I am working on talking to a SPI slave device using SPI mode 3, so CPOL = 1 and CPHA = 1.
It is currently a very minimalistic project for testing purposes.
I am using the zephyr API for doing a single SPI transceive.
The problem is that the clock polarity is incorrect when doing a transaction. After the SPI CS is pulled low by the SPI API, the clock polarity is still low. While it should be high in SPI mode 3. This causes a rising edge, where it is visible that the SPI API has some vague understanding of what SPI mode it should be, as it is then high for a short idle period.
The result is that the SPI slave is confused now, since a rising edge on the SCLK when CS is low means that it samples a bit.
During the transceive, the SPI CLK goes to a low idle state (seems to not comply to its configured SPI mode).
I am struggling to find a way to make the SCLK be high from the moment CS is low (or before, I don't need this GPIO for anything else, it can be always high when idle).
Relevent code:
proj conf
CONFIG_SPI=y
dtsi
spi0_default: spi0_default {
group1 {
psels = <NRF_PSEL(SPIM_MISO, 0, 30)>,
<NRF_PSEL(SPIM_MOSI, 0, 05)>,
<NRF_PSEL(SPIM_SCK, 0, 02)>;
dts
slave_spi: &spi1 {
status = "okay";
overrun-character = <0xFF>;
pinctrl-0 = <&spi0_default>;
pinctrl-1 = <&spi0_sleep>;
cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
slave: q123@0 {
label = "spi-slave-device";
compatible = "vnd,spi-device";
status = "okay";
reg = <0>;
spi-max-frequency = <4000000>;
application code
#define SPI_OP_MODE3 (SPI_OP_MODE_MASTER | SPI_LINES_SINGLE | SPI_WORD_SET(8) | SPI_LOCK_ON | SPI_HOLD_ON_CS | SPI_MODE_CPHA | SPI_MODE_CPOL) const struct spi_dt_spec spi_slave_mode3 = SPI_DT_SPEC_GET(DT_NODELABEL(slave), SPI_OP_MODE3, 0);
err = spi_transceive_dt(&spi_slave_mode3, &tx, &rx);
I hope I provided enough info. Your help would be much appreciated.
Kind regards.
