nRF5340 Audio - configure gateway unit also as ACL peripheral
I'm working with nRF5340 Audio DKs.
I'm able to successfully run the audio example in BIS mode (with gateway and headset devices).
My goal is to open another BT connection, in parallel to the audio broadcast on my gateway device, to which I can connect with the headset units and the nRF Toolbox App via NUS. I'd like the gateway device to act as peripheral in that manner and to be able to connect to 6 different devices concurrently via NUS (5 headset units + 1 smartphone app).
I tried implementing it by myself, and I feel like on the brink of it, but calling bt_le_ext_adv_create() twice (once for audio and once for ACL) fails with EIO (I/O error). It's unclear to me why it happens. As I see it, the challange is to create 2 concurrent advertisements in the gateway unit - audio streaming and ACL connection.
On this ticket I received great help from , which implemented the gateway device as central in terms of ACL connection.
I'll share that I was able to deduce from his development and successfully configure the headset device as central in terms of ACL connection (in parallel to audio streaming receival). here are the relevant files: headset_as_ACL_central.rar
I would appreciate any help with such implementation.
Thank you,
Dekel
  • Dekel said:
    I did just that - still receive the same error (BT_HCI_ERR_CONN_FAIL_TO_ESTAB).
    It looks like QoS issue. You should find the optimized parameters tweaking them for your device. This information should be useful to figure out proper number of the parameters.
    Dekel said:
    Sounds like the legacy ADV could be an adequate solution for the Android as well, isn't it?
    For iOS, if Apple doesn't change anything about this issue, that could be an alternatives. For Android, as I said above, this would be more of QoS timing issue rather than ADV-EXT, but it's worth a shot.
  • Thanks for the info.
    Interestingly, when trying to connect with another smartphone, running Android 12, everything works well using your original code! That's awesome. I'm able to communicate through nRF Toolbox app and even send data from the device back to the smartphone (with a small code modification).
    Therefore, I assume that's something about the smartphone I've been using. I'll try with a few more devices to get better statistics.
    Is it complicated to implement the legacy ADV? If it's relatively simple and you assume it should work without issues, I prefer proceeding in that direction in order to make progress. I'd really appreciate your guidance with that.
  • Thanks for the good news!
    It would be a little complicated, but it's very promising. However, replacing with legacy ADV might connect iOS devices, but that won't completely fix this issue because this comes from timing-activities in the end. Are you satisfied with the current audio quality? Also, even slightly lower quality than this would be acceptable? If yes, that will bring more stable ACL link.
    Brian
  • Hello Dekel,
    In the meantime, we tried it out for legacy advertising for the ACL connection.
    It's not fully optimized yet, but it looks good for both iPhone and Android. you can simply merge the attached one file((\broadcast_source\main.c) to your previous patch. Feel free to comment about your result.
    //Brian
     * Copyright (c) 2023 Nordic Semiconductor ASA
    #include "streamctrl.h"
    #include <zephyr/bluetooth/audio/audio.h>
    #include <zephyr/kernel.h>
    #include <zephyr/zbus/zbus.h>
    #include "nrf5340_audio_common.h"
    #include "nrf5340_audio_dk.h"
    #include "broadcast_source.h"
    #include "led.h"
    #include "button_assignments.h"
    #include "macros_common.h"
    #include "audio_system.h"
    #include "bt_mgmt.h"
    //Adding for NUS peri.
    #include <bluetooth/services/nus.h>
    LOG_MODULE_REGISTER(main, CONFIG_MAIN_LOG_LEVEL);
    ZBUS_SUBSCRIBER_DEFINE(button_evt_sub, CONFIG_BUTTON_MSG_SUB_QUEUE_SIZE);
    ZBUS_MSG_SUBSCRIBER_DEFINE(le_audio_evt_sub);
    ZBUS_CHAN_DECLARE(button_chan);
    ZBUS_CHAN_DECLARE(le_audio_chan);
    ZBUS_CHAN_DECLARE(bt_mgmt_chan);
    ZBUS_CHAN_DECLARE(sdu_ref_chan);
    ZBUS_OBS_DECLARE(sdu_ref_msg_listen);
    static struct k_thread button_msg_sub_thread_data;
    static struct k_thread le_audio_msg_sub_thread_data;
    static struct bt_le_ext_adv *adv_for_conn;
    static k_tid_t button_msg_sub_thread_id;
    static k_tid_t le_audio_msg_sub_thread_id;
    K_THREAD_STACK_DEFINE(button_msg_sub_thread_stack, CONFIG_BUTTON_MSG_SUB_STACK_SIZE);
    K_THREAD_STACK_DEFINE(le_audio_msg_sub_thread_stack, CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE);
    static enum stream_state strm_state = STATE_PAUSED;
    //Advertise with Legacy mode(instead of ADV-EXT) for ACL connection..
    #define CONFIG_BT_LEGACY_ADV4ACL
    #ifndef CONFIG_BT_LEGACY_ADV4ACL //Adding for NUS peri. w/ ADV-EXT.
    #define BT_LE_EXT_ADV_CONN BT_LE_ADV_PARAM(BT_LE_ADV_OPT_EXT_ADV | \
    						BT_LE_ADV_OPT_CONNECTABLE, \
    						BT_GAP_ADV_FAST_INT_MIN_1, \
    						BT_GAP_ADV_FAST_INT_MAX_1, \
    						NULL)
    #else	//Adding for NUS peri. w/ legacy ADV.
    #define BT_LE_ADV_CONN_CUSTOM BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, \
    						NULL)
    #define DEVICE_NAME "BROADCASTER_NUS"
    #define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_SHORTENED, DEVICE_NAME, DEVICE_NAME_LEN),
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    #else
    static const struct bt_data sd[] = {
    static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data, uint16_t len)
    	LOG_HEXDUMP_INF(data, len, " NUS");
    static struct bt_nus_cb nus_cb = {
    	.received = bt_receive_cb,
    /* Function for handling all stream state changes */
    static void stream_state_set(enum stream_state stream_state_new)
    	strm_state = stream_state_new;
     * @brief	Handle button activity.
    static void button_msg_sub_thread(void)
    	int ret;
    	const struct zbus_channel *chan;
    	while (1) {
    		ret = zbus_sub_wait(&button_evt_sub, &chan, K_FOREVER);
    		ERR_CHK(ret);
    		struct button_msg msg;
    		ret = zbus_chan_read(chan, &msg, ZBUS_READ_TIMEOUT_MS);
    		ERR_CHK(ret);
    		LOG_DBG("Got btn evt from queue - id = %d, action = %d", msg.button_pin,
    			msg.button_action);
    		if (msg.button_action != BUTTON_PRESS) {
    			LOG_WRN("Unhandled button action");
    			return;
    		switch (msg.button_pin) {
    		case BUTTON_PLAY_PAUSE:
    			if (strm_state == STATE_STREAMING) {
    				ret = broadcast_source_stop();
    				if (ret) {
    					LOG_WRN("Failed to stop broadcaster: %d", ret);
    			} else if (strm_state == STATE_PAUSED) {
    				ret = broadcast_source_start(NULL);
    				if (ret) {
    					LOG_WRN("Failed to start broadcaster: %d", ret);
    			} else {
    				LOG_WRN("In invalid state: %d", strm_state);
    		case BUTTON_4:
    			if (IS_ENABLED(CONFIG_AUDIO_TEST_TONE)) {
    				if (strm_state != STATE_STREAMING) {
    					LOG_WRN("Not in streaming state");
    				ret = audio_system_encode_test_tone_step();
    				if (ret) {
    					LOG_WRN("Failed to play test tone, ret: %d", ret);
    			LOG_WRN("Unexpected/unhandled button id: %d", msg.button_pin);
    		STACK_USAGE_PRINT("button_msg_thread", &button_msg_sub_thread_data);
     * @brief	Handle Bluetooth LE audio events.
    static void le_audio_msg_sub_thread(void)
    	int ret;
    	while (1) {
    		struct le_audio_msg msg;
    		ret = zbus_sub_wait_msg(&le_audio_evt_sub, &chan, &msg, K_FOREVER);
    		ERR_CHK(ret);
    		LOG_DBG("Received event = %d, current state = %d", msg.event, strm_state);
    		switch (msg.event) {
    		case LE_AUDIO_EVT_STREAMING:
    			LOG_DBG("LE audio evt streaming");
    			audio_system_encoder_start();
    				LOG_DBG("Got streaming event in streaming state");
    			audio_system_start();
    			stream_state_set(STATE_STREAMING);
    			ret = led_blink(LED_APP_1_BLUE);
    			ERR_CHK(ret);
    		case LE_AUDIO_EVT_NOT_STREAMING:
    			LOG_DBG("LE audio evt not_streaming");
    			audio_system_encoder_stop();
    				LOG_DBG("Got not_streaming event in paused state");
    			stream_state_set(STATE_PAUSED);
    			audio_system_stop();
    			ret = led_on(LED_APP_1_BLUE);
    			ERR_CHK(ret);
    			LOG_WRN("Unexpected/unhandled le_audio event: %d", msg.event);
    		STACK_USAGE_PRINT("le_audio_msg_thread", &le_audio_msg_sub_thread_data);
     * @brief	Create zbus subscriber threads.
     * @return	0 for success, error otherwise.
    static int zbus_subscribers_create(void)
    	int ret;
    	button_msg_sub_thread_id = k_thread_create(
    		&button_msg_sub_thread_data, button_msg_sub_thread_stack,
    		CONFIG_BUTTON_MSG_SUB_STACK_SIZE, (k_thread_entry_t)button_msg_sub_thread, NULL,
    		NULL, NULL, K_PRIO_PREEMPT(CONFIG_BUTTON_MSG_SUB_THREAD_PRIO), 0, K_NO_WAIT);
    	ret = k_thread_name_set(button_msg_sub_thread_id, "BUTTON_MSG_SUB");
    	if (ret) {
    		LOG_ERR("Failed to create button_msg thread");
    		return ret;
    	le_audio_msg_sub_thread_id = k_thread_create(
    		&le_audio_msg_sub_thread_data, le_audio_msg_sub_thread_stack,
    		CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE, (k_thread_entry_t)le_audio_msg_sub_thread, NULL,
    		NULL, NULL, K_PRIO_PREEMPT(CONFIG_LE_AUDIO_MSG_SUB_THREAD_PRIO), 0, K_NO_WAIT);
    	ret = k_thread_name_set(le_audio_msg_sub_thread_id, "LE_AUDIO_MSG_SUB");
    	if (ret) {
    		LOG_ERR("Failed to create le_audio_msg thread");
    		return ret;
    	ret = zbus_chan_add_obs(&sdu_ref_chan, &sdu_ref_msg_listen, ZBUS_ADD_OBS_TIMEOUT_MS);
    	if (ret) {
    		LOG_ERR("Failed to add timestamp listener");
    		return ret;
    	return 0;
    static struct k_work adv_work;
    static void advertising_process(struct k_work *work)
    	int ret;
    #ifndef CONFIG_BT_LEGACY_ADV4ACL	//ADV-EXT
    	ret = bt_le_ext_adv_start(adv_for_conn, BT_LE_EXT_ADV_START_DEFAULT);
    	if (ret) {
    		printk("Failed to set advertising data (err %d)\n", ret);
    #else	//legacy ADV.
    	ret = bt_le_adv_start(BT_LE_ADV_CONN_CUSTOM, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
    	if(ret) {
    		LOG_WRN("Failed to start advertiser, ret = %d", ret);
     * @brief	Zbus listener to receive events from bt_mgmt.
     * @param[in]	chan	Zbus channel.
     * @note	Will in most cases be called from BT_RX context,
     *		so there should not be too much processing done here.
    static void bt_mgmt_evt_handler(const struct zbus_channel *chan)
    	int ret;
    	const struct bt_mgmt_msg *msg;
    	msg = zbus_chan_const_msg(chan);
    	switch (msg->event) {
    	case BT_MGMT_CONNECTED:
    		LOG_INF("BT_MGMT_CONNECTED");
    	case BT_MGMT_DISCONNECTED:
    		LOG_INF("BT_MGMT_DISCONNECTED");
    		k_work_submit(&adv_work);
    	case BT_MGMT_SECURITY_CHANGED:
    		LOG_INF("BT_MGMT_SECURITY_CHANGED");
    	case BT_MGMT_EXT_ADV_WITH_PA_READY:
    		LOG_INF("Ext adv ready");
    		ret = broadcast_source_start(msg->ext_adv);
    		if (ret) {
    			LOG_ERR("Failed to start broadcaster: %d", ret);
    		LOG_WRN("Unexpected/unhandled bt_mgmt event: %d", msg->event);
    ZBUS_LISTENER_DEFINE(bt_mgmt_evt_listen, bt_mgmt_evt_handler);
     * @brief	Link zbus producers and observers.
    static int zbus_link_producers_observers(void)
    	int ret;
    	if (!IS_ENABLED(CONFIG_ZBUS)) {
    		return -ENOTSUP;
    	ret = zbus_chan_add_obs(&button_chan, &button_evt_sub, ZBUS_ADD_OBS_TIMEOUT_MS);
    	if (ret) {
    		LOG_ERR("Failed to add button sub");
    		return ret;
    	ret = zbus_chan_add_obs(&le_audio_chan, &le_audio_evt_sub, ZBUS_ADD_OBS_TIMEOUT_MS);
    	if (ret) {
    		LOG_ERR("Failed to add le_audio sub");
    		return ret;
    	ret = zbus_chan_add_obs(&bt_mgmt_chan, &bt_mgmt_evt_listen, ZBUS_ADD_OBS_TIMEOUT_MS);
    	if (ret) {
    		LOG_ERR("Failed to add bt_mgmt listener");
    		return ret;
    	return 0;
    uint8_t stream_state_get(void)
    	return strm_state;
    void streamctrl_send(void const *const data, size_t size, uint8_t num_ch)
    	int ret;
    	static int prev_ret;
    	struct le_audio_encoded_audio enc_audio = {.data = data, .size = size, .num_ch = num_ch};
    		ret = broadcast_source_send(enc_audio);
    		if (ret != 0 && ret != prev_ret) {
    			if (ret == -ECANCELED) {
    				LOG_WRN("Sending operation cancelled");
    			} else {
    				LOG_WRN("Problem with sending LE audio data, ret: %d", ret);
    		prev_ret = ret;
    	int ret;
    	static const struct bt_data *ext_adv;
    	static const struct bt_data *per_adv;
    	LOG_DBG("nRF5340 APP core started");
    	ret = nrf5340_audio_dk_init();
    	ERR_CHK(ret);
    	ret = nrf5340_audio_common_init();
    	ERR_CHK(ret);
    	size_t ext_adv_size = 0;
    	size_t per_adv_size = 0;
    	ret = zbus_subscribers_create();
    	ERR_CHK_MSG(ret, "Failed to create zbus subscriber threads");
    	ret = zbus_link_producers_observers();
    	ERR_CHK_MSG(ret, "Failed to link zbus producers and observers");
    	ret = broadcast_source_enable();
    	ERR_CHK_MSG(ret, "Failed to enable broadcaster");
    	ret = audio_system_config_set(
    		bt_audio_codec_cfg_freq_to_freq_hz(CONFIG_BT_AUDIO_PREF_SAMPLE_RATE_VALUE),
    		CONFIG_BT_AUDIO_BITRATE_BROADCAST_SRC, VALUE_NOT_SET);
    	ERR_CHK_MSG(ret, "Failed to set sample- and bitrate");
    	broadcast_source_adv_get(&ext_adv, &ext_adv_size, &per_adv, &per_adv_size);
    	ret = bt_mgmt_adv_start(ext_adv, ext_adv_size, per_adv, per_adv_size, false);
    	ERR_CHK_MSG(ret, "Failed to start advertiser");
    	int err;
    	err = bt_le_ext_adv_create(BT_LE_EXT_ADV_CONN, NULL, &adv_for_conn);
    	if (err) {
    		printk("Failed to create advertising set (err %d)\n", err);
    	err = bt_le_ext_adv_set_data(adv_for_conn, ad, ARRAY_SIZE(ad), NULL, 0);
    	if (err) {
    		printk("Failed to set advertising data (err %d)\n", err);
    	err = bt_le_ext_adv_start(adv_for_conn, BT_LE_EXT_ADV_START_DEFAULT);
    	if (err) {
    #else	//legacy ADV.
    	k_work_init(&adv_work, advertising_process);
    	bt_nus_init(&nus_cb);
    	return 0;
  • In the meantime, we tried it out for legacy advertising for the ACL connection.
    That's great news, I really appreciate it! I've been on vacation this past week, hope to test it during the next one. I'll keep you updated.
    I am satisfied, and it absolutely can be lowered (more than 'slightly'), since audio quality may be set to minimum in our project.
    Which parameters should I tweak to achieve this?
    Dekel
