NRF9160 Azure IoT hub DPS Certification Connection Rejected
Hi Nordic
Sample: asset_tracker_v2 (with only changes to overlay-azure.conf)
SDK: 2.5.2
Modem FW: nrf9160_1.3.5
I have followed this tutorial https://learn.microsoft.com/en-us/azure/iot-dps/tutorial-custom-hsm-enrollment-group-x509?tabs=windows&pivots=programming-language-ansi-c for getting my device connected to IOT Hub via DPS. Which I have followed and re-tried many times.
On Azure, in my DPS Certificates, I've uploaded azure-iot-test-only.root.ca.cert.pem, per tutorial.
And in my Managed Enrollments, I've added an Enrollment Group with the azure-iot-test-only.intermediate.cert.pem, per tutorial.
But, I am struggling with the certification and getting a valid connection.
The error that keeps persisting is:
[00:00:15.799,896] <err> azure_iot_hub_dps: Connection was rejected with return code 5
[00:00:15.799,926] <wrn> azure_iot_hub_dps: Is the device certificate valid?
[00:00:15.799,987] <err> mqtt_helper: Library is in the wrong state (MQTT_STATE_DISCONNECTED), MQTT_STATE_CONNECTED required
[00:00:15.800,018] <err> azure_iot_hub_dps: Failed to disconnect gracefully, error: -95
[00:00:15.800,048] <err> azure_iot_hub_dps: There was a failure during DPS registration, process is stopped
[00:00:15.801,086] <err> mqtt_helper: Cloud MQTT input error: -111
Here is what I have successfully uploaded to the modem:
And my overlay-azure.conf looks like:
CONFIG_AZURE_IOT_HUB=y
CONFIG_AZURE_IOT_HUB_DPS=y
CONFIG_AZURE_IOT_HUB_AUTO_DEVICE_TWIN_REQUEST=y
# Increase the number of maximum message properties that can be parsed by the Azure IoT Hub library.
# Needed to be able to parse P-GPS responses.
CONFIG_AZURE_IOT_HUB_MSG_PROPERTY_RECV_MAX_COUNT=4
# Azure IoT Hub options that must be configured in order to establish a connection.
CONFIG_AZURE_IOT_HUB_DPS_HOSTNAME="global.azure-devices-provisioning.net"
CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="0ne********" # Stars replaces with my ID scope
# MQTT helper library
CONFIG_MQTT_HELPER_RX_TX_BUFFER_SIZE=2048
CONFIG_MQTT_HELPER_STACK_SIZE=4096
CONFIG_MQTT_HELPER_SEC_TAG=11
# MQTT Transport library
# Maximum specified MQTT keepalive timeout for Azure IoT Hub is 1177 seconds.
CONFIG_MQTT_KEEPALIVE=1177
The full trace is:
*** Booting nRF Connect SDK v2.5.2 ***
[00:00:00.257,446] <inf> app_event_manager: APP_EVT_START
[00:00:00.506,896] <inf> app_event_manager: MODEM_EVT_INITIALIZED
[00:00:00.516,571] <inf> azure_fota: Current firmware version: 0.0.0-development
[00:00:00.570,159] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:01.293,548] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
%CESQ: 48,2,10,1
+CEREG: 2,"AEFE","005C4C16",7
[00:00:02.401,519] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CSCON: 1
+CGEV: ME PDN ACT 0,0
[00:00:03.967,681] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
[00:00:03.968,902] <inf> app_event_manager: CLOUD_EVT_CONNECTING
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"AEFE","005C4C16",7,,,"00001010","11000001"
%XTIME: "0A","4220328121620A","00"
[00:00:04.073,364] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[00:00:04.073,913] <inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
%CESQ: 47,2,5,0
%CESQ: 47,2,10,1
+CSCON: 0
+CSCON: 1
[00:00:17.401,397] <err> azure_iot_hub_dps: Connection was rejected with return code 5
[00:00:17.401,397] <wrn> azure_iot_hub_dps: Is the device certificate valid?
[00:00:17.401,458] <err> mqtt_helper: Library is in the wrong state (MQTT_STATE_DISCONNECTED), MQTT_STATE_CONNECTED required
[00:00:17.401,489] <err> azure_iot_hub_dps: Failed to disconnect gracefully, error: -95
[00:00:17.401,519] <err> azure_iot_hub_dps: There was a failure during DPS registration, process is stopped
[00:00:17.402,832] <err> mqtt_helper: Cloud MQTT input error: -111
+CSCON: 0
%CESQ: 46,2,4,0
%CESQ: 255,0,255,0
Hope you can help.
Thank you!
-Jeremy
  • Hello, I'm receiving the exact same issue. Followed the tutorial 1:1, copied the ETAG from the JSON response at each invocation and all. Not sure what the issue is at this point
  • Yes, I have done that. I can't seem to shake the -111 error (Is the device certificate valid?). I have a feeling it might be related to Azure DigiCert migration.
  • Unfortunately not, I haven’t worked on the project in a few months so things might have changed on Azure since then.
  • I wrote this script to create modem keys, send them to Azure and prepare DPS for automatic registration.
    It uses MQTT SEC TAG 42 and SECONDARY 43.  Requires signing CA and CAs previously generated.
    #!/bin/bash
    DEFAULT_MODEM_PORT="/dev/tty.usbserial-B002XPXB"
    MODEM_PORT=
    RESGROUP="<My-IoT-ResourceGroup>"
    HUBNAME="<My-IoTHub>"
    CERTNAME="my_root_ca"
    IOTHUB_URL="<my-iot-hub>.azure-devices.net"
    ENROLLMENT_NAME="<my-enrollment>"
    DPS="<my-dps>"
    SEC_TAG=42 # for GlobalSign G2 root CA
    SECONDARY_SEC_TAG=43 # for legacy Baltimore root CA
    TENANT="<my-tenant>"
    check() {
        st=$1
        if [[ $st != 0 ]]; then
            echo "error occured: $st"
            echo "are you logged in? otherwise, run::"
            echo
            echo "    az login --scope https://management.core.windows.net//.default"
            exit $st
        fi
    configure() {
        echo "********* (step 0) removing old client data: client-csr.der, client-csr.pem, client-cert.pem"
        rm -f certs/client-csr.der certs/client-csr.pem certs/client-cert.pem > /dev/null
        echo "********* (step 1) listing current data"
        nrfcredstore $MODEM_PORT list
        echo "********* (step 2) deleting old data: will create errors first time run on a device, disregard these."
        nrfcredstore $MODEM_PORT delete $SEC_TAG CLIENT_CERT > /dev/null
        nrfcredstore $MODEM_PORT delete $SEC_TAG CLIENT_KEY > /dev/null
        echo "********* (step 3) generating private key in device and output CSR in sec tag $SEC_TAG => certs/client-csr.der"
        nrfcredstore $MODEM_PORT generate $SEC_TAG certs/client-csr.der
        check $?
        #Convert the CSR from DER format to PEM format using the following command:
        echo "********* (step 4) convert CSR from DER to PEM => certs/client-csr.pem"
        openssl req -inform DER -in certs/client-csr.der -outform PEM -out certs/client-csr.pem
        check $?
        echo "********* (step 5) \"give\" the CSR client-csr.pem to sub-CA (sub-ca-key.pem, sub-ca-cert.pem) to generate client cert => certs/client-cert.pem"
        ./cert_tool.py sign
        check $?
        DEVICE_CN=$(openssl x509 -in certs/client-cert.pem -noout -subject | sed -e 's/.*CN=\(.*\)/\1/g')
        [[ $DEVICE_CN != "" ]]
        check $?
        echo "********* (step 5.5) DEVICE_CN: $DEVICE_CN"
        az iot dps enrollment delete --enrollment-id $DEVICE_CN --resource-group $RESGROUP  --dps-name $DPS > /dev/null
        echo "********* (step 6) write signed client cert in sec tag $SEC_TAG => certs/client-cert.pem"
        nrfcredstore $MODEM_PORT write $SEC_TAG CLIENT_CERT certs/client-cert.pem
        check $?
        echo "********* (step 7) listing current credentials in sec tag $SEC_TAG"
        nrfcredstore $MODEM_PORT list | grep -w $SEC_TAG
        echo "********* (step 8) registering device-id my-device-revN-$DEVICE_CN using certs/client-cert.pem"
        az iot dps enrollment create --enrollment-id $DEVICE_CN --device-id "my-device-revN-$DEVICE_CN" \
        --provisioning-status enabled --resource-group $RESGROUP \
        --iot-hubs $IOTHUB_URL --attestation-type x509 \
        --certificate-path certs/client-cert.pem --dps-name $DPS \
        --allocation-policy static  > /dev/null
        check $?
        echo "********* (step 9) adding credentials for DigiCert and Baltimore"
        nrfcredstore $MODEM_PORT write $SEC_TAG ROOT_CA_CERT DigiCertGlobalRootG2.crt.pem
        check $?
        nrfcredstore $MODEM_PORT write $SECONDARY_SEC_TAG ROOT_CA_CERT BaltimoreCyberTrustRoot.crt.pem
        check $?
        echo "********* (step 10) listing current credentials in primary and secondary sec tags"
        nrfcredstore $MODEM_PORT list | grep -Ew '42|43'
        check $?
    help() {
        echo "usage: $0 [--skip-install] [<modem port>]"
        echo
        echo "--skip-install:   don't install firmware"
        echo "<modem port>:     the port where the modem is connected, default $DEFAULT_MODEM_PORT"
        echo
        echo "requirements:"
        echo "- BaltimoreCyberTrustRoot.crt.pem"
        echo "- DigiCertGlobalRootG2.crt.pem"
        echo "ca/"
        echo "- root-ca-cert.pem"
        echo "- root-ca-key.pem"
        echo "- sub-ca-cert.pem"
        echo "- sub-ca-key.pem"
        echo
        echo "intermediates:"
        echo "certs/"
        echo "- client-cert.pem"
        echo "- client-csr.der"
        echo "- client-csr.pem"
        echo
        echo "Possible devices":
        ls -1 /dev/tty.*serial*
        exit 0
    install_firmware() {
        GDB=/opt/nordic/ncs/toolchains/20d68df7e5//opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb
        $GDB -q \
             -ex "target extended-remote /opt/bmp" \
             -ex "monitor swd_scan" -ex "att 1" \
             -ex "set confirm off" \
             -ex "load at_client/merged.hex" -ex "file at_client/zephyr.elf" \
             -ex "start" -ex "quit"
    iothub_login() {
        az group list -o table > /dev/null
        if [[ "$?" != "0" ]]; then
            az login --tenant $TENANT --scope https://management.core.windows.net//.default
        fi
    main() {
        if [[ "$1" == "--help" ]]; then
            help
        fi
        local INSTALL_FIRMWARE=1
        if [[ "$1" == "--skip-install" ]]; then
            INSTALL_FIRMWARE=0
            shift
        fi
        MODEM_PORT=$1
        if [[ ! -e $MODEM_PORT ]]; then
            echo "no modem port specified, using default $DEFAULT_MODEM_PORT"
            MODEM_PORT=$DEFAULT_MODEM_PORT
        fi
        source ~/.zephyrtools/venv-python3.13/bin/activate
        if [[ $INSTALL_FIRMWARE == 1 ]]; then
            install_firmware
            echo "Power reset the device and enter to continue"
            read
            sleep 1
        fi
        iothub_login
        configure
        echo ""
        echo "Azure IoTHub Device Name: $DEVICE_CN"
    main $*
