I'm trying to port the acconeer project that worked on the old one ncs 2.2.0 to new ncs 2.5.2 and ran into a problem with the difference in the DeviceTree description
-- Found devicetree overlay: c:/Work/new/boards/shields/acconeer_xb122/acconeer_xb122.overlay
devicetree error: 'pinctrl-0' is marked as required in 'properties:' in C:/ncs/v2.5.2/zephyr/dts/bindings\serial\nordic,nrf-uarte.yaml, but does not appear in <Node /soc/uart@40002000 in 'C:/ncs/v2.5.2/zephyr/misc/empty_file.c'>
/* * Copyright (c) 2022 Acconeer AB * * SPDX-License-Identifier: BSD-3-Clause */ /dts-v1/; #include <nordic/nrf52840_qiaa.dtsi> / { model = "Acconeer XM122"; compatible = "acc,xm122"; chosen { zephyr,console = &uart0; zephyr,shell-uart = &uart0; zephyr,uart-mcumgr = &uart0; zephyr,bt-mon-uart = &uart0; zephyr,bt-c2h-uart = &uart0; zephyr,sram = &sram0; zephyr,flash = &flash0; zephyr,code-partition = &slot0_partition; zephyr,ieee802154 = &ieee802154; }; leds { compatible = "gpio-leds"; led0: led_0 { gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; label = "XM122 LED"; }; }; /* These aliases are provided for compatibility with samples */ aliases { led0 = &led0; }; }; &adc { status = "okay"; }; &gpiote { status = "okay"; }; &gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &uart0 { compatible = "nordic,nrf-uarte"; status = "okay"; current-speed = <115200>; tx-pin = <16>; rx-pin = <6>; rx-pull-up; rts-pin = <20>; cts-pin = <19>; cts-pull-up; }; &i2c1 { compatible = "nordic,nrf-twi"; status = "okay"; sda-pin = <26>; scl-pin = <27>; }; &spi0 { compatible = "nordic,nrf-spi"; status = "okay"; sck-pin = <27>; mosi-pin = <40>; miso-pin = <5>; cs-gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>; a111@0 { compatible = "acc,a111"; reg = <0x0>; spi-max-frequency = <32000000>; irq-gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; ctrl-gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>; enable-gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>; ps-enable-gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; board-ref-freq = <24000000>; ps-enable-time = <300>; sensor-stab-time = <2000>; status = "okay"; }; }; &ieee802154 { status = "okay"; }; &flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x00000000 0x0000C000>; }; slot0_partition: partition@c000 { label = "image-0"; reg = <0x0000C000 0x00067000>; }; slot1_partition: partition@73000 { label = "image-1"; reg = <0x00073000 0x00067000>; }; scratch_partition: partition@da000 { label = "image-scratch"; reg = <0x000da000 0x0001e000>; }; /* * The flash starting at 0x000f8000 and ending at * 0x000fffff is reserved for use by the application. */ /* * Storage partition will be used by FCB/LittleFS/NVS * if enabled. */ storage_partition: partition@f8000 { label = "storage"; reg = <0x000f8000 0x00008000>; }; }; }; / { vbatt { compatible = "voltage-divider"; io-channels = <&adc 0>; output-ohms = <180000>; full-ohms = <(360000 + 180000)>; power-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>; }; };
