Getting Write verify failed every time when try to debug or write without erase.
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
[ #################### ]  12.131s | Erase file - Done erasing
[ #################### ]   1.269s | Program file - Done programming
[ #################### ]   1.299s | Verify file - Done verifying
[ #################### ]  14.504s | Erase file - Done erasing
[ #################### ]   2.654s | Program file - Done programming
[error] [ Client] - Encountered error -160: Command verify_file executed for 2719 milliseconds with result -160
[error] [  nRF53] - Failed while performing 'Verify' operation on target address 0x00FF8128.
-160: Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
Expected byte value 0xFF but read 0xFC at address 0x00FF8150.
[error] [  nRF53] - Failed while verifying device. -160: Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
[error] [ Worker] - Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
ERROR: Write verify failed.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 25: nrfjprog --program 'd:\project\..\build\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 960130361
We do not see this error if we try Erase and Flash option from VS Code. We observe the same issue even with the nRF5340DK board.
This is very annoying us as we cannot debug or program without erasing. Please help us solving the issue.
We are using VS Code with NRF Connect extensions. SDK v2.5.2.
  • Thank you for the answers. About the last one, west error: did you try to run it specifically from nRF Connect terminal inside VS Code?
    Our nRF Connect for VS Code extension should set up all the environmental variables for you automatically.
    Michal
  • About the last one, west error: did you try to run it specifically from nRF Connect terminal inside VS Code?
    --> Yes, tried on both VS Code terminal and command prompt (with ADMIN access) and I see the same error.
    --> How can I confirm this on my end?
  • From the VS Code, please try generating support information. It's the headset icon in the welcome view, please check here:
    https://nrfconnect.github.io/vscode-nrf-connect/reference/ui_sidebar_welcome.html#toolbar-actions
    Michal
  • Please see below.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Home Single Language",
        "osKernel": "10.0.26058",
        "vscode": "1.87.0",
        "electron": "27.3.2",
        "node": "v18.17.1"
      "system": {
        "date": "2024-03-06T06:14:36.245Z",
        "vscodeRoot": "c:\\Users\\user\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "16:17:20",
        "osUptime": "120:56:29",
        "cpu": "Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz"
      "workspace": {
        "name": "prj (Workspace)",
        "workspaceFile": "d:\\work\\prj.code-workspace",
        "folders": [
          "d:\\work"
      "sdks": [
          "version": "v2.5.2",
          "path": "d:\\nrf\\sdk\\v2.5.2\\v2.5.2"
      "activeBuild": "d:\\work\\build",
      "apps": [
          "workspace": "d:\\work",
          "uri": "d:\\work",
          "buildConfigurations": [
              "id": "d:\\work\\build",
              "name": "build",
              "boardId": "nrf5340dk_nrf5340_cpuapp_ns",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
      "topdir": "d:\\nrf\\sdk\\v2.5.2\\v2.5.2",
      "workspaceState": "freestanding-ready",
      "toolchains": [
          "version": "2.5.2",
          "path": "d:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7"
      "connectedDevices": [
          "serialNumber": "000682458844"
      "deviceProvider": "nrfutil",
      "tools": {
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.1",
        "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.94e",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.0",
        "nrfutil": "Not found",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\cmake.exe": "3.20.5",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\Scripts\\west.exe": "1.1.0",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\python.exe": "3.8.2",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\ninja.exe": "1.9.0",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\gperf.exe": "3.1",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\dtc.exe": "1.4.7",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\gn.exe": "2122",
        "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
        "gdbPath": "d:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.0.0",
          "binPath": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
        "nrfutil-toolchain-manager": {
          "version": "0.14.1",
          "binPath": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\user",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\user",
          "PATH": "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\mingw64\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\Scripts;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\nanopb\\generator-bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\starship\\bin\\;C:\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\user\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\user\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "d:\\nrf\\sdk\\v2.5.2\\v2.5.2\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk",
          "PYTHONPATH": "D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\Lib;D:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\starship\\bin\\;C:\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\user\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\user\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\starship\\bin\\;C:\\mingw64\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\Scripts\\;C:\\Users\\user\\AppData\\Local\\Programs\\Python\\Python37\\;C:\\Users\\user\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\user\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "d:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7",
        "toolchainBinPath": "d:\\nrf\\sdk\\v2.5.2\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.5.2"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "${nrf-connect.sdk:2.5.2}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.5.2}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": true
          "deviceProvider": "",
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": "D:\\nrf\\sdk"
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "welcome": {
            "showOnStartup": false
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.2.214",
            "path": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64",
            "isActive": true
            "version": "2024.2.78",
            "path": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.2.78",
            "isActive": true
            "version": "2024.2.418",
            "path": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.2.418",
            "isActive": true
            "version": "2024.2.71",
            "path": "c:\\Users\\user\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.2.71",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.19.5",
          "ms-vscode.js-debug": "1.87.0",
          "ms-vscode.js-debug-companion": "1.1.2",
          "ms-vscode.vscode-js-profile-table": "1.0.8",
          "ashwingopalsamy.macos-dark-theme": "0.0.4",
          "cschlosser.doxdocgen": "1.4.0",
          "davidbwaters.macos-modern-theme": "2.3.19",
          "donjayamanne.python-environment-manager": "1.2.4",
          "donjayamanne.python-extension-pack": "1.7.0",
          "KevinRose.vsc-python-indent": "1.18.0",
          "Maqing01223.zephyr": "0.0.1",
          "mgesbert.python-path": "0.0.14",
          "ms-python.debugpy": "2024.2.0",
          "ms-python.python": "2024.2.1",
          "ms-python.vscode-pylance": "2024.2.3",
          "ms-vscode-remote.remote-ssh": "0.109.0",
          "ms-vscode-remote.remote-ssh-edit": "0.86.0",
          "ms-vscode-remote.remote-wsl": "0.86.0",
          "ms-vscode-remote.vscode-remote-extensionpack": "0.25.0",
          "ms-vscode.hexeditor": "1.9.14",
          "ms-vscode.remote-server": "1.5.1",
          "njpwerner.autodocstring": "0.6.1",
          "PKief.material-icon-theme": "4.34.0",
          "streetsidesoftware.code-spell-checker": "3.0.1",
          "vvisionnn.one-dark-darker-with-border": "0.0.1"
  • Thank you, I will look if I can find any issues there.
    Michal
