Bluetooth AOA IQ samples
I am a BLE beginner and have some confusion about the IQ data of Bluetooth AOA. I used the example direction_finding_connectionless_rx and direction_finding_connectionless_tx from the SDK and I tried to print raw IQ data which contains 45 samples.
1. Why is the data in each frame exactly the same starting from 24? In the picture are 2 sets of data, I used printk("%d+%di\n", report->sample16[i].i, report->sample16[i].q) to print by console.
2. I also saw the existence of TSAMPLEOFFSET in the white paper, and saw CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_2US=20 in the project's .config. The CTE of sending the beacon is 160us, but OFFSET is 20us. Does this mean that the effective sampling is 160us - 20us = 140us and the IQ samples the last 20us / 4 = 5 pieces of data are invalid?
3. Another question is about antenna switching. If I set ant_patterns to 0x1 0x2 0x3 0x4, will the sampled IQ array be 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x2 0x3 0x4 0x1 0x2 0x3 0x4 0x1 0x2 0x3 0x4 ..., because based on the white paper I'm not quite sure whether 0x1 should be included in the loop or not. And because the example uses a 2us slot by default, the first 8 data are sampled once every 1us, followed by every 4us, and part of the intermediate interval switching is 3us, right?And post-data processing requires phase correction due to the delay in sampling.
Hao
  • What is the data format you describe? As I known, IQ data can obtain by cte_recv_cb report->sample16[i].i, report->sample16[i].q in SDK and the sequence of IQ values should from antena 2, 2, 2, 2, 2, 2, 2, 2, 2, 0, 5, 6, 1, 4, 12, 9, 14, 13, 8, 10, 2, 0, 5, 6, 1, 4, 12, 9, 14, 13, 8, 10, 2, 0, 5, 6, 1, 4, 12, 9, 14, 13, 8, 10 ... (until reach the end of CTE). How did you get this data? Are you using the SDK?
  • [{ "gateway":"ac233fc00001", "timestamp":"2021-01-08T05:38:05.443Z" },{ "mac":"c6c504030201", "timestamp":"2021-01-08T05:38:05.817Z", "no":2, "rssi":-69, "raw":"02010605ff3906cafb0809416f412d746167", "aoa":{ "frequency":2402, "iq":[-97,175,-173,-111,137,-165,168,145,-147,138,-135,-167,169,-143,131,171,-75,-194,66,235,-40,-249,34,228,2,-202,-16,211,36,-190,-36,170,141,-245,-86,180,117,-176,-149,146,178,-178,-204,132,201,-119,-194,83,204,-78,-185,14, 181,-27,-266,-29,201,23,-224,-38,186,89,-229,-94,190,149,-198,-118,134,171,-132,-177,86,165,-103,-157,73,254,-44,-200,42,224,-6,-205] } }
    I have used MQTT, I don't know if you would have any part of the code to get the angle and the xy position of the tag from this data, if I could abuse your wisdom to be able to make the code, I am using python....thanks
  • I think the better way to resolve your problem is consulting gateway developer. Because json data format depends on gateway developer's design which maybe use raw sdk to obtain data and combine json data.
  • Hello Antonio,
    I am not sure if I understand exactly what you are struggling with, but it would be preferable if you made a new case for this.
    Elfving
  • Sorry about the wait Hao, I've been away for a while.
    Hao Du said:
    1. As I mentioned question 1 before, I use the official Nordic 12 square array, and I only output 45 sampling points, but every time I output, the following IQ values are the same. I think this is not normal. My code is as follows:
    You are right in a way. The buffer we use for this only support switch pattern lengths of 38. This is unfortunately a hardware limitation. I am not sure why you are seeing one half repeating exactly when you use 45 samples though. Could you try lowering to <=38 and see if you see any issues like this?
    Hao Du said:
    2. You said that CONFIG_BT_CTLR_DF_SAMPLE_OFFSET_PHY_2M_SAMPLING_2US is measured in number of 16M cycles. Since the delay is 1.25µs, can it be considered that the actual sampling time is 160us - 1.25us? But I see that the output is still 45 points. Does this mean that the last point alaways invalid?
    I guess that would depend on how you define the sampling time, though as even the guard period is considered a part of the sampling time (and isn't even used for sampling) then I wouldn't say so. Though I think you will still end up with the right amount of sample slots sampled, if that is what you are afraid of, this just defines how far into the slot you do the sampling. You simply move from the red to the green arrow in this awful illustration here.
    Hao Du said:
    3. The additional problem is the IQ data processing I mentioned. Because the Bluetooth antenna is time-division multiplexed, I want to do phase correction and beamforming, that is, each antenna rotates 2*pi*f*t on the IQ plane, and t is the time elapsed from the sampling moment of the antenna to the reference antenna sampling. I noticed that the example uses 2M PHY as the broadcast train physical layer. I learned from the white paper that theoretically f is 500kHZ. But considering the frequency offset, I tried to perform FFT on the first 8 points to obtain the actual f. Considering that the reference period is 1us once, which is a 1MHZ sampling rate, this does not seem to be well distinguished on the FFT spectrum. Is there a better way to get actual f or phase correction?
    This is unfortunately something I am unsure about. You might be on your own here.
    Elfving
