Boards getting bricked
I am trying to develop using a custom pcb. And after some time my boards stop connecting to the debugger. How do I unbrick the boards? I have read multiple solutions like connecting pin 18 to vdd which did not work. When I run nrfjrog --reset I get the following error message:
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 221 milliseconds with result -102
ERROR: Unable to connect to a debugger.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
PS C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin>
I know it has something to do with reset pins or something, so I will be defining the reset pin in my boardfile, but does that fix the issue or is there a better fix.
Niels Redegeld
  • Niels Redegeld said:
    The DC/DC was set automatically to yes in the config file, so I turned it off: CONFIG_BOARD_ENABLE_DCDC=n
    But it didn't make any difference disabling it?
    Do you know if you have the internal pull-up on the reset pin active? I can see you have added an external one. It could also be an idea to add a shunt capacitor to the pin. There isn't a problem with the switch there?
  • It did not make a difference no, I'll have to look in getting a shunt capacitor, but I dont think the problem relies here. I want to know how to unbrick the boards, before I can even test the solutions.
    PS C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin> nrfjprog --recover --log
    WARNING: Logging is unavailable. nrfjprog.exe does not have write
    WARNING: permission for the log file
    Could you try running "nrfjprog --recover --log" from an admin window to see if this will let you provide some logs?
    The periods I could flash the chip was about a week to two weeks per chip,
    And in these periods the DC/DC was enabled?
  • If I run nrfjprog --recover --log I get the following error:
    I can't upload to my boards so currently the DC/DC is not Disabled
    So I didn't make a difference running it from an admin window?
    What I tried to ask was if it was enabled when you were able to flash them?
1 2 3 4
