16 0>; }; }; &spi4_default { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 17)>, <NRF_PSEL(SPIM_MISO, 0, 14)>, <NRF_PSEL(SPIM_MOSI, 0, 13)>; nordic,drive-mode = < 3 >; }; }; &spi4_sleep { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 17)>, <NRF_PSEL(SPIM_MISO, 0, 14)>, <NRF_PSEL(SPIM_MOSI, 0, 13)>; }; };
which produces .dts output of
spi4: arduino_spi: spi@a000 { compatible = "nordic,nrf-spim"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0xa000 0x1000 >; interrupts = < 0xa 0x1 >; max-frequency = < 0x1f78a40 >; easydma-maxcnt-bits = < 0x10 >; rx-delay-supported; rx-delay = < 0x0 >; status = "okay"; cs-gpios = < &gpio0 0x12 0x1 >; pinctrl-0 = < &spi4_default >; pinctrl-1 = < &spi4_sleep >; pinctrl-names = "default", "sleep"; w25q64jv: w25q64jv@0 { compatible = "jedec,spi-nor"; size = < 0x4000000 >; spi-max-frequency = < 0x1f78a40 >; reg = < 0x0 >; jedec-id = [ EF 40 17 ]; wp-gpios = < &gpio0 0x13 0x0 >; hold-gpios = < &gpio0 0x10 0x0 >; }; };
Which looks to be correct for the what the driver would need to set up the peripheral correctly?
It is interesting to note that I could set the frequency lower than 16MHz with overlay changes.
There seems to be no difference in using either CONFIG_SPI, or CONFIG_SPI_NOR.
Thanks
Simon
Hi Simon,
Sorry, I forgot to mention this. SPIM4 is 32M capable with dedicated pins, as described here:
https://infocenter.nordicsemi.com/topic/ps_nrf5340/spim.html?cp=4_0_0_6_29_6#topic
https://infocenter.nordicsemi.com/topic/ps_nrf5340/chapters/pin.html?cp=4_0_0_8_0
You can see this in the source code as well:
Håkon
Hi Hakon,
I've just noticed that I'm not using the SPIM4 dedicated pins. I'm using the QSPI pins P0.13, P0.14, P0.16. Everything seems to be working with this setup. I wonder if the driver could be updated to support this? i.e. all the other high drive pins?
I had wired the NOR Flash to the QSPI pins for 2-Bit mode, but it appears the qspi driver only supports 4 bit mode.
(p_config->skip_gpio_cfg && p_config->skip_psel_cfg)
is true in my case which might explain why the frequency and rx-delay were not picked up from the device tree settings.
Regards
Simon
Hi Simon,
QSPI supports both quad, dual, and single mode by declaring these in DT:
Here's an example of them used for quad io operation:
Håkon
