Only low power after programming low power hex file
I am developing a custom board which a based on the CircuitDojo designs. I try to get it in a low power state.
Step 1:
If I upload my application I have a average power consumption of 2,85 mA
Step 2:
Now I program the 1452.sysoff.hex from this page: Getting started with current measurements on the nRF9160  using Segger programmer and NRF Programmer application. Now I measure around 990 uA, much better.
Step 3:
Now I reprogram exactly the same application as in step 1. And I measure 25 uA, which is perfect! I tested if the application is still running using the blinky sketch to blink the LED, this is working so all is good.
If I disconnect the board from the power source the power consumption is back at the power consumption of step 1. If I reset the device it has still the low power consumption of step 3.
Is this a known issue? Does the 1452.sysoff.hex set some registers I don't know of?
This is my application main.c
 * Copyright (c) 2016 Intel Corporation
#include <zephyr/kernel.h>
#include <zephyr/pm/device.h>
#include <zephyr/logging/log_ctrl.h>
#include <modem/lte_lc.h>
#include <zephyr/drivers/flash.h>
#include <zephyr/device.h>
#include <zephyr/drivers/i2c.h>
#include <zephyr/drivers/regulator.h>
#define SLEEP_TIME_MS 11000
#define LED0_NODE DT_ALIAS(led0)
const struct device *gpio_dev = DEVICE_DT_GET(DT_NODELABEL(gpio0));
const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
const struct device *reg_dev = DEVICE_DT_GET(DT_NODELABEL(reg_5v));
int pins[] = {1, 2, 3, 4, 5, 6, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31};
int num_pins = sizeof(pins) / sizeof(pins[0]);
void setPowerLow()
	const struct device *flash_dev = DEVICE_DT_GET(DT_ALIAS(spi_flash0));
	static const struct device *const console_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
	NRF_CLOCK->TASKS_HFCLKSTOP = 1;
	pm_device_action_run(flash_dev, PM_DEVICE_ACTION_SUSPEND);
	pm_device_action_run(console_dev, PM_DEVICE_ACTION_SUSPEND);
	setPowerLow();
	lte_lc_power_off();
	for (int i = 0; i < num_pins; i++)
		gpio_pin_configure(gpio_dev, pins[i], GPIO_INPUT | GPIO_PULL_UP);
	gpio_pin_configure(gpio_dev, 9, GPIO_INPUT | GPIO_PULL_UP);
	gpio_pin_configure(gpio_dev, 10, GPIO_INPUT | GPIO_PULL_UP);
	gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
	while (1)
		k_msleep(SLEEP_TIME_MS);
	return 0;
This is my prj.conf
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_GPIO=y
CONFIG_PM_DEVICE=y
CONFIG_LOG=y
CONFIG_LTE_LINK_CONTROL=y
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_I2C=y
CONFIG_DEBUG=n
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_SPI_NOR_IDLE_IN_DPD=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_PM_DEVICE=y
Devicetree
 * Copyright (c) 2018-2020 Nordic Semiconductor ASA
 * Copyright (c) 2020 Circuit Dojo LLC
#include "circuitdojo_feather_nrf9160_common-pinctrl.dtsi"
#include <zephyr/dt-bindings/input/input-event-codes.h>
	model = "Circuit Dojo nRF9160 Feather";
	compatible = "circuitdojo,feather-nrf9160";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
	leds {
		compatible = "gpio-leds";
		red_led: led_0 {
			gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
			label = "Red LED";
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Switch 1";
			zephyr,code = <INPUT_KEY_0>;
	reg_5v: reg-5v {
		compatible = "regulator-fixed";
		regulator-name = "reg-5v";
		enable-gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>;
	aliases {
		led0 = &red_led;
		bootloader-led0 = &red_led;
		sw0 = &button0;
		mcuboot-button0 = &button0;
		mcuboot-led0 = &red_led;
		watchdog0 = &wdt0;
		spi-flash0 = &w25q32jv;
&adc {
	status = "disabled";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
&spi3 {
	status = "okay";
	cs-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
	w25q32jv: w25q32jv@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <40000000>;
		wp-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
		size = <0x2000000>;
		has-dpd;
		t-enter-dpd = <3000>;
		t-exit-dpd = <30000>;
		jedec-id = [ ef 40 16  ];
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0x10000>;
		slot0_partition: partition@10000 {
			label = "image-0";
		slot0_ns_partition: partition@40000 {
			label = "image-0-nonsecure";
		slot1_partition: partition@80000 {
			label = "image-1";
		slot1_ns_partition: partition@b0000 {
			label = "image-1-nonsecure";
		scratch_partition: partition@f0000 {
			label = "image-scratch";
			reg = <0x000f0000 0xa000>;
		storage_partition: partition@fa000 {
			label = "storage";
			reg = <0x000fa000 0x00006000>;
	reserved-memory {
		#size-cells = <1>;
		ranges;
		sram0_s: image_s@20000000 {
			/* Secure image memory */
		sram0_bsd: image_bsd@20010000 {
			/* BSD (shared) memory */
		sram0_ns: image_ns@20020000 {
			/* Non-Secure image memory */
/* Include partition configuration file */
#include "circuitdojo_feather_nrf9160_partition_conf.dtsi"
Pinctrl file
 * Copyright (c) 2022 Nordic Semiconductor
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 6)>,
				<NRF_PSEL(UART_RX, 0, 5)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
	spi3_default: spi3_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 11)>,
				<NRF_PSEL(SPIM_MOSI, 0, 12)>,
				<NRF_PSEL(SPIM_MISO, 0, 8)>;
	spi3_sleep: spi3_sleep {
		group1 {
			low-power-enable;
Thanks!
    It looks like you might have run into NCSDK-10106.
    Can you try to enable the modem library by enabling CONFIG_NRF_MODEM_LIB and calling nrf_modem_lib_init()?
    Didrik
  • That fixed it! Great, thanks for the super fast reply :)
    For anyone who has the same issues, this is the new main.c file:
    #include <modem/nrf_modem_lib.h>
    void setPowerLow()
    	setPowerLow();
    	lte_lc_power_off();
    	nrf_modem_lib_init();
    	while (1)
    	return 0;
