DTM not compiling for nRF52811
I am trying to run the Direct Test Mode on a custom board. We have two boards revisions, one with a nRF52832 and one with a nRF52811. I managed to build the DTM for the nRF52832 one and I edited the app.overlay to match the pinctrl we use on our custom board regarding the UART pins.
	chosen {
		ncs,dtm-uart = &uart0;
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 3)>,
				<NRF_PSEL(UART_RX, 0, 5)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
&uart0 {
	status = "okay";
	current-speed = < 19200 >;
	pinctrl-0 = < &uart0_default >;
	pinctrl-1 = < &uart0_sleep >;
Everything is working fine on this one and I could even test it both with the CLI and the GUI provided in nRF for Desktop.
After that, I tried to make it work on the nRF52811 one but I get FATAL_ERROR during the compiling step :
 *  Executing task: nRF Connect: Build [pristine]: direct_test_mode/build_ISP1907ll (active)
Building direct_test_mode
west build --build-dir /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode --pristine --board nrf52840dk_nrf52811 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode -DCACHED_CONF_FILE=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/prj.conf
-- Application: /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode
-- CMake version: 3.20.5
-- Found Python3: /home/[myuser]/ncs/toolchains/7795df4459/usr/local/bin/python3.8 (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /home/[myuser]/.cache/zephyr
-- Zephyr version: 3.4.99 (/home/[myuser]/ncs/v2.5.1/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: nrf52840dk_nrf52811
-- Found host-tools: zephyr 0.16.1 (/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk)
-- Found Dtc: /home/[myuser]/ncs/toolchains/7795df4459/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: /home/[myuser]/ncs/v2.5.1/zephyr/boards/arm/nrf52840dk_nrf52811/nrf52840dk_nrf52811.dts
-- Generated zephyr.dts: /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/dts.cmake
Parsing /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/Kconfig
Loaded configuration '/home/[myuser]/ncs/v2.5.1/zephyr/boards/arm/nrf52840dk_nrf52811/nrf52840dk_nrf52811_defconfig'
Merged configuration '/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/prj.conf'
Configuration saved to '/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/.config'
Kconfig header saved to '/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /home/[myuser]/ncs/v2.5.1/zephyr/CMakeLists.txt:1958 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll
[1/148] Preparing syscall dependency handling
[4/148] Generating include/generated/version.h
-- Zephyr version: 3.4.99 (/home/[myuser]/ncs/v2.5.1/zephyr), build: v3.4.99-ncs1-1
[16/148] Building C object CMakeFiles/app.dir/src/dtm_hw.c.obj
FAILED: CMakeFiles/app.dir/src/dtm_hw.c.obj
ccache /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DDEVELOP_IN_NRF52840 -DKERNEL -DNRF52811_XXAA -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 -DPICOLIBC_INTEGER_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I.././src -I/home/[myuser]/ncs/v2.5.1/zephyr/include -Izephyr/include/generated -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/common/. -I/home/[myuser]/ncs/v2.5.1/nrf/include -I/home/[myuser]/ncs/v2.5.1/nrf/lib/fem_al/. -I/home/[myuser]/ncs/v2.5.1/nrf/tests/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/cmsis/CMSIS/Core/Include -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/cmsis/. -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/mdk -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/. -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/SEGGER -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/Config -fno-strict-aliasing -Os -imacros /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/dtm_hw.c.obj -MF CMakeFiles/app.dir/src/dtm_hw.c.obj.d -o CMakeFiles/app.dir/src/dtm_hw.c.obj -c ../src/dtm_hw.c
In file included from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain.h:50,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/sys/time_units.h:10,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/sys/util.h:615,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/devicetree.h:25,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/./nrfx_config.h:10,
                 from /home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/nrfx.h:37,
                 from /home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/hal/nrf_radio.h:37,
                 from ../src/dtm_hw.h:13,
                 from ../src/dtm_hw.c:9:
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/gcc.h:81:36: error: static assertion failed: "You must set the dfe-antenna-num property in the radio node to enable antenna switching."
   81 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
../src/dtm_hw.c:106:1: note: in expansion of macro 'BUILD_ASSERT'
  106 | BUILD_ASSERT(HAS_ANTENNA_NUM,
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/gcc.h:81:36: error: static assertion failed: "Missing antenna pattern used to select antenna for PDU Tx during the CTE Idle state. Set the dfe-pdu-antenna devicetree property."
../src/dtm_hw.c:122:1: note: in expansion of macro 'BUILD_ASSERT'
  122 | BUILD_ASSERT(HAS_PDU_ANTENNA,
../src/dtm_hw.c: In function 'dtm_hw_radio_pdu_antenna_get':
zephyr/include/generated/devicetree_generated.h:9057:38: error: 'DT_N_S_soc_S_radio_40001000_P_dfe_pdu_antenna' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_radio_40001000_P_dfe_supported'?
 9057 | #define DT_N_NODELABEL_radio         DT_N_S_soc_S_radio_40001000
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/devicetree.h:4231:29: note: in definition of macro 'DT_CAT3'
 4231 | #define DT_CAT3(a1, a2, a3) a1 ## a2 ## a3
../src/dtm_hw.c:85:21: note: in expansion of macro 'DT_PROP'
   85 | #define PDU_ANTENNA DT_PROP(RADIO_NODE, dfe_pdu_antenna)
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/devicetree.h:4229:24: note: in expansion of macro 'DT_N_NODELABEL_radio'
 4229 | #define DT_CAT(a1, a2) a1 ## a2
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/devicetree.h:197:29: note: in expansion of macro 'DT_CAT'
  197 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
../src/dtm_hw_config.h:15:20: note: in expansion of macro 'DT_NODELABEL'
   15 | #define RADIO_NODE DT_NODELABEL(radio)
../src/dtm_hw.c:85:29: note: in expansion of macro 'RADIO_NODE'
../src/dtm_hw.c:228:16: note: in expansion of macro 'PDU_ANTENNA'
  228 |         return PDU_ANTENNA;
zephyr/include/generated/devicetree_generated.h:9057:38: note: each undeclared identifier is reported only once for each function it appears in
../src/dtm_hw.c:229:1: warning: control reaches end of non-void function [-Wreturn-type]
  229 | }
[34/148] Building C object CMakeFiles/app.dir/src/transport/dtm_uart_wait.c.obj
FAILED: CMakeFiles/app.dir/src/transport/dtm_uart_wait.c.obj
ccache /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DDEVELOP_IN_NRF52840 -DKERNEL -DNRF52811_XXAA -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 -DPICOLIBC_INTEGER_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I.././src -I/home/[myuser]/ncs/v2.5.1/zephyr/include -Izephyr/include/generated -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/common/. -I/home/[myuser]/ncs/v2.5.1/nrf/include -I/home/[myuser]/ncs/v2.5.1/nrf/lib/fem_al/. -I/home/[myuser]/ncs/v2.5.1/nrf/tests/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/cmsis/CMSIS/Core/Include -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/cmsis/. -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/mdk -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/. -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/SEGGER -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/Config -fno-strict-aliasing -Os -imacros /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/transport/dtm_uart_wait.c.obj -MF CMakeFiles/app.dir/src/transport/dtm_uart_wait.c.obj.d -o CMakeFiles/app.dir/src/transport/dtm_uart_wait.c.obj -c ../src/transport/dtm_uart_wait.c
../src/transport/dtm_uart_wait.c:40:2: error: #error "DTM UART node not found"
   40 | #error "DTM UART node not found"
../src/transport/dtm_uart_wait.c: In function 'dtm_uart_wait_init':
../src/transport/dtm_uart_wait.c:77:53: error: 'DTM_UART_POLL_CYCLE' undeclared (first use in this function)
   77 |                 nrfx_timer_us_to_ticks(&wait_timer, DTM_UART_POLL_CYCLE),
../src/transport/dtm_uart_wait.c:77:53: note: each undeclared identifier is reported only once for each function it appears in
[36/148] Building C object CMakeFiles/app.dir/src/transport/dtm_uart_twowire.c.obj
FAILED: CMakeFiles/app.dir/src/transport/dtm_uart_twowire.c.obj
ccache /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DDEVELOP_IN_NRF52840 -DKERNEL -DNRF52811_XXAA -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 -DPICOLIBC_INTEGER_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I.././src -I/home/[myuser]/ncs/v2.5.1/zephyr/include -Izephyr/include/generated -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/common/. -I/home/[myuser]/ncs/v2.5.1/nrf/include -I/home/[myuser]/ncs/v2.5.1/nrf/lib/fem_al/. -I/home/[myuser]/ncs/v2.5.1/nrf/tests/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/cmsis/CMSIS/Core/Include -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/cmsis/. -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/mdk -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/. -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/SEGGER -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/Config -fno-strict-aliasing -Os -imacros /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/transport/dtm_uart_twowire.c.obj -MF CMakeFiles/app.dir/src/transport/dtm_uart_twowire.c.obj.d -o CMakeFiles/app.dir/src/transport/dtm_uart_twowire.c.obj -c ../src/transport/dtm_uart_twowire.c
In file included from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/gcc.h:92,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/device.h:12,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/drivers/uart.h:26,
                 from ../src/transport/dtm_uart_twowire.c:8:
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/device.h:85:41: error: '__device_dts_ord_DT_CHOSEN_ncs_dtm_uart_ORD' undeclared here (not in a function)
   85 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
  132 | #define _DO_CONCAT(x, y) x ## y
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/device.h:85:33: note: in expansion of macro '_CONCAT'
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/device.h:211:37: note: in expansion of macro 'DEVICE_NAME_GET'
  211 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/device.h:228:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
  228 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
../src/transport/dtm_uart_twowire.c:73:40: note: in expansion of macro 'DEVICE_DT_GET'
   73 | static const struct device *dtm_uart = DEVICE_DT_GET(DTM_UART);
[37/148] Building C object CMakeFiles/app.dir/src/dtm.c.obj
FAILED: CMakeFiles/app.dir/src/dtm.c.obj
ccache /home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DDEVELOP_IN_NRF52840 -DKERNEL -DNRF52811_XXAA -DNRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 -DPICOLIBC_INTEGER_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I.././src -I/home/[myuser]/ncs/v2.5.1/zephyr/include -Izephyr/include/generated -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/[myuser]/ncs/v2.5.1/zephyr/soc/arm/nordic_nrf/common/. -I/home/[myuser]/ncs/v2.5.1/nrf/include -I/home/[myuser]/ncs/v2.5.1/nrf/lib/fem_al/. -I/home/[myuser]/ncs/v2.5.1/nrf/tests/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/cmsis/CMSIS/Core/Include -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/cmsis/. -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include -I/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/mdk -I/home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/. -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/SEGGER -I/home/[myuser]/ncs/v2.5.1/modules/debug/segger/Config -fno-strict-aliasing -Os -imacros /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/[myuser]/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/[myuser]/ncs/v2.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/dtm.c.obj -MF CMakeFiles/app.dir/src/dtm.c.obj.d -o CMakeFiles/app.dir/src/dtm.c.obj -c ../src/dtm.c
                 from ../src/dtm.h:12,
                 from ../src/dtm.c:10:
../src/dtm.c:60:53: error: 'CONFIG_NRFX_TIMER3' undeclared here (not in a function); did you mean 'CONFIG_NRFX_TIMER0'?
   60 | #define NRFX_TIMER_CONFIG_LABEL(_num) NRFX_CONCAT_3(CONFIG_, NRFX_TIMER, _num)
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/toolchain/gcc.h:81:51: note: in definition of macro 'BUILD_ASSERT'
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/nrfx_common.h:185:35: note: in expansion of macro 'NRFX_CONCAT_3_'
  185 | #define NRFX_CONCAT_3(p1, p2, p3) NRFX_CONCAT_3_(p1, p2, p3)
../src/dtm.c:60:39: note: in expansion of macro 'NRFX_CONCAT_3'
../src/dtm.c:65:14: note: in expansion of macro 'NRFX_TIMER_CONFIG_LABEL'
   65 | BUILD_ASSERT(NRFX_TIMER_CONFIG_LABEL(ANOMALY_172_TIMER_INSTANCE) == 1,
../src/dtm.c:60:53: error: expression in static assertion is not an integer
In file included from /home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/nrfx.h:38,
                 from ../src/dtm.c:11:
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h:64:39: error: 'NRF_TIMER3' undeclared here (not in a function); did you mean 'NRF_TIMER0'?
   64 |     .p_reg            = NRFX_CONCAT_2(NRF_TIMER, id),             \
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/nrfx_common.h:167:32: note: in definition of macro 'NRFX_CONCAT_2_'
  167 | #define NRFX_CONCAT_2_(p1, p2) p1 ## p2
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h:64:25: note: in expansion of macro 'NRFX_CONCAT_2'
../src/dtm.c:398:26: note: in expansion of macro 'NRFX_TIMER_INSTANCE'
  398 |         .anomaly_timer = NRFX_TIMER_INSTANCE(ANOMALY_172_TIMER_INSTANCE),
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h:65:39: error: 'NRFX_TIMER3_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER2_INST_IDX'?
   65 |     .instance_id      = NRFX_CONCAT_3(NRFX_TIMER, id, _INST_IDX), \
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/nrfx_common.h:188:36: note: in definition of macro 'NRFX_CONCAT_3_'
  188 | #define NRFX_CONCAT_3_(p1, p2, p3) p1 ## p2 ## p3
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h:65:25: note: in expansion of macro 'NRFX_CONCAT_3'
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/hal/nrf_timer.h:242:54: error: 'TIMER3_CC_NUM' undeclared here (not in a function); did you mean 'TIMER2_CC_NUM'?
  242 | #define NRF_TIMER_CC_CHANNEL_COUNT(id) NRFX_CONCAT_3(TIMER, id, _CC_NUM)
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/hal/nrf_timer.h:242:40: note: in expansion of macro 'NRFX_CONCAT_3'
/home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h:66:25: note: in expansion of macro 'NRF_TIMER_CC_CHANNEL_COUNT'
   66 |     .cc_channel_count = NRF_TIMER_CC_CHANNEL_COUNT(id),           \
../src/dtm.c: In function 'anomaly_timer_init':
../src/dtm.c:672:21: error: 'CONFIG_ANOMALY_172_TIMER_IRQ_PRIORITY' undeclared (first use in this function); did you mean 'CONFIG_DTM_TIMER_IRQ_PRIORITY'?
  672 |                     CONFIG_ANOMALY_172_TIMER_IRQ_PRIORITY,
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/arch/arm/aarch32/irq.h:128:9: note: in expansion of macro '_CHECK_PRIO'
  128 |         _CHECK_PRIO(priority_p, flags_p) \
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/irq.h:49:9: note: in expansion of macro 'ARCH_IRQ_CONNECT'
   49 |         ARCH_IRQ_CONNECT(irq_p, priority_p, isr_p, isr_param_p, flags_p)
../src/dtm.c:671:9: note: in expansion of macro 'IRQ_CONNECT'
  671 |         IRQ_CONNECT(ANOMALY_172_TIMER_IRQ,
../src/dtm.c:672:21: note: each undeclared identifier is reported only once for each function it appears in
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/arch/arm/aarch32/irq.h:105:22: error: expression in static assertion is not an integer
  105 |         BUILD_ASSERT(((flags_p & IRQ_ZERO_LATENCY) && \
In file included from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/arch/arm/aarch32/irq.h:19,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/arch/arm/aarch32/arch.h:27,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/arch/cpu.h:19,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/irq.h:15,
                 from /home/[myuser]/ncs/v2.5.1/zephyr/modules/hal_nordic/nrfx/./nrfx_glue.h:12,
                 from /home/[myuser]/ncs/v2.5.1/modules/hal/nordic/nrfx/nrfx.h:39:
../src/dtm.c:51:54: error: 'TIMER3_IRQn' undeclared (first use in this function); did you mean 'TIMER2_IRQn'?
   51 | #define ANOMALY_172_TIMER_IRQ          NRFX_CONCAT_3(TIMER,                 \
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/sw_isr_table.h:77:26: note: in definition of macro 'Z_ISR_DECLARE'
   77 |                         {irq, flags, (void *)&func, (const void *)param}
../src/dtm.c:51:40: note: in expansion of macro 'NRFX_CONCAT_3'
../src/dtm.c:671:21: note: in expansion of macro 'ANOMALY_172_TIMER_IRQ'
../src/dtm.c:54:54: error: 'nrfx_timer_3_irq_handler' undeclared (first use in this function); did you mean 'nrfx_timer_2_irq_handler'?
   54 | #define ANOMALY_172_TIMER_IRQ_HANDLER  NRFX_CONCAT_3(nrfx_timer_,           \
/home/[myuser]/ncs/v2.5.1/zephyr/include/zephyr/sw_isr_table.h:77:47: note: in definition of macro 'Z_ISR_DECLARE'
../src/dtm.c:54:40: note: in expansion of macro 'NRFX_CONCAT_3'
../src/dtm.c:673:21: note: in expansion of macro 'ANOMALY_172_TIMER_IRQ_HANDLER'
  673 |                     ANOMALY_172_TIMER_IRQ_HANDLER,
FATAL ERROR: command exited with status 1: /home/[myuser]/ncs/toolchains/7795df4459/usr/local/bin/cmake --build /home/[myuser]/ncs/v2.5.1/nrf/samples/bluetooth/direct_test_mode/build_ISP1907ll
 *  The terminal process terminated with exit code: 1.
I use the same overlay as we also have mapped the UART pins on pin 5 and 3 for this board. I also tried to remove my modification in the app.overlay, trying to build for a Dev Kit version of the 52811 and I still have the exact same error.
Can I have some support to make this compile?
Fabien
  • Hi Fabien,
    Thanks for sharing the compiled pinctrl. I think I know what the issue is.
    In the original uart0_default definition, there are two groups, one for the outputs (group1) and one for the inputs (group2).
    RXD will be located on the group2 and will not be overwritten by the .overlay that you have created.
    What you could do is to rename your uart0_my_custom_default and point to that, similar to this:
    &pinctrl {
    	uart0_my_custom_default: uart0_my_custom_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 0)>,
    				<NRF_PSEL(UART_RTS, 0, 10)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 1, 1)>,
    				<NRF_PSEL(UART_CTS, 0, 11)>;
    			bias-pull-up;
    &uart0 {
    	status = "okay";
    	current-speed = <19200>;
    	pinctrl-0 = <&uart0_my_custom_default>;
    	pinctrl-1 = <&uart0_sleep>;
    Or follow the same grouping as done in the board itself:
    &pinctrl {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, X)>,
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, Y)>,
    			bias-pull-up;
    &uart0 {
    	status = "okay";
    	pinctrl-0 = <&uart0_default>;
    Could you try this and see if that works as expected?
    Fabv said:
    In the meantime, if you have any updates regarding the state of the bug we saw earlier and when it will be fixed officially, I am interested.
    Unfortunately, it is still open internally, and the next major release is 2.7.0.
    Håkon
  • Hi Håkon,
    I tried by adapting your 2nd example to our setup and it worked! It still compile for both nRF52832 and nRF52811.
    Thanks for your help!
    Fabien
  • Hi Fabien,
    That is great to hear! I'm always happy to help out.
    Be sure to contact us again if you have any questions or run into any issues.
    Hope you have a wonderful day!
    Håkon
  • Hello
    I have a similar problem running the DTM application on the 52840 DK
    is this a good place to raise questions?
    or shall I open a new ticket?
    Thank you
    Jamal
    Please create a dedicated ticket and explain the issues that you are seeing.
    Håkon
