NRF9160 Azure IoT hub DPS Certification Connection Rejected
Hi Nordic
Sample: asset_tracker_v2 (with only changes to overlay-azure.conf)
SDK: 2.5.2
Modem FW: nrf9160_1.3.5
I have followed this tutorial https://learn.microsoft.com/en-us/azure/iot-dps/tutorial-custom-hsm-enrollment-group-x509?tabs=windows&pivots=programming-language-ansi-c for getting my device connected to IOT Hub via DPS. Which I have followed and re-tried many times.
On Azure, in my DPS Certificates, I've uploaded azure-iot-test-only.root.ca.cert.pem, per tutorial.
And in my Managed Enrollments, I've added an Enrollment Group with the azure-iot-test-only.intermediate.cert.pem, per tutorial.
But, I am struggling with the certification and getting a valid connection.
The error that keeps persisting is:
[00:00:15.799,896] <err> azure_iot_hub_dps: Connection was rejected with return code 5
[00:00:15.799,926] <wrn> azure_iot_hub_dps: Is the device certificate valid?
[00:00:15.799,987] <err> mqtt_helper: Library is in the wrong state (MQTT_STATE_DISCONNECTED), MQTT_STATE_CONNECTED required
[00:00:15.800,018] <err> azure_iot_hub_dps: Failed to disconnect gracefully, error: -95
[00:00:15.800,048] <err> azure_iot_hub_dps: There was a failure during DPS registration, process is stopped
[00:00:15.801,086] <err> mqtt_helper: Cloud MQTT input error: -111
Here is what I have successfully uploaded to the modem:
And my overlay-azure.conf looks like:
CONFIG_AZURE_IOT_HUB=y
CONFIG_AZURE_IOT_HUB_DPS=y
CONFIG_AZURE_IOT_HUB_AUTO_DEVICE_TWIN_REQUEST=y
# Increase the number of maximum message properties that can be parsed by the Azure IoT Hub library.
# Needed to be able to parse P-GPS responses.
CONFIG_AZURE_IOT_HUB_MSG_PROPERTY_RECV_MAX_COUNT=4
# Azure IoT Hub options that must be configured in order to establish a connection.
CONFIG_AZURE_IOT_HUB_DPS_HOSTNAME="global.azure-devices-provisioning.net"
CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="0ne********" # Stars replaces with my ID scope
# MQTT helper library
CONFIG_MQTT_HELPER_RX_TX_BUFFER_SIZE=2048
CONFIG_MQTT_HELPER_STACK_SIZE=4096
CONFIG_MQTT_HELPER_SEC_TAG=11
# MQTT Transport library
# Maximum specified MQTT keepalive timeout for Azure IoT Hub is 1177 seconds.
CONFIG_MQTT_KEEPALIVE=1177
The full trace is:
*** Booting nRF Connect SDK v2.5.2 ***
[00:00:00.257,446] <inf> app_event_manager: APP_EVT_START
[00:00:00.506,896] <inf> app_event_manager: MODEM_EVT_INITIALIZED
[00:00:00.516,571] <inf> azure_fota: Current firmware version: 0.0.0-development
[00:00:00.570,159] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:01.293,548] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
%CESQ: 48,2,10,1
+CEREG: 2,"AEFE","005C4C16",7
[00:00:02.401,519] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CSCON: 1
+CGEV: ME PDN ACT 0,0
[00:00:03.967,681] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
[00:00:03.968,902] <inf> app_event_manager: CLOUD_EVT_CONNECTING
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"AEFE","005C4C16",7,,,"00001010","11000001"
%XTIME: "0A","4220328121620A","00"
[00:00:04.073,364] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[00:00:04.073,913] <inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
%CESQ: 47,2,5,0
%CESQ: 47,2,10,1
+CSCON: 0
+CSCON: 1
[00:00:17.401,397] <err> azure_iot_hub_dps: Connection was rejected with return code 5
[00:00:17.401,397] <wrn> azure_iot_hub_dps: Is the device certificate valid?
[00:00:17.401,458] <err> mqtt_helper: Library is in the wrong state (MQTT_STATE_DISCONNECTED), MQTT_STATE_CONNECTED required
[00:00:17.401,489] <err> azure_iot_hub_dps: Failed to disconnect gracefully, error: -95
[00:00:17.401,519] <err> azure_iot_hub_dps: There was a failure during DPS registration, process is stopped
[00:00:17.402,832] <err> mqtt_helper: Cloud MQTT input error: -111
+CSCON: 0
%CESQ: 46,2,4,0
%CESQ: 255,0,255,0
Hope you can help.
Thank you!
-Jeremy
  • I've tried it with:
    • SDK v2.5.2 - MFW 1.3.5
    • SDK v2.5.2 - MFW 1.3.6
    • SDK v2.5.1 - MFW 1.3.5
    • SDK v2.5.1 - MFW 1.3.6
    • SDK v2.5.99-dev1 - MFW 1.3.6
    • SDK v2.5.99-dev1 - MFW 1.3.5
    I even tried this on a couple of brand-new nRF9160-DKs and same issue.
    Though, connecting is nRF Cloud has been successful for all devices.
    I was planning on creating a video going step by step but I feel as though it might be redundant since it's just going through the documentation.
    Is there a direct line of contact with the Nordic engineering team to address this challenge efficiently?
    I am working with a company that is entering the market with a custom IoT hardware product, which is built on the Nordic platform. Over the past few years, we have developed a deep appreciation for the robustness and versatility of this platform but seeing that Azure and Nordic are changing rapidly and are currently facing this firmware/certification issue that is hampering our progress. Despite diligently following the latest documentation, even including the new tutorial and cert_tool.py script released on February 29, 2024, we have been unable to resolve this issue, which we suspect may be external.
    I would be more than willing to contribute to the software and documentation to get a sound solution to this seeing that others are having similar problems.
    Any help will be met with reciprocation.
    Thanks!
    Although it is often normal to have first-line support, we in technical support here at Nordic are application engineers in R&D at the same level as the rest of our engineering team, and have similar competence.
    That being said, you are onto something: Most of our nRF9160 experts are at a conference this week. I do not have the most experience in this topic, although I have indeed used Azure with both DPS and normal provisioning myself a couple of years ago.
    Next week I will ask for help from the people back from the conference and we will see what we can figure out here.
  • Just as an update: I have successfully connected to AWS. Still have no idea why Azure doesn't recognize my certificates.
  • Hi Jeremy,
    Sorry to hear your struggling. I helped a customer with a similar issue three months ago and provide the details about my tests.
    Could you refer to this ticket to see if it helps?
    (+) API registration of certification for Azure IoT Hub / DPS - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
    Charlie
  • Did you make sure to copy the ETAG from the JSON response for each invocation of "az iot hub"?
    az iot hub certificate create --hub-name "$HUBNAME" --name "$CERTNAME" --path ca/root-ca-cert.pem
    > read the ETAG, use in following command:
    az iot hub certificate generate-verification-code --hub-name $HUBNAME --name MYROOTCA --etag "$ETAG"
    > read the ETAG from the above command, use it in the following:
    az iot hub certificate verify --hub-name $HUBNAME --name $CERTNAME --etag $ETAG2 --path certs/client-cert.pem
    and so on.
