I'm getting started with nrf52840DK.
But when i connect my USB i get this error message:
i saw in this topic that when i press on the boot/reset long press when turning the DK on i should help.
However i still get the same error message.
Make sure you are connecting to right USB port, see the picture below (marked with red). Please make sure all the switches marked with green are in correct position. See this page.
Are you able to see your device inside the device manager(Device Manger-->Ports-->Jlink).
Kind Regards,
Abhijith
i changed the switch's as describe in the picture.
However, i cant connect to the device. nef connect programmer sees a jlink and isnt able to erase or flash.
Led 5 is on and i'm getting this note:
To narrow down the issue, I recommend following the below steps:
Kind Regards,
Abhijith
