Getting Write verify failed every time when try to debug or write without erase.
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
[ #################### ]  12.131s | Erase file - Done erasing
[ #################### ]   1.269s | Program file - Done programming
[ #################### ]   1.299s | Verify file - Done verifying
[ #################### ]  14.504s | Erase file - Done erasing
[ #################### ]   2.654s | Program file - Done programming
[error] [ Client] - Encountered error -160: Command verify_file executed for 2719 milliseconds with result -160
[error] [  nRF53] - Failed while performing 'Verify' operation on target address 0x00FF8128.
-160: Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
Expected byte value 0xFF but read 0xFC at address 0x00FF8150.
[error] [  nRF53] - Failed while verifying device. -160: Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
[error] [ Worker] - Data does not match in address range [0x00FF8128 - 0x00FF8177] (APP UICR)
ERROR: Write verify failed.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 25: nrfjprog --program 'd:\project\..\build\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 960130361
We do not see this error if we try Erase and Flash option from VS Code. We observe the same issue even with the nRF5340DK board.
This is very annoying us as we cannot debug or program without erasing. Please help us solving the issue.
We are using VS Code with NRF Connect extensions. SDK v2.5.2.
    I am starting to look into this from the beginning now because Michal is away. Sorry about the delay.
    I will share a few things which caught my eye as I was reading through your original ticket and the replies.
    From the error log I saw that the addresses in the logs are from the UICR for the application core, more specifically the UICR part which is handled by the Key management unit. The KMU documentation has a section on the intended usage which includes the required format for OTP (one-time programmable) write operations. My initial hypothesis is that when you flash without erasing, you write something to the UICR which has a wrong format. Please read the documentation on UICR and KMU and let me know if there is something which is not clear on those pages.
    This error is a NrfjprogIniNotFoundError with the explanation that nrfjprog.ini is not found in the install folder. The proposed solution is to reinstall nrfjprog. More nrfjprog error codes can be found here.
    After looking quickly over the nRF Connect for VS Code support information you attached I could not find any indicators for what causes the error.
    Since the error only happens when you don't fully erase the chip, I want you to look over the documentation I linked for the UICR and KMU before we go further into other possibilities.
    Maria
  • Hi Maria,
    We are not able to solve the issue.
    Can you educate me on the below error message.
    WARNING: runners.nrfjprog: The hex file contains data placed in the UICR, which may require a full erase before reprogramming. Run west flash again with --erase, or --recover.
    We are not writing anything into UICR and yet we see the above message. How come the hex contains data to be written UICR when we are not including anything to write on UICR. Please let us know if we are doing something wrong.
    The UICR is the address space 0x00FF8000-0x00FF8FFC. nrfjprog reads that there is data in the address space which is reserved for UICR. I get that you haven't purposefully configured anything to be written to UICR, so we need to find out if something unexpected has been configured for the UICR.
    Finding out if there is a partition which uses the address space will help us to find out why nrfjprog sees data in the UICR. If you have a multi-image build, the partition manager will generate a partitions.yml file in the build folder. There you can read the addresses for every partition and check if one of them is configured within the UICR address space.
    Is your application based on a sample from nRF Connect SDK? If yes: which?
